[GRASS-SVN] r50663 - grass/branches/releasebranch_6_4
Sun Feb 5 06:51:18 EST 2012
Author: hamish
Date: 2012-02-05 03:51:17 -0800 (Sun, 05 Feb 2012)
New Revision: 50663
   grass/branches/releasebranch_6_4/configure
   grass/branches/releasebranch_6_4/configure.in
handle case when source tree is not a svn branch (#587, merge from trunk)
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure	2012-02-05 11:40:47 UTC (rev 50662)
+++ grass/branches/releasebranch_6_4/configure	2012-02-05 11:51:17 UTC (rev 50663)
@@ -1326,6 +1326,9 @@
 if test "$SVN_VERSION" != "no" ; then
    GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
+   if test "$GRASS_VERSION_SVN" = "exported" ; then
+      GRASS_VERSION_SVN=
+   fi
 fi
@@ -1350,7 +1353,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1354: checking for MacOSX App" >&5
+echo "configure:1357: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1362,7 +1365,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1366: checking for MacOSX architectures" >&5
+echo "configure:1369: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1391,7 +1394,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1395: checking for MacOSX SDK" >&5
+echo "configure:1398: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1401,7 +1404,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1405: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1408: checking for $with_macosx_sdk/SDKSettings.plist" >&5
 if test "$cross_compiling" = yes; then
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1445,7 +1448,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1449: checking how to build libraries" >&5
+echo "configure:1452: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1488,7 +1491,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1492: checking for $ac_word" >&5
+echo "configure:1495: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1513,7 +1516,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1517: checking how to run the C preprocessor" >&5
+echo "configure:1520: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1526,13 +1529,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
   cat > conftest.$ac_ext <<EOF
-#line 1530 "configure"
+#line 1533 "configure"
 #include "confdefs.h"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1539: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1543,13 +1546,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1547 "configure"
+#line 1550 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1553: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1560,13 +1563,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1564 "configure"
+#line 1567 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1570: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1594,7 +1597,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1598: checking if 64bit support is requested" >&5
+echo "configure:1601: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1614,7 +1617,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1618: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1621: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1638,7 +1641,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1642: checking system version (for dynamic loading)" >&5
+echo "configure:1645: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1664,13 +1667,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1668: checking for dlopen in -ldl" >&5
+echo "configure:1671: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1674 "configure"
+#line 1677 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1681,7 +1684,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1728,7 +1731,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1732: checking for $ac_word" >&5
+echo "configure:1735: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1857,13 +1860,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1861: checking for gettimeofday in -lbsd" >&5
+echo "configure:1864: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1867 "configure"
+#line 1870 "configure"
@@ -1874,7 +1877,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1915,13 +1918,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1919: checking for inet_ntoa in -lbind" >&5
+echo "configure:1922: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1925 "configure"
+#line 1928 "configure"
@@ -1932,7 +1935,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1993,13 +1996,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1997: checking for shl_load in -ldld" >&5
+echo "configure:2000: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 2003 "configure"
+#line 2006 "configure"
@@ -2010,7 +2013,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2075,13 +2078,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:2079: checking for shl_load in -ldld" >&5
+echo "configure:2082: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 2085 "configure"
+#line 2088 "configure"
@@ -2092,7 +2095,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2214,15 +2217,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2218: checking for dld.h" >&5
+echo "configure:2221: checking for dld.h" >&5
-#line 2221 "configure"
+#line 2224 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2226: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2282,15 +2285,15 @@
 	    else
-echo "configure:2286: checking for dld.h" >&5
+echo "configure:2289: checking for dld.h" >&5
-#line 2289 "configure"
+#line 2292 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2387,9 +2390,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2391: checking for ELF" >&5
+echo "configure:2394: checking for ELF" >&5
-#line 2393 "configure"
+#line 2396 "configure"
 #ifdef __ELF__
@@ -2419,15 +2422,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2423: checking for dlfcn.h" >&5
+echo "configure:2426: checking for dlfcn.h" >&5
-#line 2426 "configure"
+#line 2429 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2451,9 +2454,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2455: checking for ELF" >&5
+echo "configure:2458: checking for ELF" >&5
-#line 2457 "configure"
+#line 2460 "configure"
 #ifdef __ELF__
@@ -2777,17 +2780,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2781: checking for ld accepts -Bexport flag" >&5
+echo "configure:2784: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2784 "configure"
+#line 2787 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3612,7 +3615,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3616: checking for additional include dirs" >&5
+echo "configure:3619: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3635,7 +3638,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3639: checking for additional library dirs" >&5
+echo "configure:3642: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3669,7 +3672,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3673: checking for a BSD compatible install" >&5
+echo "configure:3676: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3722,7 +3725,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3726: checking for $ac_word" >&5
+echo "configure:3729: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3753,13 +3756,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3757: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3760: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3763 "configure"
+#line 3766 "configure"
@@ -3770,7 +3773,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3795,7 +3798,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3799: checking for $ac_word" >&5
+echo "configure:3802: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3835,7 +3838,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3839: checking for $ac_word" >&5
+echo "configure:3842: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3866,7 +3869,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3870: checking for $ac_word" >&5
+echo "configure:3873: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3904,7 +3907,7 @@
-echo "configure:3908: checking for $ac_word" >&5
+echo "configure:3911: checking for $ac_word" >&5
@@ -3933,7 +3936,7 @@
-echo "configure:3937: checking for $ac_word" >&5
+echo "configure:3940: checking for $ac_word" >&5
@@ -3964,7 +3967,7 @@
-echo "configure:3968: checking for $ac_word" >&5
+echo "configure:3971: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3993,7 +3996,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3997: checking for $ac_word" >&5
+echo "configure:4000: checking for $ac_word" >&5
 case "$PERL" in
@@ -4024,10 +4027,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:4028: checking for ANSI C header files" >&5
+echo "configure:4031: checking for ANSI C header files" >&5
-#line 4031 "configure"
+#line 4034 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -4035,7 +4038,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:4039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4052,7 +4055,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4056 "configure"
+#line 4059 "configure"
 #include <string.h>
 EOF
@@ -4070,7 +4073,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4074 "configure"
+#line 4077 "configure"
 #include <stdlib.h>
 EOF
@@ -4091,7 +4094,7 @@
 else
-#line 4095 "configure"
+#line 4098 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4102,7 +4105,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:4106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -4129,15 +4132,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4133: checking for $ac_hdr" >&5
+echo "configure:4136: checking for $ac_hdr" >&5
-#line 4136 "configure"
+#line 4139 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4144: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4166,15 +4169,15 @@
 do
-echo "configure:4170: checking for $ac_hdr" >&5
+echo "configure:4173: checking for $ac_hdr" >&5
-#line 4173 "configure"
+#line 4176 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4203,15 +4206,15 @@
 do
-echo "configure:4207: checking for $ac_hdr" >&5
+echo "configure:4210: checking for $ac_hdr" >&5
-#line 4210 "configure"
+#line 4213 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4240,15 +4243,15 @@
 do
-echo "configure:4244: checking for $ac_hdr" >&5
+echo "configure:4247: checking for $ac_hdr" >&5
-#line 4247 "configure"
+#line 4250 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4277,15 +4280,15 @@
 do
-echo "configure:4281: checking for $ac_hdr" >&5
+echo "configure:4284: checking for $ac_hdr" >&5
-#line 4284 "configure"
+#line 4287 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4292: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4311,10 +4314,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4315: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4318: checking whether time.h and sys/time.h may both be included" >&5
-#line 4318 "configure"
+#line 4321 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4323,7 +4326,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4327: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4343,10 +4346,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4347: checking for off_t" >&5
+echo "configure:4350: checking for off_t" >&5
-#line 4350 "configure"
+#line 4353 "configure"
 #if STDC_HEADERS
@@ -4373,10 +4376,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4377: checking for uid_t in sys/types.h" >&5
+echo "configure:4380: checking for uid_t in sys/types.h" >&5
-#line 4380 "configure"
