[GRASS-SVN] r54365 - grass/branches/develbranch_6/lib/init
svn_grass at osgeo.org
Sat Dec 22 01:45:28 PST 2012
Author: martinl
Date: 2012-12-22 01:45:28 -0800 (Sat, 22 Dec 2012)
New Revision: 54365
grass/branches/develbranch_6/lib/init/init.bat
init.bat -> eol-style: CRLF
Modified: grass/branches/develbranch_6/lib/init/init.bat
--- grass/branches/develbranch_6/lib/init/init.bat 2012-12-20 13:32:18 UTC (rev 54364)
+++ grass/branches/develbranch_6/lib/init/init.bat 2012-12-22 09:45:28 UTC (rev 54365)
@@ -1,208 +1,208 @@
- at echo off
-rem #########################################################################
-rem
-rem MODULE: GRASS Initialization
-rem AUTHOR(S): Paul Kelly
-rem
-rem PURPOSE: The source file for this batch script is lib/init/init.bat.
-rem It sets up some environment variables, default GISRC file
-rem if necessary, etc. prior to starting GRASS proper.
-rem It is intended to be a native Windows replacement for Init.bat,
-rem but does not (yet) contain all the same functionality.
-rem
-rem In particular also, GUI mode prints nothing to the terminal
-rem and does not expect or provide an interactive terminal
-rem running in addition to the GUI display.
-rem
-rem COPYRIGHT: (C) 2006, 2011 by the GRASS Development Team
-rem
-rem This program is free software under the GNU General Public
-rem License (>=v2). Read the file COPYING that comes with GRASS
-rem for details.
-rem
-set SAVEPATH=%PATH%
-rem DON'T include scripts directory in PATH - .bat files in bin directory
-rem are used to run scripts on Windows
-if exist "%APPDATA%\GRASS6\env.bat" (
- call %APPDATA%\GRASS6\env.bat
-if "%GRASS_ADDON_PATH%"=="" set GRASS_ADDON_PATH=%APPDATA%\GRASS6\addons
-PATH=%GISBASE%\bin;%GISBASE%\lib;%GRASS_ADDON_PATH%;%PATH%
-set GIS_LOCK=1
-set GRASS_VERSION=GRASS_VERSION_NUMBER
-if "%HOME%"=="" set HOME=%USERPROFILE%
-set WINGISRC=%APPDATA%\GRASS6\grassrc6
-rem Create missing folder
-if not exist "%APPDATA%\GRASS6" (
- md "%APPDATA%\GRASS6"
-rem Make sure %GISRC% is set so g.dirseps will work
-rem (not actually used)
-set GISRC=junk
-rem Generate GISBASE by converting dirsep characters from \ to /
-FOR /F "usebackq delims==" %%i IN (`g.dirseps -g "%GISBASE%"`) DO @set GISBASE=%%i
-if not "%LANG%"=="" goto langset
-FOR /F "usebackq delims==" %%i IN (`"%GISBASE%\etc\winlocale"`) DO @set LANG=%%i
-:langset
-set GRASS_PAGER=more
-if "%GRASS_WISH%"=="" set GRASS_WISH=wish.exe
-if "%GRASS_SH%"=="" set GRASS_SH=c:\msys\1.0\bin\sh.exe
-rem Should do something with "assoc .html" and ftype here but would require
-rem a new g.manual.bat too so leaving it like this for now...
