[GRASS-SVN] r54371 - in grass/trunk/lib/python/pygrass: . gis
svn_grass at osgeo.org
Sun Dec 23 03:13:18 PST 2012
Author: zarch
Date: 2012-12-23 03:13:18 -0800 (Sun, 23 Dec 2012)
New Revision: 54371
Added:
grass/trunk/lib/python/pygrass/gis/
grass/trunk/lib/python/pygrass/gis/__init__.py
grass/trunk/lib/python/pygrass/gis/region.py
Removed:
grass/trunk/lib/python/pygrass/region.py
grass/trunk/lib/python/pygrass/__init__.py
Add the 'gis' module with Gisdbase, Location and Mapset, and move region.py to gis/region.py
Modified: grass/trunk/lib/python/pygrass/__init__.py
--- grass/trunk/lib/python/pygrass/__init__.py 2012-12-23 10:43:37 UTC (rev 54370)
+++ grass/trunk/lib/python/pygrass/__init__.py 2012-12-23 11:13:18 UTC (rev 54371)
@@ -13,7 +13,7 @@
_sys.path.append(_os.path.join(_os.sep, *_pygrasspath[:-1]))
-import region
+import gis
import raster
import vector
import modules
Added: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py (rev 0)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py 2012-12-23 11:13:18 UTC (rev 54371)
@@ -0,0 +1,281 @@
+# -*- coding: utf-8 -*-
+#!/usr/bin/env python2.7
+from __future__ import print_function
+#import os
+from os import listdir
+from os.path import join
+import ctypes as ct
+from grass import script
+#from grass.script import setup
+#GISBASE = "/home/pietro/docdat/src/gis/grass/grass70/dist.x86_64-unknown-linux-gnu"
+#LOCATION = "nc_basic_spm_grass7'"
+#GISDBASE = "/home/pietro/docdat/gis"
+#MAPSET = "sqlite"
+#GUI = "wxpython"
+#setup.init(GISBASE, GISDBASE, LOCATION, MAPSET)
+script.gisenv()
+import grass.lib.gis as libgis
+from grass.pygrass.functions import getenv
+from grass.pygrass.errors import GrassError
+#write dec to check if user have permissions or not
+ETYPE = {'rast': libgis.G_ELEMENT_RASTER,
+ 'rast3d': libgis.G_ELEMENT_RASTER3D,
+ 'vect': libgis.G_ELEMENT_VECTOR,
+ 'oldvect': libgis.G_ELEMENT_OLDVECTOR,
+ 'asciivect': libgis.G_ELEMENT_ASCIIVECTOR,
+ 'icon': libgis.G_ELEMENT_ICON,
+ 'labels': libgis.G_ELEMENT_LABEL,
+ 'sites': libgis.G_ELEMENT_SITE,
+ 'region': libgis.G_ELEMENT_REGION,
+ 'region3d': libgis.G_ELEMENT_REGION3D,
+ 'group': libgis.G_ELEMENT_GROUP,
+ 'view3d': libgis.G_ELEMENT_3DVIEW}
+CHECK_IS = {"GISBASE": libgis.G_is_gisbase,
+ "GISDBASE": lambda x: True,
+ "LOCATION_NAME": libgis.G_is_location,
+ "MAPSET": libgis.G_is_mapset}
+def _check(value, path, type):
+ #import pdb; pdb.set_trace()
+ if value and CHECK_IS[type](join(path, value)):
+ return value
+ elif value is '':
+ return getenv(type)
+ else:
+ raise GrassError("%s <%s> not found." % (type.title(),
+ join(path, value)))
+class Gisdbase(object):
+ """Return Gisdbase object. ::
+ >>> gisdbase = Gisdbase()
+ >>> gisdbase.name # doctest: +ELLIPSIS, +NORMALIZE_WHITESPACE
+ '/home/...'
+ def __init__(self, gisdbase=''):
+ self.name = gisdbase
+ def _get_name(self):
+ return self._name
+ def _set_name(self, name):
+ self._name = _check(name, '', "GISDBASE")
+ name = property(fget=_get_name, fset=_set_name)
+ def __str__(self):
+ return self.name
+ def __repr__(self):
+ return 'Gisdbase(%s)' % self.name
+ def __getitem__(self, location):
+ """Return a Location object. ::
+ >>> gisdbase['nc_basic_spm_grass7']
+ Location('nc_basic_spm_grass7')
+ if location in self.locations():
+ return Location(location, self.name)
+ else:
+ raise KeyError('Location: %s does not exist' % location)
+ def __iter__(self):
+ for loc in self.locations():
+ yield Location(loc, self.name)
+ def new_location(self):
+ if libgis.G__make_location() != 0:
+ raise GrassError("I cannot create a new mapset.")
+ def locations(self):
+ """Return a list of locations that are available in the gisdbase: ::
+ >>> gisdbase.locations() # doctest: +ELLIPSIS
+ locations = []
+ for loc in listdir(self.name):
+ if libgis.G_is_location(join(self.name, loc)):
+ locations.append(loc)
+ locations.sort()
+ return locations
+class Location(object):
+ """Location object ::
+ >>> location = Location()
+ >>> location # doctest: +ELLIPSIS
+ Location(...)
+ >>> location.gisdbase # doctest: +ELLIPSIS
+ '/home/...'
+ >>> location.name
+ 'nc_basic_spm_grass7'
+ def __init__(self, location='', gisdbase=''):
+ self.gisdbase = gisdbase
+ self.name = location
+ def _get_gisdb(self):
+ return self._gisdb
+ def _set_gisdb(self, gisdb):
+ self._gisdb = _check(gisdb, '', "GISDBASE")
+ gisdbase = property(fget=_get_gisdb, fset=_set_gisdb)
+ return self._name
+ self._name = _check(name, self._gisdb, "LOCATION_NAME")
+ def __getitem__(self, mapset):
+ if mapset in self.mapsets():
+ return Mapset(mapset)
+ else:
+ raise KeyError('Mapset: %s does not exist' % mapset)
+ for mapset in libgis.G_available_mapsets():
+ mapset_name = ct.cast(mapset, ct.c_char_p).value
+ if mapset_name and libgis.G__mapset_permissions(mapset):
+ yield mapset_name
+ else:
+ break
+ def __len__(self):
+ return len(self.mapsets())
+ return self.name
+ return 'Location(%r)' % self.name
+ def mapsets(self):
+ """Return a list of the available mapsets. ::
+ >>> location.mapsets()
+ ['PERMANENT', 'user1']
+ return [mapset for mapset in self]
+ def new_mapset(self, mapset):
+ if libgis.G__make_mapset(self.gisdbase, self.location, mapset) != 0:
+class Mapset(object):
+ """Mapset ::
+ >>> mapset = Mapset()
+ >>> mapset
+ Mapset('user1')
+ >>> mapset.gisdbase # doctest: +ELLIPSIS
+ '/home/...'
+ >>> mapset.location
+ >>> mapset.name
+ 'user1'
+ def __init__(self, mapset='', location='', gisdbase=''):
+ self.location = location
+ self.name = mapset
+ def _get_loc(self):
+ return self._loc
+ def _set_loc(self, loc):
+ self._loc = _check(loc, self._gisdb, "LOCATION_NAME")
+ location = property(fget=_get_loc, fset=_set_loc)
+ return self._name
+ self._name = _check(name, join(self._gisdb, self._loc), "MAPSET")
+ return self.name
+ return 'Mapset(%r)' % self.name
+ def glist(self, type):
+ """Return a list of grass types like:
+ * 'asciivect',
+ * 'group',
+ * 'icon',
+ * 'labels',
+ * 'oldvect',
+ * 'rast',
+ * 'rast3d',
+ * 'region',
+ * 'region3d',
+ * 'sites',
+ * 'vect',
+ * 'view3d'
+ >>> mapset = Mapset('PERMANENT')
+ >>> rast = mapset.glist('rast')
+ >>> rast.sort()
+ >>> rast # doctest: +ELLIPSIS
+ ['basins', 'elevation', ...]
+ if type not in ETYPE:
+ str_err = "Type %s is not valid, valid types are: %s."
