[GRASS-SVN] r54473 - in grass/branches/develbranch_6/vector: . v.vect.stats
svn_grass at osgeo.org
Mon Dec 31 04:46:58 PST 2012
Author: neteler
Date: 2012-12-31 04:46:56 -0800 (Mon, 31 Dec 2012)
New Revision: 54473
Added:
grass/branches/develbranch_6/vector/v.vect.stats/
Removed:
grass/branches/develbranch_6/vector/v.vect.stats/grass640.patch
grass/branches/develbranch_6/vector/Makefile
moved from Addons to 6.5 according to release plan
Modified: grass/branches/develbranch_6/vector/Makefile
--- grass/branches/develbranch_6/vector/Makefile 2012-12-31 12:44:29 UTC (rev 54472)
+++ grass/branches/develbranch_6/vector/Makefile 2012-12-31 12:46:56 UTC (rev 54473)
@@ -77,6 +77,7 @@
v.to.rast3 \
v.type \
v.univar \
+ v.vect.stats \
v.voronoi \
v.what \
v.what.rast\
Deleted: grass/branches/develbranch_6/vector/v.vect.stats/grass640.patch
--- grass-addons/grass6/vector/v.vect.stats/grass640.patch 2012-12-31 12:44:29 UTC (rev 54472)
+++ grass/branches/develbranch_6/vector/v.vect.stats/grass640.patch 2012-12-31 12:46:56 UTC (rev 54473)
@@ -1,14 +0,0 @@
-Index: main.c
---- main.c (revision 50221)
-+++ main.c (working copy)
-@@ -656,8 +656,7 @@
- if (Area_cat[i].count > 0 && method_opt->answer) {
- /* get stats */
-- statsvalue(&result, Area_cat[i].values, Area_cat[i].nvalues,
-- NULL);
-+ statsvalue(&result, Area_cat[i].values, Area_cat[i].nvalues);
- if (half)
- result += 0.5;
