[GRASS-SVN] r50611 - grass/branches/releasebranch_6_4/debian
Wed Feb 1 05:00:03 EST 2012
Author: hamish
Date: 2012-02-01 02:00:03 -0800 (Wed, 01 Feb 2012)
New Revision: 50611
   grass/branches/releasebranch_6_4/debian/README.debian
further tweaks (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/debian/README.debian
--- grass/branches/releasebranch_6_4/debian/README.debian	2012-02-01 09:56:56 UTC (rev 50610)
+++ grass/branches/releasebranch_6_4/debian/README.debian	2012-02-01 10:00:03 UTC (rev 50611)
@@ -3,9 +3,13 @@
 # to construct the .deb files.
 # Make sure git and the debian build scripts are installed:
-  sudo apt-get install git-core devscripts
+  sudo apt-get install git-core devscripts subversion
+# and download the latest svn copy of GRASS:
+  cd src/grass/
+  svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4 relbr64
 # From the grass source dir download the packaging rules (the contents
 #  of debiangis/grass/ can be ignored, only the debian/ dir is needed):
   git clone git://git.debian.org/git/pkg-grass/grass.git debiangis
@@ -27,15 +31,19 @@
 # After that, you can build the current version of GRASS with
+  cd relbr64
+  ln -s ../debian .
+  svn up
   debuild -i -uc -us -b
-# in main GRASS source directory. After the packages are generated, you can
-# install them with:
+# run from the main GRASS source directory. After the packages are
+# generated, you can install them with:
   sudo dpkg -i ../grass*.deb
-# (make sure to remove older grass*.deb files first)
+# (make sure to move away older grass*.deb files first)
 # to try again, first clean out the old build by running:
