[GRASS-SVN] r50777 - in grass/trunk/temporal: . t.register
svn_grass at osgeo.org
Sun Feb 12 18:09:11 EST 2012
Author: huhabla
Date: 2012-02-12 15:09:11 -0800 (Sun, 12 Feb 2012)
New Revision: 50777
Added:
grass/trunk/temporal/t.register/
grass/trunk/temporal/t.register/Makefile
grass/trunk/temporal/t.register/t.register.html
grass/trunk/temporal/t.register/t.register.py
grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh
grass/trunk/temporal/t.register/test.t.register.raster.file.sh
grass/trunk/temporal/t.register/test.t.register.raster.sh
grass/trunk/temporal/t.register/test.t.register.raster3d.sh
grass/trunk/temporal/t.register/test.t.register.vector.sh
Replacement for t.time.rel, t.time.abs, tr.register, tv.register
and tr3.register to reduce the complexity of the temporal GIS framework
and to avoid redundant functionality
Added: grass/trunk/temporal/t.register/Makefile
--- grass/trunk/temporal/t.register/Makefile (rev 0)
+++ grass/trunk/temporal/t.register/Makefile 2012-02-12 23:09:11 UTC (rev 50777)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.register
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.register/t.register.html
Added: grass/trunk/temporal/t.register/t.register.py
--- grass/trunk/temporal/t.register/t.register.py (rev 0)
+++ grass/trunk/temporal/t.register/t.register.py 2012-02-12 23:09:11 UTC (rev 50777)
@@ -0,0 +1,421 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.register
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Register raster, vector and raster3d maps in a space time datasets
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Register raster, vector adn raster3d maps in a space time datasets
+#% keywords: temnporal
+#% keywords: raster
+#% keywords: vector
+#% keywords: raster3d
+#%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of an existing space time dataset of type raster, vector or raster3d
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: maps
+#% type: string
+#% description: Name(s) of existing map(s) of type raster, vector or raster3d
+#% required: no
+#% multiple: yes
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: Input space time dataset type
+#% required: no
+#% options: strds, stvds, str3ds
+#% answer: strds
+#%end
+#%option
+#% key: file
+#% type: string
+#% description: Input file with map names, one per line. Additionally the start time and the end time can be specified per line
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: start
+#% type: string
+#% description: The valid start date and time of the first map. Format absolute time: "yyyy-mm-dd HH:MM:SS +HHMM", relative time is of type integer).
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: end
+#% type: string
+#% description: The valid end date and time of all map. Format absolute time: "yyyy-mm-dd HH:MM:SS +HHMM", relative time is of type integer).
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: unit
+#% type: string
+#% description: This unit must be set in case of relative time stamps
+#% required: no
+#% multiple: no
+#% options: years,months,days,hours,minutes,seconds
+#%end
+#%option
+#% key: increment
+#% type: string
+#% description: Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer: 5)
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: fs
+#% type: string
+#% description: The field separator character of the input file
+#% required: no
+#% answer: |
+#%end
+#%flag
+#% key: i
+#% description: Create an interval (start and end time) in case an increment is provided
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+ # Get the options
+ name = options["input"]
+ maps = options["maps"]
+ type = options["type"]
+ file = options["file"]
+ fs = options["fs"]
+ start = options["start"]
+ end = options["end"]
+ unit = options["unit"]
+ increment = options["increment"]
+ interval = flags["i"]
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ # Register maps
+ register_maps_in_space_time_dataset(type=type, name=name, maps=maps, file=file, start=start, end=end, \
+ unit=unit, increment=increment, dbif=None, interval=interval, fs=fs)
+def register_maps_in_space_time_dataset(type, name, maps=None, file=None, start=None, \
+ end=None, unit=None, increment=None, dbif = None, \
+ interval=False, fs="|"):
+ """Use this method to register maps in space time datasets. This function is generic and
+ Additionally a start time string and an increment string can be specified
+ to assign a time interval automatically to the maps.
+ It takes care of the correct update of the space time datasets from all
+ registered maps.
+ @param type: The type of the maps raster, raster3d or vector
+ @param name: The name of the space time dataset
+ @param maps: A comma separated list of map names
+ @param file: Input file one map with start and optional end time, one per line
+ @param start: The start date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative is integer 5)
+ @param end: The end date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative is integer 5)
+ @param unit: The unit of the relative time: years, months, days, hours, minutes, seconds
+ @param increment: Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
+ @param dbif: The database interface to be used
+ @param interval: If True, time intervals are created in case the start time and an increment is provided
+ @param fs: Field separator used in input file
+ start_time_in_file = False
+ end_time_in_file = False
+ if maps and file:
+ grass.fatal(_("%s= and %s= are mutually exclusive") % ("input","file"))
+ if end and increment:
+ grass.fatal(_("%s= and %s= are mutually exclusive") % ("end","increment"))
+ if end and not start:
+ grass.fatal(_("Please specify %s= and %s=") % ("start_time","end_time"))
+ if not maps and not file:
+ grass.fatal(_("Please specify %s= or %s=") % ("input","file"))
+ # We may need the mapset
+ mapset = grass.gisenv()["MAPSET"]
+ # Check if the dataset name contains the mapset as well
+ if name.find("@") < 0:
+ id = name + "@" + mapset
+ else:
+ id = name
+ sp = tgis.dataset_factory(type, id)
+ connect = False
+ if dbif == None:
+ dbif = tgis.sql_database_interface()
+ dbif.connect()
+ connect = True
+ # Read content from temporal database
+ sp.select(dbif)
+ if sp.is_in_db(dbif) == False:
+ dbif.close()
+ grass.fatal(_("Space time %s dataset <%s> no found") % (sp.get_new_map_instance(None).get_type(), name))
+ if sp.is_time_relative() and not unit:
+ dbif.close()
+ grass.fatal(_("Space time %s dataset <%s> with relative time found, but no relative unit set for %s maps") % (sp.get_new_map_instance(None).get_type(), name, sp.get_new_map_instance(None).get_type()))
+ dummy = sp.get_new_map_instance(None)
+ maplist = []
+ # Map names as comma separated string
+ if maps:
+ if maps.find(",") < 0:
+ maplist = [maps,]
+ else:
+ maplist = maps.split(",")
+ # Build the maplist again with the ids
+ for count in range(len(maplist)):
+ row = {}
+ mapid = dummy.build_id(maplist[count], mapset, None)
+ row["id"] = mapid
+ maplist[count] = row
+ # Read the map list from file
+ if file:
+ fd = open(file, "r")
+ line = True
+ while True:
+ line = fd.readline()
+ if not line:
+ break
+ line_list = line.split(fs)
+ # Detect start and end time
+ if len(line_list) == 2:
+ start_time_in_file = True
+ elif len(line_list) == 3:
+ end_time_in_file = True
+ else:
+ mapname = line_list[0].strip()
+ row = {}
+ if start_time_in_file and end_time_in_file:
+ row["start"] = line_list[1].strip()
+ row["end"] = line_list[2].strip()
+ if start_time_in_file and not end_time_in_file:
+ row["id"] = dummy.build_id(mapname, mapset)
+ maplist.append(row)
+ num_maps = len(maplist)
+ grass.percent(count, num_maps, 1)
+ # Get a new instance of the space time dataset map type
+ map = sp.get_new_map_instance(maplist[count]["id"])
+ # Use the time data from file
+ if maplist[count].has_key("start"):
+ start = maplist[count]["start"]
+ if maplist[count].has_key("end"):
+ end = maplist[count]["end"]
+ # Put the map into the database
+ if map.is_in_db(dbif) == False:
+ # Break in case no valid time is provided
+ if start == "" or start == None:
+ dbif.close()
+ if map.get_layer():
+ grass.fatal(_("Unable to register %s map <%s> with layer %s. The map has no valid time and the start time is not set.") % \
+ (map.get_type(), map.get_map_id(), map.get_layer() ))
+ else:
+ grass.fatal(_("Unable to register %s map <%s>. The map has no valid time and the start time is not set.") % \
+ (map.get_type(), map.get_map_id() ))
+ # Load the data from the grass file database
+ map.load()
+ if sp.get_temporal_type() == "absolute":
+ map.set_time_to_absolute()
+ else:
+ map.set_time_to_relative()
+ # Put it into the temporal database
+ map.insert(dbif)
+ else:
+ map.select(dbif)
+ if map.get_temporal_type() != sp.get_temporal_type():
+ dbif.close()
+ grass.fatal(_("Unable to register %s map <%s> with layer. The temporal types are different.") % \
+ (map.get_type(), map.get_map_id(), map.get_layer()))
+ grass.fatal(_("Unable to register %s map <%s>. The temporal types are different.") % \
+ (map.get_type(), map.get_map_id()))
+ # In case the time is in the input file we ignore the increment counter
+ if start_time_in_file:
+ count = 1
+ # Set the valid time
+ if start:
+ tgis.assign_valid_time_to_map(ttype=sp.get_temporal_type(), map=map, start=start, end=end, unit=unit, increment=increment, mult=count, dbif=dbif, interval=interval)
+ # Finally Register map in the space time dataset
+ sp.register_map(map, dbif)
+ # Update the space time tables
+ sp.update_from_registered_maps(dbif)
+ if connect == True:
+ dbif.close()
+ grass.percent(num_maps, num_maps, 1)
+def unregister_maps_from_space_time_datasets(type, name, maps, file=None, dbif=None):
+ """Unregister maps from a single space time dataset or, in case no dataset name is provided,
+ unregister from all datasets within the maps are registered.
+ @param type: The type of the maps raster, vector or raster3d
+ @param name: Name of an existing space time raster dataset. If no name is provided the raster map(s) are unregistered from all space time datasets in which they are registered.
+ @param file: Input file one map per line
+ if maps and file:
+ if dbif == None:
+ dbif = sql_database_interface()
+ dbif.connect()
+ connect = True
+ # In case a space time dataset is specified
+ if name:
+ else:
+ id = name
+ if type == "rast":
+ sp = dataset_factory("strds", id)
+ if type == "rast3d":
+ sp = dataset_factory("str3ds", id)
+ if type == "vect":
+ sp = dataset_factory("stvds", id)
+ dbif.close()
+ grass.fatal("Space time " + sp.get_new_map_instance(None).get_type() + " dataset <" + name + "> not found")
+ maplist = []
+ dummy = raster_dataset(None)
+ if maps != None:
+ if maps.find(",") == -1:
+ maplist = [maps,]
+ else:
+ mapname = maplist[count]
+ mapid = dummy.build_id(mapname, mapset)
+ maplist[count] = mapid
+ if file:
+ line = True
+ while True:
+ if not line:
+ break
+ maplist.append(mapid)
+ count = 0
+ for mapid in maplist:
+ print mapid
+ map = dataset_factory(type, mapid)
+ # Unregister map if in database
+ if map.is_in_db(dbif) == True:
+ if name:
+ sp.select(dbif)
+ sp.unregister_map(map, dbif)
+ else:
+ map.select(dbif)
+ map.unregister(dbif)
+ count += 1
+ if name:
+ dbif.close()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/t.register/t.register.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh (rev 0)
+++ grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh 2012-02-12 23:09:11 UTC (rev 50777)
@@ -0,0 +1,96 @@
+# This is a test to register and unregister raster maps in
+# space time raster input.
