[GRASS-SVN] r50635 - grass/trunk/lib/db/dbmi_base
svn_grass at osgeo.org
Thu Feb 2 07:50:48 EST 2012
Author: martinl
Date: 2012-02-02 04:50:48 -0800 (Thu, 02 Feb 2012)
New Revision: 50635
grass/trunk/lib/db/dbmi_base/dbmscap.c
revert r50632 which doesn't work on Windows
Modified: grass/trunk/lib/db/dbmi_base/dbmscap.c
--- grass/trunk/lib/db/dbmi_base/dbmscap.c 2012-02-02 12:46:17 UTC (rev 50634)
+++ grass/trunk/lib/db/dbmi_base/dbmscap.c 2012-02-02 12:50:48 UTC (rev 50635)
@@ -178,17 +178,19 @@
while ((ent = readdir(dir))) {
char *name;
- if ((strcmp(ent->d_name, ".") == 0) ||
- (strcmp(ent->d_name, "..") == 0))
+ if ((strcmp(ent->d_name, ".") == 0)
+ || (strcmp(ent->d_name, "..") == 0))
continue;
#ifdef __MINGW32__
- /* remove '.exe' from name (windows extension) */
- name = G_str_replace(ent->d_name, ".exe", "");
-#else
- name = G_store(ent->d_name);
+ /* skip manifest files on Windows */
+ if (G_strstr(ent->d_name, ".manifest"))
+ continue;
#endif
+ /* Remove '.exe' from name (windows extension) */
+ name = G_str_replace(ent->d_name, ".exe", "");
#ifdef __MINGW32__
dirpath = G_malloc(strlen("\\driver\\db\\")
+ strlen(G_gisbase()) + strlen(ent->d_name) + 1);
@@ -197,9 +199,6 @@
#else
G_asprintf(&dirpath, "%s/driver/db/%s", G_gisbase(), ent->d_name);
#endif
- if (access(dirpath, X_OK) != 0)
- continue;
add_entry(&list, name, dirpath, "");
G_free(name);
G_free(dirpath);
