[GRASS-SVN] r50637 - grass/branches/develbranch_6/lib/vector/Vlib
svn_grass at osgeo.org
Thu Feb 2 17:44:41 EST 2012
Author: hamish
Date: 2012-02-02 14:44:40 -0800 (Thu, 02 Feb 2012)
New Revision: 50637
grass/branches/develbranch_6/lib/vector/Vlib/header.c
ignore PROJ parameter in vector head file
Modified: grass/branches/develbranch_6/lib/vector/Vlib/header.c
--- grass/branches/develbranch_6/lib/vector/Vlib/header.c 2012-02-02 14:28:15 UTC (rev 50636)
+++ grass/branches/develbranch_6/lib/vector/Vlib/header.c 2012-02-02 22:44:40 UTC (rev 50637)
@@ -170,6 +170,8 @@
Vect_set_scale(Map, atoi(ptr));
else if (strncmp(buff, "OTHER INFO:", sizeof(char) * 11) == 0)
Vect_set_comment(Map, ptr);
+ else if (strncmp(buff, "PROJ:", sizeof(char) * 5) == 0)
+ G_debug(1, "Projection code for map is %s", ptr);
else if (strncmp(buff, "ZONE:", sizeof(char) * 5) == 0 ||
strncmp(buff, "UTM ZONE:", sizeof(char) * 9) == 0)
Vect_set_zone(Map, atoi(ptr));
