[GRASS-SVN] r50699 - in grass/branches/develbranch_6:
gui/wxpython/xml raster/r.le
svn_grass at osgeo.org
Tue Feb 7 05:30:26 EST 2012
Author: hamish
Date: 2012-02-07 02:30:25 -0800 (Tue, 07 Feb 2012)
New Revision: 50699
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
grass/branches/develbranch_6/raster/r.le/Makefile
specify r.le modules that need xterms and xmons (r.le.setup is interactive with an xmon, r.le.trace draws to a display driver but also is interactive in the terminal window)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2012-02-07 05:35:30 UTC (rev 50698)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2012-02-07 10:30:25 UTC (rev 50699)
@@ -1445,7 +1445,7 @@
<label>Output</label>
<help>Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file.</help>
<keywords>raster,landscape structure analysis,patch index</keywords>
- <handler>OnMenuCmd</handler>
+ <handler>OnXTerm</handler>
<command>r.le.trace</command>
</menuitem>
</items>
Modified: grass/branches/develbranch_6/raster/r.le/Makefile
--- grass/branches/develbranch_6/raster/r.le/Makefile 2012-02-07 05:35:30 UTC (rev 50698)
+++ grass/branches/develbranch_6/raster/r.le/Makefile 2012-02-07 10:30:25 UTC (rev 50699)
@@ -3,11 +3,16 @@
SUBDIRS = \
r.le.patch \
- r.le.pixel \
- r.le.setup \
- r.le.trace
+ r.le.pixel
# r.le.setup/polytocell
+XMONBASED = r.le.setup r.le.trace
+#compile if interactive Xmons are present:
+ifneq ($(USE_X11),)
+ SUBDIRS += $(XMONBASED)
+endif
include $(MODULE_TOPDIR)/include/Make/Dir.make
default: parsubdirs
