[GRASS-SVN] r50645 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Fri Feb 3 07:00:44 EST 2012
Author: neteler
Date: 2012-02-03 04:00:44 -0800 (Fri, 03 Feb 2012)
New Revision: 50645
grass/trunk/gui/wxpython/xml/menudata.xml
further simplify vector menu structure
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2012-02-03 11:52:01 UTC (rev 50644)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2012-02-03 12:00:44 UTC (rev 50645)
@@ -2449,6 +2449,54 @@
</menuitem>
</items>
</menu>
+ <menu>
+ <label>Update attributes</label>
+ <items>
+ <menuitem>
+ <label>Update area attributes from raster</label>
+ <help>Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns.</help>
+ <keywords>vector,raster,statistics</keywords>
+ <handler>OnMenuCmd</handler>
+ <command>v.rast.stats</command>
+ </menuitem>
+ <menuitem>
+ <label>Update area attributes from vector</label>
+ <help>Count points in areas, calculate statistics from point attributes.</help>
+ <keywords>vector,database,attribute table</keywords>
+ <command>v.vect.stats</command>
+ </menuitem>
+ <menuitem>
+ <label>Update point attributes from areas</label>
+ <help>Uploads vector values at positions of vector points to the table.</help>
+ <command>v.what.vect</command>
+ </menuitem>
+ <menuitem>
+ <label>Update database values from vector</label>
+ <help>Populates database values from vector features.</help>
+ <command>v.to.db</command>
+ </menuitem>
+ <separator />
+ <menuitem>
+ <label>Sample raster maps at point locations</label>
+ <help>Uploads raster values at positions of vector points to the table.</help>
+ <keywords>vector,raster,position,querying,attribute table</keywords>
+ <command>v.what.rast</command>
+ </menuitem>
+ <menuitem>
+ <label>Sample raster neighborhood around points</label>
+ <help>Samples a raster map at vector point locations.</help>
+ <keywords>vector,raster,resample</keywords>
+ <command>v.sample</command>
+ </menuitem>
+ </items>
+ </menu>
<separator />
<menuitem>
<label>Generate area for current region</label>
@@ -2521,68 +2569,20 @@
<command>v.perturb</command>
</menuitem>
- </items>
- </menu>
- <separator />
- <menuitem>
- <label>Remove outliers in point sets</label>
- <help>Removes outliers from vector point data.</help>
- <keywords>vector,statistics</keywords>
- <handler>OnMenuCmd</handler>
- <command>v.outlier</command>
- </menuitem>
- <menuitem>
- <label>Test/training point sets</label>
- <help>Randomly partition points into test/train sets.</help>
- <keywords>vector,statistics,points</keywords>
- <command>v.kcv</command>
- </menuitem>
- <separator />
- <menuitem>
- <label>Update area attributes from raster</label>
- <help>Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns.</help>
- <keywords>vector,raster,statistics</keywords>
- <command>v.rast.stats</command>
- </menuitem>
- <menuitem>
- <label>Update area attributes from vector</label>
- <help>Count points in areas, calculate statistics from point attributes.</help>
- <keywords>vector,database,attribute table</keywords>
- <command>v.vect.stats</command>
- </menuitem>
- <menuitem>
- <label>Update point attributes from areas</label>
- <help>Uploads vector values at positions of vector points to the table.</help>
- <command>v.what.vect</command>
- </menuitem>
- <menuitem>
- <label>Update database values from vector</label>
- <help>Populates database values from vector features.</help>
- <command>v.to.db</command>
- </menuitem>
- <menu>
- <label>Update point attributes from raster</label>
- <items>
+ <separator />
<menuitem>
- <label>Sample raster maps at point locations</label>
- <help>Uploads raster values at positions of vector points to the table.</help>
- <keywords>vector,raster,position,querying,attribute table</keywords>
+ <label>Remove outliers in point sets</label>
+ <help>Removes outliers from vector point data.</help>
+ <keywords>vector,statistics</keywords>
- <command>v.what.rast</command>
+ <command>v.outlier</command>
</menuitem>
<menuitem>
- <label>Sample raster neighborhood around points</label>
- <help>Samples a raster map at vector point locations.</help>
- <keywords>vector,raster,resample</keywords>
+ <label>Test/training point sets</label>
+ <help>Randomly partition points into test/train sets.</help>
+ <keywords>vector,statistics,points</keywords>
- <command>v.sample</command>
+ <command>v.kcv</command>
</menuitem>
</items>
</menu>