-if "%GRASS_HTML_BROWSER%"=="" set GRASS_HTML_BROWSER=explorer
-if "%GRASS_PROJSHARE%"=="" set GRASS_PROJSHARE=CONFIG_PROJSHARE
-rem Add python scripts to the PATHEXT variable
-set PATHEXT=%PATHEXT%;.PY
-if "%1" == "-version" goto displaylicence
-if "%1" == "-v" goto displaylicence
-if "%1" == "-text" goto settextmode
-:aftertextcheck
-if "%1" == "-tcltk" goto setguimode
-if "%1" == "-wxpython" goto setwxmode
-if "%1" == "-wx" goto setwxmode
-if "%1" == "-gui" goto setguimode
-:afterguicheck
-if exist "%WINGISRC%" (
- set HAVE_GISRC=true
- goto aftercreategisrc
-set HAVE_GISRC=false
-rem Create an initial GISRC file based on current directory
-"%GISBASE%\etc\echo" "GISDBASE: %USERPROFILE%" | g.dirseps -g > "%WINGISRC%"
-"%GISBASE%\etc\echo" "LOCATION_NAME: <UNKNOWN>" >> "%WINGISRC%"
-"%GISBASE%\etc\echo" "MAPSET: <UNKNOWN>" >> "%WINGISRC%"
-:aftercreategisrc
-rem Now set the real GISRC
-FOR /F "usebackq delims==" %%i IN (`g.dirseps -g "%WINGISRC%"`) DO @set GISRC=%%i
-rem Fetch the language setting from user's prefs
-FOR /F "usebackq delims==" %%i IN (`g.gisenv "get=LANG"`) DO @set LANG=%%i
-rem Set GRASS_GUI
-if "%GRASS_GUI%" == "" (
- FOR /F "usebackq delims==" %%i IN (`g.gisenv "get=GRASS_GUI"`) DO @set GRASS_GUI=%%i
-) else (
- g.gisenv "set=GRASS_GUI=%GRASS_GUI%"
-rem Set wxGUI as default if not specified elsewhere
-if "%GRASS_GUI%"=="" set GRASS_GUI=wxpython
-rem Clean out old .tmp files from the mapset
-if "%HAVE_GISRC%"=="true" (
- "%GISBASE%\etc\clean_temp" > NUL:
-set HAVE_GISRC=
-if "%GRASS_GUI%"=="text" goto text
-if "%GRASS_GUI%"=="wxpython" goto wxpython
-if not "%GRASS_WISH%"=="" (
- "%GRASS_WISH%" "%GISBASE%\etc\gis_set.tcl"
-) else (
- "%GISBASE%\etc\gis_set.tcl"
-rem This doesn't seem to work; don't understand return codes from gis_set.tcl PK
-rem if return ok, gis.m start:
-if %errorlevel% == 2 goto exitinit
-rem Does line 42 above mean that GRASS_WISH will always be set?
- start /b "GRASS Tcl/Tk" "%GRASS_WISH%" "%GISBASE%\etc\gm\gm.tcl"
-) else (
- start /b "GRASS Tcl/Tk" "%GISBASE%\etc\gm\gm.tcl"
-rem Will redirecting output to NUL hide legitamite error messages, harming debugging?
-"%GISBASE%\etc\clean_temp" > NUL:
-goto exitinit
-:wxpython
-set PYTHONPATH=%PYTHONPATH%;%GISBASE%\etc\python;%GISBASE%\etc\wxpython
-python "%GISBASE%/etc/wxpython/gis_set.py"
-python "%GISBASE%/etc/wxpython/wxgui.py"
-goto exitinit
-:text
-"%GISBASE%\etc\set_data"
-if %errorlevel% == 1 goto exitinit
-rem Get LOCATION_NAME to use in prompt
-FOR /F "usebackq delims==" %%i IN (`g.gisenv "get=LOCATION_NAME"`) DO @set LOCATION_NAME=%%i
-type "%GISBASE%\etc\welcome"
-"%GISBASE%\etc\echo" ""
-"%GISBASE%\etc\echo" "GRASS homepage: http://grass.osgeo.org/"
-"%GISBASE%\etc\echo" "This version running thru: Windows Command Shell (cmd.exe)"
-"%GISBASE%\etc\echo" "When ready to quit enter: exit"
-"%GISBASE%\etc\echo" "Help is available with the command: g.manual -i"
-"%GISBASE%\etc\echo" "See the licence terms with: g.version -c"
-prompt GRASS %GRASS_VERSION% $C%LOCATION_NAME%$F$G
-cmd.exe
-prompt
-goto exitinit
-:displaylicence
-type "%GISBASE%\etc\license"
-goto exitinit
-:settextmode
-set GRASS_GUI=text
-shift
-goto aftertextcheck
-:setguimode
-set GRASS_GUI=tcltk
-shift
-goto afterguicheck
-:setwxmode
-set GRASS_GUI=wxpython
-shift
-goto afterguicheck
-:exitinit
-set PATH=%SAVEPATH%
-set SAVEPATH=
-exit /b
+ at echo off
+rem #########################################################################
+rem
+rem MODULE: GRASS Initialization
+rem AUTHOR(S): Paul Kelly
+rem
+rem PURPOSE: The source file for this batch script is lib/init/init.bat.
+rem It sets up some environment variables, default GISRC file
+rem if necessary, etc. prior to starting GRASS proper.
+rem It is intended to be a native Windows replacement for Init.bat,
+rem but does not (yet) contain all the same functionality.
+rem
+rem In particular also, GUI mode prints nothing to the terminal
+rem and does not expect or provide an interactive terminal
+rem running in addition to the GUI display.
+rem
+rem COPYRIGHT: (C) 2006, 2011 by the GRASS Development Team
+rem
+rem This program is free software under the GNU General Public
+rem License (>=v2). Read the file COPYING that comes with GRASS
+rem for details.
+rem
+set SAVEPATH=%PATH%
+rem DON'T include scripts directory in PATH - .bat files in bin directory
+rem are used to run scripts on Windows
+if exist "%APPDATA%\GRASS6\env.bat" (
+ call %APPDATA%\GRASS6\env.bat
+if "%GRASS_ADDON_PATH%"=="" set GRASS_ADDON_PATH=%APPDATA%\GRASS6\addons
+PATH=%GISBASE%\bin;%GISBASE%\lib;%GRASS_ADDON_PATH%;%PATH%
+set GIS_LOCK=1
+set GRASS_VERSION=GRASS_VERSION_NUMBER
+if "%HOME%"=="" set HOME=%USERPROFILE%
+set WINGISRC=%APPDATA%\GRASS6\grassrc6
+rem Create missing folder
+if not exist "%APPDATA%\GRASS6" (
+ md "%APPDATA%\GRASS6"
+rem Make sure %GISRC% is set so g.dirseps will work
+rem (not actually used)
+set GISRC=junk
+rem Generate GISBASE by converting dirsep characters from \ to /
+FOR /F "usebackq delims==" %%i IN (`g.dirseps -g "%GISBASE%"`) DO @set GISBASE=%%i
+if not "%LANG%"=="" goto langset
+FOR /F "usebackq delims==" %%i IN (`"%GISBASE%\etc\winlocale"`) DO @set LANG=%%i
+:langset
+set GRASS_PAGER=more
+if "%GRASS_WISH%"=="" set GRASS_WISH=wish.exe
+if "%GRASS_SH%"=="" set GRASS_SH=c:\msys\1.0\bin\sh.exe
+rem Should do something with "assoc .html" and ftype here but would require
+rem a new g.manual.bat too so leaving it like this for now...
