[GRASS-SVN] r50836 - grass/trunk/gui/wxpython/psmap
svn_grass at osgeo.org
Thu Feb 16 14:59:47 EST 2012
Author: annakrat
Date: 2012-02-16 11:59:47 -0800 (Thu, 16 Feb 2012)
New Revision: 50836
grass/trunk/gui/wxpython/psmap/dialogs.py
grass/trunk/gui/wxpython/psmap/frame.py
grass/trunk/gui/wxpython/psmap/instructions.py
grass/trunk/gui/wxpython/psmap/utils.py
wxGUI/wxpsmap: simplified method for coordinates conversion, changed parameter name (map is python built-in function)
Modified: grass/trunk/gui/wxpython/psmap/dialogs.py
--- grass/trunk/gui/wxpython/psmap/dialogs.py 2012-02-16 11:12:59 UTC (rev 50835)
+++ grass/trunk/gui/wxpython/psmap/dialogs.py 2012-02-16 19:59:47 UTC (rev 50836)
@@ -91,7 +91,7 @@
if key < wx.WXK_SPACE or key == wx.WXK_DELETE or key > 255:
event.Skip()
return
- if self.flag == 'DIGIT_ONLY' and chr(key) in string.digits + '.':
+ if self.flag == 'DIGIT_ONLY' and chr(key) in string.digits + '.-':
event.Skip()
return
## if self.flag == 'SCALE' and chr(key) in string.digits + ':':
@@ -259,7 +259,7 @@
northingLabel = wx.StaticText(panel, id = wx.ID_ANY, label = "N:")
panel.position['eCtrl'] = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
panel.position['nCtrl'] = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
- east, north = PaperMapCoordinates(map = self.instruction[self.mapId], x = dialogDict['where'][0], y = dialogDict['where'][1], paperToMap = True)
+ east, north = PaperMapCoordinates(mapInstr = self.instruction[self.mapId], x = dialogDict['where'][0], y = dialogDict['where'][1], paperToMap = True)
panel.position['eCtrl'].SetValue(str(east))
panel.position['nCtrl'].SetValue(str(north))
@@ -3687,7 +3687,7 @@
map = self.instruction.FindInstructionByType('initMap')
self.mapId = map.id
- self.textDict['east'], self.textDict['north'] = PaperMapCoordinates(map = map, x = self.textDict['where'][0], y = self.textDict['where'][1], paperToMap = True)
+ self.textDict['east'], self.textDict['north'] = PaperMapCoordinates(mapInstr = map, x = self.textDict['where'][0], y = self.textDict['where'][1], paperToMap = True)
notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
self.textPanel = self._textPanel(notebook)
@@ -4015,7 +4015,7 @@
else:
self.textDict['north'] = self.textDict['north']
- self.textDict['where'] = PaperMapCoordinates(map = self.instruction[self.mapId], x = float(self.textDict['east']),
+ self.textDict['where'] = PaperMapCoordinates(mapInstr = self.instruction[self.mapId], x = float(self.textDict['east']),
y = float(self.textDict['north']), paperToMap = False)
#rotation
if self.rotCtrl.GetValue():
@@ -4078,7 +4078,7 @@
self.mapId = map.id
- self.imageDict['east'], self.imageDict['north'] = PaperMapCoordinates(map = map, x = self.imageDict['where'][0], y = self.imageDict['where'][1], paperToMap = True)
+ self.imageDict['east'], self.imageDict['north'] = PaperMapCoordinates(mapInstr = map, x = self.imageDict['where'][0], y = self.imageDict['where'][1], paperToMap = True)
self.imagePanelName = imagePanelName
@@ -4429,7 +4429,7 @@
else:
self.imageDict['north'] = self.imageDict['north']
- x, y = PaperMapCoordinates(map = self.instruction[self.mapId], x = float(self.imageDict['east']),
+ x, y = PaperMapCoordinates(mapInstr = self.instruction[self.mapId], x = float(self.imageDict['east']),
y = float(self.imageDict['north']), paperToMap = False)
#rotation
@@ -4539,7 +4539,7 @@
mapObj = self.instruction.FindInstructionByType('initMap')
self.mapId = mapObj.id
- self.pointDict['east'], self.pointDict['north'] = PaperMapCoordinates(map = mapObj, x = self.pointDict['where'][0], y = self.pointDict['where'][1], paperToMap = True)
+ self.pointDict['east'], self.pointDict['north'] = PaperMapCoordinates(mapInstr = mapObj, x = self.pointDict['where'][0], y = self.pointDict['where'][1], paperToMap = True)
self.pointPanelName = pointPanelName
@@ -4757,7 +4757,7 @@
else:
self.pointDict['north'] = self.pointDict['north']
- x, y = PaperMapCoordinates(map = self.instruction[self.mapId], x = float(self.pointDict['east']),
+ x, y = PaperMapCoordinates(mapInstr = self.instruction[self.mapId], x = float(self.pointDict['east']),
y = float(self.pointDict['north']), paperToMap = False)
#rotation
@@ -4923,11 +4923,11 @@
self.mapId = mapInstr.id
point1 = self.rectDict['where'][0]
point2 = self.rectDict['where'][1]
- self.rectDict['east1'], self.rectDict['north1'] = PaperMapCoordinates(map = mapInstr,
+ self.rectDict['east1'], self.rectDict['north1'] = PaperMapCoordinates(mapInstr = mapInstr,
x = point1[0],
y = point1[1],
paperToMap = True)
- self.rectDict['east2'], self.rectDict['north2'] = PaperMapCoordinates(map = mapInstr,
+ self.rectDict['east2'], self.rectDict['north2'] = PaperMapCoordinates(mapInstr = mapInstr,
x = point2[0],
y = point2[1],
paperToMap = True)
Modified: grass/trunk/gui/wxpython/psmap/frame.py
--- grass/trunk/gui/wxpython/psmap/frame.py 2012-02-16 11:12:59 UTC (rev 50835)
+++ grass/trunk/gui/wxpython/psmap/frame.py 2012-02-16 19:59:47 UTC (rev 50836)
@@ -1210,21 +1210,21 @@
instr = self.instruction[item.id]
if itemType in ('line', 'rectangle'):
if itemType == 'line':
- e1, n1 = PaperMapCoordinates(map = self.instruction[mapId], x = instr['where'][0][0],
+ e1, n1 = PaperMapCoordinates(mapInstr = self.instruction[mapId], x = instr['where'][0][0],
y = instr['where'][0][1], paperToMap = True)
- e2, n2 = PaperMapCoordinates(map = self.instruction[mapId], x = instr['where'][1][0],
+ e2, n2 = PaperMapCoordinates(mapInstr = self.instruction[mapId], x = instr['where'][1][0],
y = instr['where'][1][1], paperToMap = True)
else:
- e1, n1 = PaperMapCoordinates(map = self.instruction[mapId], x = instr['rect'].GetLeft(),
+ e1, n1 = PaperMapCoordinates(mapInstr = self.instruction[mapId], x = instr['rect'].GetLeft(),
y = instr['rect'].GetTop(), paperToMap = True)
- e2, n2 = PaperMapCoordinates(map = self.instruction[mapId], x = instr['rect'].GetRight(),
+ e2, n2 = PaperMapCoordinates(mapInstr = self.instruction[mapId], x = instr['rect'].GetRight(),
y = instr['rect'].GetBottom(), paperToMap = True)
instr['east1'] = e1
instr['north1'] = n1
instr['east2'] = e2
instr['north2'] = n2
else:
- e, n = PaperMapCoordinates(map = self.instruction[mapId], x = instr['where'][0],
+ e, n = PaperMapCoordinates(mapInstr = self.instruction[mapId], x = instr['where'][0],
y = instr['where'][1], paperToMap = True)
instr['east'], instr['north'] = e, n
Modified: grass/trunk/gui/wxpython/psmap/instructions.py
--- grass/trunk/gui/wxpython/psmap/instructions.py 2012-02-16 11:12:59 UTC (rev 50835)
+++ grass/trunk/gui/wxpython/psmap/instructions.py 2012-02-16 19:59:47 UTC (rev 50836)
@@ -869,7 +869,7 @@
except(IndexError, ValueError):
GError(_("Failed to read instruction %s") % instruction)
return False
- instr['where'] = PaperMapCoordinates(map = map, x = instr['east'], y = instr['north'], paperToMap = False)
+ instr['where'] = PaperMapCoordinates(mapInstr = map, x = instr['east'], y = instr['north'], paperToMap = False)
self.instruction.update(instr)
return True
@@ -937,7 +937,7 @@
instr['size'] = BBoxAfterRotation(instr['size'][0], instr['size'][1], instr['rotate'])
self.ChangeRefPoint(toCenter = False)
- instr['where'] = PaperMapCoordinates(map = mapInstr, x = self.instruction['east'],
+ instr['where'] = PaperMapCoordinates(mapInstr = mapInstr, x = self.instruction['east'],
y = self.instruction['north'], paperToMap = False)
w = self.unitConv.convert(value = instr['size'][0], fromUnit = 'point', toUnit = 'inch')
h = self.unitConv.convert(value = instr['size'][1], fromUnit = 'point', toUnit = 'inch')
@@ -955,18 +955,18 @@
mapId = mapInstr.id
if toCenter:
center = self.instruction['rect'].GetCentre()
- ENCenter = PaperMapCoordinates(map = self.settings[mapId],
+ ENCenter = PaperMapCoordinates(mapInstr = self.settings[mapId],
x = center[0], y = center[1], paperToMap = True)
self.instruction['east'], self.instruction['north'] = ENCenter
else:
- x, y = PaperMapCoordinates(map = self.settings[mapId], x = self.instruction['east'],
+ x, y = PaperMapCoordinates(mapInstr = self.settings[mapId], x = self.instruction['east'],
w = self.unitConv.convert(value = self.instruction['size'][0], fromUnit = 'point', toUnit = 'inch')
h = self.unitConv.convert(value = self.instruction['size'][1], fromUnit = 'point', toUnit = 'inch')
x -= w * self.instruction['scale'] / 2
y -= h * self.instruction['scale'] / 2
- e, n = PaperMapCoordinates(map = self.settings[mapId], x = x, y = y, paperToMap = True)
+ e, n = PaperMapCoordinates(mapInstr = self.settings[mapId], x = x, y = y, paperToMap = True)
self.instruction['east'], self.instruction['north'] = e, n
def GetImageOrigSize(self, imagePath):
@@ -1067,7 +1067,7 @@
return False
w = h = self.unitConv.convert(value = instr['size'], fromUnit = 'point', toUnit = 'inch')
instr['rect'] = Rect2D(x = float(instr['where'][0]) - w / 2, y = float(instr['where'][1] - h / 2),
@@ -1122,9 +1122,9 @@
return False
- e1, n1 = PaperMapCoordinates(map = mapInstr, x = self.instruction['east1'],
+ e1, n1 = PaperMapCoordinates(mapInstr = mapInstr, x = self.instruction['east1'],
y = self.instruction['north1'], paperToMap = False)
- e2, n2 = PaperMapCoordinates(map = mapInstr, x = self.instruction['east2'],
+ e2, n2 = PaperMapCoordinates(mapInstr = mapInstr, x = self.instruction['east2'],
y = self.instruction['north2'], paperToMap = False)
instr['where'] = [wx.Point2D(e1, n1), wx.Point2D(e2, n2)]
instr['rect'] = Rect2DPP(instr['where'][0], instr['where'][1])
@@ -1181,9 +1181,9 @@
return False
instr['rect'] = Rect2DPP(wx.Point2D(e1, n1), wx.Point2D(e2, n2))
