[GRASS-SVN] r50854 - in grass/trunk: . mswindows
svn_grass at osgeo.org
Fri Feb 17 17:53:09 EST 2012
Author: martinl
Date: 2012-02-17 14:53:08 -0800 (Fri, 17 Feb 2012)
New Revision: 50854
Added:
grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
grass/trunk/mswindows/GRASS-Packager.bat.tmpl
grass/trunk/mswindows/Makefile
Removed:
grass/trunk/Makefile
wingrass: first step for generic GRASS-Packager and GRASS-Installer files
Modified: grass/trunk/Makefile
--- grass/trunk/Makefile 2012-02-17 21:23:59 UTC (rev 50853)
+++ grass/trunk/Makefile 2012-02-17 22:53:08 UTC (rev 50854)
@@ -44,7 +44,8 @@
gui \
visualization \
locale \
- macosx
+ macosx \
+ mswindows
SUBDIRS = $(DIRS)
Deleted: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi 2012-02-17 21:23:59 UTC (rev 50853)
+++ grass/trunk/mswindows/GRASS-Installer.nsi 2012-02-17 22:53:08 UTC (rev 50854)
@@ -1,1020 +0,0 @@
-;GRASS Installer for Windows
-;Written by Marco Pasetti
-;Updated for OSGeo4W by Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
-;Last Update: $Id$
-;Mail to: grass-dev at lists.osgeo.org
-;Define the source path of the demolocation files
-!define DEMOLOCATION_PATH "c:\osgeo4w\usr\src\grass_trunk\demolocation"
-;Define the source of the patched msys.bat
-!define MSYS_BATCH "C:\OSGeo4W\usr\src\grass_trunk\mswindows\osgeo4w\msys.bat"
-;Select if you are building a "Development Version" (Devel) or a "Release Version" (Release) of the GRASS Installer
-!define INSTALLER_TYPE "Devel"
-;set compression configuration
-SetCompressor /SOLID lzma
-SetCompressorDictSize 64
-;Version variables
-!define SVN_REVISION "36599"
-!define BINARY_REVISION "1"
-!if ${INSTALLER_TYPE} == "Release"
- !define VERSION_NUMBER "7.0.0"
- !define GRASS_COMMAND "grass70"
- !define GRASS_BASE "GRASS 7.0"
-!else
- !define VERSION_NUMBER "7.0.svn"
- !define GRASS_COMMAND "grass70svn"
- !define GRASS_BASE "GRASS 7.0.svn"
-!endif
-;Don't modify the following lines
-;NSIS Includes
-!include "MUI2.nsh"
-!include "LogicLib.nsh"
-;Set the installer variables, depending on the selected version to build
-!define PACKAGE_FOLDER ".\GRASS-70-Package"
- !define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
- !define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-${BINARY_REVISION}"
- !define CHECK_INSTALL_NAME "GRASS 70"
-!else
- !define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
- !define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
- !define CHECK_INSTALL_NAME "GRASS 70 SVN"
-!endif
-;Publisher variables
-!define PUBLISHER "GRASS Development Team"
-!define WEB_SITE "http://grass.osgeo.org"
-!define WIKI_PAGE "http://grass.osgeo.org/wiki"
-;General Definitions
-;Name of the application shown during install
-Name "${DISPLAYED_NAME}"
-;Name of the output file (installer executable)
-OutFile "${INSTALLER_NAME}"
-;Define installation folder
-InstallDir "$PROGRAMFILES\${GRASS_BASE}"
-;Request application privileges for Windows Vista
-RequestExecutionLevel admin
-;Tell the installer to show Install and Uninstall details as default
-ShowInstDetails show
-ShowUnInstDetails show
-;StrReplace Function
-;Replaces all ocurrences of a given needle within a haystack with another string
-;Written by dandaman32
-Var STR_REPLACE_VAR_0
-Var STR_REPLACE_VAR_1
-Var STR_REPLACE_VAR_2
-Var STR_REPLACE_VAR_3
-Var STR_REPLACE_VAR_4
-Var STR_REPLACE_VAR_5
-Var STR_REPLACE_VAR_6
-Var STR_REPLACE_VAR_7
-Var STR_REPLACE_VAR_8
-Function StrReplace
- Exch $STR_REPLACE_VAR_2
- Exch 1
- Exch $STR_REPLACE_VAR_1
- Exch 2
- Exch $STR_REPLACE_VAR_0
- StrCpy $STR_REPLACE_VAR_3 -1
- StrLen $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_1
- StrLen $STR_REPLACE_VAR_6 $STR_REPLACE_VAR_0
- loop:
- IntOp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_3 + 1
- StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_3
- StrCmp $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_1 found
- StrCmp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_6 done
- Goto loop
- found:
- StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_3
- IntOp $STR_REPLACE_VAR_8 $STR_REPLACE_VAR_3 + $STR_REPLACE_VAR_4
- StrCpy $STR_REPLACE_VAR_7 $STR_REPLACE_VAR_0 "" $STR_REPLACE_VAR_8
- StrCpy $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_5$STR_REPLACE_VAR_2$STR_REPLACE_VAR_7
- Goto loop
- done:
- Pop $STR_REPLACE_VAR_1 ; Prevent "invalid opcode" errors and keep the
- Pop $STR_REPLACE_VAR_1 ; stack as it was before the function was called
-FunctionEnd
-!macro _strReplaceConstructor OUT NEEDLE NEEDLE2 HAYSTACK
- Push "${HAYSTACK}"
- Push "${NEEDLE}"
- Push "${NEEDLE2}"
- Call StrReplace
- Pop "${OUT}"
-!macroend
-!define StrReplace '!insertmacro "_strReplaceConstructor"'
-;.onInit Function (called when the installer is nearly finished initializing)
-;Check if GRASS is already installed on the system and, if yes, what version and binary release;
-;depending on that, select the install procedure:
-;1. first installation = if GRASS is not already installed
-;install GRASS asking for the install PATH
-;2. upgrade installation = if an older release of GRASS is already installed
-;call the uninstaller of the currently installed GRASS release
-;if the uninstall procedure succeeded, call the current installer without asking for the install PATH
-;GRASS will be installed in the same PATH of the previous installation
-;3. downgrade installation = if a newer release of GRASS is already installed
-;4. repair installation = if the same release of GRASS is already installed
-;if the uninstall procedure succeeded, call the current installer asking for the install PATH
-;the currently installed release of GRASS is defined by the variable $INSTALLED_VERSION = $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
-Function .onInit
- Var /GLOBAL ASK_FOR_PATH
- StrCpy $ASK_FOR_PATH "YES"
- Var /GLOBAL UNINSTALL_STRING
- Var /GLOBAL INSTALL_PATH
- Var /GLOBAL INSTALLED_VERSION_NUMBER
- Var /GLOBAL INSTALLED_SVN_REVISION
- Var /GLOBAL INSTALLED_BINARY_REVISION
- Var /GLOBAL DISPLAYED_INSTALLED_VERSION
- Var /GLOBAL MESSAGE_0_
- Var /GLOBAL MESSAGE_1_
- Var /GLOBAL MESSAGE_2_
- Var /GLOBAL MESSAGE_3_
- Var /GLOBAL R_HKLM_INSTALL_PATH
- Var /GLOBAL R_HKCU_INSTALL_PATH
- ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
- ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
- ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
- ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
- ReadRegStr $R_HKLM_INSTALL_PATH HKLM "Software\R-core\R" "InstallPath"
- ReadRegStr $R_HKCU_INSTALL_PATH HKCU "Software\R-core\R" "InstallPath"
- ${If} $INSTALLED_SVN_REVISION == ""
- ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
- ${EndIf}
- ReadRegStr $INSTALLED_BINARY_REVISION HKLM "Software\${GRASS_BASE}" "BinaryRevision"
- StrCpy $MESSAGE_0_ "${CHECK_INSTALL_NAME} is already installed on your system.$\r$\n"
- StrCpy $MESSAGE_0_ "$MESSAGE_0_$\r$\n"
- !if ${INSTALLER_TYPE} == "Release"
- ${If} $INSTALLED_BINARY_REVISION == ""
- StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER"
- ${Else}
- StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_BINARY_REVISION"
- ${EndIf}
- !else
- StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_SVN_REVISION-$INSTALLED_BINARY_REVISION"
- !endif
- StrCpy $MESSAGE_0_ "$MESSAGE_0_The installed release is $DISPLAYED_INSTALLED_VERSION$\r$\n"
- StrCpy $MESSAGE_1_ "$MESSAGE_0_$\r$\n"
- StrCpy $MESSAGE_1_ "$MESSAGE_1_You are going to install a newer release of ${CHECK_INSTALL_NAME}$\r$\n"
- StrCpy $MESSAGE_1_ "$MESSAGE_1_$\r$\n"
- StrCpy $MESSAGE_1_ "$MESSAGE_1_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
- StrCpy $MESSAGE_1_ "$MESSAGE_1_ and install ${DISPLAYED_NAME} or Cancel to quit."
- StrCpy $MESSAGE_2_ "$MESSAGE_0_$\r$\n"
- StrCpy $MESSAGE_2_ "$MESSAGE_2_You are going to install an older release of ${CHECK_INSTALL_NAME}$\r$\n"
- StrCpy $MESSAGE_2_ "$MESSAGE_2_$\r$\n"
- StrCpy $MESSAGE_2_ "$MESSAGE_2_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
- StrCpy $MESSAGE_2_ "$MESSAGE_2_ and install ${DISPLAYED_NAME} or Cancel to quit."
- StrCpy $MESSAGE_3_ "$MESSAGE_0_$\r$\n"
- StrCpy $MESSAGE_3_ "$MESSAGE_3_This is the latest release available.$\r$\n"
- StrCpy $MESSAGE_3_ "$MESSAGE_3_$\r$\n"
- StrCpy $MESSAGE_3_ "$MESSAGE_3_Press OK to reinstall ${DISPLAYED_NAME} or Cancel to quit."
- IntOp $INSTALLED_SVN_REVISION $INSTALLED_SVN_REVISION * 1
- IntOp $INSTALLED_BINARY_REVISION $INSTALLED_BINARY_REVISION * 1
- IntOp $INSTALLED_VERSION $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
- !define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
- ${If} $INSTALLED_VERSION_NUMBER == ""
- ${Else}
- ${If} $INSTALLED_VERSION < ${VERSION}
- MessageBox MB_OKCANCEL "$MESSAGE_1_" IDOK upgrade IDCANCEL quit_upgrade
- upgrade:
- StrCpy $ASK_FOR_PATH "NO"
- ExecWait '"$UNINSTALL_STRING" _?=$INSTALL_PATH' $0
- Goto continue_upgrade
- quit_upgrade:
- Abort
- continue_upgrade:
- ${ElseIf} $INSTALLED_VERSION > ${VERSION}
- MessageBox MB_OKCANCEL "$MESSAGE_2_" IDOK downgrade IDCANCEL quit_downgrade
- downgrade:
- Goto continue_downgrade
- quit_downgrade:
- Abort
- continue_downgrade:
- ${ElseIf} $INSTALLED_VERSION = ${VERSION}
- MessageBox MB_OKCANCEL "$MESSAGE_3_" IDOK reinstall IDCANCEL quit_reinstall
- reinstall:
- Goto continue_reinstall
- quit_reinstall:
- Abort
- continue_reinstall:
- ${EndIf}
- ${EndIf}
- ${Else}
- ${If} $0 = 0
- ${Else}
- Abort
- ${EndIf}
- ${EndIf}
-FunctionEnd
-;CheckUpdate Function
-;Check if to show the MUI_PAGE_DIRECTORY during the installation (to ask for the install PATH)
-Function CheckUpdate
- ${If} $ASK_FOR_PATH == "NO"
- Abort
- ${EndIf}
-FunctionEnd
-;CheckInstDir Function
-;this is commented out, because the installation path should be in $PROGRAMFILES
-;Check if GRASS is going to be installed in a directory containing spaces
-;if yes, show a warning message
-;Function CheckInstDir
-; Var /GLOBAL INSTDIR_TEST
-; Var /GLOBAL INSTDIR_LENGHT
-; Var /GLOBAL INSTDIR_TEST_LENGHT
-; Var /GLOBAL MESSAGE_CHKINST_
-; StrCpy $MESSAGE_CHKINST_ "WARNING: you are about to install GRASS into a directory that has spaces$\r$\n"
-; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_in either its name or the path of directories leading up to it.$\r$\n"
-; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_Some functionalities of GRASS might be hampered by this. We would highly$\r$\n"
-; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_appreciate if you tried and reported any problems, so that we can fix them.$\r$\n"
-; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_However, if you want to avoid any such issues, we recommend that you$\r$\n"
-; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_choose a simple installation path without spaces, such as: C:\${GRASS_BASE}.$\r$\n"
-; ${StrReplace} "$INSTDIR_TEST" " " "" "$INSTDIR"
-; StrLen $INSTDIR_LENGHT "$INSTDIR"
-; StrLen $INSTDIR_TEST_LENGHT "$INSTDIR_TEST"
-; ${If} $INSTDIR_TEST_LENGHT < $INSTDIR_LENGHT
-; MessageBox MB_OK|MB_ICONEXCLAMATION "$MESSAGE_CHKINST_"
-; ${EndIf}
-;FunctionEnd
-;ReplaceLineString Function
-;Replace String in an existing file
-; code taken from http://nsis.sourceforge.net/Replace_line_that_starts_with_specified_string
-Function ReplaceLineStr
- Exch $R0 ; string to replace that whole line with
- Exch
- Exch $R1 ; string that line should start with
- Exch
- Exch 2
- Exch $R2 ; file
- Push $R3 ; file handle
- Push $R4 ; temp file
- Push $R5 ; temp file handle
- Push $R6 ; global
- Push $R7 ; input string length
- Push $R8 ; line string length
- Push $R9 ; global
- StrLen $R7 $R1
- GetTempFileName $R4
- FileOpen $R5 $R4 w
- FileOpen $R3 $R2 r
- ReadLoop:
- ClearErrors
- FileRead $R3 $R6
- IfErrors Done
- StrLen $R8 $R6
- StrCpy $R9 $R6 $R7 -$R8
- StrCmp $R9 $R1 0 +3
- FileWrite $R5 "$R0$\r$\n"
- Goto ReadLoop
- FileWrite $R5 $R6
- Goto ReadLoop
- Done:
- FileClose $R3
- FileClose $R5
- SetDetailsPrint none
- Delete $R2
- Rename $R4 $R2
- SetDetailsPrint both
- Pop $R9
- Pop $R8
- Pop $R7
- Pop $R6
- Pop $R5
- Pop $R4
- Pop $R3
- Pop $R2
- Pop $R1
- Pop $R0
-FunctionEnd
-;Interface Settings
-!define MUI_ABORTWARNING
-!define MUI_ICON ".\Installer-Files\Install_GRASS.ico"
-!define MUI_UNICON ".\Installer-Files\Uninstall_GRASS.ico"
-!define MUI_HEADERIMAGE_BITMAP_NOSTETCH ".\Installer-Files\InstallHeaderImage.bmp"
-!define MUI_HEADERIMAGE_UNBITMAP_NOSTRETCH ".\Installer-Files\UnInstallHeaderImage.bmp"
-!define MUI_WELCOMEFINISHPAGE_BITMAP ".\Installer-Files\WelcomeFinishPage.bmp"
-!define MUI_UNWELCOMEFINISHPAGE_BITMAP ".\Installer-Files\UnWelcomeFinishPage.bmp"
-;Installer Pages
-!insertmacro MUI_PAGE_WELCOME
-;These indented statements modify settings for MUI_PAGE_LICENSE
-; (with thanks to Ubuntu)
- !define MUI_LICENSEPAGE_TEXT_BOTTOM "GRASS is software libre. You are encouraged and legally \
- entitled to copy, reinstall, modify, and redistribute this program \
- for yourself and your friends under the terms of the GPL. Happy \
- mapping!"
- !define MUI_LICENSEPAGE_BUTTON "Next >"
-!insertmacro MUI_PAGE_LICENSE "${PACKAGE_FOLDER}\GPL.TXT"
-!define MUI_PAGE_CUSTOMFUNCTION_PRE CheckUpdate
-!insertmacro MUI_PAGE_DIRECTORY
-;Page custom CheckInstDir
-!insertmacro MUI_PAGE_COMPONENTS
-!insertmacro MUI_PAGE_INSTFILES
-;These indented statements modify settings for MUI_PAGE_FINISH
- !define MUI_FINISHPAGE_NOAUTOCLOSE
- !define MUI_FINISHPAGE_RUN
- !define MUI_FINISHPAGE_RUN_NOTCHECKED
- !define MUI_FINISHPAGE_RUN_TEXT "Launch GRASS GIS"
- !define MUI_FINISHPAGE_RUN_FUNCTION "LaunchGrass"
- !define MUI_FINISHPAGE_SHOWREADME
- !define MUI_FINISHPAGE_SHOWREADME_NOTCHECKED
- !define MUI_FINISHPAGE_SHOWREADME_TEXT "View the reference manual"
- !define MUI_FINISHPAGE_SHOWREADME_FUNCTION "ViewReadme"
-!insertmacro MUI_PAGE_FINISH
-!insertmacro MUI_UNPAGE_WELCOME
-!insertmacro MUI_UNPAGE_CONFIRM
-!insertmacro MUI_UNPAGE_INSTFILES
-!insertmacro MUI_UNPAGE_FINISH
-;Language files
-!insertmacro MUI_LANGUAGE "English"
-;launch Grass Gis by exit the installation wizard
-Function LaunchGrass
- ExecShell "" "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
-FunctionEnd
-;launch reference manual by exit the installation wizard
-Function ViewReadme
- ExecShell "open" "$INSTDIR\docs\html\index.html"
-FunctionEnd
-;Installer Sections
-;Declares the variables for optional Sample Data Sections
-Var /GLOBAL HTTP_PATH
-Var /GLOBAL ARCHIVE_NAME
-Var /GLOBAL EXTENDED_ARCHIVE_NAME
-Var /GLOBAL ORIGINAL_UNTAR_FOLDER
-Var /GLOBAL CUSTOM_UNTAR_FOLDER
-Var /GLOBAL ARCHIVE_SIZE_KB
-Var /GLOBAL ARCHIVE_SIZE_MB
-Var /GLOBAL DOWNLOAD_MESSAGE_
-Section "GRASS" SecGRASS
- SectionIn RO
- ;Set the INSTALL_DIR variable
- Var /GLOBAL INSTALL_DIR
- StrCpy $INSTALL_DIR "$INSTALL_PATH"
- ${Else}
- StrCpy $INSTALL_DIR "$INSTDIR"
- ${EndIf}
- ;Set to try to overwrite existing files
- SetOverwrite try
- ;Set the GIS_DATABASE directory
- SetShellVarContext current
- Var /GLOBAL GIS_DATABASE
- StrCpy $GIS_DATABASE "$DOCUMENTS\GIS DataBase"
- ;Create the GIS_DATABASE directory
- CreateDirectory "$GIS_DATABASE"
- ;add Installer files
- SetOutPath "$INSTALL_DIR"
- File .\Installer-Files\GRASS-WebSite.url
- File .\Installer-Files\WinGRASS-README.url
- ;add GRASS files
- File /r ${PACKAGE_FOLDER}\*.*
- ;create run_gmkfontcap.bat
- ClearErrors
- FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat w
- IfErrors done_create_run_gmkfontcap.bat
- FileWrite $0 '@echo off$\r$\n'
- FileWrite $0 'rem #########################################################################$\r$\n'
- FileWrite $0 'rem #$\r$\n'
- FileWrite $0 'rem # Run g.mkfontcap outside a grass session during installation$\r$\n'
- FileWrite $0 'echo Setup of WinGRASS-${VERSION_NUMBER}$\r$\n'
- FileWrite $0 'echo Generating the font configuration file by scanning various directories for fonts.$\r$\n'
- FileWrite $0 'echo Please wait. Console window will close automatically ....$\r$\n'
- FileWrite $0 '$\r$\n'
- FileWrite $0 'rem set gisbase$\r$\n'
- FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
- FileWrite $0 'rem set path to freetype dll$\r$\n'
- FileWrite $0 'set FREETYPEBASE=$INSTALL_DIR\extralib;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
- FileWrite $0 'rem set dependecies path$\r$\n'
- FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
- FileWrite $0 'rem run g.mkfontcap outside a grass session$\r$\n'
- FileWrite $0 '"%GISBASE%\bin\g.mkfontcap.exe" -o$\r$\n'
- FileWrite $0 'exit$\r$\n'
- FileClose $0
- done_create_run_gmkfontcap.bat:
- ;create run_gmkfontcap.bat.manifest
- ClearErrors
- FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat.manifest w
- IfErrors done_create_run_gmkfontcap.bat.manifest
- FileWrite $0 ' <?xml version="1.0" encoding="UTF-8" standalone="yes"?>$\r$\n'
- FileWrite $0 '<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">$\r$\n'
- FileWrite $0 ' <assemblyIdentity version="1.0.0.0"$\r$\n'
- FileWrite $0 ' processorArchitecture="X86"$\r$\n'
- FileWrite $0 ' name="run_gmkfontcap"$\r$\n'
- FileWrite $0 ' type="win32"/>$\r$\n'
- FileWrite $0 ' <description>GRASS help script:run_gmkfontcap<description>$\r$\n'
- FileWrite $0 ' <!-- Identify the application security requirements. -->$\r$\n'
- FileWrite $0 ' <trustInfo xmlns="urn:schemas-microsoft-com:asm.v2">$\r$\n'
- FileWrite $0 ' <security>$\r$\n'
- FileWrite $0 ' <requestedPrivileges>$\r$\n'
- FileWrite $0 ' <requestedExecutionLevel$\r$\n'
- FileWrite $0 ' level="asInvoker"$\r$\n'
- FileWrite $0 ' uiAccess="false"/>$\r$\n'
- FileWrite $0 ' </requestedPrivileges>$\r$\n'
- FileWrite $0 ' </security>$\r$\n'
- FileWrite $0 ' </trustInfo>$\r$\n'
- FileWrite $0 '</assembly>$\r$\n'
- FileClose $0
- done_create_run_gmkfontcap.bat.manifest:
- ;Run g.mkfontcap outside a grass session during installation to catch all fonts
- ExecWait '"$INSTALL_DIR\etc\run_gmkfontcap.bat"'
- ;Install demolocation into the GIS_DATABASE directory
- SetOutPath "$GIS_DATABASE\demolocation"
- File /r ${DEMOLOCATION_PATH}\*.*
- ;add msys.bat into the INSTALL_DIR\msys directory
- SetOutPath "$INSTALL_DIR\msys"
- File /r ${MSYS_BATCH}
- ;Create the Uninstaller
- WriteUninstaller "$INSTALL_DIR\Uninstall-GRASS.exe"
- ;Registry Key Entries
- ;HKEY_LOCAL_MACHINE Install entries
- ;Set the Name, Version and Revision of GRASS + PublisherInfo + InstallPath
- WriteRegStr HKLM "Software\${GRASS_BASE}" "Name" "GRASS 7.0"
- WriteRegStr HKLM "Software\${GRASS_BASE}" "VersionNumber" "${VERSION_NUMBER}"
- WriteRegStr HKLM "Software\${GRASS_BASE}" "SvnRevision" "${SVN_REVISION}"
- WriteRegStr HKLM "Software\${GRASS_BASE}" "BinaryRevision" "${BINARY_REVISION}"
- WriteRegStr HKLM "Software\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
- WriteRegStr HKLM "Software\${GRASS_BASE}" "WebSite" "${WEB_SITE}"
- WriteRegStr HKLM "Software\${GRASS_BASE}" "InstallPath" "$INSTALL_DIR"
- ;HKEY_LOCAL_MACHINE Uninstall entries
- WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayName" "GRASS 7.0"
- WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString" "$INSTALL_DIR\Uninstall-GRASS.exe"
- WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"\
- "DisplayVersion" "${VERSION_NUMBER}-${BINARY_REVISION}"
- !else
- "DisplayVersion" "${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
- !endif
- WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayIcon" "$INSTALL_DIR\etc\gui\icons\grass.ico"
- WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "EstimatedSize" 1
- WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "HelpLink" "${WIKI_PAGE}"
- WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "URLInfoAbout" "${WEB_SITE}"
- WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
- ;Create the Desktop Shortcut
- CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
- "$INSTALL_DIR\etc\gui\icons\grass.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD terminal"
- ;Create the Windows Start Menu Shortcuts
- SetShellVarContext all
- CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
- CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
- "$INSTALL_DIR\etc\gui\icons\grass.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD console"
- CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} GUI with MSYS.lnk" "$INSTALL_DIR\${GRASS_COMMAND}_msys.bat" "-wx"\
- "$INSTALL_DIR\etc\gui\icons\grass_msys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and MSYS UNIX console"
- CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} Command Line.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-text"\
- "$INSTALL_DIR\etc\gui\icons\grass_cmd.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} in text mode"
- CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\MSYS UNIX Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
- "$INSTALL_DIR\etc\gui\icons\msys.ico" "" SW_SHOWNORMAL "" "Open a MSYS UNIX console"
- CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
- "$INSTALL_DIR\etc\gui\icons\grass_web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS website"
-; FIXME: ship the WinGrass release notes .html file instead of URL
-; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass70/binary/mswindows/native/README.html?format=raw
-; probably ship with devel versions too? ie Release Notes, not the Release Announcement press release.
- CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
- "$INSTALL_DIR\etc\gui\icons\wingrass.ico" "" SW_SHOWNORMAL "" "Visit the WinGRASS Project Web Page"
- !endif
- CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Uninstall GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\Uninstall-GRASS.exe" ""\
- "$INSTALL_DIR\Uninstall-GRASS.exe" "" SW_SHOWNORMAL "" "Uninstall GRASS ${VERSION_NUMBER}"
- ;Create the grass_command.bat
- ClearErrors
- FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.bat w
- IfErrors done_create_grass_command.bat
- FileWrite $0 'rem # File dynamically created by NSIS installer script;$\r$\n'
- FileWrite $0 'rem # GRASS Initialization$\r$\n'
- ${If} $R_HKLM_INSTALL_PATH != ""
- FileWrite $0 'set PATH=$R_HKLM_INSTALL_PATH\bin;%PATH%$\r$\n'
- ${EndIf}
- ${If} $R_HKCU_INSTALL_PATH != ""
- FileWrite $0 'set PATH=$R_HKCU_INSTALL_PATH\bin;%PATH%$\r$\n'
- ${EndIf}
- FileWrite $0 'call "%GISBASE%\etc\env.bat"$\r$\n'
- FileWrite $0 'cd "%USERPROFILE%"'
- FileWrite $0 '%GRASS_PYTHON% "%GISBASE%\etc\grass70.py" %*'
- FileClose $0
- done_create_grass_command.bat:
- ;Create the grass_command_msys.bat
- ClearErrors
- FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}_msys.bat w
- IfErrors done_create_grass_command_msys.bat
- FileWrite $0 'rem # GRASS Initialization (MSYS)$\r$\n'
- FileWrite $0 'set GRASS_SH=%GISBASE%\msys\bin\sh.exe$\r$\n'
- ${EndIf}
- ${EndIf}
- FileClose $0
- done_create_grass_command_msys.bat:
- ;Set the UNIX_LIKE GRASS Path
- Var /GLOBAL UNIX_LIKE_DRIVE
- Var /GLOBAL UNIX_LIKE_GRASS_PATH
- StrCpy $UNIX_LIKE_DRIVE "$INSTALL_DIR" 3
- StrCpy $UNIX_LIKE_GRASS_PATH "$INSTALL_DIR" "" 3
- ;replace "\" with "/" in $UNIX_LIKE_DRIVE
- ${StrReplace} "$UNIX_LIKE_DRIVE" "\" "/" "$UNIX_LIKE_DRIVE"
- ;replace ":" with "" in $UNIX_LIKE_DRIVE
- ${StrReplace} "$UNIX_LIKE_DRIVE" ":" "" "$UNIX_LIKE_DRIVE"
- ;replace "\" with "/" in $UNIX_LIKE_GRASS_PATH
- ${StrReplace} "$UNIX_LIKE_GRASS_PATH" "\" "/" "$UNIX_LIKE_GRASS_PATH"
- ;Set the USERNAME variable
- Var /GLOBAL USERNAME
- Var /GLOBAL PROFILE_DRIVE
- Var /GLOBAL PROFILE_ROOT
- ;It first searches for the Key Regestry value "Logon User Name" in HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer"
- ReadRegStr $USERNAME HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer" "Logon User Name"
- ;If the Key Registry value is empty, it uses a work around, retrieving the Username string from the System User Profile variable ($PROFILE)
- ;It first read the $PROFILE variable, to scan the OS version:
- ;If equal to "drive:\Users\UserName", the OS is Vista, and the $USERNAME variable set to $PROFILE - "drive:\Users\"
- ;If not, the OS is XP or previous, and the $USERNAME variable set to $PROFILE - "drive:\Documents and Settings\"
- ${If} $USERNAME == ""
- StrCpy $PROFILE_DRIVE "$PROFILE" 2
- StrCpy $PROFILE_ROOT "$PROFILE" 5 -3
- ${If} $USERNAME = "Users"
- ${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Users\" "" "$PROFILE"
- ${Else}
- ${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Documents and Settings\" "" "$PROFILE"
- ${EndIf}
- ${EndIf}
- ;create the $INSTALL_DIR\bin grass_command
- ClearErrors
- FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.sh w
- FileWrite $0 '#! /bin/sh$\r$\n'
- FileWrite $0 '#########################################################################$\r$\n'
- FileWrite $0 '#$\r$\n'
- FileWrite $0 '# File dynamically created by NSIS installer script;$\r$\n'
- FileWrite $0 '# Written by Marco Pasetti;$\r$\n'
- FileWrite $0 '# MODULE: GRASS Initialization$\r$\n'
- FileWrite $0 '# AUTHOR(S): Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th$\r$\n'
- FileWrite $0 '# PURPOSE: The source file for this shell script is in$\r$\n'
- FileWrite $0 '# lib/init/grass.src and is the grass startup script. It$\r$\n'
- FileWrite $0 '# requires a source file because the definition of GISBASE$\r$\n'
- FileWrite $0 '# is not known until compile time and is substituted from the$\r$\n'
- FileWrite $0 '# Makefile. Any command line options are passed to Init.sh.$\r$\n'
- FileWrite $0 '# COPYRIGHT: (C) 2000-2010 by the GRASS Development Team$\r$\n'
- FileWrite $0 '# This program is free software under the GNU General Public$\r$\n'
- FileWrite $0 '# License (>=v2). Read the file COPYING that comes with GRASS$\r$\n'
- FileWrite $0 '# for details.$\r$\n'
- FileWrite $0 '# Modified by Marco Pasetti$\r$\n'
- FileWrite $0 '# added the export PATH instruction to let GRASS work from$\r$\n'
- FileWrite $0 '# the MSYS environment in the dynamic NSIS installation$\r$\n'
- FileWrite $0 'trap "echo '
- FileWrite $0 "'User break!' ; "
- FileWrite $0 'exit" 2 3 9 15$\r$\n'
- FileWrite $0 '# Set the GISBASE variable$\r$\n'
- FileWrite $0 'GISBASE="/$UNIX_LIKE_DRIVE$UNIX_LIKE_GRASS_PATH"$\r$\n'
- FileWrite $0 'export GISBASE$\r$\n'
- FileWrite $0 '# Set the PATH variable$\r$\n'
- FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
- FileWrite $0 'PATH="$$GISBASE/tcl-tk/bin:$$GISBASE/sqlite/bin:$$GISBASE/gpsbabel:$$PATH"$\r$\n'
- FileWrite $0 'export PATH$\r$\n'
- FileWrite $0 '# Set the PYTHONPATH variable$\r$\n'
- FileWrite $0 'PYTHONPATH="$$GISBASE/etc/python:$$GISBASE/Python27:$$PYTHONPATH"$\r$\n'
- FileWrite $0 'export PYTHONPATH$\r$\n'
- FileWrite $0 'PYTHONHOME="$INSTALL_DIR\Python27"$\r$\n'
- FileWrite $0 'export PYTHONHOME$\r$\n'
- FileWrite $0 'if [ -z "$$GRASS_PYTHON" ] ; then$\r$\n'
- FileWrite $0 ' GRASS_PYTHON=python$\r$\n'
- FileWrite $0 ' export GRASS_PYTHON$\r$\n'
- FileWrite $0 'fi$\r$\n'
- FileWrite $0 '# Set the GRASS_PROJSHARE variable$\r$\n'
- FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
- FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
- FileWrite $0 '# Set the GDAL_DATA variable$\r$\n'
- FileWrite $0 'GDAL_DATA="$INSTALL_DIR\share\gdal"$\r$\n'
- FileWrite $0 'export GDAL_DATA$\r$\n'
- FileWrite $0 '# Set the PROJ_LIB variable$\r$\n'
- FileWrite $0 'PROJ_LIB="$INSTALL_DIR\proj"$\r$\n'
- FileWrite $0 'export PROJ_LIB $\r$\n'
- FileWrite $0 '# Set the GEOTIFF_CSV variable$\r$\n'
- FileWrite $0 'GEOTIFF_CSV="$INSTALL_DIR\share\epsg_csv"$\r$\n'
- FileWrite $0 'export GEOTIFF_CSV$\r$\n'
- FileWrite $0 '"$$GRASS_PYTHON $$GISBASE/etc/grass70.py" "$$@"'
- FileClose $0
- done_create_grass_command:
- ;Get the short form of the install path (to allow for paths with spaces)
- VAR /GLOBAL INST_DIR_SHORT
- GetFullPathName /SHORT $INST_DIR_SHORT $INSTALL_DIR
- ;create the $INSTALL_DIR\msys\etc\fstab with the main grass dir mount info
- ClearErrors
- FileOpen $0 $INSTALL_DIR\msys\etc\fstab w
- IfErrors done_create_fstab
- FileWrite $0 '$INST_DIR_SHORT /grass$\r$\n'
- FileClose $0
- done_create_fstab:
- ;Set the Unix-Like GIS_DATABASE Path
- ;Var /GLOBAL UNIX_LIKE_GIS_DATABASE_PATH
- ;replace \ with / in $GIS_DATABASE
- ;${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
- ${If} ${FileExists} "$APPDATA\GRASS7\rc"
- DetailPrint "File $APPDATA\GRASS7\rc already exists. Skipping."
- ${Else}
- ;create $APPDATA\GRASS7\rc
- ClearErrors
- CreateDirectory $APPDATA\GRASS7
- FileOpen $0 $APPDATA\GRASS7\rc w
- IfErrors done_create_grass7_rc
- FileWrite $0 'GISDBASE: $GIS_DATABASE$\r$\n'
- FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
- FileWrite $0 'MAPSET: PERMANENT$\r$\n'
- FileClose $0
- done_create_grass7_rc:
- ${EndIf}
- ;replace gisbase = "/c/OSGeo4W/apps/grass/grass-7.0.svn" in grass70.py with $INSTDIR
- Push "$INSTDIR\etc\grass70.py" ; file to modify
- Push 'gisbase = "/c/OSGeo4W/apps/grass/grass-7.0.svn"' ; string that a line must begin with *WS Sensitive*
- Push 'gisbase = "$INSTDIR"' ; string to replace whole line with
- Call ReplaceLineStr
- ;replace config_projshare = "/c/OSGeo4W/share/proj" i n grass70.py with $INSTDIR\proj
- Push 'config_projshare = "/c/OSGeo4W/share/proj"' ; string that a line must begin with *WS Sensitive*
- Push 'config_projshare = "$INSTDIR\proj"' ; string to replace whole line with
-SectionEnd
-Function DownloadDataSet
- IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
- StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the GRASS"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
- MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
- download:
- InitPluginsDir
- NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
- Pop $0
- StrCmp $0 "success" download_ok download_failed
- download_ok:
- InitPluginsDir
- untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
- Pop $0
- StrCmp $0 "success" untar_ok untar_failed
- untar_ok:
- Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
- Delete "$TEMP\$ARCHIVE_NAME"
- Goto end
- download_failed:
- DetailPrint "$0" ;print error message to log
- MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
- Goto end
- cancel_download:
- MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
- Goto end
- untar_failed:
- end:
-FunctionEnd
-Section /O "North Carolina (Wake County) Data Set" SecNorthCarolinaSDB
- ;Set the size (in KB) of the archive file
- StrCpy $ARCHIVE_SIZE_KB 138629
- ;Set the size (in KB) of the unpacked archive file
- AddSize 293314
- StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
- StrCpy $ARCHIVE_NAME "nc_spm_latest.tar.gz"
- StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina (Wake County)"
- StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08"
- StrCpy $CUSTOM_UNTAR_FOLDER "North-Carolina"
- Call DownloadDataSet
-SectionEnd
-Section /O "South Dakota (Spearfish County) Data Set" SecSpearfishSDB
- StrCpy $ARCHIVE_SIZE_KB 20803
- AddSize 42171
- StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
- StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish County)"
- StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
- StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
-SectionEnd
-;Uninstaller Section
-Section "Uninstall"
- ;remove files & folders
- RMDir /r "$INSTDIR"
- ;remove the Desktop ShortCut
- Delete "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
- Delete "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk"
- ;remove the Programs Start ShortCuts
- RMDir /r "$SMPROGRAMS\${GRASS_BASE}"
- ;remove the $APPDATA\GRASS7 folder
- ;disabled, don't remove user settings
- ; SetShellVarContext current
- ;RMDir /r "$APPDATA\GRASS7"
- ;${If} ${FileExists} "$APPDATA\GRASS7\addons\*.*"
- ; RMDir /r "$APPDATA\GRASS7\addons"
- ;${EndIf}
- ;remove the Registry Entries
- DeleteRegKey HKLM "Software\${GRASS_BASE}"
- DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
-SectionEnd
-;Installer Section Descriptions
-!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
- !insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
- !insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina (Wake County) sample data set"
- !insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish County) sample data set"
-!insertmacro MUI_FUNCTION_DESCRIPTION_END
Copied: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl (from rev 50843, grass/trunk/mswindows/GRASS-Installer.nsi)
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl (rev 0)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2012-02-17 22:53:08 UTC (rev 50854)
@@ -0,0 +1,1018 @@
+;GRASS Installer for Windows
+;Written by Marco Pasetti
+;Updated for OSGeo4W by Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
+;Last Update: $Id$
+;Mail to: grass-dev at lists.osgeo.org
+;Define the source path of the demolocation files
+!define DEMOLOCATION_PATH "c:\osgeo4w\usr\src\grass_trunk\demolocation"
+;Define the source of the patched msys.bat
+!define MSYS_BATCH "C:\OSGeo4W\usr\src\grass_trunk\mswindows\osgeo4w\msys.bat"
+;Select if you are building a "Development Version" (Devel) or a "Release Version" (Release) of the GRASS Installer
+!define INSTALLER_TYPE "Devel"
+;set compression configuration
+SetCompressor /SOLID lzma
+SetCompressorDictSize 64
+;Version variables
+!define SVN_REVISION "@GRASS_VERSION_SVN@"
+!define BINARY_REVISION "1"
+!define VERSION_NUMBER "@GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@"
+!define GRASS_BASE "GRASS @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@"
+!if ${INSTALLER_TYPE} == "Release"
+ !define GRASS_COMMAND "grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@"
+!else
+ !define GRASS_COMMAND "grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at svn"
+!endif
+;Don't modify the following lines
+;NSIS Includes
+!include "MUI2.nsh"
+!include "LogicLib.nsh"
+;Set the installer variables, depending on the selected version to build
+!define PACKAGE_FOLDER ".\GRASS- at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at -Package"
+ !define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
+ !define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-${BINARY_REVISION}"
+ !define CHECK_INSTALL_NAME "GRASS @GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@"
+!else
+ !define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
+ !define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+ !define CHECK_INSTALL_NAME "GRASS @GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@ SVN"
+!endif
+;Publisher variables
+!define PUBLISHER "GRASS Development Team"
+!define WEB_SITE "http://grass.osgeo.org"
+!define WIKI_PAGE "http://grass.osgeo.org/wiki"
+;General Definitions
+;Name of the application shown during install
+Name "${DISPLAYED_NAME}"
+;Name of the output file (installer executable)
+OutFile "${INSTALLER_NAME}"
+;Define installation folder
+InstallDir "$PROGRAMFILES\${GRASS_BASE}"
+;Request application privileges for Windows Vista
+RequestExecutionLevel admin
+;Tell the installer to show Install and Uninstall details as default
+ShowInstDetails show
+ShowUnInstDetails show
+;StrReplace Function
+;Replaces all ocurrences of a given needle within a haystack with another string
+;Written by dandaman32
+Var STR_REPLACE_VAR_0
+Var STR_REPLACE_VAR_1
+Var STR_REPLACE_VAR_2
+Var STR_REPLACE_VAR_3
+Var STR_REPLACE_VAR_4
+Var STR_REPLACE_VAR_5
+Var STR_REPLACE_VAR_6
+Var STR_REPLACE_VAR_7
+Var STR_REPLACE_VAR_8
+Function StrReplace
+ Exch $STR_REPLACE_VAR_2
+ Exch 1
+ Exch $STR_REPLACE_VAR_1
+ Exch 2
+ Exch $STR_REPLACE_VAR_0
+ StrCpy $STR_REPLACE_VAR_3 -1
+ StrLen $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_1
+ StrLen $STR_REPLACE_VAR_6 $STR_REPLACE_VAR_0
+ loop:
+ IntOp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_3 + 1
+ StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_3
+ StrCmp $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_1 found
+ StrCmp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_6 done
+ Goto loop
+ found:
+ StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_3
+ IntOp $STR_REPLACE_VAR_8 $STR_REPLACE_VAR_3 + $STR_REPLACE_VAR_4
+ StrCpy $STR_REPLACE_VAR_7 $STR_REPLACE_VAR_0 "" $STR_REPLACE_VAR_8
+ StrCpy $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_5$STR_REPLACE_VAR_2$STR_REPLACE_VAR_7
+ Goto loop
+ done:
+ Pop $STR_REPLACE_VAR_1 ; Prevent "invalid opcode" errors and keep the
+ Pop $STR_REPLACE_VAR_1 ; stack as it was before the function was called
+FunctionEnd
+!macro _strReplaceConstructor OUT NEEDLE NEEDLE2 HAYSTACK
+ Push "${HAYSTACK}"
+ Push "${NEEDLE}"
+ Push "${NEEDLE2}"
+ Call StrReplace
+ Pop "${OUT}"
+!macroend
+!define StrReplace '!insertmacro "_strReplaceConstructor"'
+;.onInit Function (called when the installer is nearly finished initializing)
+;Check if GRASS is already installed on the system and, if yes, what version and binary release;
+;depending on that, select the install procedure:
+;1. first installation = if GRASS is not already installed
+;install GRASS asking for the install PATH
+;2. upgrade installation = if an older release of GRASS is already installed
+;call the uninstaller of the currently installed GRASS release
+;if the uninstall procedure succeeded, call the current installer without asking for the install PATH
+;GRASS will be installed in the same PATH of the previous installation
+;3. downgrade installation = if a newer release of GRASS is already installed
+;4. repair installation = if the same release of GRASS is already installed
+;if the uninstall procedure succeeded, call the current installer asking for the install PATH
+;the currently installed release of GRASS is defined by the variable $INSTALLED_VERSION = $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+Function .onInit
+ Var /GLOBAL ASK_FOR_PATH
+ StrCpy $ASK_FOR_PATH "YES"
+ Var /GLOBAL UNINSTALL_STRING
+ Var /GLOBAL INSTALL_PATH
+ Var /GLOBAL INSTALLED_VERSION_NUMBER
+ Var /GLOBAL INSTALLED_SVN_REVISION
+ Var /GLOBAL INSTALLED_BINARY_REVISION
+ Var /GLOBAL DISPLAYED_INSTALLED_VERSION
+ Var /GLOBAL MESSAGE_0_
+ Var /GLOBAL MESSAGE_1_
+ Var /GLOBAL MESSAGE_2_
+ Var /GLOBAL MESSAGE_3_
+ Var /GLOBAL R_HKLM_INSTALL_PATH
+ Var /GLOBAL R_HKCU_INSTALL_PATH
+ ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
+ ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
+ ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
+ ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
+ ReadRegStr $R_HKLM_INSTALL_PATH HKLM "Software\R-core\R" "InstallPath"
+ ReadRegStr $R_HKCU_INSTALL_PATH HKCU "Software\R-core\R" "InstallPath"
+ ${If} $INSTALLED_SVN_REVISION == ""
+ ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
+ ${EndIf}
+ ReadRegStr $INSTALLED_BINARY_REVISION HKLM "Software\${GRASS_BASE}" "BinaryRevision"
+ StrCpy $MESSAGE_0_ "${CHECK_INSTALL_NAME} is already installed on your system.$\r$\n"
+ StrCpy $MESSAGE_0_ "$MESSAGE_0_$\r$\n"
+ !if ${INSTALLER_TYPE} == "Release"
+ ${If} $INSTALLED_BINARY_REVISION == ""
+ StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER"
+ ${Else}
+ StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_BINARY_REVISION"
+ ${EndIf}
+ !else
+ StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_SVN_REVISION-$INSTALLED_BINARY_REVISION"
+ !endif
+ StrCpy $MESSAGE_0_ "$MESSAGE_0_The installed release is $DISPLAYED_INSTALLED_VERSION$\r$\n"
+ StrCpy $MESSAGE_1_ "$MESSAGE_0_$\r$\n"
+ StrCpy $MESSAGE_1_ "$MESSAGE_1_You are going to install a newer release of ${CHECK_INSTALL_NAME}$\r$\n"
+ StrCpy $MESSAGE_1_ "$MESSAGE_1_$\r$\n"
+ StrCpy $MESSAGE_1_ "$MESSAGE_1_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
+ StrCpy $MESSAGE_1_ "$MESSAGE_1_ and install ${DISPLAYED_NAME} or Cancel to quit."
+ StrCpy $MESSAGE_2_ "$MESSAGE_0_$\r$\n"
+ StrCpy $MESSAGE_2_ "$MESSAGE_2_You are going to install an older release of ${CHECK_INSTALL_NAME}$\r$\n"
+ StrCpy $MESSAGE_2_ "$MESSAGE_2_$\r$\n"
+ StrCpy $MESSAGE_2_ "$MESSAGE_2_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
+ StrCpy $MESSAGE_2_ "$MESSAGE_2_ and install ${DISPLAYED_NAME} or Cancel to quit."
+ StrCpy $MESSAGE_3_ "$MESSAGE_0_$\r$\n"
+ StrCpy $MESSAGE_3_ "$MESSAGE_3_This is the latest release available.$\r$\n"
+ StrCpy $MESSAGE_3_ "$MESSAGE_3_$\r$\n"
+ StrCpy $MESSAGE_3_ "$MESSAGE_3_Press OK to reinstall ${DISPLAYED_NAME} or Cancel to quit."
