[GRASS-SVN] r50831 - grass/trunk/ps/ps.map
svn_grass at osgeo.org
Thu Feb 16 03:55:02 EST 2012
Author: hamish
Date: 2012-02-16 00:55:02 -0800 (Thu, 16 Feb 2012)
New Revision: 50831
grass/trunk/ps/ps.map/do_plt.c
allow drawing of line decorations entirely outside of the map window. This is deactivated for lat/lon as apparently it would bypass 180 longitude wrap-around safeguards.
Modified: grass/trunk/ps/ps.map/do_plt.c
--- grass/trunk/ps/ps.map/do_plt.c 2012-02-16 08:25:39 UTC (rev 50830)
+++ grass/trunk/ps/ps.map/do_plt.c 2012-02-16 08:55:02 UTC (rev 50831)
@@ -56,10 +56,34 @@
set_color(&pcolor, color_R, color_G, color_B);
set_ps_color(&pcolor);
set_line_width(width);
- start_line(e1, n1);
- sec_draw = 0;
- G_plot_line(e1, n1, e2, n2);
+ if (G_projection() == PROJECTION_LL) {
+ /* use the same method as the vlines instruction,
+ for completely out of region lines just move, don't put
+ the pen down. but the thing this method has going for it
+ is that for lat/lon (AFAIU) it draws the line twice,
+ so that at least one of them will go the desired way
+ around the sphere, and the other will be discarded.
+ (I think). But it means your self-defined lines need to
+ keep at least one little toe in the map box. --HB Feb2012 */
+ start_line(e1, n1);
+ sec_draw = 0;
+ G_plot_line(e1, n1, e2, n2);
+ else {
+ G_plot_where_xy(e1, n1, &x_int, &y_int);
+ llx = (double)x_int / 10.;
+ lly = (double)y_int / 10.;
+ G_plot_where_xy(e2, n2, &x_int, &y_int);
+ urx = (double)x_int / 10.;
+ ury = (double)y_int / 10.;
+ fprintf(PS.fp, " %.1f %.1f NM %.1f %.1f LN",
+ llx, lly, urx, ury);
fprintf(PS.fp, " stroke\n");
break;
