[GRASS-SVN] r50806 -
grass/branches/develbranch_6/vector/lidar/v.surf.bspline
svn_grass at osgeo.org
Mon Feb 13 18:34:14 EST 2012
Author: hamish
Date: 2012-02-13 15:34:14 -0800 (Mon, 13 Feb 2012)
New Revision: 50806
grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c
change default lambda_i to 0.01 before it ruins any more results (see #1088; setting it to '1' was apparently a mistake as seen by the range of values tested for the cross-validation)
Modified: grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c
--- grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c 2012-02-13 23:31:01 UTC (rev 50805)
+++ grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c 2012-02-13 23:34:14 UTC (rev 50806)
@@ -142,7 +142,7 @@
lambda_f_opt->type = TYPE_DOUBLE;
lambda_f_opt->required = NO;
lambda_f_opt->description = _("Tykhonov regularization parameter (affects smoothing)");
- lambda_f_opt->answer = "1";
+ lambda_f_opt->answer = "0.01";
lambda_f_opt->guisection = _("Settings");
dfield_opt = G_define_standard_option(G_OPT_V_FIELD);