+#line 4383 "configure"
 EOF
@@ -4404,10 +4407,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4408: checking return type of signal handlers" >&5
+echo "configure:4411: checking return type of signal handlers" >&5
-#line 4411 "configure"
+#line 4414 "configure"
 #include <signal.h>
@@ -4424,7 +4427,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4428: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4442,10 +4445,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4446: checking for Cygwin environment" >&5
+echo "configure:4449: checking for Cygwin environment" >&5
-#line 4449 "configure"
+#line 4452 "configure"
 int main() {
@@ -4456,7 +4459,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4460: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4463: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4474,10 +4477,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4478: checking for $ac_func" >&5
+echo "configure:4481: checking for $ac_func" >&5
-#line 4481 "configure"
+#line 4484 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4500,7 +4503,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4526,10 +4529,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4530: checking for $ac_func" >&5
+echo "configure:4533: checking for $ac_func" >&5
-#line 4533 "configure"
+#line 4536 "configure"
@@ -4552,7 +4555,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4578,10 +4581,10 @@
 for ac_func in drand48
 do
-echo "configure:4582: checking for $ac_func" >&5
+echo "configure:4585: checking for $ac_func" >&5
-#line 4585 "configure"
+#line 4588 "configure"
@@ -4604,7 +4607,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4630,10 +4633,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4634: checking for $ac_func" >&5
+echo "configure:4637: checking for $ac_func" >&5
-#line 4637 "configure"
+#line 4640 "configure"
@@ -4656,7 +4659,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4682,10 +4685,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4686: checking for $ac_func" >&5
+echo "configure:4689: checking for $ac_func" >&5
-#line 4689 "configure"
+#line 4692 "configure"
@@ -4708,7 +4711,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4733,13 +4736,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4737: checking whether setpgrp takes no argument" >&5
+echo "configure:4740: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4743 "configure"
+#line 4746 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4759,7 +4762,7 @@
 EOF
-if { (eval echo configure:4763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4787,16 +4790,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4791: checking for long long int" >&5
+echo "configure:4794: checking for long long int" >&5
-#line 4793 "configure"
+#line 4796 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4800: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 echo "$ac_t""yes" 1>&6
@@ -4816,7 +4819,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4820: checking for W11" >&5
+echo "configure:4823: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4844,7 +4847,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4848: checking for X" >&5
+echo "configure:4851: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4904,12 +4907,12 @@
   # First, try using that file with no special directory specified.
-#line 4908 "configure"
+#line 4911 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4913: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4978,14 +4981,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4982 "configure"
+#line 4985 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -5090,17 +5093,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5094: checking whether -R must be followed by a space" >&5
+echo "configure:5097: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5097 "configure"
+#line 5100 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -5116,14 +5119,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5120 "configure"
+#line 5123 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5155,13 +5158,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5159: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5162: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5165 "configure"
+#line 5168 "configure"
@@ -5172,7 +5175,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5193,13 +5196,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5197: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5200: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5203 "configure"
+#line 5206 "configure"
@@ -5210,7 +5213,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5238,10 +5241,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5242: checking for gethostbyname" >&5
+echo "configure:5245: checking for gethostbyname" >&5
-#line 5245 "configure"
+#line 5248 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5264,7 +5267,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5284,13 +5287,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5288: checking for gethostbyname in -lnsl" >&5
+echo "configure:5291: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5294 "configure"
+#line 5297 "configure"
@@ -5301,7 +5304,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5330,10 +5333,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5334: checking for connect" >&5
+echo "configure:5337: checking for connect" >&5
-#line 5337 "configure"
+#line 5340 "configure"
     which can conflict with char connect(); below.  */
@@ -5356,7 +5359,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5376,13 +5379,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5380: checking for connect in -lsocket" >&5
+echo "configure:5383: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5386 "configure"
+#line 5389 "configure"
@@ -5393,7 +5396,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5416,10 +5419,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5420: checking for remove" >&5
+echo "configure:5423: checking for remove" >&5
-#line 5423 "configure"
+#line 5426 "configure"
     which can conflict with char remove(); below.  */
@@ -5442,7 +5445,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5462,13 +5465,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5466: checking for remove in -lposix" >&5
+echo "configure:5469: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5472 "configure"
+#line 5475 "configure"
@@ -5479,7 +5482,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5502,10 +5505,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5506: checking for shmat" >&5
+echo "configure:5509: checking for shmat" >&5
-#line 5509 "configure"
+#line 5512 "configure"
     which can conflict with char shmat(); below.  */
@@ -5528,7 +5531,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5548,13 +5551,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5552: checking for shmat in -lipc" >&5
+echo "configure:5555: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5558 "configure"
+#line 5561 "configure"
@@ -5565,7 +5568,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5597,13 +5600,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5601: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5604: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5607 "configure"
+#line 5610 "configure"
@@ -5614,7 +5617,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5652,7 +5655,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5656: checking whether to use Curses" >&5
+echo "configure:5659: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5671,15 +5674,15 @@
 do
-echo "configure:5675: checking for $ac_hdr" >&5
+echo "configure:5678: checking for $ac_hdr" >&5
-#line 5678 "configure"
+#line 5681 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5683: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5710,10 +5713,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5714: checking curses.h WINDOW structure component" >&5
+echo "configure:5717: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5717 "configure"
+#line 5720 "configure"
 #include <curses.h>
@@ -5722,7 +5725,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5726: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5729: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5731,7 +5734,7 @@
 fi
 rm -f conftest*
-#line 5735 "configure"
+#line 5738 "configure"
 #include <curses.h>
@@ -5740,7 +5743,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5744: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5747: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5756,13 +5759,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5760: checking for initscr in -lncurses" >&5
+echo "configure:5763: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5766 "configure"
+#line 5769 "configure"
@@ -5773,7 +5776,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5792,13 +5795,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5796: checking for initscr in -lcurses" >&5
+echo "configure:5799: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5802 "configure"
+#line 5805 "configure"
@@ -5809,7 +5812,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5838,13 +5841,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5842: checking for keypad in -lncurses" >&5
+echo "configure:5845: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5848 "configure"
+#line 5851 "configure"
@@ -5855,7 +5858,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5877,13 +5880,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5881: checking for keypad in -lcurses" >&5
+echo "configure:5884: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5887 "configure"
+#line 5890 "configure"
@@ -5894,7 +5897,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5924,13 +5927,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5928: checking for gtty in -lcompat" >&5
+echo "configure:5931: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5934 "configure"
+#line 5937 "configure"
@@ -5941,7 +5944,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5960,13 +5963,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5964: checking for gtty in -lbsd-compat" >&5
+echo "configure:5967: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5970 "configure"
+#line 5973 "configure"
@@ -5977,7 +5980,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5996,13 +5999,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:6000: checking for gtty in -lbsd" >&5
+echo "configure:6003: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 6006 "configure"
+#line 6009 "configure"
@@ -6013,7 +6016,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:6017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6047,12 +6050,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6051: checking for library containing cuserid" >&5
+echo "configure:6054: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 6056 "configure"
+#line 6059 "configure"
@@ -6063,7 +6066,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -6074,7 +6077,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 6078 "configure"
+#line 6081 "configure"
@@ -6085,7 +6088,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -6111,10 +6114,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6115: checking for xdrmem_create" >&5
+echo "configure:6118: checking for xdrmem_create" >&5
-#line 6118 "configure"
