[GRASS-SVN] r50620 - sandbox/martinl/v.test
svn_grass at osgeo.org
Wed Feb 1 17:18:59 EST 2012
Author: martinl
Date: 2012-02-01 14:18:59 -0800 (Wed, 01 Feb 2012)
New Revision: 50620
sandbox/martinl/v.test/v.test.html
v.test (sandbox): cosmetics in manual page
Modified: sandbox/martinl/v.test/v.test.html
--- sandbox/martinl/v.test/v.test.html 2012-02-01 22:06:54 UTC (rev 50619)
+++ sandbox/martinl/v.test/v.test.html 2012-02-01 22:18:59 UTC (rev 50620)
@@ -6,60 +6,64 @@
<h2>EXAMPLES</h2>
+<div class="code"><pre>
+export MAP=vector_map
+</pre></div>
Testing sequential access:
# sequential access on non-topological level
-v.test -s1 map
+v.test -s1 map=$MAP
# sequential access on non-topological level with type constraint
-v.test -s1 map type=line
+v.test -s1 map=$MAP type=line
# sequential access on non-topological level with layer constraint
-v.test -s1 map layer=2
+v.test -s1 map=$MAP layer=2
# sequential access on non-topological level with region constraint
-v.test -s1r map
+v.test -s1r map=$MAP
# sequential access on topological level
-v.test -s map
+v.test -s map=$MAP
# sequential access on topological level with type constraint
-v.test -s map type=line
+v.test -s map=$MAP type=line
# sequential access on topological level with layer constraint
-v.test -s map layer=2
+v.test -s map=$MAP layer=2
# sequential access on topological level with region constraint
-v.test -sr map
+v.test -sr map=$MAP
</pre></div>
Testing random access:
# random access on non-topological level
-v.test -1 map
+v.test -1 map=$MAP
# random access on non-topological level with type constraint
-v.test -1 map type=line
+v.test -1 map=$MAP type=line
# random access on non-topological level with layer constraint
-v.test -1 map layer=2
+v.test -1 map=$MAP layer=2
# random access on non-topological level with region constraint
-v.test -1r map
+v.test -1r map=$MAP
# random access on topological level
-v.test map
+v.test map=$MAP
# random access on topological level with type constraint
-v.test map type=line
+v.test map=$MAP type=line
# random access on topological level with layer constraint
-v.test map layer=2
+v.test map=$MAP layer=2
# random access on topological level with region constraint
-v.test -r map
+v.test -r map=$MAP
</pre></div>
<h2>AUTHOR</h2>
