[GRASS-SVN] r54422 - grass/trunk/imagery/i.ortho.photo/i.ortho.camera
svn_grass at osgeo.org
Thu Dec 27 08:27:51 PST 2012
Author: mmetz
Date: 2012-12-27 08:27:50 -0800 (Thu, 27 Dec 2012)
New Revision: 54422
grass/trunk/imagery/i.ortho.photo/i.ortho.camera/main.c
add i.ortho.camera
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.camera/main.c
--- grass/trunk/imagery/i.ortho.photo/i.ortho.camera/main.c 2012-12-27 16:11:57 UTC (rev 54421)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.camera/main.c 2012-12-27 16:27:50 UTC (rev 54422)
@@ -17,9 +17,10 @@
* for details.
-/* select_camera */
-/* select a camera reference file for a given imagery group */
+/* create/edit a camera reference file
+ * optionally set the camera for a given imagery group */
#include <stdlib.h>
#include <string.h>
@@ -30,19 +31,24 @@
int main(int argc, char *argv[])
struct GModule *module;
- struct Option *group_opt, *camera_opt;
- /* options for
- * camera name
- * camera definition
- * calibrated focal length
- * principal point of symmetry x,y
- * fiducial coordinates in mm from the principal point */
+ struct Option *group_opt, /* group */
+ *camera_opt, /* name of camera file camera */
+ *cname_opt, /* camera name */
+ *cid_opt, /* camera id */
+ *cfl_opt, /* calibrated focal length */
+ *pp_opt, /* principal point of symmetry x,y */
+ *fid_opt; /* coordinates of fiducials */
+ /* flag to print camera info */
+ /* flag to print camera info in shell script style */
const char *location;
const char *mapset;
char *group;
- char *camera;
+ char *camera, *cam_name, *cam_id;
+ double ppx, ppy, cfl;
struct Ortho_Camera_File_Ref cam_info;
+ int put_cam_info = 0;
G_gisinit(argv[0]);
@@ -50,56 +56,166 @@
G_add_keyword(_("imagery"));
G_add_keyword(_("orthorectify"));
module->description =
- _("Interactively select and modify the imagery group camera reference file.");
+ _("Select and modify the imagery group camera reference file.");
group_opt = G_define_standard_option(G_OPT_I_GROUP);
+ group_opt->required = NO;
group_opt->description =
_("Name of imagery group for ortho-rectification");
camera_opt = G_define_standard_option(G_OPT_F_INPUT);
camera_opt->key = "camera";
- camera_opt->required = NO;
+ camera_opt->required = YES;
camera_opt->gisprompt = "old_file,camera,camera";
- camera_opt->description =
- _("Name of camera reference file to use");
+ camera_opt->label =
+ _("Name of camera reference file");
+ cname_opt = G_define_option();
+ cname_opt->type = TYPE_STRING;
+ cname_opt->key = "name";
+ cname_opt->label =
+ _("Camera name");
+ cid_opt = G_define_option();
+ cid_opt->type = TYPE_STRING;
+ cid_opt->key = "id";
+ cid_opt->label =
+ _("Camera id");
+ cfl_opt = G_define_option();
+ cfl_opt->type = TYPE_DOUBLE;
+ cfl_opt->key = "clf";
+ cfl_opt->label =
+ _("Calibrated focal length");
+ pp_opt = G_define_standard_option(G_OPT_M_COORDS);
+ pp_opt->key = "pp";
+ pp_opt->label =
+ _("Principal point coordinates");
+ fid_opt = G_define_standard_option(G_OPT_M_COORDS);
+ fid_opt->key = "fid";
+ fid_opt->multiple = YES;
+ fid_opt->label =
+ _("Fiducial coordinates");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- camera = (char *)G_malloc(GNAME_MAX * sizeof(char));
location = G_location();
mapset = G_mapset();
group = group_opt->answer;
+ camera = camera_opt->answer;
