[GRASS-SVN] r54351 - grass/branches/releasebranch_6_4/imagery/i.maxlik
svn_grass at osgeo.org
Wed Dec 19 14:16:41 PST 2012
Author: mmetz
Date: 2012-12-19 14:16:40 -0800 (Wed, 19 Dec 2012)
New Revision: 54351
grass/branches/releasebranch_6_4/imagery/i.maxlik/description.html
i.maxlik: update manual
Modified: grass/branches/releasebranch_6_4/imagery/i.maxlik/description.html
--- grass/branches/releasebranch_6_4/imagery/i.maxlik/description.html 2012-12-19 22:16:31 UTC (rev 54350)
+++ grass/branches/releasebranch_6_4/imagery/i.maxlik/description.html 2012-12-19 22:16:40 UTC (rev 54351)
@@ -112,11 +112,13 @@
on each discriminant result at various threshold levels of
confidence to determine at what confidence level each cell
classified (categorized). It is the reject threshold map
-layer, and contains one calculated confidence level for
-each classified cell in the classified image. One of the
-possible uses for this map layer is as a mask, to identify
-cells in the classified image that have the lowest
-probability of being assigned to the correct class.
+layer, and contains the index to one calculated confidence level for
+each classified cell in the classified image. 16 confidence intervals
+are predefined, and the reject map is to be interpreted as 1 = keep and
+16 = reject. One of the possible uses for this map layer is as a mask,
+to identify cells in the classified image that have a low
+probability (high reject index) of being assigned to the correct
+class.
</dl>
