[GRASS-SVN] r54355 - grass-addons/grass7/gui/wxpython/wx.rdigit/rdigit
svn_grass at osgeo.org
Thu Dec 20 03:30:32 PST 2012
Author: rashadkm
Date: 2012-12-20 03:30:32 -0800 (Thu, 20 Dec 2012)
New Revision: 54355
grass-addons/grass7/gui/wxpython/wx.rdigit/rdigit/toolbars.py
fixed message text for rdigit
Modified: grass-addons/grass7/gui/wxpython/wx.rdigit/rdigit/toolbars.py
--- grass-addons/grass7/gui/wxpython/wx.rdigit/rdigit/toolbars.py 2012-12-20 11:26:41 UTC (rev 54354)
+++ grass-addons/grass7/gui/wxpython/wx.rdigit/rdigit/toolbars.py 2012-12-20 11:30:32 UTC (rev 54355)
@@ -14,11 +14,8 @@
@author Mohammed Rashad <rashadkm gmail.com>
import wx
from grass.script import core as grass
from gui_core.toolbars import BaseToolbar, BaseIcons
-from gui_core.dialogs import CreateNewVector
from dialogs_core import CreateNewRaster
from vdigit.preferences import VDigitSettingsDialog
from core.debug import Debug
@@ -43,8 +40,6 @@
# currently selected map layer for editing (reference to MapLayer instance)
self.mapLayer = None
self.mapName = None
- # list of vector layers from Layer Manager (only in the current mapset)
- #self.laayers = []
self.comboid = self.combo = None
self.undo = -1
@@ -62,7 +57,7 @@
'type' : '',
'id' : -1 }
- # list of available vector maps
+ # list of available raster maps
self.UpdateListOfLayers(updateTool = True)
self.layerNameList = []
@@ -234,7 +229,7 @@
def OnAddLine(self, event):
- """!Add line to the vector map layer"""
+ """!Add line to the raster map layer"""
Debug.msg (2, "RDigitToolbar.OnAddLine()")
@@ -245,7 +240,7 @@
def OnAddBoundary(self, event):
- """!Add boundary to the vector map layer"""
+ """!Add boundary to the raster map layer"""
Debug.msg (2, "RDigitToolbar.OnAddBoundary()")
@@ -258,7 +253,7 @@
self.MapWindow.mouse['box'] = 'line'
def OnAddCircle(self, event):
- """!Add cirlce to the vector map layer"""
+ """!Add cirlce to the raster map layer"""
Debug.msg (2, "RDigitToolbar.OnAddCircle()")
@@ -381,10 +376,10 @@
selection = -1
if event.GetSelection() == 0: # create new raster map layer
if self.mapLayer:
- openVectorMap = self.mapLayer.GetName(fullyQualified = False)['name']
+ openRasterMap = self.mapLayer.GetName(fullyQualified = False)['name']
else:
- openVectorMap = None
- dlg = CreateNewRaster(self.parent, exceptMap = openVectorMap,disableAdd = True)
+ openRasterMap = None
+ dlg = CreateNewRaster(self.parent, exceptMap = openRasterMap,disableAdd = True)
@@ -425,7 +420,7 @@
event.Skip()
def StartEditing (self, mapLayer):
- """!Start editing selected vector map layer.
+ """!Start editing selected raster map layer.
@param mapLayer MapLayer to be edited
@@ -443,7 +438,7 @@
# subkey = 'value', value = '', internal = True)
# self.parent.SetStatusText(_("Please wait, "
-# "opening vector map <%s> for editing...") % mapLayer,
+# "opening raster map <%s> for editing...") % mapLayer,
# 0)
self.MapWindow.pdcVector = wx.PseudoDC()
@@ -474,13 +469,13 @@
return True
def StopEditing(self):
- """!Stop editing of selected vector map layer.
+ """!Stop editing of selected raster map layer.
@return True on success
@return False on failure
if self.combo:
- self.combo.SetValue (_('Select vector map'))
+ self.combo.SetValue (_('Select raster map'))
# save changes
if self.mapLayer:
@@ -488,7 +483,7 @@
dlg = wx.MessageDialog(parent = self.parent,
message = _("Do you want to save changes "
- "in vector map <%s>?") % self.mapLayer,
+ "in raster map <%s>?") % self.mapLayer,
caption = _("Save changes?"),
style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
if dlg.ShowModal() == wx.ID_NO:
@@ -514,7 +509,7 @@
return True
def UpdateListOfLayers (self, updateTool = False):
- """!Update list of available vector map layers.
+ """!Update list of available raster map layers.
This list consists only editable layers (in the current mapset)
@param updateTool True to update also toolbar
@@ -526,7 +521,7 @@
if self.mapLayer:
layerNameSelected = self.mapLayer
- # select vector map layer in the current mapset
+ # select raster map layer in the current mapset
layerNameList = []
self.layers = self.Map.GetListOfLayers(l_type = "raster",
l_mapset = grass.gisenv()['MAPSET'])
@@ -537,7 +532,7 @@
if updateTool: # update toolbar
if not self.mapLayer:
- value = _('Select vector map')
+ value = _('Select raster map')
else:
value = layerNameSelected