Modified: grass/trunk/gui/wxpython/psmap/utils.py
--- grass/trunk/gui/wxpython/psmap/utils.py 2012-02-16 11:12:59 UTC (rev 50835)
+++ grass/trunk/gui/wxpython/psmap/utils.py 2012-02-16 19:59:47 UTC (rev 50836)
@@ -154,50 +154,44 @@
else:
return None
-def PaperMapCoordinates(map, x, y, paperToMap = True):
- """!Converts paper (inch) coordinates -> map coordinates"""
- unitConv = UnitConversion()
- currRegionDict = grass.region()
- cornerEasting, cornerNorthing = currRegionDict['w'], currRegionDict['n']
- xMap = map['rect'][0]
- yMap = map['rect'][1]
- widthMap = map['rect'][2] * 0.0254 # to meter
- heightMap = map['rect'][3] * 0.0254
- xScale = widthMap / abs(currRegionDict['w'] - currRegionDict['e'])
- yScale = heightMap / abs(currRegionDict['n'] - currRegionDict['s'])
- currScale = (xScale + yScale) / 2
- if not paperToMap:
- textEasting, textNorthing = x, y
- eastingDiff = textEasting - cornerEasting
- if currRegionDict['w'] > currRegionDict['e']:
- eastingDiff = - eastingDiff
- else:
- eastingDiff = eastingDiff
+def PaperMapCoordinates(mapInstr, x, y, paperToMap = True):
+ """!Converts paper (inch) coordinates <-> map coordinates.
- northingDiff = textNorthing - cornerNorthing
- if currRegionDict['n'] > currRegionDict['s']:
- northingDiff = - northingDiff
+ @param mapInstr map frame instruction
+ @param x,y paper coords in inches or mapcoords in map units
+ @param paperToMap specify conversion direction
+ region = grass.region()
+ mapWidthPaper = mapInstr['rect'].GetWidth()
+ mapHeightPaper = mapInstr['rect'].GetHeight()
+ mapWidthEN = region['e'] - region['w']
+ mapHeightEN = region['n'] - region['s']
+ if paperToMap:
+ diffX = x - mapInstr['rect'].GetX()
+ diffY = y - mapInstr['rect'].GetY()
+ diffEW = diffX * mapWidthEN / mapWidthPaper
+ diffNS = diffY * mapHeightEN / mapHeightPaper
+ e = region['w'] + diffEW
+ n = region['n'] - diffNS
+ if projInfo()['proj'] == 'll':
+ return e, n
else:
- northingDiff = northingDiff
+ return int(e), int(n)
- xPaper = xMap + unitConv.convert(value = eastingDiff, fromUnit = 'meter', toUnit = 'inch') * currScale
- yPaper = yMap + unitConv.convert(value = northingDiff, fromUnit = 'meter', toUnit = 'inch') * currScale
- return xPaper, yPaper
else:
- if currRegionDict['w'] < currRegionDict['e']:
- eastingDiff = (x - xMap)
- else:
- eastingDiff = (xMap - x)
- if currRegionDict['n'] < currRegionDict['s']:
- northingDiff = (y - yMap)
- else:
- northingDiff = (yMap - y)
+ diffEW = x - region['w']
+ diffNS = region['n'] - y
+ diffX = mapWidthPaper * diffEW / mapWidthEN
+ diffY = mapHeightPaper * diffNS / mapHeightEN
+ xPaper = mapInstr['rect'].GetX() + diffX
+ yPaper = mapInstr['rect'].GetY() + diffY
- textEasting = cornerEasting + unitConv.convert(value = eastingDiff, fromUnit = 'inch', toUnit = 'meter') / currScale
- textNorthing = cornerNorthing + unitConv.convert(value = northingDiff, fromUnit = 'inch', toUnit = 'meter') / currScale
- return int(textEasting), int(textNorthing)
+ return xPaper, yPaper
def AutoAdjust(self, scaleType, rect, map = None, mapType = None, region = None):
"""!Computes map scale, center and map frame rectangle to fit region (scale is not fixed)"""
currRegionDict = {}
