[GRASS-SVN] r54361 - grass/trunk/raster/r.drain/tests
svn_grass at osgeo.org
Thu Dec 20 05:00:27 PST 2012
Author: neteler
Date: 2012-12-20 05:00:26 -0800 (Thu, 20 Dec 2012)
New Revision: 54361
grass/trunk/raster/r.drain/tests/test.r.drain.sh
trying FP map to no avail
Modified: grass/trunk/raster/r.drain/tests/test.r.drain.sh
--- grass/trunk/raster/r.drain/tests/test.r.drain.sh 2012-12-20 13:00:13 UTC (rev 54360)
+++ grass/trunk/raster/r.drain/tests/test.r.drain.sh 2012-12-20 13:00:26 UTC (rev 54361)
@@ -11,9 +11,14 @@
sleep 2
d.rast.num testascii
-r.drain testascii out=drain coord=638442.5,220548.5
-d.rast -o drain
+r.drain input=testascii output=drain coord=638442.5,220548.5
+d.rast drain
+d.erase
+r.mapcalc "testascii_float = float(testascii)"
+r.drain input=testascii_float output=drain coord=638442.5,220548.5
+d.rast drain
# for statistical test results:
# - verify number of resulting pixels (r.univar -g)
# - verify minimum and maximum of result (r.univar -g)