+ IntOp $INSTALLED_SVN_REVISION $INSTALLED_SVN_REVISION * 1
+ IntOp $INSTALLED_BINARY_REVISION $INSTALLED_BINARY_REVISION * 1
+ IntOp $INSTALLED_VERSION $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+ !define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
+ ${If} $INSTALLED_VERSION_NUMBER == ""
+ ${Else}
+ ${If} $INSTALLED_VERSION < ${VERSION}
+ MessageBox MB_OKCANCEL "$MESSAGE_1_" IDOK upgrade IDCANCEL quit_upgrade
+ upgrade:
+ StrCpy $ASK_FOR_PATH "NO"
+ ExecWait '"$UNINSTALL_STRING" _?=$INSTALL_PATH' $0
+ Goto continue_upgrade
+ quit_upgrade:
+ Abort
+ continue_upgrade:
+ ${ElseIf} $INSTALLED_VERSION > ${VERSION}
+ MessageBox MB_OKCANCEL "$MESSAGE_2_" IDOK downgrade IDCANCEL quit_downgrade
+ downgrade:
+ Goto continue_downgrade
+ quit_downgrade:
+ Abort
+ continue_downgrade:
+ ${ElseIf} $INSTALLED_VERSION = ${VERSION}
+ MessageBox MB_OKCANCEL "$MESSAGE_3_" IDOK reinstall IDCANCEL quit_reinstall
+ reinstall:
+ Goto continue_reinstall
+ quit_reinstall:
+ Abort
+ continue_reinstall:
+ ${EndIf}
+ ${EndIf}
+ ${Else}
+ ${If} $0 = 0
+ ${Else}
+ Abort
+ ${EndIf}
+ ${EndIf}
+FunctionEnd
+;CheckUpdate Function
+;Check if to show the MUI_PAGE_DIRECTORY during the installation (to ask for the install PATH)
+Function CheckUpdate
+ ${If} $ASK_FOR_PATH == "NO"
+ Abort
+ ${EndIf}
+FunctionEnd
+;CheckInstDir Function
+;this is commented out, because the installation path should be in $PROGRAMFILES
+;Check if GRASS is going to be installed in a directory containing spaces
+;if yes, show a warning message
+;Function CheckInstDir
+; Var /GLOBAL INSTDIR_TEST
+; Var /GLOBAL INSTDIR_LENGHT
+; Var /GLOBAL INSTDIR_TEST_LENGHT
+; Var /GLOBAL MESSAGE_CHKINST_
+; StrCpy $MESSAGE_CHKINST_ "WARNING: you are about to install GRASS into a directory that has spaces$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_in either its name or the path of directories leading up to it.$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_Some functionalities of GRASS might be hampered by this. We would highly$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_appreciate if you tried and reported any problems, so that we can fix them.$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_However, if you want to avoid any such issues, we recommend that you$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_choose a simple installation path without spaces, such as: C:\${GRASS_BASE}.$\r$\n"
+; ${StrReplace} "$INSTDIR_TEST" " " "" "$INSTDIR"
+; StrLen $INSTDIR_LENGHT "$INSTDIR"
+; StrLen $INSTDIR_TEST_LENGHT "$INSTDIR_TEST"
+; ${If} $INSTDIR_TEST_LENGHT < $INSTDIR_LENGHT
+; MessageBox MB_OK|MB_ICONEXCLAMATION "$MESSAGE_CHKINST_"
+; ${EndIf}
+;FunctionEnd
+;ReplaceLineString Function
+;Replace String in an existing file
+; code taken from http://nsis.sourceforge.net/Replace_line_that_starts_with_specified_string
+Function ReplaceLineStr
+ Exch $R0 ; string to replace that whole line with
+ Exch
+ Exch $R1 ; string that line should start with
+ Exch
+ Exch 2
+ Exch $R2 ; file
+ Push $R3 ; file handle
+ Push $R4 ; temp file
+ Push $R5 ; temp file handle
+ Push $R6 ; global
+ Push $R7 ; input string length
+ Push $R8 ; line string length
+ Push $R9 ; global
+ StrLen $R7 $R1
+ GetTempFileName $R4
+ FileOpen $R5 $R4 w
+ FileOpen $R3 $R2 r
+ ReadLoop:
+ ClearErrors
+ FileRead $R3 $R6
+ IfErrors Done
+ StrLen $R8 $R6
+ StrCpy $R9 $R6 $R7 -$R8
+ StrCmp $R9 $R1 0 +3
+ FileWrite $R5 "$R0$\r$\n"
+ Goto ReadLoop
+ FileWrite $R5 $R6
+ Goto ReadLoop
+ Done:
+ FileClose $R3
+ FileClose $R5
+ SetDetailsPrint none
+ Delete $R2
+ Rename $R4 $R2
+ SetDetailsPrint both
+ Pop $R9
+ Pop $R8
+ Pop $R7
+ Pop $R6
+ Pop $R5
+ Pop $R4
+ Pop $R3
+ Pop $R2
+ Pop $R1
+ Pop $R0
+FunctionEnd
+;Interface Settings
+!define MUI_ABORTWARNING
+!define MUI_ICON ".\Installer-Files\Install_GRASS.ico"
+!define MUI_UNICON ".\Installer-Files\Uninstall_GRASS.ico"
+!define MUI_HEADERIMAGE_BITMAP_NOSTETCH ".\Installer-Files\InstallHeaderImage.bmp"
+!define MUI_HEADERIMAGE_UNBITMAP_NOSTRETCH ".\Installer-Files\UnInstallHeaderImage.bmp"
+!define MUI_WELCOMEFINISHPAGE_BITMAP ".\Installer-Files\WelcomeFinishPage.bmp"
+!define MUI_UNWELCOMEFINISHPAGE_BITMAP ".\Installer-Files\UnWelcomeFinishPage.bmp"
+;Installer Pages
+!insertmacro MUI_PAGE_WELCOME
+;These indented statements modify settings for MUI_PAGE_LICENSE
+; (with thanks to Ubuntu)
+ !define MUI_LICENSEPAGE_TEXT_BOTTOM "GRASS is software libre. You are encouraged and legally \
+ entitled to copy, reinstall, modify, and redistribute this program \
+ for yourself and your friends under the terms of the GPL. Happy \
+ mapping!"
+ !define MUI_LICENSEPAGE_BUTTON "Next >"
+!insertmacro MUI_PAGE_LICENSE "${PACKAGE_FOLDER}\GPL.TXT"
+!define MUI_PAGE_CUSTOMFUNCTION_PRE CheckUpdate
+!insertmacro MUI_PAGE_DIRECTORY
+;Page custom CheckInstDir
+!insertmacro MUI_PAGE_COMPONENTS
+!insertmacro MUI_PAGE_INSTFILES
+;These indented statements modify settings for MUI_PAGE_FINISH
+ !define MUI_FINISHPAGE_NOAUTOCLOSE
+ !define MUI_FINISHPAGE_RUN
+ !define MUI_FINISHPAGE_RUN_NOTCHECKED
+ !define MUI_FINISHPAGE_RUN_TEXT "Launch GRASS GIS"
+ !define MUI_FINISHPAGE_RUN_FUNCTION "LaunchGrass"
+ !define MUI_FINISHPAGE_SHOWREADME
+ !define MUI_FINISHPAGE_SHOWREADME_NOTCHECKED
+ !define MUI_FINISHPAGE_SHOWREADME_TEXT "View the reference manual"
+ !define MUI_FINISHPAGE_SHOWREADME_FUNCTION "ViewReadme"
+!insertmacro MUI_PAGE_FINISH
+!insertmacro MUI_UNPAGE_WELCOME
+!insertmacro MUI_UNPAGE_CONFIRM
+!insertmacro MUI_UNPAGE_INSTFILES
+!insertmacro MUI_UNPAGE_FINISH
+;Language files
+!insertmacro MUI_LANGUAGE "English"
+;launch Grass Gis by exit the installation wizard
+Function LaunchGrass
+ ExecShell "" "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
+FunctionEnd
+;launch reference manual by exit the installation wizard
+Function ViewReadme
+ ExecShell "open" "$INSTDIR\docs\html\index.html"
+FunctionEnd
+;Installer Sections
+;Declares the variables for optional Sample Data Sections
+Var /GLOBAL HTTP_PATH
+Var /GLOBAL ARCHIVE_NAME
+Var /GLOBAL EXTENDED_ARCHIVE_NAME
+Var /GLOBAL ORIGINAL_UNTAR_FOLDER
+Var /GLOBAL CUSTOM_UNTAR_FOLDER
+Var /GLOBAL ARCHIVE_SIZE_KB
+Var /GLOBAL ARCHIVE_SIZE_MB
+Var /GLOBAL DOWNLOAD_MESSAGE_
+Section "GRASS" SecGRASS
+ SectionIn RO
+ ;Set the INSTALL_DIR variable
+ Var /GLOBAL INSTALL_DIR
+ StrCpy $INSTALL_DIR "$INSTALL_PATH"
+ ${Else}
+ StrCpy $INSTALL_DIR "$INSTDIR"
+ ${EndIf}
+ ;Set to try to overwrite existing files
+ SetOverwrite try
+ ;Set the GIS_DATABASE directory
+ SetShellVarContext current
+ Var /GLOBAL GIS_DATABASE
+ StrCpy $GIS_DATABASE "$DOCUMENTS\GIS DataBase"
+ ;Create the GIS_DATABASE directory
+ CreateDirectory "$GIS_DATABASE"
+ ;add Installer files
+ SetOutPath "$INSTALL_DIR"
+ File .\Installer-Files\GRASS-WebSite.url
+ File .\Installer-Files\WinGRASS-README.url
+ ;add GRASS files
+ File /r ${PACKAGE_FOLDER}\*.*
+ ;create run_gmkfontcap.bat
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat w