+ raise TypeError(str_err % (type, ', '.join(ETYPE.keys())))
+ clist = libgis.G_list(ETYPE[type], self.gisdbase,
+ self.location, self.name)
+ elist = []
+ for el in clist:
+ el_name = ct.cast(el, ct.c_char_p).value
+ if el_name:
+ elist.append(el_name)
+ else:
+ return elist
+if __name__ == "__main__":
+ import doctest
+ doctest.testmod(verbose=False)
\ No newline at end of file
Copied: grass/trunk/lib/python/pygrass/gis/region.py (from rev 54370, grass/trunk/lib/python/pygrass/region.py)
--- grass/trunk/lib/python/pygrass/gis/region.py (rev 0)
+++ grass/trunk/lib/python/pygrass/gis/region.py 2012-12-23 11:13:18 UTC (rev 54371)
@@ -0,0 +1,224 @@
+Created on Fri May 25 12:57:10 2012
+ at author: Pietro Zambelli
+import ctypes
+import grass.script as grass
+from pygrass.errors import GrassError
+class Region(object):
+ def __init__(self, default=False):
+ >>> default = Region(default=True)
+ >>> current = Region()
+ >>> default == current
+ True
+ >>> current.cols
+ 1500
+ >>> current.ewres
+ 10.0
+ >>> current.cols = 3000
+ >>> current.ewres
+ 5.0
+ >>> current.ewres = 20.0
+ >>> current.cols
+ 750
+ >>> current.set_current()
+ False
+ >>> current.set_default()
+ True
+ >>> default
+ Region(n=228500, s=215000, e=645000, w=630000, nsres=10, ewres=20)
+ >>> current
+ >>> default.ewres = 10.
+ >>> default.set_default()
+ self.c_region = ctypes.pointer(libgis.Cell_head())
+ if default:
+ self.get_default()
+ else:
+ self.get_current()
+ def _set_param(self, key, value):
+ grass.run_command('g.region', **{key: value})
+ #----------LIMITS----------
+ def _get_n(self):
+ return self.c_region.contents.north
+ def _set_n(self, value):
+ self.c_region.contents.north = value
+ north = property(fget=_get_n, fset=_set_n)
+ def _get_s(self):
+ return self.c_region.contents.south
+ def _set_s(self, value):
+ self.c_region.contents.south = value
+ south = property(fget=_get_s, fset=_set_s)
+ def _get_e(self):
+ return self.c_region.contents.east
+ def _set_e(self, value):
+ self.c_region.contents.east = value
+ east = property(fget=_get_e, fset=_set_e)
+ def _get_w(self):
+ return self.c_region.contents.west
+ def _set_w(self, value):
+ self.c_region.contents.west = value
+ west = property(fget=_get_w, fset=_set_w)
+ def _get_t(self):
+ return self.c_region.contents.top
+ def _set_t(self, value):
+ self.c_region.contents.top = value
+ top = property(fget=_get_t, fset=_set_t)
+ def _get_b(self):
+ return self.c_region.contents.bottom
+ def _set_b(self, value):
+ self.c_region.contents.bottom = value
+ bottom = property(fget=_get_b, fset=_set_b)
+ #----------RESOLUTION----------
+ def _get_rows(self):
+ return self.c_region.contents.rows
+ def _set_rows(self, value):
+ self.c_region.contents.rows = value
+ self.adjust(rows=True)
+ rows = property(fget=_get_rows, fset=_set_rows)
+ def _get_cols(self):
+ return self.c_region.contents.cols
+ def _set_cols(self, value):
+ self.c_region.contents.cols = value
+ self.adjust(cols=True)
+ cols = property(fget=_get_cols, fset=_set_cols)
+ def _get_nsres(self):
+ return self.c_region.contents.ns_res
+ def _set_nsres(self, value):
+ self.c_region.contents.ns_res = value
+ self.adjust()
+ nsres = property(fget=_get_nsres, fset=_set_nsres)
+ def _get_ewres(self):
+ return self.c_region.contents.ew_res
