[GRASS-SVN] r50802 - grass/trunk/scripts/i.landsat.rgb
Mon Feb 13 11:26:11 EST 2012
Author: neteler
Date: 2012-02-13 08:26:10 -0800 (Mon, 13 Feb 2012)
New Revision: 50802
Added:
   grass/trunk/scripts/i.landsat.rgb/i_landsat_rgb_corrected.jpg
   grass/trunk/scripts/i.landsat.rgb/i_landsat_rgb_uncorrected.jpg
   grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.html
   grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
example added
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.html
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.html	2012-02-13 16:24:10 UTC (rev 50801)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.html	2012-02-13 16:26:10 UTC (rev 50802)
@@ -3,10 +3,12 @@
 <em>i.landsat.rgb</em> auto-balances and enhances the color channels of a
 LANDSAT RGB image to provide a more natural color mixture. Only the color
 table of each image band is modified, the base data remains untouched.
-<p>The module works by calculating a histogram for each color channel and
+<p>
+The module works by calculating a histogram for each color channel and
 removing an adjustable amount of outliers from either end before recalibrating
 the color scale with <em>r.colors</em>.
-<p>It will work with any 8-bit RGB imagery set and the script is easily modified
+<p>
+It will work with any 8-bit RGB imagery set and the script is easily modified
 to work with other datasets of greater band-depth.
 <h2>NOTES</h2>
@@ -15,24 +17,39 @@
 flag to preserve the relative color scaling. You will have to experiment
 with the different options to find a setting that works best for your
 particular imagery.
-<p>The <b>strength</b> option should generally be set in the 90-99 range. The
+<p>
+The <b>strength</b> option should generally be set in the 90-99 range. The
 lower the number, the more saturated the image becomes. It represents the
 percentage cut-off for the top end of the color histogram curve. The lower
 end is fixed at 2% of the area under the curve.
-<p>For quicker execution of this module on large images you can achieve largely
+<p>
+For quicker execution of this module on large images you can achieve largely
 similar results by switching to a coarser resolution before the running of
 the module (using <em>g.region</em>) and then back to the original resolution
 afterwards.
 <h2>EXAMPLE</h2>
-North Carolina sample dataset:
+North Carolina sample dataset example:
 <div class="code"><pre>
-g.region rast=lsat7_2002_10
-i.landsat.rgb blue=lsat7_2002_10 green=lsat7_2002_20 red=lsat7_2002_30
+g.region rast=lsat7_2002_10 -p
+d.rgb blue=lsat7_2002_10 green=lsat7_2002_20 red=lsat7_2002_30
+d.barscale at=55.312500,93.125000 bcolor=white tcolor=black -t
+i.landsat.rgb blue=lsat7_2002_10 green=lsat7_2002_20 red=lsat7_2002_30 strength=95
 </pre></div>
+<center>
+<img src="i_landsat_rgb_uncorrected.jpg" alt="Uncorrected RGB composite of Landsat ETM channels B/G/R"><br>
+Uncorrected RGB composite of Landsat ETM channels B/G/R
+<p>
+<img src="i_landsat_rgb_corrected.jpg" alt="Color corrected RGB composite of Landsat ETM channels B/G/R"><br>
+Color corrected RGB composite of Landsat ETM channels B/G/R
+</center>
 <h2>TODO</h2>
 The <b>strength</b> option requires further refinement.
@@ -51,7 +68,7 @@
 <h2>AUTHORS</h2>
-Markus Neteler<br>
+Markus Neteler, Trento, Italy<br>
 M. Hamish Bowman, Dept. Marine Science, Otago University, New Zealand
 <p><i>Last changed: $Date$</i>
Property changes on: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: grass/trunk/scripts/i.landsat.rgb/i_landsat_rgb_corrected.jpg
(Binary files differ)
Property changes on: grass/trunk/scripts/i.landsat.rgb/i_landsat_rgb_corrected.jpg
   + image/jpeg
Added: grass/trunk/scripts/i.landsat.rgb/i_landsat_rgb_uncorrected.jpg
Property changes on: grass/trunk/scripts/i.landsat.rgb/i_landsat_rgb_uncorrected.jpg
   + image/jpeg
