[GRASS-SVN] r50779 - grass/trunk/scripts/r.fillnulls
Sun Feb 12 21:32:40 EST 2012
Author: hamish
Date: 2012-02-12 18:32:40 -0800 (Sun, 12 Feb 2012)
New Revision: 50779
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
zoom into tight region for RST; fix coeffs for bspline; note 'r.to.vect -b' might be a good idea. (#1088)
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2012-02-13 00:43:38 UTC (rev 50778)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2012-02-13 02:32:40 UTC (rev 50779)
@@ -6,7 +6,7 @@
 # AUTHOR(S):	Markus Neteler
 #               Updated to GRASS 5.7 by Michael Barton
 #               Updated to GRASS 6.0 by Markus Neteler
-#               Ring improvements by Hamish Bowman
+#               Ring and zoom improvements by Hamish Bowman
 #               Converted to Python by Glynn Clements
 #               Add support to v.surf.bspline by Luca Delucchi
 # PURPOSE:	fills NULL (no data areas) in raster maps
@@ -134,6 +134,7 @@
     # Use this outline (raster border) for interpolating the fill data:
     vecttmp = "vecttmp_fillnulls_" + unique
     grass.message(_("Creating interpolation points..."))
+    ## use the -b flag to avoid topology building on big jobs?
     if grass.run_command('r.to.vect', input = input, output = vecttmp, type = 'point'):
 	grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
@@ -145,7 +146,6 @@
     if pointsnumber < 2:
 	grass.fatal(_("Not sufficient points to interpolate. Maybe no hole(s) to fill in the current map region?"))
-    grass.message(_("Note: The following warnings may be ignored."))
     # remove internal MASK first -- WHY???? MN 10/2005
     grass.run_command('g.remove', quiet = True, rast = 'MASK')
@@ -157,8 +157,15 @@
     else:
 	maskmap = None
+    grass.message(_("Note: The following 'consider changing' warnings may be ignored."))
     #check if method is rst to use v.surf.rst
     if method == 'rst':
+        # clone current region
+        grass.use_temp_region()
+        grass.run_command('g.region', vect = vecttmp, align = input)
         # set the max number before segmantation
         segmax = 600
         if pointsnumber > segmax:
@@ -174,19 +181,26 @@
 	grass.message(_("Note: Above warnings may be ignored."))
+        # restore the real region
+        grass.del_temp_region()
     # restoring user's mask, if present:
+    #  (should all this MASK stuff go into the method==rst conditional?)
     if grass.find_file(usermask, mapset = mapset)['file']:
 	grass.message(_("Restoring user mask (MASK)..."))
 	grass.run_command('g.rename', quiet = True, rast = (usermask, 'MASK'))
     #check if method is different from rst to use v.surf.bspline
     if method != 'rst':
 	grass.message(_("Using %s (v.surf.bspline) interpolation") % method)
 	reg = grass.region()
 	# launch v.surf.bspline
 	grass.run_command('v.surf.bspline', input = vecttmp, layer = 1,
-			raster = tmp1 + '_filled', method = method, column = 'value',
-			sie = reg['ewres'], sin = reg['nsres'])
+			raster = tmp1 + '_filled', method = method,
+			column = 'value', lambda_i = 0.005,
+			sie = reg['ewres'] * 3.0, sin = reg['nsres'] * 3.0)
     # patch orig and fill map
     grass.message(_("Patching fill data into NULL areas..."))
