[GRASS-SVN] r54417 - grass/trunk/raster/r.cost
svn_grass at osgeo.org
Thu Dec 27 08:06:06 PST 2012
Author: mmetz
Date: 2012-12-27 08:06:06 -0800 (Thu, 27 Dec 2012)
New Revision: 54417
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.cost/r.cost.html
r.cost: use standard GRASS directions
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2012-12-27 14:54:22 UTC (rev 54416)
+++ grass/trunk/raster/r.cost/main.c 2012-12-27 16:06:06 UTC (rev 54417)
@@ -95,7 +95,7 @@
double NS_fac, EW_fac, DIAG_fac, H_DIAG_fac, V_DIAG_fac;
double fcost;
double min_cost, old_min_cost;
- double cur_dir;
+ FCELL cur_dir;
double zero = 0.0;
int at_percent = 0;
int col, row, nrows, ncols;
@@ -126,7 +126,7 @@
} costs;
void *ptr2;
- RASTER_MAP_TYPE data_type, dir_data_type = DCELL_TYPE, nearest_data_type = CELL_TYPE;
+ RASTER_MAP_TYPE data_type, dir_data_type = FCELL_TYPE, nearest_data_type = CELL_TYPE;
struct History history;
double peak = 0.0;
int dsize, nearest_size;
@@ -394,8 +394,8 @@
/* report disk space and memory requirements */
if (dir == TRUE) {
- disk_mb = (double) nrows * ncols * 32. / 1048576.;
- mem_mb = (double) srows * scols * 32. / 1048576. * segments_in_memory;
+ disk_mb = (double) nrows * ncols * 28. / 1048576.;
+ mem_mb = (double) srows * scols * 28. / 1048576. * segments_in_memory;
mem_mb += nrows * ncols * 0.05 * 20. / 1048576.; /* for Dijkstra search */
else {
@@ -424,7 +424,7 @@
if (dir == TRUE) {
if (segment_open(&dir_seg, G_tempfile(), nrows, ncols, srows, scols,
- sizeof(double), segments_in_memory) != 1)
+ sizeof(FCELL), segments_in_memory) != 1)
G_fatal_error(_("Can not create temporary file"));
@@ -775,75 +775,97 @@
* 16 8 4 7 15
* 12 11
+ /* drainage directions in degrees CCW from East
+ * drainage directions are set for each neighbor and must be
+ * read as from neighbor to current cell
+ * X = neighbor:
+ * 112.5 67.5
+ * 157.5 135 90 45 22.5
+ * 180 X 360
+ * 202.5 225 270 315 337.5
+ * 247.5 292.5
+ * X = present cell, directions for neighbors:
+ * 292.5 247.5
+ * 337.5 315 270 225 202.5
+ * 360 X 180
+ * 22.5 45 90 135 157.5
+ * 67.5 112.5
for (neighbor = 1; neighbor <= total_reviewed; neighbor++) {
switch (neighbor) {
case 1:
col = pres_cell->col - 1;
- cur_dir = 180.0;
+ cur_dir = 360.0;
break;
case 2:
col = pres_cell->col + 1;
- cur_dir = 0.0;
+ cur_dir = 180.0;
break;
case 3:
row = pres_cell->row - 1;
col = pres_cell->col;
- cur_dir = 90.0;
+ cur_dir = 270.0;
break;
case 4:
row = pres_cell->row + 1;
- cur_dir = 270.0;
+ cur_dir = 90.0;
break;
case 5:
- cur_dir = 135.0;
+ cur_dir = 315.0;
break;
case 6:
- cur_dir = 45.0;
+ cur_dir = 225.0;
break;
case 7:
- cur_dir = 315.0;
+ cur_dir = 135.0;
break;
case 8:
- cur_dir = 225.0;
+ cur_dir = 45.0;
break;
case 9:
row = pres_cell->row - 2;
- cur_dir = 112.5;
+ cur_dir = 292.5;
break;
case 10:
- cur_dir = 67.5;
+ cur_dir = 247.5;
break;
case 11:
row = pres_cell->row + 2;
- cur_dir = 292.5;
+ cur_dir = 112.5;
break;
case 12:
- cur_dir = 247.5;
+ cur_dir = 67.5;
break;
case 13:
col = pres_cell->col - 2;
- cur_dir = 157.5;
+ cur_dir = 337.5;
break;
case 14:
col = pres_cell->col + 2;
- cur_dir = 22.5;
+ cur_dir = 202.5;
break;
case 15:
- cur_dir = 337.5;
+ cur_dir = 157.5;
break;
case 16:
- cur_dir = 202.5;
+ cur_dir = 22.5;
break;
@@ -1101,7 +1123,8 @@
if (dir == TRUE) {
- double *p;
+ void *p;
+ size_t dir_size = Rast_cell_size(dir_data_type);