+#line 6121 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -6137,7 +6140,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -6155,13 +6158,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6159: checking for xdrmem_create in -lsun" >&5
+echo "configure:6162: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 6165 "configure"
+#line 6168 "configure"
@@ -6172,7 +6175,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6191,13 +6194,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6195: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6198: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 6201 "configure"
+#line 6204 "configure"
@@ -6208,7 +6211,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6227,13 +6230,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6231: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6234: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6237 "configure"
+#line 6240 "configure"
@@ -6244,7 +6247,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6263,13 +6266,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6267: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6270: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6273 "configure"
+#line 6276 "configure"
@@ -6280,7 +6283,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6314,10 +6317,10 @@
 for ac_func in asprintf
 do
-echo "configure:6318: checking for $ac_func" >&5
+echo "configure:6321: checking for $ac_func" >&5
-#line 6321 "configure"
+#line 6324 "configure"
@@ -6340,7 +6343,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6367,10 +6370,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6371: checking for atan" >&5
+echo "configure:6374: checking for atan" >&5
-#line 6374 "configure"
+#line 6377 "configure"
     which can conflict with char atan(); below.  */
@@ -6393,7 +6396,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6411,13 +6414,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6415: checking for atan in -lm" >&5
+echo "configure:6418: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6421 "configure"
+#line 6424 "configure"
@@ -6428,7 +6431,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6455,10 +6458,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6459: checking for dlsym" >&5
+echo "configure:6462: checking for dlsym" >&5
-#line 6462 "configure"
+#line 6465 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6481,7 +6484,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6499,13 +6502,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6503: checking for dlsym in -ldl" >&5
+echo "configure:6506: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6509 "configure"
+#line 6512 "configure"
@@ -6516,7 +6519,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6543,10 +6546,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6547: checking for iconv" >&5
+echo "configure:6550: checking for iconv" >&5
-#line 6550 "configure"
+#line 6553 "configure"
     which can conflict with char iconv(); below.  */
@@ -6569,7 +6572,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6587,13 +6590,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6591: checking for iconv in -liconv" >&5
+echo "configure:6594: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6597 "configure"
+#line 6600 "configure"
@@ -6604,7 +6607,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6623,13 +6626,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6627: checking for iconv in -lgiconv" >&5
+echo "configure:6630: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6633 "configure"
+#line 6636 "configure"
@@ -6640,7 +6643,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6659,10 +6662,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6663: checking for libiconv" >&5
+echo "configure:6666: checking for libiconv" >&5
-#line 6666 "configure"
+#line 6669 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6685,7 +6688,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6703,13 +6706,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6707: checking for libiconv in -liconv" >&5
+echo "configure:6710: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6713 "configure"
+#line 6716 "configure"
@@ -6720,7 +6723,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6739,13 +6742,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6743: checking for libiconv in -lgiconv" >&5
+echo "configure:6746: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6749 "configure"
+#line 6752 "configure"
@@ -6756,7 +6759,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6793,10 +6796,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6797: checking for socket" >&5
+echo "configure:6800: checking for socket" >&5
-#line 6800 "configure"
+#line 6803 "configure"
     which can conflict with char socket(); below.  */
@@ -6819,7 +6822,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6837,13 +6840,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6841: checking for socket in -lsocket" >&5
+echo "configure:6844: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6847 "configure"
+#line 6850 "configure"
@@ -6854,7 +6857,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6902,7 +6905,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6906: checking for location of zlib includes" >&5
+echo "configure:6909: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6928,15 +6931,15 @@
 do
-echo "configure:6932: checking for $ac_hdr" >&5
+echo "configure:6935: checking for $ac_hdr" >&5
-#line 6935 "configure"
+#line 6938 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6943: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6970,7 +6973,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6974: checking for location of zlib library" >&5
+echo "configure:6977: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6995,13 +6998,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6999: checking for deflate in -lz" >&5
+echo "configure:7002: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 7005 "configure"
+#line 7008 "configure"
@@ -7012,7 +7015,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:7016: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7060,7 +7063,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7064: checking for location of External PROJ.4 includes" >&5
+echo "configure:7067: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7086,15 +7089,15 @@
 do
-echo "configure:7090: checking for $ac_hdr" >&5
+echo "configure:7093: checking for $ac_hdr" >&5
-#line 7093 "configure"
+#line 7096 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7131,7 +7134,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7135: checking External PROJ.4 version" >&5
+echo "configure:7138: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7139,7 +7142,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 7143 "configure"
+#line 7146 "configure"
 #include <stdio.h>
@@ -7151,7 +7154,7 @@
 EOF
-if { (eval echo configure:7155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -7176,7 +7179,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7180: checking for location of External PROJ.4 library" >&5
+echo "configure:7183: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7201,13 +7204,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7205: checking for pj_get_def in -lproj" >&5
+echo "configure:7208: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 7211 "configure"
+#line 7214 "configure"
@@ -7218,7 +7221,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7252,7 +7255,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7256: checking for location of External PROJ.4 data files" >&5
+echo "configure:7259: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7276,14 +7279,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7280: checking for epsg" >&5
+echo "configure:7283: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7287: checking for $PROJSHARE/epsg" >&5
+echo "configure:7290: checking for $PROJSHARE/epsg" >&5
@@ -7315,7 +7318,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:7319: checking for $ac_word" >&5
+echo "configure:7322: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7355,7 +7358,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7359: checking whether to use regex" >&5
+echo "configure:7362: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -7375,7 +7378,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7379: checking for location of regex includes" >&5
+echo "configure:7382: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7401,15 +7404,15 @@
 do
-echo "configure:7405: checking for $ac_hdr" >&5
+echo "configure:7408: checking for $ac_hdr" >&5
-#line 7408 "configure"
+#line 7411 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7416: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7443,7 +7446,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7447: checking for location of regex library" >&5
+echo "configure:7450: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7468,10 +7471,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7472: checking for regcomp" >&5
+echo "configure:7475: checking for regcomp" >&5
-#line 7475 "configure"
+#line 7478 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7494,7 +7497,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7521,13 +7524,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7525: checking for regcomp in -lregex" >&5
+echo "configure:7528: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7531 "configure"
+#line 7534 "configure"
@@ -7538,7 +7541,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7588,7 +7591,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7592: checking whether to use Readline" >&5
+echo "configure:7595: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7609,7 +7612,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7613: checking for location of Readline includes" >&5
+echo "configure:7616: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7635,15 +7638,15 @@
 do
-echo "configure:7639: checking for $ac_hdr" >&5
+echo "configure:7642: checking for $ac_hdr" >&5
-#line 7642 "configure"
+#line 7645 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7647: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7650: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7679,15 +7682,15 @@
 do
-echo "configure:7683: checking for $ac_hdr" >&5
+echo "configure:7686: checking for $ac_hdr" >&5
-#line 7686 "configure"
+#line 7689 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7691: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7721,7 +7724,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7725: checking for location of Readline library" >&5
+echo "configure:7728: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7746,13 +7749,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7750: checking for readline in -lreadline" >&5
+echo "configure:7753: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7756 "configure"
+#line 7759 "configure"
 #include "confdefs.h"
@@ -7763,7 +7766,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7798,13 +7801,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7802: checking for add_history in -lhistory" >&5
+echo "configure:7805: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7808 "configure"
+#line 7811 "configure"
@@ -7815,7 +7818,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7858,7 +7861,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7862: checking whether to use JPEG" >&5
