[GRASS-SVN] r50633 - grass/branches/develbranch_6/lib/db/dbmi_base
svn_grass at osgeo.org
Thu Feb 2 07:27:44 EST 2012
Author: martinl
Date: 2012-02-02 04:27:44 -0800 (Thu, 02 Feb 2012)
New Revision: 50633
grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c
dbmi_base: skip manifest files when listing drivers - check permission X_OK
(merge r50632 from trunk)
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c 2012-02-02 12:26:35 UTC (rev 50632)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c 2012-02-02 12:27:44 UTC (rev 50633)
@@ -165,19 +165,17 @@
while ((ent = readdir(dir))) {
char *name;
- if ((strcmp(ent->d_name, ".") == 0)
- || (strcmp(ent->d_name, "..") == 0))
+ if ((strcmp(ent->d_name, ".") == 0) ||
+ (strcmp(ent->d_name, "..") == 0))
continue;
#ifdef __MINGW32__
- /* skip manifest files on Windows */
- if (G_strstr(ent->d_name, ".manifest"))
- continue;
+ /* remove '.exe' from name (windows extension) */
+ name = G_str_replace(ent->d_name, ".exe", "");
+#else
+ name = G_store(ent->d_name);
#endif
- /* Remove '.exe' from name (windows extension) */
- name = G_str_replace(ent->d_name, ".exe", "");
#ifdef __MINGW32__
dirpath = G_malloc(strlen("\\driver\\db\\")
+ strlen(G_gisbase()) + strlen(ent->d_name) + 1);
@@ -186,6 +184,9 @@
#else
G_asprintf(&dirpath, "%s/driver/db/%s", G_gisbase(), ent->d_name);
#endif
+ if (access(dirpath, X_OK) != 0)
+ continue;
add_entry(&list, name, dirpath, "");
G_free(name);
G_free(dirpath);