dir_fd = Rast_open_new(move_dir_layer, dir_data_type);
dir_cell = Rast_allocate_buf(dir_data_type);
@@ -1111,7 +1134,8 @@
p = dir_cell;
for (col = 0; col < ncols; col++) {
segment_get(&dir_seg, &cur_dir, row, col);
- *(p + col) = cur_dir;
+ *((FCELL *) p) = cur_dir;
+ p = G_incr_void_ptr(p, dir_size);
Rast_put_row(dir_fd, dir_cell, dir_data_type);
G_percent(row, nrows, 2);
@@ -1123,7 +1147,7 @@
segment_close(&cost_seg); /* release memory */
if (dir == TRUE)
segment_close(&dir_seg);
- Rast_close(cost_fd);
+ Rast_close(cost_fd);
Rast_close(cum_fd);
if (dir == TRUE)
Rast_close(dir_fd);
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2012-12-27 14:54:22 UTC (rev 54416)
+++ grass/trunk/raster/r.cost/r.cost.html 2012-12-27 16:06:06 UTC (rev 54417)
@@ -12,9 +12,9 @@
costs are multiplied by a factor that depends on the dimensions of
the cell) and 2) a second raster map layer showing the movement
direction to the next cell on the path back to the start point (see
-<a href="#move">Movement Direction</a>). This program uses the current geographic region settings.
-The <b>output</b> map will be of the same data format as the <b>input</b>
-map, integer or floating point.
+<a href="#move">Movement Direction</a>). This module uses the current
+geographic region settings. The <b>output</b> map will be of the same
+data format as the <b>input</b> map, integer or floating point.
<h2>OPTIONS</h2>
@@ -186,7 +186,7 @@
</pre></div>
<p><!-- ??? are "starting" and "ending" swapped in the following text ??? -->
-The user-provided ending location in the above example is the boxed <b>3</b>
+The user-provided starting location in the above example is the boxed <b>3</b>
in the above input map. The costs in the output map represent the total
cost of moving from each box ("cell") to one or more (here,
only one) starting location(s). Cells surrounded by asterisks are
@@ -227,26 +227,22 @@
<p>The movement direction surface is created to record the sequence of
movements that created the cost accumulation surface. Without it
<em>r.drain</em> would not correctly create a path from an end point
-back to the start point. The direction shown in each cell points <b>away</b>
-from the cell that came before it. The directions are recorded as
-GRASS standard directions:<div class="code"><pre>
- 112.5 90 67.5 i.e. a cell with the value 135
-157.5 135 0 45 22.5 means the cell <b>before</b> it is
- 180 x 0 to the south-east.
+back to the start point. The direction of each cell points towards
+the next cell. The directions are recorded as degrees CCW from East:
+<div class="code"><pre>
+ 112.5 67.5 i.e. a cell with the value 135
+157.5 135 90 45 22.5 means the next cell is to the north-west
+ 180 x 360
247.5 292.5
</pre></div>
-<p>Once <em>r.cost</em> computes the cumulative cost map, <em>r.drain</em>
+<p>
+Once <em>r.cost</em> computes the cumulative cost map, <em>r.drain</em>
can be used to find the minimum cost path. Make sure to use the <b>-d</b> flag
and the movement direction raster map when running r.drain to ensure
the path is computed according to the proper movement directions.
-<h2>BUGS</h2>
-The percentage done calculation reported in verbose mode is often not linear
-and ends well before 100%. This does not affect output.
<h2>SEE ALSO</h2>
<em><a href="r.drain.html">r.drain</a></em>,
