[GRASS-SVN] r54399 - grass/trunk/gui/wxpython/iclass
svn_grass at osgeo.org
Tue Dec 25 08:32:56 PST 2012
Author: martinl
Date: 2012-12-25 08:32:55 -0800 (Tue, 25 Dec 2012)
New Revision: 54399
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
g.gui.iclass: add parameters - 'group' and 'map'
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2012-12-25 12:02:09 UTC (rev 54398)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2012-12-25 16:32:55 UTC (rev 54399)
@@ -45,7 +45,7 @@
from vdigit.toolbars import VDigitToolbar
from gui_core.mapdisp import DoubleMapFrame
from core.render import Map, MapLayer
-from core.gcmd import RunCommand, GMessage
+from core.gcmd import RunCommand, GMessage, GError
from gui_core.dialogs import SetOpacityDialog
from dbmgr.vinfo import VectorDBInfo
import grass.script as grass
@@ -422,12 +422,17 @@
"""!Add imagery group"""
dlg = IClassGroupDialog(self, group = self.group)
if dlg.ShowModal() == wx.ID_OK:
- group = grass.find_file(name = dlg.GetGroup(), element = 'group')
- if group['name']:
- self.group = group['name']
+ self.SetGroup(dlg.GetGroup())
dlg.Destroy()
+ def SetGroup(self, name):
+ """!Set immagery group"""
+ group = grass.find_file(name = name, element = 'group')
+ if group['name']:
+ self.group = group['name']
+ else:
+ GError(_("Group <%s> not found") % name, parent = self)
def OnImportAreas(self, event):
"""!Import training areas"""
# check if we have any changes
Modified: grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
--- grass/trunk/gui/wxpython/iclass/g.gui.iclass.py 2012-12-25 12:02:09 UTC (rev 54398)
+++ grass/trunk/gui/wxpython/iclass/g.gui.iclass.py 2012-12-25 16:32:55 UTC (rev 54399)
@@ -28,6 +28,13 @@
#% keywords: classification
#% keywords: signatures
#%end
+#%option G_OPT_I_GROUP
+#% required: no
+#%end
+#%option G_OPT_R_MAP
+#% description: Name of raster map to load
+#% required: no
+#%end
import os
import sys
@@ -45,6 +52,15 @@
from iclass.frame import IClassMapFrame
def main():
+ if options['group']:
+ group_name = grass.find_file(name = options['group'], element = 'group')['name']
+ if not group_name:
+ grass.fatal(_("Group <%s> not found") % options['group'])
+ if options['map']:
+ map_name = grass.find_file(name = options['map'], element = 'cell')['fullname']
+ if not map_name:
+ grass.fatal(_("Raster map <%s> not found") % options['map'])
# define display driver
driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
if driver == 'png':
@@ -57,12 +73,20 @@
wx.InitAllImageHandlers()
# show main frame
- frame = IClassMapFrame(parent = None, giface = StandaloneGrassInterface())
+ giface = StandaloneGrassInterface()
+ frame = IClassMapFrame(parent = None, giface = giface)
+ if group_name:
+ frame.SetGroup(group_name)
+ if map_name:
+ giface.WriteLog(_("Loading raster map <%s>...") % map_name)
+ frame.trainingMapManager.AddLayer(map_name)
frame.Show()
app.MainLoop()
if __name__ == '__main__':
gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+ grass.set_raise_on_error(False)
options, flags = grass.parser()
main()