+echo "configure:7865: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7878,7 +7881,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7882: checking for location of JPEG includes" >&5
+echo "configure:7885: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7904,15 +7907,15 @@
 do
-echo "configure:7908: checking for $ac_hdr" >&5
+echo "configure:7911: checking for $ac_hdr" >&5
-#line 7911 "configure"
+#line 7914 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7946,7 +7949,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7950: checking for location of JPEG library" >&5
+echo "configure:7953: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7973,13 +7976,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7977: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7980: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ljpeg  $LIBS"
-#line 7983 "configure"
+#line 7986 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7990,7 +7993,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -8009,13 +8012,13 @@
-echo "configure:8013: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:8016: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 8019 "configure"
+#line 8022 "configure"
@@ -8026,7 +8029,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8075,7 +8078,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:8079: checking whether to use GDAL" >&5
+echo "configure:8082: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -8093,7 +8096,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8097: checking for $ac_word" >&5
+echo "configure:8100: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -8148,14 +8151,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 8152 "configure"
+#line 8155 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:8159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -8164,14 +8167,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 8168 "configure"
+#line 8171 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:8175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -8203,7 +8206,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:8207: checking whether to use GEOS" >&5
+echo "configure:8210: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -8221,7 +8224,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:8225: checking for $ac_word" >&5
+echo "configure:8228: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -8269,15 +8272,15 @@
 do
-echo "configure:8273: checking for $ac_hdr" >&5
+echo "configure:8276: checking for $ac_hdr" >&5
-#line 8276 "configure"
+#line 8279 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8313,13 +8316,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:8317: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:8320: checking for initGEOS in -lgeos_c_i" >&5
 ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c_i  $LIBS"
-#line 8323 "configure"
+#line 8326 "configure"
@@ -8330,7 +8333,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8366,13 +8369,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8370: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8373: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 8376 "configure"
+#line 8379 "configure"
@@ -8383,7 +8386,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8428,7 +8431,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8432: checking whether to use TIFF" >&5
+echo "configure:8435: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8448,7 +8451,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8452: checking for location of TIFF includes" >&5
+echo "configure:8455: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8474,15 +8477,15 @@
 do
-echo "configure:8478: checking for $ac_hdr" >&5
+echo "configure:8481: checking for $ac_hdr" >&5
-#line 8481 "configure"
+#line 8484 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8516,7 +8519,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8520: checking for location of TIFF library" >&5
+echo "configure:8523: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8547,13 +8550,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8551: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8554: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8557 "configure"
+#line 8560 "configure"
@@ -8564,7 +8567,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8583,13 +8586,13 @@
-echo "configure:8587: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8590: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8593 "configure"
+#line 8596 "configure"
@@ -8600,7 +8603,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8619,13 +8622,13 @@
-echo "configure:8623: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8626: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8629 "configure"
+#line 8632 "configure"
@@ -8636,7 +8639,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8655,13 +8658,13 @@
-echo "configure:8659: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8662: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8665 "configure"
+#line 8668 "configure"
@@ -8672,7 +8675,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8691,13 +8694,13 @@
-echo "configure:8695: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8698: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8701 "configure"
+#line 8704 "configure"
@@ -8708,7 +8711,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8727,13 +8730,13 @@
-echo "configure:8731: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8734: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8737 "configure"
+#line 8740 "configure"
@@ -8744,7 +8747,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8763,13 +8766,13 @@
-echo "configure:8767: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8770: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8773 "configure"
+#line 8776 "configure"
@@ -8780,7 +8783,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8799,13 +8802,13 @@
-echo "configure:8803: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8806: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8809 "configure"
+#line 8812 "configure"
@@ -8816,7 +8819,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8914,7 +8917,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8918: checking whether to use PNG" >&5
+echo "configure:8921: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8933,7 +8936,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8937: checking for location of PNG includes" >&5
+echo "configure:8940: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8959,15 +8962,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8963: checking for $ac_hdr" >&5
+echo "configure:8966: checking for $ac_hdr" >&5
-#line 8966 "configure"
+#line 8969 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9001,7 +9004,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:9005: checking for location of PNG library" >&5
+echo "configure:9008: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -9026,13 +9029,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:9030: checking for png_read_image in -lpng" >&5
+echo "configure:9033: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 9036 "configure"
+#line 9039 "configure"
@@ -9043,7 +9046,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:9047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9085,7 +9088,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9089: checking whether to use PostgreSQL" >&5
+echo "configure:9092: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9112,7 +9115,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9116: checking for location of PostgreSQL includes" >&5
+echo "configure:9119: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9138,15 +9141,15 @@
 do
-echo "configure:9142: checking for $ac_hdr" >&5
+echo "configure:9145: checking for $ac_hdr" >&5
-#line 9145 "configure"
+#line 9148 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9153: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9184,7 +9187,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9188: checking for location of PostgreSQL library" >&5
+echo "configure:9191: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9213,13 +9216,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9217: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9220: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9223 "configure"
+#line 9226 "configure"
@@ -9230,7 +9233,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9249,13 +9252,13 @@
-echo "configure:9253: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9256: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9259 "configure"
+#line 9262 "configure"
@@ -9266,7 +9269,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9285,13 +9288,13 @@
-echo "configure:9289: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9292: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9295 "configure"
+#line 9298 "configure"
@@ -9302,7 +9305,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9321,13 +9324,13 @@
-echo "configure:9325: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9328: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9331 "configure"
+#line 9334 "configure"
@@ -9338,7 +9341,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9395,13 +9398,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9399: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9402: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9405 "configure"
+#line 9408 "configure"
@@ -9412,7 +9415,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9434,13 +9437,13 @@
-echo "configure:9438: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9441: checking for PQcmdTuples in -lpq" >&5
-#line 9444 "configure"
+#line 9447 "configure"
@@ -9451,7 +9454,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9494,7 +9497,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9498: checking whether to use MySQL" >&5
+echo "configure:9501: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9514,7 +9517,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9518: checking for location of MySQL includes" >&5
+echo "configure:9521: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9540,15 +9543,15 @@
 do
-echo "configure:9544: checking for $ac_hdr" >&5
+echo "configure:9547: checking for $ac_hdr" >&5
-#line 9547 "configure"
+#line 9550 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9552: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9555: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9585,7 +9588,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9589: checking for location of MySQL library" >&5
+echo "configure:9592: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9616,13 +9619,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9620: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9623: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9626 "configure"
+#line 9629 "configure"
@@ -9633,7 +9636,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9652,13 +9655,13 @@
-echo "configure:9656: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9659: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9662 "configure"
+#line 9665 "configure"
@@ -9669,7 +9672,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9688,13 +9691,13 @@
-echo "configure:9692: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9695: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9698 "configure"
+#line 9701 "configure"
@@ -9705,7 +9708,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9724,13 +9727,13 @@
-echo "configure:9728: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9731: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9734 "configure"
+#line 9737 "configure"
@@ -9741,7 +9744,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9760,13 +9763,13 @@
-echo "configure:9764: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9767: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9770 "configure"
+#line 9773 "configure"
@@ -9777,7 +9780,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9796,13 +9799,13 @@
-echo "configure:9800: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9803: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9806 "configure"
+#line 9809 "configure"
@@ -9813,7 +9816,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9832,13 +9835,13 @@
-echo "configure:9836: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9839: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9842 "configure"
+#line 9845 "configure"
@@ -9849,7 +9852,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9868,13 +9871,13 @@
-echo "configure:9872: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9875: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9878 "configure"
+#line 9881 "configure"
@@ -9885,7 +9888,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9975,7 +9978,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9979: checking for $ac_word" >&5
+echo "configure:9982: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10016,10 +10019,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10020: checking for mysql_server_init" >&5
+echo "configure:10023: checking for mysql_server_init" >&5
-#line 10023 "configure"
+#line 10026 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10042,7 +10045,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10080,7 +10083,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10084: checking whether to use SQLite" >&5
+echo "configure:10087: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10100,7 +10103,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10104: checking for location of SQLite includes" >&5
+echo "configure:10107: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10126,15 +10129,15 @@
 do
-echo "configure:10130: checking for $ac_hdr" >&5
+echo "configure:10133: checking for $ac_hdr" >&5
-#line 10133 "configure"
+#line 10136 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10138: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10177,7 +10180,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10181: checking for location of SQLite library" >&5
+echo "configure:10184: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10206,13 +10209,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10210: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10213: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10216 "configure"
+#line 10219 "configure"
@@ -10223,7 +10226,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10242,13 +10245,13 @@
-echo "configure:10246: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10249: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 10252 "configure"
+#line 10255 "configure"
@@ -10259,7 +10262,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10278,13 +10281,13 @@
-echo "configure:10282: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10285: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10288 "configure"
+#line 10291 "configure"
@@ -10295,7 +10298,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10314,13 +10317,13 @@
-echo "configure:10318: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10321: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10324 "configure"
+#line 10327 "configure"
@@ -10331,7 +10334,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10400,7 +10403,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10404: checking whether to use FFMPEG" >&5
+echo "configure:10407: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10420,7 +10423,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10424: checking for location of FFMPEG includes" >&5
+echo "configure:10427: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10446,15 +10449,15 @@
 do
-echo "configure:10450: checking for $ac_hdr" >&5
+echo "configure:10453: checking for $ac_hdr" >&5
-#line 10453 "configure"
+#line 10456 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10461: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10490,15 +10493,15 @@
 do
-echo "configure:10494: checking for $ac_hdr" >&5
+echo "configure:10497: checking for $ac_hdr" >&5
-#line 10497 "configure"
+#line 10500 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10534,15 +10537,15 @@
 do
-echo "configure:10538: checking for $ac_hdr" >&5
+echo "configure:10541: checking for $ac_hdr" >&5
-#line 10541 "configure"
+#line 10544 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10546: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10585,7 +10588,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10589: checking for location of FFMPEG library" >&5
+echo "configure:10592: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10612,13 +10615,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10616: checking for av_free in -lavutil" >&5
+echo "configure:10619: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10622 "configure"
+#line 10625 "configure"
@@ -10629,7 +10632,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10648,13 +10651,13 @@
-echo "configure:10652: checking for av_free in -lavutil" >&5
+echo "configure:10655: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10658 "configure"
+#line 10661 "configure"
@@ -10665,7 +10668,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10710,13 +10713,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10714: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10717: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10720 "configure"
+#line 10723 "configure"
@@ -10727,7 +10730,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10746,13 +10749,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10750: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10753: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10756 "configure"
+#line 10759 "configure"
@@ -10763,7 +10766,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10808,13 +10811,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10812: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10815: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10818 "configure"
+#line 10821 "configure"
@@ -10825,7 +10828,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10844,13 +10847,13 @@
-echo "configure:10848: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10851: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10854 "configure"
+#line 10857 "configure"
@@ -10861,7 +10864,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10920,7 +10923,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10924: checking whether to use OpenGL" >&5
+echo "configure:10927: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10954,7 +10957,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10958: checking for location of OpenGL includes" >&5
+echo "configure:10961: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10980,15 +10983,15 @@
 do
-echo "configure:10984: checking for $ac_hdr" >&5
+echo "configure:10987: checking for $ac_hdr" >&5
-#line 10987 "configure"
+#line 10990 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10992: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10995: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11022,7 +11025,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11026: checking for location of OpenGL library" >&5
+echo "configure:11029: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11051,13 +11054,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11055: checking for glBegin in -lGL" >&5
+echo "configure:11058: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11061 "configure"
+#line 11064 "configure"
@@ -11068,7 +11071,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11087,13 +11090,13 @@
-echo "configure:11091: checking for glBegin in -lGL" >&5
+echo "configure:11094: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11097 "configure"
+#line 11100 "configure"
@@ -11104,7 +11107,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11123,13 +11126,13 @@
-echo "configure:11127: checking for glBegin in -lGL" >&5
+echo "configure:11130: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11133 "configure"
+#line 11136 "configure"
@@ -11140,7 +11143,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11159,13 +11162,13 @@
-echo "configure:11163: checking for glBegin in -lGL" >&5
+echo "configure:11166: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11169 "configure"
+#line 11172 "configure"
@@ -11176,7 +11179,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11238,13 +11241,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11242: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11245: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11248 "configure"
+#line 11251 "configure"
@@ -11255,7 +11258,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11274,13 +11277,13 @@
-echo "configure:11278: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11281: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11284 "configure"
+#line 11287 "configure"
@@ -11291,7 +11294,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11335,10 +11338,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11339: checking for glXCreatePbuffer" >&5
+echo "configure:11342: checking for glXCreatePbuffer" >&5
-#line 11342 "configure"
+#line 11345 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11361,7 +11364,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11383,10 +11386,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11387: checking for glXCreateGLXPixmap" >&5
+echo "configure:11390: checking for glXCreateGLXPixmap" >&5
-#line 11390 "configure"
+#line 11393 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11409,7 +11412,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11448,7 +11451,7 @@
-echo "configure:11452: checking for location of OpenGL includes" >&5
+echo "configure:11455: checking for location of OpenGL includes" >&5
@@ -11474,15 +11477,15 @@
 do
-echo "configure:11478: checking for $ac_hdr" >&5
+echo "configure:11481: checking for $ac_hdr" >&5
-#line 11481 "configure"
+#line 11484 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11517,10 +11520,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11521: checking for glBegin" >&5
+echo "configure:11524: checking for glBegin" >&5
-#line 11524 "configure"
+#line 11527 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11543,7 +11546,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11558,10 +11561,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11562: checking for gluBeginCurve" >&5
+echo "configure:11565: checking for gluBeginCurve" >&5
-#line 11565 "configure"
+#line 11568 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11584,7 +11587,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11628,7 +11631,7 @@
-echo "configure:11632: checking for location of OpenGL includes" >&5
+echo "configure:11635: checking for location of OpenGL includes" >&5
@@ -11654,15 +11657,15 @@
 do
-echo "configure:11658: checking for $ac_hdr" >&5
+echo "configure:11661: checking for $ac_hdr" >&5
-#line 11661 "configure"
+#line 11664 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11696,7 +11699,7 @@
-echo "configure:11700: checking for location of OpenGL library" >&5
+echo "configure:11703: checking for location of OpenGL library" >&5
@@ -11721,18 +11724,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11725: checking for OpenGL library" >&5
+echo "configure:11728: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11729 "configure"
+#line 11732 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11756,18 +11759,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11760: checking for GLU library" >&5
+echo "configure:11763: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11764 "configure"
+#line 11767 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11816,7 +11819,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11820: checking whether to use Tcl/Tk" >&5
+echo "configure:11823: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11836,7 +11839,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11840: checking for location of Tcl/Tk includes" >&5
+echo "configure:11843: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11862,15 +11865,15 @@
 do
-echo "configure:11866: checking for $ac_hdr" >&5
+echo "configure:11869: checking for $ac_hdr" >&5
-#line 11869 "configure"
+#line 11872 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11877: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11907,15 +11910,15 @@
 do
-echo "configure:11911: checking for $ac_hdr" >&5
+echo "configure:11914: checking for $ac_hdr" >&5
-#line 11914 "configure"
+#line 11917 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11922: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11948,7 +11951,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11952: checking Tcl version" >&5
+echo "configure:11955: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11956,7 +11959,7 @@
 else
-#line 11960 "configure"
+#line 11963 "configure"
 #include <stdio.h>
@@ -11968,7 +11971,7 @@
 EOF
-if { (eval echo configure:11972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11986,7 +11989,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11990: checking Tk version" >&5
+echo "configure:11993: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11994,7 +11997,7 @@
 else
-#line 11998 "configure"
+#line 12001 "configure"
 #include <stdio.h>
@@ -12006,7 +12009,7 @@
 EOF
-if { (eval echo configure:12010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:12013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -12037,7 +12040,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:12041: checking for location of Tcl/Tk library" >&5
+echo "configure:12044: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -12077,13 +12080,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:12081: checking for Tcl_Init in -ltcl" >&5
+echo "configure:12084: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 12087 "configure"
+#line 12090 "configure"
@@ -12094,7 +12097,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12113,13 +12116,13 @@
-echo "configure:12117: checking for Tcl_Init in -ltcl" >&5
+echo "configure:12120: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 12123 "configure"
+#line 12126 "configure"
@@ -12130,7 +12133,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12157,13 +12160,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12161: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12164: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 12167 "configure"
+#line 12170 "configure"
@@ -12174,7 +12177,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12193,13 +12196,13 @@
-echo "configure:12197: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12200: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12203 "configure"
+#line 12206 "configure"
@@ -12210,7 +12213,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12237,13 +12240,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12241: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12244: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12247 "configure"
+#line 12250 "configure"
@@ -12254,7 +12257,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12273,13 +12276,13 @@
-echo "configure:12277: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12280: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12283 "configure"
+#line 12286 "configure"
@@ -12290,7 +12293,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12368,13 +12371,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12372: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12375: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12378 "configure"
+#line 12381 "configure"
@@ -12385,7 +12388,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12404,13 +12407,13 @@
-echo "configure:12408: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12411: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12414 "configure"
+#line 12417 "configure"
@@ -12421,7 +12424,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12448,13 +12451,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12452: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12455: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12458 "configure"
+#line 12461 "configure"
@@ -12465,7 +12468,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12484,13 +12487,13 @@
-echo "configure:12488: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12491: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12494 "configure"
+#line 12497 "configure"
@@ -12501,7 +12504,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12528,13 +12531,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12532: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12535: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12538 "configure"
+#line 12541 "configure"
@@ -12545,7 +12548,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12564,13 +12567,13 @@
-echo "configure:12568: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12571: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12574 "configure"
+#line 12577 "configure"
@@ -12581,7 +12584,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12671,13 +12674,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12675: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12678: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12681 "configure"
+#line 12684 "configure"
@@ -12688,7 +12691,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12737,7 +12740,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12741: checking whether to use ODBC" >&5
+echo "configure:12744: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12756,7 +12759,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12760: checking for location of ODBC includes" >&5
+echo "configure:12763: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12782,15 +12785,15 @@
 do
-echo "configure:12786: checking for $ac_hdr" >&5
+echo "configure:12789: checking for $ac_hdr" >&5
-#line 12789 "configure"
+#line 12792 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12794: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12797: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12824,7 +12827,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12828: checking for location of ODBC library" >&5
+echo "configure:12831: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12849,13 +12852,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12853: checking for SQLConnect in -lodbc" >&5
+echo "configure:12856: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12859 "configure"
+#line 12862 "configure"
 #include "confdefs.h"
@@ -12866,7 +12869,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12891,13 +12894,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12895: checking for SQLConnect in -liodbc" >&5
+echo "configure:12898: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12901 "configure"
+#line 12904 "configure"
@@ -12908,7 +12911,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12933,11 +12936,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12937: checking for ODBC library" >&5
+echo "configure:12940: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12941 "configure"
+#line 12944 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12945,7 +12948,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12994,7 +12997,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12998: checking whether to use FFTW" >&5
+echo "configure:13001: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -13013,7 +13016,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:13017: checking for location of FFTW includes" >&5
+echo "configure:13020: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -13039,15 +13042,15 @@
 do
-echo "configure:13043: checking for $ac_hdr" >&5
+echo "configure:13046: checking for $ac_hdr" >&5
-#line 13046 "configure"
+#line 13049 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13051: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13054: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13075,15 +13078,15 @@
 do
-echo "configure:13079: checking for $ac_hdr" >&5
+echo "configure:13082: checking for $ac_hdr" >&5
-#line 13082 "configure"
+#line 13085 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13087: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13090: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13111,15 +13114,15 @@
 do
-echo "configure:13115: checking for $ac_hdr" >&5
+echo "configure:13118: checking for $ac_hdr" >&5
-#line 13118 "configure"
+#line 13121 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13123: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13126: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13165,7 +13168,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:13169: checking for location of FFTW library" >&5
+echo "configure:13172: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13190,13 +13193,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13194: checking for fftw_execute in -lfftw3" >&5
+echo "configure:13197: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13200 "configure"
+#line 13203 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13207,7 +13210,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:13211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13232,13 +13235,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13236: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13239: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 13242 "configure"
+#line 13245 "configure"
@@ -13249,7 +13252,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13274,13 +13277,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13278: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13281: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13284 "configure"
+#line 13287 "configure"
@@ -13291,7 +13294,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13348,7 +13351,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13352: checking whether to use BLAS" >&5
+echo "configure:13355: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -13369,7 +13372,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13373: checking for location of BLAS includes" >&5
+echo "configure:13376: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13389,7 +13392,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13393: checking for location of BLAS library" >&5
+echo "configure:13396: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13415,15 +13418,15 @@
 do
-echo "configure:13419: checking for $ac_hdr" >&5
+echo "configure:13422: checking for $ac_hdr" >&5
-#line 13422 "configure"
+#line 13425 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13430: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13458,13 +13461,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13462: checking for dnrm2_ in -lblas" >&5
+echo "configure:13465: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 13468 "configure"
+#line 13471 "configure"
@@ -13475,7 +13478,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13494,13 +13497,13 @@
-echo "configure:13498: checking for dnrm2_ in -lblas" >&5
+echo "configure:13501: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13504 "configure"
+#line 13507 "configure"
@@ -13511,7 +13514,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13555,13 +13558,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13559: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13562: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13565 "configure"
+#line 13568 "configure"
@@ -13572,7 +13575,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13587,13 +13590,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13591: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13594: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13597 "configure"
+#line 13600 "configure"
@@ -13604,7 +13607,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13619,13 +13622,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13623: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13626: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13629 "configure"
+#line 13632 "configure"
@@ -13636,7 +13639,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13682,16 +13685,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13686: checking for sgemm in $vlib_flags" >&5
+echo "configure:13689: checking for sgemm in $vlib_flags" >&5
-#line 13688 "configure"
+#line 13691 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13709,13 +13712,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13713: checking for sgemm_ in -lblas" >&5
+echo "configure:13716: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13719 "configure"
+#line 13722 "configure"
@@ -13726,7 +13729,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13741,13 +13744,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13745: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13748: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13751 "configure"
+#line 13754 "configure"
@@ -13758,7 +13761,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13773,13 +13776,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13777: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13780: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13783 "configure"
+#line 13786 "configure"
@@ -13790,7 +13793,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13824,13 +13827,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13828: checking for acosp in -lsunmath" >&5
+echo "configure:13831: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13834 "configure"
+#line 13837 "configure"
@@ -13841,7 +13844,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13856,13 +13859,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13860: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13863: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13866 "configure"
+#line 13869 "configure"
@@ -13873,7 +13876,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13903,13 +13906,13 @@
 # Generic BLAS library
-echo "configure:13907: checking for sgemm_ in -lblas" >&5
+echo "configure:13910: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13913 "configure"
+#line 13916 "configure"
@@ -13920,7 +13923,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13959,7 +13962,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13963: checking whether to use LAPACK" >&5
+echo "configure:13966: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13984,7 +13987,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13988: checking for location of LAPACK includes" >&5
+echo "configure:13991: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -14004,7 +14007,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:14008: checking for location of LAPACK library" >&5
+echo "configure:14011: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -14030,15 +14033,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14034: checking for $ac_hdr" >&5
+echo "configure:14037: checking for $ac_hdr" >&5
-#line 14037 "configure"
+#line 14040 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14070,10 +14073,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:14074: checking for dsegv_" >&5
+echo "configure:14077: checking for dsegv_" >&5
-#line 14077 "configure"
+#line 14080 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -14096,7 +14099,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -14123,13 +14126,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14127: checking for desgv_ in -llapack" >&5
+echo "configure:14130: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 14133 "configure"
+#line 14136 "configure"
@@ -14140,7 +14143,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:14144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14172,13 +14175,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14176: checking for dgesv_ in -llapack" >&5
+echo "configure:14179: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 14182 "configure"
+#line 14185 "configure"
@@ -14189,7 +14192,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:14193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14208,13 +14211,13 @@
-echo "configure:14212: checking for dgesv_ in -llapack" >&5
+echo "configure:14215: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14218 "configure"
+#line 14221 "configure"
@@ -14225,7 +14228,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:14229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14281,7 +14284,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14285: checking whether to use Motif" >&5
+echo "configure:14288: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -14300,7 +14303,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14304: checking for location of Motif includes" >&5
+echo "configure:14307: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14326,15 +14329,15 @@
 do
-echo "configure:14330: checking for $ac_hdr" >&5
+echo "configure:14333: checking for $ac_hdr" >&5
-#line 14333 "configure"
+#line 14336 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14338: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14368,7 +14371,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14372: checking for location of Motif library" >&5
+echo "configure:14375: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14393,13 +14396,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14397: checking for XmStringCreate in -lXm" >&5
+echo "configure:14400: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 14403 "configure"
+#line 14406 "configure"
@@ -14410,7 +14413,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:14414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14451,7 +14454,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14455: checking whether to use Cairo" >&5
+echo "configure:14458: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -14483,7 +14486,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14487: checking for location of cairo includes" >&5
+echo "configure:14490: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14509,15 +14512,15 @@
 do
-echo "configure:14513: checking for $ac_hdr" >&5
+echo "configure:14516: checking for $ac_hdr" >&5
-#line 14516 "configure"
+#line 14519 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14521: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14524: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14553,7 +14556,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14557: checking for location of cairo library" >&5
+echo "configure:14560: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14573,7 +14576,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14577: checking for cairo linking flags" >&5
+echo "configure:14580: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14589,10 +14592,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14593: checking for cairo_create" >&5
+echo "configure:14596: checking for cairo_create" >&5
-#line 14596 "configure"
+#line 14599 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14615,7 +14618,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14649,10 +14652,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14653: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14656: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14656 "configure"
+#line 14659 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14675,7 +14678,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14708,10 +14711,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14712: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14715: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14715 "configure"
+#line 14718 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -14734,7 +14737,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -14776,7 +14779,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14780: checking whether to use GLw" >&5
+echo "configure:14783: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14795,7 +14798,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14799: checking for location of GLw includes" >&5
+echo "configure:14802: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14821,15 +14824,15 @@
 do
-echo "configure:14825: checking for $ac_hdr" >&5
+echo "configure:14828: checking for $ac_hdr" >&5
-#line 14828 "configure"
+#line 14831 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14833: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14857,15 +14860,15 @@
 do
-echo "configure:14861: checking for $ac_hdr" >&5
+echo "configure:14864: checking for $ac_hdr" >&5
-#line 14864 "configure"
+#line 14867 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14869: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14872: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14905,7 +14908,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14909: checking for location of GLw library" >&5
+echo "configure:14912: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14930,13 +14933,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14934: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14937: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14940 "configure"
+#line 14943 "configure"
@@ -14947,7 +14950,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14972,13 +14975,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14976: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14979: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14982 "configure"
+#line 14985 "configure"
@@ -14989,7 +14992,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15014,13 +15017,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:15018: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:15021: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15024 "configure"
+#line 15027 "configure"
