[GRASS-SVN] r50824 - grass/trunk/scripts/r.fillnulls
svn_grass at osgeo.org
Wed Feb 15 20:43:49 EST 2012
Author: hamish
Date: 2012-02-15 17:43:49 -0800 (Wed, 15 Feb 2012)
New Revision: 50824
grass/trunk/scripts/r.fillnulls/r.fillnulls.py
explicitly list lambda in options so it is easier to know how to change it
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2012-02-15 23:12:34 UTC (rev 50823)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2012-02-16 01:43:49 UTC (rev 50824)
@@ -199,12 +199,12 @@
grass.run_command('r.resamp.bspline', input = input, mask = usermask,
output = tmp1 + '_filled', method = method,
se = 3 * reg['ewres'], sn = 3 * reg['nsres'],
- flags = 'n')
+ _lambda = 0.01, flags = 'n')
else:
- flags = 'n')
# restoring user's mask, if present:
if grass.find_file(usermask, mapset = mapset)['file']:
