[GRASS-SVN] r50639 -
grass/branches/releasebranch_6_4/scripts/r.in.aster
svn_grass at osgeo.org
Thu Feb 2 22:01:18 EST 2012
Author: hamish
Date: 2012-02-02 19:01:18 -0800 (Thu, 02 Feb 2012)
New Revision: 50639
grass/branches/releasebranch_6_4/scripts/r.in.aster/r.in.aster
complete merge of r50478 from devbr6 (#1552)
catch bad band numbers;
more robust test for XY locations;
test for gdalwarp;
cleanup all temp files.
Modified: grass/branches/releasebranch_6_4/scripts/r.in.aster/r.in.aster
--- grass/branches/releasebranch_6_4/scripts/r.in.aster/r.in.aster 2012-02-02 22:50:20 UTC (rev 50638)
+++ grass/branches/releasebranch_6_4/scripts/r.in.aster/r.in.aster 2012-02-03 03:01:18 UTC (rev 50639)
@@ -50,9 +50,9 @@
#%end
-if [ -z "$GISBASE" ] ; then
+if [ -z "$GISBASE" ] ; then
echo "You must be in GRASS GIS to run this program." >&2
- exit 1
+ exit 1
fi
# save command line
@@ -65,11 +65,24 @@
exec g.parser "$0" "$@"
fi
+#### check if we have gdalwarp
+if [ ! -x "`which gdalwarp`" ] ; then
+ g.message -e "gdalwarp required, please install the GDAL utilities first"
+ exit 1
+fi
+# It's impossible to reproject from an arbitrary XY location
+proj_code=`g.region -p | grep '^projection:' | cut -f2 -d' '`
+if [ "$proj_code" -eq 0 ] ; then
+ g.message -e "This module needs to be run in a projected location"
+ exit 1
+fi
#initialize datasets for L1A and L1B
-if [ "$GIS_OPT_PROCTYPE" = "L1A" ]
-then
- case $GIS_OPT_BAND in
+if [ "$GIS_OPT_PROCTYPE" = "L1A" ] ; then
+ case "$GIS_OPT_BAND" in
1)
dataset="VNIR_Band1:ImageData" ;;
2)
@@ -100,10 +113,14 @@
dataset="TIR_Band13:ImageData" ;;
14)
dataset="TIR_Band14:ImageData" ;;
+ g.message -e "Unsupported band [$GIS_OPT_BAND]"
+ exit 1 ;;
esac
- srcfile="HDF4_EOS:EOS_SWATH:"\"$GIS_OPT_INPUT\"":"$dataset
-elif [ "$GIS_OPT_PROCTYPE" = "L1B" ]
-then
+ srcfile="HDF4_EOS:EOS_SWATH:\"$GIS_OPT_INPUT\":$dataset"
+elif [ "$GIS_OPT_PROCTYPE" = "L1B" ] ; then
1)
dataset="VNIR_Swath:ImageData1" ;;
@@ -135,40 +152,41 @@
dataset="TIR_Swath:ImageData13" ;;
14)
dataset="TIR_Swath:ImageData14" ;;
+ exit 1 ;;
esac
-elif [ "$GIS_OPT_PROCTYPE" = "DEM" ]
-then
- srcfile="$GIS_OPT_INPUT"
+elif [ "$GIS_OPT_PROCTYPE" = "DEM" ] ; then
+ srcfile="$GIS_OPT_INPUT"
fi
-tempfile="`g.tempfile $$`.tif"
+tempfile="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$tempfile" ] ; then
+ g.message -e "Unable to create temporary file"
+ exit 1
+fi
-#run gdalwarp with selected options (must be in $PATH)
-#to translate aster image to geotiff
+# run gdalwarp with selected options (must be in $PATH)
+# to translate aster image to geotiff
g.message "Georeferencing aster image ..."
-proj=`g.proj -jf`
-echo $proj | grep 'XY location' > /dev/null
-if [ $? -eq 0 ] ; then
- g.message -e "This module needs to be run in a projected location (found: $proj)"
- exit 1
-fi
-g.message -d message="gdalwarp -t srs $proj $srcfile $tempfile"
+g.message -d message="gdalwarp -t srs $proj \"$srcfile\" \"$tempfile.tif\""
-gdalwarp -t_srs "`g.proj -jf`" "$srcfile" "$tempfile"
+gdalwarp -t_srs "`g.proj -jf`" "$srcfile" "$tempfile.tif"
#import geotiff to GRASS
g.message "Importing into GRASS ..."
-r.in.gdal input="$tempfile" output="$GIS_OPT_OUTPUT"
+r.in.gdal input="$tempfile.tif" output="$GIS_OPT_OUTPUT"
#cleanup
g.message "Cleaning up ..."
-rm -f "$tempfile"
+rm -f "$tempfile" "$tempfile.tif"
# write cmd history:
-r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
+r.support map="$GIS_OPT_OUTPUT" history="$CMDLINE"
g.message "Done."
