[GRASS-SVN] r54409 - grass/trunk/gui/wxpython/vdigit
svn_grass at osgeo.org
Wed Dec 26 04:14:06 PST 2012
Author: martinl
Date: 2012-12-26 04:14:06 -0800 (Wed, 26 Dec 2012)
New Revision: 54409
grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.html
wxGUI/vdigit: update manual
Modified: grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.html
--- grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.html 2012-12-26 11:13:01 UTC (rev 54408)
+++ grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.html 2012-12-26 12:14:06 UTC (rev 54409)
@@ -8,40 +8,45 @@
vector editing GRASS capabilities).
<p>
-The digitizer supports editing of 2D vector features (points, lines,
+Note that only vector maps from the current mapset is possible to open
+for editing.
+<p>
+The digitizer allows editing 2D vector features only (points, lines,
centroids, boundaries, and areas).
-Vector features can be selected by mouse or by query (e.g. minimal
-vector line length). Vector features can be selected by bounding box
-or simply by mouse click (based on 'Settings→General→Select
-threshold' value).
+Vector features can be selected by mouse (bounding box or simply by
+mouse click, see select threshold
+in <i>Settings→General→Select threshold</i>), or by query
+(eg. by line length, see <i>Settings→Query Tool</i>).
<p>
-Vector digitizer can be activated from Main toolbar in Map Display by
-selecting "Digitize" from "Tools" combobox. Vector map to be edited
-can be afterwards selected from digitizer toolbar ("Select vector map"
-combobox, note that only vector maps from the current layer tree in Layer
-Manager are available).
+Vector digitizer can be launched from Map Display toolbar by selecting
+"Digitize" from <i>Tools</i> combobox. Vector map is
+selectable for editing from Digitizer toolbar ("Select vector
+map" combobox, note that only vector maps from the current layer
+tree in Layer Manager are listed).
Vector digitizer can be alternatively also activated from contextual
menu in Layer Manager by selecting "Start editing" on selected vector
-map in the layer tree.
+map in the layer tree, or directly from Layer Manager
+toolbar <img src="icons/edit.png" alt="icon">.
<p>
New vector map can be easily created from digitizer toolbar by
-selecting "New vector map" in "Select vector map" combobox. A new
-vector map is created, added to the current layer tree in Layer
-Manager and opened for editing. "Select vector map" combobox in
-digitizer toolbar also allows switching easily between vector maps to be
-edited.
+selecting "New vector map" in "Select vector map"
+combobox. A new vector map is created, added to the current layer tree
+in Layer Manager and opened for editing. "Select vector map"
+combobox in digitizer toolbar also allows switching easily between
+vector maps to be edited.
<p>
-The wxGUI vector digitizer draws all maps in the Layer Manager in the Map
-Display window; in addition, the digitizer also recognizes a special
-"background" vector map. This map is selected from the Layer Manager by
-right-clicking on the map and selecting "Use as Background Map" from the
-contextual menu. The features of the background map may then be copied into
-the currently edited vector map using the "Copy features from (background)
-vector map" button in the "Additional Tools" menu on the Digitzer Toolbar.
+Vector digitizer allows to define "background" vector map. A
+background map can be selected from map layer contextual menu in Layer
+Manager ("Use as Background Map"). Newly digitized vector
+features are snapped in the given threshold to the features from the
+background map. Vector features may be also copied from the background
+map by "Copy features from (background) vector map" tool
+from the digitizer toolbar.
<h3>DIGITIZER TOOLBAR</h3>
@@ -203,7 +208,7 @@
<dt><img src="icons/settings.png" alt="icon">
<em>Settings</em></dt>
- <dd>Dialog for vector digitizer settings.</dd>
+ <dd>Digitizer settings.</dd>
<dt><img src="icons/quit.png" alt="icon">
<em>Quit digitizing tool</em></dt>
@@ -214,9 +219,9 @@
<h2>NOTES</h2>
-<dl><dt><b>Mouse button Functions:</b><dd>
- <dt><i>Left</i> - select/deselect features</dt>
- <dt><i>Control+Left</i> - cancel action/undo vertex</dt>
+<dl><dt><b>Mouse button functions:</b><dd>
+ <dt><i>Left</i> - select or deselect features</dt>
+ <dt><i>Control+Left</i> - cancel action or undo vertex when digitizing lines</dt>
<dt><i>Right</i> - confirm action</dt>
</dl>
@@ -233,9 +238,9 @@
disable snapping set the snapping threshold to '0'.
<p>
-If the digitizer crashes for some reason you can repair the vector map
-which was left open with
-the <em><a href="v.build.html">v.build</a></em> module.
+If the digitizer crashes for some reason, the changes are
+automatically saved. Broken topology can be repaired by running
+<em><a href="v.build.html">v.build</a></em>.
<h2>REFERENCE</h2>