+# The raster maps will be registered in different space time raster
+# inputs
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create two space time raster inputs
+# with relative and absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+n1=`g.tempfile pid=1 -d` # Only map names
+n2=`g.tempfile pid=2 -d` # Map names and start time
+n3=`g.tempfile pid=3 -d` # Map names start time and increment
+cat > "${n1}" << EOF
+prec_1
+prec_2
+prec_3
+prec_4
+prec_5
+prec_6
+EOF
+cat "${n1}"
+cat > "${n2}" << EOF
+prec_1|1
+prec_2|2
+prec_3|3
+prec_4|4
+prec_5|5
+prec_6|6
+EOF
+cat "${n2}"
+cat > "${n3}" << EOF
+prec_1|1|4
+prec_2|4|7
+prec_3|7|10
+prec_4|10|11
+prec_5|11|14
+prec_6|14|17
+EOF
+cat "${n3}"
+# The first @test
+# We create the space time raster inputs and register the raster maps with absolute time interval
+t.create --o type=strds temporaltype=relative output=precip_abs8 title="A test with input files" descr="A test with input files"
+# Test with input files
+# File 1
+t.register -i input=precip_abs8 file="${n1}" start=0 increment=7 unit=days
+t.info type=strds input=precip_abs8
+tr.list input=precip_abs8
+# File 1
+t.remove --v type=rast file="${n1}"
+t.register input=precip_abs8 file="${n1}" start=20 unit=years
+# File 2
+t.register input=precip_abs8 file="${n2}" unit=minutes
+# File 2 ERROR ERROR -- Increment computation needs to be fixed
+t.register input=precip_abs8 file="${n2}" increment=14 unit=days
+t.register -i input=precip_abs8 file="${n2}" increment=14 unit=days
+# File 3
+t.register -i input=precip_abs8 file="${n3}" unit=seconds
+# @test of correct @failure handling
+t.register -i input=precip_abs8 maps=preac_1,prec_2 file="${n3}" # Maps and file set
+t.register -i input=precip_abs8 file="${n3}" # No relative unit set
+t.remove --v type=strds input=precip_abs8
Added: grass/trunk/temporal/t.register/test.t.register.raster.file.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.file.sh (rev 0)
+++ grass/trunk/temporal/t.register/test.t.register.raster.file.sh 2012-02-12 23:09:11 UTC (rev 50777)
@@ -0,0 +1,81 @@
+# inputs
+prec_1
+prec_2
+prec_3
+prec_4
+prec_5
+prec_6
+EOF
+cat "${n1}"
+prec_1|2001-01-01
+prec_2|2001-02-01
+prec_3|2001-03-01
+prec_4|2001-04-01
+prec_5|2001-05-01
+prec_6|2001-06-01
+EOF
+cat "${n2}"
+prec_1|2001-01-01|2001-04-01
+prec_2|2001-04-01|2001-07-01
+prec_3|2001-07-01|2001-10-01
+prec_4|2001-10-01|2002-01-01
+prec_5|2002-01-01|2002-04-01
+prec_6|2002-04-01|2002-07-01
+EOF
+cat "${n3}"
+# The first @test
+t.create --o type=strds temporaltype=absolute output=precip_abs8 title="A test with input files" descr="A test with input files"
+# File 1
+t.register -i input=precip_abs8 file="${n1}" start="2001-01-01" increment="1 months"
+# File 1
+t.register input=precip_abs8 file="${n1}" start="2001-01-01"
+# File 2
+# File 2
+t.register input=precip_abs8 file="${n2}" increment="1 months"
+# File 3
Added: grass/trunk/temporal/t.register/test.t.register.raster.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.sh (rev 0)
+++ grass/trunk/temporal/t.register/test.t.register.raster.sh 2012-02-12 23:09:11 UTC (rev 50777)
@@ -0,0 +1,96 @@
+# inputs
+# The first @test
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
+t.create --o type=strds temporaltype=absolute output=precip_abs3 title="A test" descr="A test"
+t.create --o type=strds temporaltype=absolute output=precip_abs4 title="A test" descr="A test"
+t.create --o type=strds temporaltype=absolute output=precip_abs5 title="A test" descr="A test"
+t.create --o type=strds temporaltype=absolute output=precip_abs6 title="A test" descr="A test"
+t.create --o type=strds temporaltype=absolute output=precip_abs7 title="A test" descr="A test"
+t.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 seconds"
+t.info type=strds input=precip_abs1
+t.info -g type=strds input=precip_abs1
+r.info map=prec_1
+tr.list input=precip_abs1
+t.topology input=precip_abs1
+t.register -i input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 seconds, 5 minutes"
+t.info type=strds input=precip_abs2
+t.info -g type=strds input=precip_abs2
