[GRASS-SVN] r50617 - sandbox/lucadelu
Wed Feb 1 12:21:49 EST 2012
Author: lucadelu
Date: 2012-02-01 09:21:49 -0800 (Wed, 01 Feb 2012)
New Revision: 50617
   sandbox/lucadelu/r.li.setup.py
improvement
Modified: sandbox/lucadelu/r.li.setup.py
--- sandbox/lucadelu/r.li.setup.py	2012-02-01 16:03:42 UTC (rev 50616)
+++ sandbox/lucadelu/r.li.setup.py	2012-02-01 17:21:49 UTC (rev 50617)
@@ -184,9 +184,40 @@
         self.wizard.FitToPage(self.startpage)
         #run_wizard
-        self.wizard.RunWizard(self.startpage)
+        if self.wizard.RunWizard(self.startpage):
+            dlg = wx.MessageDialog(parent = self.parent,
+                                message = _("Do you want to create r.li configuration file <%s>?") % self.startpage.conf_name,
+                                caption = _("Create new r.li configuration file?"),
+                                style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+            if dlg.ShowModal() == wx.ID_NO:
+                dlg.Destroy()
+                print "no"
+                self._cleanup()
+            else:
+                dlg.Destroy()
+                print "yes"
+                self._cleanup()
+        else:
+            self.wizard.Destroy()
+            gcmd.GMessage(parent = self.parent,
+                     message = _("r.li.setup wizard canceled. "
+                                 "Configuration file not created."))
+            self._cleanup()
+    def _cleanup(self):
+        self.startpage.conf_name = ''
+        self.startpage.rast = ''
+        self.startpage.vect = ''
+        self.startpage.region = 'whole'
+        self.keyboardpage.col_len = ''
+        self.keyboardpage.row_len = ''
+        self.samplingareapage.samplingtype = 'whole'
+        self.samplingunitskey.sizew = ''
+        self.samplingunitskey.sizeh = ''
 class FirstPage(TitledPage):
     Set name of configuration file, choose raster and optionally vector/sites
@@ -196,10 +227,6 @@
         TitledPage.__init__(self, wizard, _("Select maps and define name"))
         self.parent = parent
-        self.region = 'whole'
-        self.rast = ''
-        self.conf_name = ''
-        self.vect = ''
         self.sizer.AddGrowableCol(2)
         #name of output configuration file
@@ -246,6 +273,7 @@
         self.vectselect.Bind(wx.EVT_TEXT, self.OnVector)
         self.mapselect.Bind(wx.EVT_TEXT, self.OnRast)
+        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
         self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
         wx.FindWindowById(wx.ID_FORWARD).Enable(False)
@@ -310,6 +338,14 @@
                 event.Veto()
                 return
+    def OnEnterPage(self, event=None):
+        """!Function during entry"""
+        self.region = 'whole'
+        self.rast = ''
+        self.conf_name = ''
+        self.vect = ''
+        wx.FindWindowById(wx.ID_FORWARD).Enable(False)
 class KeybordPage(TitledPage):
@@ -594,10 +630,12 @@
         self.sizer.Add(self.typeBox, pos = (1, 1),
                       flag = wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
         choicess = [_('Random non overlapping'), _('Systematic contiguos'),
-                    _('Stratified random'), _('Systematic non contiguos')]
+                    _('Stratified random'), _('Systematic non contiguos'),
+                    _('Centered over sites')]
         self.distributionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
                       label= _("Select method of sampling unit distribution"),
                       choices = choicess, style=wx.VERTICAL)
+        self.distributionBox.EnableItem(4,False)
         self.sizer.Add(self.distributionBox, pos = (1, 2),
         # size width
@@ -631,7 +669,7 @@
         """!Check if sites vector it is present"""
         # method of distribution
         if self.parent.startpage.vect != '':
-            self.distributionBox.SetItemLabel(5, _('Centered over sites'))
+            self.distributionBox.EnableItem(5, True)
             self.sizer.Layout()
     def OnExitPage(self, event=None):
@@ -744,7 +782,6 @@
                         flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
         #sampling area
         self.samplinglabel = wx.StaticText(parent = self, id = wx.ID_ANY,
                         label = _('Sempling area type:'))