@@ -15031,7 +15034,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:15035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15038: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15056,13 +15059,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15060: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:15063: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15066 "configure"
+#line 15069 "configure"
@@ -15073,7 +15076,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15098,13 +15101,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15102: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:15105: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 15108 "configure"
+#line 15111 "configure"
@@ -15115,7 +15118,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15140,13 +15143,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15144: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:15147: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15150 "configure"
+#line 15153 "configure"
@@ -15157,7 +15160,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15184,13 +15187,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:15188: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15191: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15194 "configure"
+#line 15197 "configure"
@@ -15201,7 +15204,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15220,13 +15223,13 @@
-echo "configure:15224: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15227: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15230 "configure"
+#line 15233 "configure"
@@ -15237,7 +15240,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15264,13 +15267,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15268: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15271: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15274 "configure"
+#line 15277 "configure"
@@ -15281,7 +15284,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15300,13 +15303,13 @@
-echo "configure:15304: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15307: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15310 "configure"
+#line 15313 "configure"
@@ -15317,7 +15320,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15430,7 +15433,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15434: checking whether to use FreeType" >&5
+echo "configure:15437: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -15449,7 +15452,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15453: checking for location of FreeType includes" >&5
+echo "configure:15456: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15475,15 +15478,15 @@
 do
-echo "configure:15479: checking for $ac_hdr" >&5
+echo "configure:15482: checking for $ac_hdr" >&5
-#line 15482 "configure"
+#line 15485 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15487: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15490: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15517,7 +15520,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15521: checking for location of FreeType library" >&5
+echo "configure:15524: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15542,13 +15545,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15546: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15549: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15552 "configure"
+#line 15555 "configure"
@@ -15559,7 +15562,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15600,7 +15603,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15604: checking whether to use NLS" >&5
+echo "configure:15607: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15620,10 +15623,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15624: checking for gettext" >&5
+echo "configure:15627: checking for gettext" >&5
-#line 15627 "configure"
+#line 15630 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15646,7 +15649,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15664,13 +15667,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15668: checking for gettext in -lintl" >&5
+echo "configure:15671: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15674 "configure"
+#line 15677 "configure"
@@ -15681,7 +15684,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15716,7 +15719,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15720: checking whether to use C++" >&5
+echo "configure:15723: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15732,7 +15735,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15736: checking for $ac_word" >&5
+echo "configure:15739: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15761,7 +15764,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15765: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15768: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15772,12 +15775,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15776 "configure"
+#line 15779 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15803,19 +15806,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15807: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15810: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15812: checking whether we are using GNU C++" >&5
+echo "configure:15815: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15822: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15833,7 +15836,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15837: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15840: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15874,7 +15877,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15878: checking whether to use openDWG" >&5
+echo "configure:15881: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15894,7 +15897,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15898: checking for location of openDGW includes" >&5
+echo "configure:15901: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15920,15 +15923,15 @@
 do
-echo "configure:15924: checking for $ac_hdr" >&5
+echo "configure:15927: checking for $ac_hdr" >&5
-#line 15927 "configure"
+#line 15930 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15932: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15962,7 +15965,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15966: checking for location of openDWG library" >&5
+echo "configure:15969: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -16009,7 +16012,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:16013: checking for special C compiler options needed for large files" >&5
+echo "configure:16016: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -16017,7 +16020,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 16021 "configure"
+#line 16024 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -16033,7 +16036,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16037: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16040: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -16042,7 +16045,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 16046 "configure"
+#line 16049 "configure"
@@ -16058,7 +16061,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -16078,11 +16081,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:16082: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:16085: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 16086 "configure"
+#line 16089 "configure"
@@ -16098,14 +16101,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16102: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16105: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 16109 "configure"
+#line 16112 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -16123,7 +16126,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16127: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16130: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -16142,11 +16145,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:16146: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:16149: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 16150 "configure"
+#line 16153 "configure"
@@ -16162,14 +16165,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16166: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16169: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16173 "configure"
+#line 16176 "configure"
 #define _LARGE_FILES 1
@@ -16187,7 +16190,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16191: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16194: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -16206,25 +16209,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16210: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16213: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 16214 "configure"
+#line 16217 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16221: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16224: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16228 "configure"
+#line 16231 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -16233,7 +16236,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16237: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16240: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -16254,10 +16257,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16258: checking if system supports Large Files at all" >&5
+echo "configure:16261: checking if system supports Large Files at all" >&5
-#line 16261 "configure"
+#line 16264 "configure"
 #include <stdio.h>
@@ -16289,7 +16292,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:16293: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16296: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -16318,7 +16321,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16322: checking whether to use Python" >&5
+echo "configure:16325: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -16338,7 +16341,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:16342: checking for $ac_word" >&5
+echo "configure:16345: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -16380,15 +16383,15 @@
 do
-echo "configure:16384: checking for $ac_hdr" >&5
+echo "configure:16387: checking for $ac_hdr" >&5
-#line 16387 "configure"
+#line 16390 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16395: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16458,7 +16461,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16462: checking whether to use wxWidgets" >&5
+echo "configure:16465: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16479,7 +16482,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16483: checking for $ac_word" >&5
+echo "configure:16486: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16527,7 +16530,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16531: checking wxWidgets version" >&5
+echo "configure:16534: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16550,15 +16553,15 @@
 do
-echo "configure:16554: checking for $ac_hdr" >&5
+echo "configure:16557: checking for $ac_hdr" >&5
-#line 16557 "configure"
+#line 16560 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16562: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16565: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in	2012-02-05 11:40:47 UTC (rev 50662)
+++ grass/branches/releasebranch_6_4/configure.in	2012-02-05 11:51:17 UTC (rev 50663)
@@ -128,6 +128,9 @@
 AC_PATH_PROG(SVN_VERSION, svnversion, no)
 if test "$SVN_VERSION" != "no" ; then
    GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
+   if test "$GRASS_VERSION_SVN" = "exported" ; then
+      GRASS_VERSION_SVN=
+   fi
 fi
 AC_SUBST(GRASS_VERSION_FILE)