+r.info map=prec_1
+tr.list input=precip_abs2
+t.topology input=precip_abs2
+t.register -i input=precip_abs3 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="8 hours"
+t.info -g type=strds input=precip_abs3
+r.info map=prec_1
+tr.list input=precip_abs3
+t.topology input=precip_abs3
+t.register input=precip_abs4 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 days"
+t.info -g type=strds input=precip_abs4
+r.info map=prec_1
+tr.list input=precip_abs4
+t.topology input=precip_abs4
+t.register input=precip_abs5 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="4 weeks"
+t.info -g type=strds input=precip_abs5
+r.info map=prec_1
+tr.list input=precip_abs5
+t.topology input=precip_abs5
+t.register input=precip_abs6 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-08-01" increment="2 months"
+t.info -g type=strds input=precip_abs6
+r.info map=prec_1
+tr.list input=precip_abs6
+t.topology input=precip_abs6
+t.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
+t.info -g type=strds input=precip_abs7
+r.info map=prec_1
+tr.list input=precip_abs7
+t.topology input=precip_abs7
+# Register with different valid time again
+t.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+r.info map=prec_1
+# Register with different valid time again creating an interval
+t.register -i input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+r.info map=prec_1
+t.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" end="2002-01-01"
+r.info map=prec_1
+t.remove type=rast input=prec_1,prec_2,prec_3
+t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5,precip_abs6,precip_abs7
+t.remove type=rast input=prec_4,prec_5,prec_6
+r.info map=prec_1
Added: grass/trunk/temporal/t.register/test.t.register.raster3d.sh
--- grass/trunk/temporal/t.register/test.t.register.raster3d.sh (rev 0)
+++ grass/trunk/temporal/t.register/test.t.register.raster3d.sh 2012-02-12 23:09:11 UTC (rev 50777)
@@ -0,0 +1,70 @@
+# This is a test to register and unregister raster3d maps in
+# space time raster3d datasets
+# The raster3d maps will be registered in different space time raster3d
+# datasets
+# 3d raster with r3.mapcalc and create two space time raster3d datasets
+r3.mapcalc --o expr="volume_1 = rand(0, 550)"
+r3.mapcalc --o expr="volume_2 = rand(0, 450)"
+r3.mapcalc --o expr="volume_3 = rand(0, 320)"
+r3.mapcalc --o expr="volume_4 = rand(0, 510)"
+r3.mapcalc --o expr="volume_5 = rand(0, 300)"
+r3.mapcalc --o expr="volume_6 = rand(0, 650)"
+# The first @test
+# We create the space time raster3d dataset and register the raster3d maps with absolute time interval
+t.create --v --o type=str3ds temporaltype=absolute output=volume_abs1 title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute output=volume_abs2 title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute output=volume_abs3 title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute output=volume_abs4 title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute output=volume_abs5 title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute output=volume_abs6 title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute output=volume_abs7 title="A test" descr="A test"
+t.register type=str3ds --v -i input=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="1 seconds"
+t.info type=str3ds input=volume_abs1
+tr3.unregister --v input=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
+t.register type=str3ds --v -i input=volume_abs2 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 seconds, 5 minutes"
+t.info type=str3ds input=volume_abs2
+r3.info volume_1
+r3.info volume_2
+r3.info volume_3
+r3.info volume_4
+r3.info volume_5
+r3.info volume_6
+t.register type=str3ds --v -i input=volume_abs3 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="8 hours"
+t.info type=str3ds input=volume_abs3
+tr3.unregister --v maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
+t.register type=str3ds input=volume_abs4 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="3 days"
+t.info type=str3ds input=volume_abs4
+t.register type=str3ds input=volume_abs5 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="4 weeks"
