[GRASS-SVN] r50782 -
grass/branches/develbranch_6/vector/lidar/v.surf.bspline
svn_grass at osgeo.org
Mon Feb 13 04:13:27 EST 2012
Author: hamish
Date: 2012-02-13 01:13:27 -0800 (Mon, 13 Feb 2012)
New Revision: 50782
grass/branches/develbranch_6/vector/lidar/v.surf.bspline/crosscorr.c
more cross-validation table cosmetics
Modified: grass/branches/develbranch_6/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/branches/develbranch_6/vector/lidar/v.surf.bspline/crosscorr.c 2012-02-13 08:54:05 UTC (rev 50781)
+++ grass/branches/develbranch_6/vector/lidar/v.surf.bspline/crosscorr.c 2012-02-13 09:13:27 UTC (rev 50782)
@@ -169,9 +169,8 @@
for (lbd = 0; lbd < PARAM_LAMBDA; lbd++) { /* For each lambda value */
G_message(_("Begining cross validation with "
- "lambda_i=%.4f..."), lambda[lbd]);
+ "lambda_i=%.4f ..."), lambda[lbd]);
- G_set_verbose(G_verbose_min());
How cross correlation algorithm is done:
For each cicle, only the first ndata-1 "observ" elements are considered for the
@@ -260,7 +259,9 @@
if (bilin) interpolation (&interp, P_BILINEAR);
else interpolation (&interp, P_BICUBIC);
+ G_set_verbose(G_verbose_min());
tcholSolve(N, TN, parVect, nparam_spl, BW);
+ G_set_verbose(verbosity);
/* Estimation of j-point */
if (bilin)
@@ -282,13 +283,8 @@
observ = swap(observ, j, ndata - 1); /* Once the last value is left out, it is swap with j-value */
-/* commented out as it could be problematic to use global libgis variables
- if the different x-val cases are each sent to their own thread in future */
-/* G_set_verbose(verbosity);
- G_clicker();
- G_set_verbose(G_verbose_min()); */
+ G_percent(j,ndata,3);
- G_set_verbose(verbosity);
mean[lbd] = calc_mean(stat_vect.error, stat_vect.n_points);
rms[lbd] =
@@ -324,11 +320,11 @@
*lambda_min = lambda[lbd_min];
#endif
- G_message(_("Results into a table:"));
- G_message(_(" lambda | mean | rms |"));
+ G_message(_("Table of results:"));
+ fprintf(stdout, _(" lambda | mean | rms |\n"));
- G_message(_(" %-10.5f| %-12.4f| %-12.4f|"), lambda[lbd],
- mean[lbd], rms[lbd]);
+ fprintf(stdout, " %9.5f | %10.4f | %10.4f |\n", lambda[lbd],
+ mean[lbd], rms[lbd]);
G_free_vector(mean);