+ def _set_ewres(self, value):
+ self.c_region.contents.ew_res = value
+ self.adjust()
+ ewres = property(fget=_get_ewres, fset=_set_ewres)
+ def _get_tbres(self):
+ return self.c_region.contents.tb_res
+ def _set_tbres(self, value):
+ self.c_region.contents.tb_res = value
+ self.adjust()
+ tbres = property(fget=_get_tbres, fset=_set_tbres)
+ @property
+ def zone(self):
+ return self.c_region.contents.zone
+ @property
+ def proj(self):
+ return self.c_region.contents.proj
+ #----------MAGIC METHODS----------
+ return 'Region(n=%g, s=%g, e=%g, w=%g, nsres=%g, ewres=%g)' % (
+ self.north, self.south, self.east, self.west,
+ self.nsres, self.ewres)
+ def __unicode__(self):
+ return grass.pipe_command("g.region", flags="p").communicate()[0]
+ return self.__unicode__()
+ def __eq__(self, reg):
+ attrs = ['north', 'south', 'west', 'east', 'top', 'bottom',
+ 'nsres', 'ewres', 'tbres']
+ for attr in attrs:
+ if getattr(self, attr) != getattr(reg, attr):
+ return False
+ return True
+ def iteritems(self):
+ return [('projection', self.proj),
+ ('zone', self.zone),
+ ('north', self.north),
+ ('south', self.south),
+ ('west', self.west),
+ ('east', self.east),
+ ('top', self.top),
+ ('bottom', self.bottom),
+ ('nsres', self.nsres),
+ ('ewres', self.ewres),
+ ('tbres', self.tbres),
+ ('rows', self.rows),
+ ('cols', self.cols),
+ ('cells', self.rows * self.cols)]
+ #----------METHODS----------
+ def zoom(self, raster_name):
+ """Shrink region until it meets non-NULL data from this raster map:"""
+ self._set_param('zoom', str(raster_name))
+ def align(self, raster_name):
+ """Adjust region cells to cleanly align with this raster map"""
+ self._set_param('align', str(raster_name))
+ def adjust(self, rows=False, cols=False):
+ """Adjust rows and cols number according with the nsres and ewres
+ resolutions. If rows or cols parameters are True, the adjust method
+ update nsres and ewres according with the rows and cols numbers.
+ libgis.G_adjust_Cell_head(self.c_region, bool(rows), bool(cols))
+ def get_current(self):
+ libgis.G_get_set_window(self.c_region)
+ def set_current(self):
+ libgis.G_set_window(self.c_region)
+ def get_default(self):
+ libgis.G_get_window(self.c_region)
+ def set_default(self):
+ self.adjust()
+ if libgis.G_put_window(self.c_region) < 0:
+ raise GrassError("Cannot change region (WIND file).")
Deleted: grass/trunk/lib/python/pygrass/region.py
--- grass/trunk/lib/python/pygrass/region.py 2012-12-23 10:43:37 UTC (rev 54370)
+++ grass/trunk/lib/python/pygrass/region.py 2012-12-23 11:13:18 UTC (rev 54371)
@@ -1,224 +0,0 @@
-# -*- coding: utf-8 -*-
-Created on Fri May 25 12:57:10 2012
- at author: Pietro Zambelli
-import ctypes
-import grass.lib.gis as libgis
-import grass.script as grass
-from errors import GrassError
-class Region(object):
- def __init__(self, default=False):
- >>> default = Region(default=True)
- >>> current = Region()
- >>> default == current
- True
- >>> current.cols
- 1500
- >>> current.ewres
- 10.0
- >>> current.cols = 3000
- >>> current.ewres
- 5.0
- >>> current.ewres = 20.0
- >>> current.cols
- 750
- >>> current.set_current()
- False
- >>> current.set_default()
- True
- >>> default
- Region(n=228500, s=215000, e=645000, w=630000, nsres=10, ewres=20)
- >>> current
- >>> default.ewres = 10.