+t.info type=str3ds input=volume_abs5
+t.register type=str3ds input=volume_abs6 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-08-01" increment="2 months"
+t.info type=str3ds input=volume_abs6
+t.register type=str3ds input=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
+t.info type=str3ds input=volume_abs7
+t.register type=str3ds input=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+# Register with different valid time again creating intervals
+t.register type=str3ds -i input=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.remove --v type=rast3d input=volume_1,volume_2,volume_3
+t.remove --v type=str3ds input=volume_abs1,volume_abs2,volume_abs3,volume_abs4,volume_abs5,volume_abs6,volume_abs7
+t.remove --v type=rast3d input=volume_4,volume_5,volume_6
Added: grass/trunk/temporal/t.register/test.t.register.vector.sh
--- grass/trunk/temporal/t.register/test.t.register.vector.sh (rev 0)
+++ grass/trunk/temporal/t.register/test.t.register.vector.sh 2012-02-12 23:09:11 UTC (rev 50777)
@@ -0,0 +1,64 @@
+# This is a test to register and unregister vector maps in
+# space time vector input.
+# The vector maps will be registered in different space time vector
+# inputs
+# vector with v.random and create several space time vector inputs
+# with absolute time
+v.random --o -z output=lidar_abs_1 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_2 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_3 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_4 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_5 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_6 n=20 zmin=0 zmax=100 column=height
+# The first @test
+# We create the space time vector inputs and register the vector maps with absolute time interval
+t.create --v --o type=stvds temporaltype=absolute output=lidar_abs_ds1 title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute output=lidar_abs_ds2 title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute output=lidar_abs_ds3 title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute output=lidar_abs_ds4 title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute output=lidar_abs_ds5 title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute output=lidar_abs_ds6 title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute output=lidar_abs_ds7 title="A test" descr="A test"
+t.register type=stvds --v -i input=lidar_abs_ds1 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="1 seconds"
+t.info type=stvds input=lidar_abs_ds1
+tv.unregister --v input=lidar_abs_ds1 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6
+t.register type=stvds --v -i input=lidar_abs_ds2 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="20 seconds, 5 minutes"
+t.info type=stvds input=lidar_abs_ds2
+t.register type=stvds --v -i input=lidar_abs_ds3 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="8 hours"
+t.info type=stvds input=lidar_abs_ds3
+tv.unregister --v maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6
+t.register type=stvds input=lidar_abs_ds4 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="3 days"
+t.info type=stvds input=lidar_abs_ds4
+t.register type=stvds input=lidar_abs_ds5 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="4 weeks"
+t.info type=stvds input=lidar_abs_ds5
+t.register type=stvds input=lidar_abs_ds6 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-08-01" increment="2 months"
+t.info type=stvds input=lidar_abs_ds6
+t.register type=stvds input=lidar_abs_ds7 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
+t.info type=stvds input=lidar_abs_ds7
+t.register type=stvds input=lidar_abs_ds7 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.register type=stvds -i input=lidar_abs_ds7 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.remove --v type=vect input=lidar_abs_1,lidar_abs_2,lidar_abs_3
+t.remove --v type=stvds input=lidar_abs_ds1,lidar_abs_ds2,lidar_abs_ds3,lidar_abs_ds4,lidar_abs_ds5,lidar_abs_ds6,lidar_abs_ds7
+t.remove --v type=vect input=lidar_abs_4,lidar_abs_5,lidar_abs_6
