[GRASS-SVN] r50736 - grass/trunk/vector/v.what.rast
svn_grass at osgeo.org
Wed Feb 8 16:40:06 EST 2012
Author: neteler
Date: 2012-02-08 13:40:06 -0800 (Wed, 08 Feb 2012)
New Revision: 50736
grass/trunk/vector/v.what.rast/v.what.rast.html
examples prettified
Modified: grass/trunk/vector/v.what.rast/v.what.rast.html
--- grass/trunk/vector/v.what.rast/v.what.rast.html 2012-02-08 21:39:58 UTC (rev 50735)
+++ grass/trunk/vector/v.what.rast/v.what.rast.html 2012-02-08 21:40:06 UTC (rev 50736)
@@ -15,31 +15,33 @@
<h2>EXAMPLES</h2>
A) Reading values from raster map at position of vector points, writing these values
- into column of vector map:
+ into a column of the attribute table connected to the vector map:
<br>
<div class="code"><pre>
v.what.rast map=pnts raster=elevation column=heights
</pre></div>
-<p>B) In case of a vector map without attached attribute table, first add
+<p>
+B) In case of a vector map without attached attribute table, first add
a new attribute table. This table is then populated with values
queried from the raster map:
<br>
-v.db.connect -p vectpoints
-# .. no table yet.
+# create new random vector points map
+v.random pnts n=100
-# add new table, link to map:
-v.db.addtable vectpoints column="cat integer, myvalue integer, otherval double precision"
+# add new table, link to map
+v.db.addtable pnts column="heights double precision"
-# query raster map and upload values to vector table into specified column:
-v.what.rast map=vectpoints raster=rastmap column=myvalue
+# query raster map and upload values to vector table into specified column
+g.region rast=elevation -p
+v.what.rast map=pnts raster=elevation column=heights
# verify new attribute table:
-v.db.select vectpoints
+v.db.select pnts
# verify statistics of uploaded values:
-v.univar map=vectpoints column=myvalue type=point
+v.univar map=pnts column=heights type=point
</pre></div>
<h2>SEE ALSO</h2>
@@ -56,4 +58,5 @@
<h2>AUTHOR</h2>
Radim Blazek
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
