[GRASS-SVN] r54437 - grass/trunk/display/d.linegraph
svn_grass at osgeo.org
Fri Dec 28 02:52:38 PST 2012
Author: lucadelu
Date: 2012-12-28 02:52:38 -0800 (Fri, 28 Dec 2012)
New Revision: 54437
grass/trunk/display/d.linegraph/d.linegraph.html
grass/trunk/display/d.linegraph/main.c
d.linegraph removed answer to directory option, fix also documentation
Modified: grass/trunk/display/d.linegraph/d.linegraph.html
--- grass/trunk/display/d.linegraph/d.linegraph.html 2012-12-28 09:35:16 UTC (rev 54436)
+++ grass/trunk/display/d.linegraph/d.linegraph.html 2012-12-28 10:52:38 UTC (rev 54437)
@@ -18,9 +18,8 @@
<p><dl>
<dt><b>directoryname</b>
-<dd>Path to the directory where the input files are located. If this option
-is not used, the <em>d.linegraph</em> looks for files in the current directory.
-<dd>Example format: directory/usr/grass/data/graph
+<dd>Path to the directory where the input files are located.
+<dd>Example format: /usr/grass/data/graph
<dt><b>ycoloroption[,option,...]]</b>
<dd>Color to be used for drawing the lines in the graph. If multiple Y data
Modified: grass/trunk/display/d.linegraph/main.c
--- grass/trunk/display/d.linegraph/main.c 2012-12-28 09:35:16 UTC (rev 54436)
+++ grass/trunk/display/d.linegraph/main.c 2012-12-28 10:52:38 UTC (rev 54437)
@@ -139,7 +139,8 @@
dir_opt->description = _("Path to file location");
dir_opt->type = TYPE_STRING;
dir_opt->required = NO;
- dir_opt->answer = ".";
+ /* Remove answer because create problem with full path */
+ /* dir_opt->answer = "."; */
y_color_opt = G_define_option();
y_color_opt->key = "y_color";
@@ -193,7 +194,11 @@
notice that in[0] will be the X file, and in[1-10]
will be the Y file(s) */
- sprintf(in[0].full_name, "%s/%s", dir_opt->answer, x_opt->answer);
+ if (dir_opt->answer != NULL) {
+ sprintf(in[0].full_name, "%s/%s", dir_opt->answer, x_opt->answer);
+ } else {
+ sprintf(in[0].full_name, "%s", x_opt->answer);
sprintf(in[0].name, "%s", x_opt->answer);
if ((in[0].fp = fopen(in[0].full_name, "r")) == NULL)
@@ -204,7 +209,12 @@
/* open all Y data files */
for (i = 0, j = 1; (name = y_opt->answers[i]); i++, j++) {
- sprintf(in[j].full_name, "%s/%s", dir_opt->answer, name);
+ sprintf(in[j].full_name, "%s/%s", dir_opt->answer, name);
+ } else {
+ sprintf(in[j].full_name, "%s", name);
sprintf(in[j].name, "%s", name);
if ((in[j].fp = fopen(in[j].full_name, "r")) == NULL)