- >>> default.set_default()
- self.c_region = ctypes.pointer(libgis.Cell_head())
- if default:
- self.get_default()
- else:
- self.get_current()
- def _set_param(self, key, value):
- grass.run_command('g.region', **{key: value})
- #----------LIMITS----------
- def _get_n(self):
- return self.c_region.contents.north
- def _set_n(self, value):
- self.c_region.contents.north = value
- north = property(fget=_get_n, fset=_set_n)
- def _get_s(self):
- return self.c_region.contents.south
- def _set_s(self, value):
- self.c_region.contents.south = value
- south = property(fget=_get_s, fset=_set_s)
- def _get_e(self):
- return self.c_region.contents.east
- def _set_e(self, value):
- self.c_region.contents.east = value
- east = property(fget=_get_e, fset=_set_e)
- def _get_w(self):
- return self.c_region.contents.west
- def _set_w(self, value):
- self.c_region.contents.west = value
- west = property(fget=_get_w, fset=_set_w)
- def _get_t(self):
- return self.c_region.contents.top
- def _set_t(self, value):
- self.c_region.contents.top = value
- top = property(fget=_get_t, fset=_set_t)
- def _get_b(self):
- return self.c_region.contents.bottom
- def _set_b(self, value):
- self.c_region.contents.bottom = value
- bottom = property(fget=_get_b, fset=_set_b)
- #----------RESOLUTION----------
- def _get_rows(self):
- return self.c_region.contents.rows
- def _set_rows(self, value):
- self.c_region.contents.rows = value
- self.adjust(rows=True)
- rows = property(fget=_get_rows, fset=_set_rows)
- def _get_cols(self):
- return self.c_region.contents.cols
- def _set_cols(self, value):
- self.c_region.contents.cols = value
- self.adjust(cols=True)
- cols = property(fget=_get_cols, fset=_set_cols)
- def _get_nsres(self):
- return self.c_region.contents.ns_res
- def _set_nsres(self, value):
- self.c_region.contents.ns_res = value
- self.adjust()
- nsres = property(fget=_get_nsres, fset=_set_nsres)
- def _get_ewres(self):
- return self.c_region.contents.ew_res
- def _set_ewres(self, value):
- self.c_region.contents.ew_res = value
- self.adjust()
- ewres = property(fget=_get_ewres, fset=_set_ewres)
- def _get_tbres(self):
- return self.c_region.contents.tb_res
- def _set_tbres(self, value):
- self.c_region.contents.tb_res = value
- self.adjust()
- tbres = property(fget=_get_tbres, fset=_set_tbres)
- @property
- def zone(self):
- return self.c_region.contents.zone
- @property
- def proj(self):
- return self.c_region.contents.proj
- #----------MAGIC METHODS----------
- def __repr__(self):
- return 'Region(n=%g, s=%g, e=%g, w=%g, nsres=%g, ewres=%g)' % (
- self.north, self.south, self.east, self.west,
- self.nsres, self.ewres)
- def __unicode__(self):
- return grass.pipe_command("g.region", flags="p").communicate()[0]
- def __str__(self):
- return self.__unicode__()
- def __eq__(self, reg):
- attrs = ['north', 'south', 'west', 'east', 'top', 'bottom',
- 'nsres', 'ewres', 'tbres']
- for attr in attrs:
- if getattr(self, attr) != getattr(reg, attr):
- return False
- return True
- def iteritems(self):
- return [('projection', self.proj),
- ('zone', self.zone),
- ('north', self.north),
- ('south', self.south),
- ('west', self.west),
- ('east', self.east),
- ('top', self.top),
- ('bottom', self.bottom),
- ('nsres', self.nsres),
- ('ewres', self.ewres),
- ('tbres', self.tbres),
- ('rows', self.rows),
- ('cols', self.cols),
- ('cells', self.rows * self.cols)]
- #----------METHODS----------
- def zoom(self, raster_name):
- """Shrink region until it meets non-NULL data from this raster map:"""
- self._set_param('zoom', str(raster_name))
- def align(self, raster_name):
- """Adjust region cells to cleanly align with this raster map"""
- self._set_param('align', str(raster_name))
- def adjust(self, rows=False, cols=False):
- """Adjust rows and cols number according with the nsres and ewres
- resolutions. If rows or cols parameters are True, the adjust method
- update nsres and ewres according with the rows and cols numbers.
- libgis.G_adjust_Cell_head(self.c_region, bool(rows), bool(cols))
- def get_current(self):
- libgis.G_get_set_window(self.c_region)
- def set_current(self):
- libgis.G_set_window(self.c_region)
- def get_default(self):
- libgis.G_get_window(self.c_region)
- def set_default(self):
- self.adjust()
- if libgis.G_put_window(self.c_region) < 0:
- raise GrassError("Cannot change region (WIND file).")