+ cam_name = cname_opt->answer;
+ cam_id = cid_opt->answer;
- /* group must be in current mapset */
- if (!I_find_group(group))
- G_fatal_error(_("No group '%s' in current mapset"), group);
+ if (G_legal_filename(camera) < 0)
+ G_fatal_error(_("<%s> is an illegal file name"),
+ camera);
- if (camera_opt->answer) {
- if (G_legal_filename (camera_opt->answer) < 0)
- G_fatal_error(_("<%s> is an illegal file name"),
- camera_opt->answer);
- else
- strcpy(camera, camera_opt->answer);
+ if (cam_name || cam_id || cfl_opt->answer || pp_opt->answers || fid_opt->answers)
+ put_cam_info = 1;
+ ppx = ppy = .0;
+ if (pp_opt->answers) {
+ sscanf(pp_opt->answers[0], "%lf", &ppx);
+ sscanf(pp_opt->answers[1], "%lf", &ppy);
+ if (G_find_file2("camera", camera, G_mapset())) {
+ /* use existing camera file */
+ if (I_get_cam_info(camera, &cam_info))
+ G_fatal_error(_("Can not read camera file '%s'"), camera);
+ if (cam_name && strcmp(cam_name, cam_info.cam_name)) {
+ G_message(_("Replacing camera name '%s' with '%s'"),
+ cam_info.cam_name, cam_name);
+ strcpy(cam_info.cam_name, cam_name);
+ if (cam_id && strcmp(cam_id, cam_info,cam_id)) {
+ G_message(_("Replacing camera cam_id '%s' with '%s'"),
+ cam_info.cam_id, cam_id);
+ strcpy(cam_info.cam_id, cam_id);
+ if (clf_opt->answer) {
+ cfl = atof(clf_opt->answer);
+ if (cfl != cam_info.CFL) {
+ G_message(_("Replacing calibrated focal length '%g' with '%g'"),
+ cam_info.CFL, cfl);
+ cam_info.CFL = cfl;
+ G_message(_("Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"),
+ cam_info.Xp, cam_info.Yp, ppx, ppy);
+ cam_info.Xp = ppx;
+ cam_info.Yp = ppy;
else {
- /* use user-provided camera definition */
+ /* create new camera file */
+ if (!cam_name)
+ G_fatal_error(_("Please provide a camera name for a new camera definition"));
+ if (!cam_id)
+ G_fatal_error(_("Please provide a camera ID for a new camera definition"));
+ if (!cfl_opt->answer)
+ G_fatal_error(_("Please provide calibrated focal length for a new camera definition"));
+ cam_info.CFL = atof(cfl_opt->answer);
+ if (!pp_opt->answers)
+ G_message(_("Using default coordinates 0.0, 0.0 for the principal point"));
+ /* fiducials */
+ if (fid_opt->answers) {
+ int i, fid_no;
+ double Xf, Yf;
+ for (i = 0, fid_no = 0; fid_opt->answers[i] != NULL; i += 2, fid_no++) {
+ /* cam_info can hold max 20 fiducials */
+ if (fid_no > 19) {
+ G_warning(_("Too many fiducials!"));
+ break;
+ sscanf(fid_opt->answers[i], "%lf", &Xf);
+ cam_info.fiducials[fid_no].Xf = Xf;
+ sscanf(fid_opt->answers[i + 1], "%lf", &Yf);
+ cam_info.fiducials[fid_no].Yf = Yf;
+ sprintf(cam_info.fiducials[fid_no].fid_id, "%d", fid_no);
+ cam_info.num_fid = fid_no;
+ if (put_cam_info) {
+ /* create/modify camera file */
I_put_cam_info(camera, &cam_info);
- /* I_put_camera (camera); */
- I_put_group_camera(group, camera);
+ /* set group camera */
+ if (group) {
+ /* group must be in current mapset */
+ if (!I_find_group(group))
+ G_fatal_error(_("No group '%s' in current mapset"), group);
- G_message(
- _("Group [%s] in location [%s] mapset [%s] now has camera file [%s]"),
- group, location, mapset, camera);
+ I_put_group_camera(group, camera);
+ G_message(
+ _("Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"),
+ group, location, mapset, camera);
- /* print camera info */
exit(EXIT_SUCCESS);
