[GRASS-SVN] r50762 - grass/trunk/vector/v.external
svn_grass at osgeo.org
Sat Feb 11 07:26:50 EST 2012
Author: martinl
Date: 2012-02-11 04:26:50 -0800 (Sat, 11 Feb 2012)
New Revision: 50762
grass/trunk/vector/v.external/main.c
v.external: define error handler for output map
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c 2012-02-11 11:36:54 UTC (rev 50761)
+++ grass/trunk/vector/v.external/main.c 2012-02-11 12:26:50 UTC (rev 50762)
@@ -98,6 +98,8 @@
Vect_open_new(&Map, output, is3D);
+ Vect_set_error_handler_io(NULL, &Map);
Vect_hist_command(&Map);
Vect_close(&Map);