+if "%GRASS_HTML_BROWSER%"=="" set GRASS_HTML_BROWSER=explorer
+if "%GRASS_PROJSHARE%"=="" set GRASS_PROJSHARE=CONFIG_PROJSHARE
+rem Add python scripts to the PATHEXT variable
+set PATHEXT=%PATHEXT%;.PY
+if "%1" == "-version" goto displaylicence
+if "%1" == "-v" goto displaylicence
+if "%1" == "-text" goto settextmode
+:aftertextcheck
+if "%1" == "-tcltk" goto setguimode
+if "%1" == "-wxpython" goto setwxmode
+if "%1" == "-wx" goto setwxmode
+if "%1" == "-gui" goto setguimode
+:afterguicheck
+if exist "%WINGISRC%" (
+ set HAVE_GISRC=true
+ goto aftercreategisrc
+set HAVE_GISRC=false
+rem Create an initial GISRC file based on current directory
+"%GISBASE%\etc\echo" "GISDBASE: %USERPROFILE%" | g.dirseps -g > "%WINGISRC%"
+"%GISBASE%\etc\echo" "LOCATION_NAME: <UNKNOWN>" >> "%WINGISRC%"
+"%GISBASE%\etc\echo" "MAPSET: <UNKNOWN>" >> "%WINGISRC%"
+:aftercreategisrc
+rem Now set the real GISRC
+FOR /F "usebackq delims==" %%i IN (`g.dirseps -g "%WINGISRC%"`) DO @set GISRC=%%i
+rem Fetch the language setting from user's prefs
+FOR /F "usebackq delims==" %%i IN (`g.gisenv "get=LANG"`) DO @set LANG=%%i
+rem Set GRASS_GUI
+if "%GRASS_GUI%" == "" (
+ FOR /F "usebackq delims==" %%i IN (`g.gisenv "get=GRASS_GUI"`) DO @set GRASS_GUI=%%i
+) else (
+ g.gisenv "set=GRASS_GUI=%GRASS_GUI%"
+rem Set wxGUI as default if not specified elsewhere
+if "%GRASS_GUI%"=="" set GRASS_GUI=wxpython
+rem Clean out old .tmp files from the mapset
+if "%HAVE_GISRC%"=="true" (
+ "%GISBASE%\etc\clean_temp" > NUL:
+set HAVE_GISRC=
+if "%GRASS_GUI%"=="text" goto text
+if "%GRASS_GUI%"=="wxpython" goto wxpython
+if not "%GRASS_WISH%"=="" (
+ "%GRASS_WISH%" "%GISBASE%\etc\gis_set.tcl"
+) else (
+ "%GISBASE%\etc\gis_set.tcl"
+rem This doesn't seem to work; don't understand return codes from gis_set.tcl PK
+rem if return ok, gis.m start:
+if %errorlevel% == 2 goto exitinit
+rem Does line 42 above mean that GRASS_WISH will always be set?
+ start /b "GRASS Tcl/Tk" "%GRASS_WISH%" "%GISBASE%\etc\gm\gm.tcl"
+) else (
+ start /b "GRASS Tcl/Tk" "%GISBASE%\etc\gm\gm.tcl"
+rem Will redirecting output to NUL hide legitamite error messages, harming debugging?
+"%GISBASE%\etc\clean_temp" > NUL:
+goto exitinit
+:wxpython
+set PYTHONPATH=%PYTHONPATH%;%GISBASE%\etc\python;%GISBASE%\etc\wxpython
+python "%GISBASE%/etc/wxpython/gis_set.py"
+python "%GISBASE%/etc/wxpython/wxgui.py"
+goto exitinit
+:text
+"%GISBASE%\etc\set_data"
+if %errorlevel% == 1 goto exitinit
+rem Get LOCATION_NAME to use in prompt
+FOR /F "usebackq delims==" %%i IN (`g.gisenv "get=LOCATION_NAME"`) DO @set LOCATION_NAME=%%i
+type "%GISBASE%\etc\welcome"
+"%GISBASE%\etc\echo" ""
+"%GISBASE%\etc\echo" "GRASS homepage: http://grass.osgeo.org/"
+"%GISBASE%\etc\echo" "This version running thru: Windows Command Shell (cmd.exe)"
+"%GISBASE%\etc\echo" "When ready to quit enter: exit"
+"%GISBASE%\etc\echo" "Help is available with the command: g.manual -i"
+"%GISBASE%\etc\echo" "See the licence terms with: g.version -c"
+prompt GRASS %GRASS_VERSION% $C%LOCATION_NAME%$F$G
+cmd.exe
+prompt
+goto exitinit
+:displaylicence
+type "%GISBASE%\etc\license"
+goto exitinit
+:settextmode
+set GRASS_GUI=text
+shift
+goto aftertextcheck
+:setguimode
+set GRASS_GUI=tcltk
+shift
+goto afterguicheck
+:setwxmode
+set GRASS_GUI=wxpython
+shift
+goto afterguicheck
+:exitinit
+set PATH=%SAVEPATH%
+set SAVEPATH=
+exit /b
Property changes on: grass/branches/develbranch_6/lib/init/init.bat
___________________________________________________________________
Modified: svn:eol-style
- native
+ CRLF
