[GRASS-SVN] r54440 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Fri Dec 28 05:50:06 PST 2012
Author: martinl
Date: 2012-12-28 05:50:02 -0800 (Fri, 28 Dec 2012)
New Revision: 54440
grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: fix message when no layer is selected
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2012-12-28 11:59:25 UTC (rev 54439)
+++ grass/trunk/vector/v.in.ogr/main.c 2012-12-28 13:50:02 UTC (rev 54440)
@@ -393,7 +393,8 @@
if (nlayers < 1)
G_fatal_error(_("No OGR layers available"));
output = G_store(layer_names[0]);
- G_message(_("All available OGR layers will be imported into vector map <%s>"), output);
+ if (param.layer->answer == NULL)
+ G_warning(_("All available OGR layers will be imported into vector map <%s>"), output);
if (!param.outloc->answer) { /* Check if the map exists */