+ IfErrors done_create_run_gmkfontcap.bat
+ FileWrite $0 '@echo off$\r$\n'
+ FileWrite $0 'rem #########################################################################$\r$\n'
+ FileWrite $0 'rem #$\r$\n'
+ FileWrite $0 'rem # Run g.mkfontcap outside a grass session during installation$\r$\n'
+ FileWrite $0 'echo Setup of WinGRASS-${VERSION_NUMBER}$\r$\n'
+ FileWrite $0 'echo Generating the font configuration file by scanning various directories for fonts.$\r$\n'
+ FileWrite $0 'echo Please wait. Console window will close automatically ....$\r$\n'
+ FileWrite $0 '$\r$\n'
+ FileWrite $0 'rem set gisbase$\r$\n'
+ FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
+ FileWrite $0 'rem set path to freetype dll$\r$\n'
+ FileWrite $0 'set FREETYPEBASE=$INSTALL_DIR\extralib;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
+ FileWrite $0 'rem set dependecies path$\r$\n'
+ FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
+ FileWrite $0 'rem run g.mkfontcap outside a grass session$\r$\n'
+ FileWrite $0 '"%GISBASE%\bin\g.mkfontcap.exe" -o$\r$\n'
+ FileWrite $0 'exit$\r$\n'
+ FileClose $0
+ done_create_run_gmkfontcap.bat:
+ ;create run_gmkfontcap.bat.manifest
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat.manifest w
+ IfErrors done_create_run_gmkfontcap.bat.manifest
+ FileWrite $0 ' <?xml version="1.0" encoding="UTF-8" standalone="yes"?>$\r$\n'
+ FileWrite $0 '<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">$\r$\n'
+ FileWrite $0 ' <assemblyIdentity version="1.0.0.0"$\r$\n'
+ FileWrite $0 ' processorArchitecture="X86"$\r$\n'
+ FileWrite $0 ' name="run_gmkfontcap"$\r$\n'
+ FileWrite $0 ' type="win32"/>$\r$\n'
+ FileWrite $0 ' <description>GRASS help script:run_gmkfontcap<description>$\r$\n'
+ FileWrite $0 ' <!-- Identify the application security requirements. -->$\r$\n'
+ FileWrite $0 ' <trustInfo xmlns="urn:schemas-microsoft-com:asm.v2">$\r$\n'
+ FileWrite $0 ' <security>$\r$\n'
+ FileWrite $0 ' <requestedPrivileges>$\r$\n'
+ FileWrite $0 ' <requestedExecutionLevel$\r$\n'
+ FileWrite $0 ' level="asInvoker"$\r$\n'
+ FileWrite $0 ' uiAccess="false"/>$\r$\n'
+ FileWrite $0 ' </requestedPrivileges>$\r$\n'
+ FileWrite $0 ' </security>$\r$\n'
+ FileWrite $0 ' </trustInfo>$\r$\n'
+ FileWrite $0 '</assembly>$\r$\n'
+ FileClose $0
+ done_create_run_gmkfontcap.bat.manifest:
+ ;Run g.mkfontcap outside a grass session during installation to catch all fonts
+ ExecWait '"$INSTALL_DIR\etc\run_gmkfontcap.bat"'
+ ;Install demolocation into the GIS_DATABASE directory
+ SetOutPath "$GIS_DATABASE\demolocation"
+ File /r ${DEMOLOCATION_PATH}\*.*
+ ;add msys.bat into the INSTALL_DIR\msys directory
+ SetOutPath "$INSTALL_DIR\msys"
+ File /r ${MSYS_BATCH}
+ ;Create the Uninstaller
+ WriteUninstaller "$INSTALL_DIR\Uninstall-GRASS.exe"
+ ;Registry Key Entries
+ ;HKEY_LOCAL_MACHINE Install entries
+ ;Set the Name, Version and Revision of GRASS + PublisherInfo + InstallPath
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "Name" "GRASS @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR@"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "VersionNumber" "${VERSION_NUMBER}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "SvnRevision" "${SVN_REVISION}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "BinaryRevision" "${BINARY_REVISION}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "WebSite" "${WEB_SITE}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "InstallPath" "$INSTALL_DIR"
+ ;HKEY_LOCAL_MACHINE Uninstall entries
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayName" "GRASS @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR@"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString" "$INSTALL_DIR\Uninstall-GRASS.exe"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"\
+ "DisplayVersion" "${VERSION_NUMBER}-${BINARY_REVISION}"
+ !else
+ "DisplayVersion" "${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+ !endif
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayIcon" "$INSTALL_DIR\etc\gui\icons\grass.ico"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "EstimatedSize" 1
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "HelpLink" "${WIKI_PAGE}"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "URLInfoAbout" "${WEB_SITE}"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
+ ;Create the Desktop Shortcut
+ CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
+ "$INSTALL_DIR\etc\gui\icons\grass.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD terminal"
+ ;Create the Windows Start Menu Shortcuts
+ SetShellVarContext all
+ CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
+ "$INSTALL_DIR\etc\gui\icons\grass.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD console"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} GUI with MSYS.lnk" "$INSTALL_DIR\${GRASS_COMMAND}_msys.bat" "-wx"\
+ "$INSTALL_DIR\etc\gui\icons\grass_msys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and MSYS UNIX console"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} Command Line.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-text"\
+ "$INSTALL_DIR\etc\gui\icons\grass_cmd.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} in text mode"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\MSYS UNIX Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
+ "$INSTALL_DIR\etc\gui\icons\msys.ico" "" SW_SHOWNORMAL "" "Open a MSYS UNIX console"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
+ "$INSTALL_DIR\etc\gui\icons\grass_web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS website"
+; FIXME: ship the WinGrass release notes .html file instead of URL
+; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass@GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@/binary/mswindows/native/README.html?format=raw
+; probably ship with devel versions too? ie Release Notes, not the Release Announcement press release.
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
+ "$INSTALL_DIR\etc\gui\icons\wingrass.ico" "" SW_SHOWNORMAL "" "Visit the WinGRASS Project Web Page"
+ !endif
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Uninstall GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\Uninstall-GRASS.exe" ""\
+ "$INSTALL_DIR\Uninstall-GRASS.exe" "" SW_SHOWNORMAL "" "Uninstall GRASS ${VERSION_NUMBER}"
+ ;Create the grass_command.bat
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.bat w
+ IfErrors done_create_grass_command.bat
+ FileWrite $0 'rem # File dynamically created by NSIS installer script;$\r$\n'
+ FileWrite $0 'rem # GRASS Initialization$\r$\n'
+ ${If} $R_HKLM_INSTALL_PATH != ""
+ FileWrite $0 'set PATH=$R_HKLM_INSTALL_PATH\bin;%PATH%$\r$\n'
+ ${EndIf}
+ ${If} $R_HKCU_INSTALL_PATH != ""
+ FileWrite $0 'set PATH=$R_HKCU_INSTALL_PATH\bin;%PATH%$\r$\n'
+ ${EndIf}
+ FileWrite $0 'call "%GISBASE%\etc\env.bat"$\r$\n'
+ FileWrite $0 'cd "%USERPROFILE%"'
+ FileWrite $0 '%GRASS_PYTHON% "%GISBASE%\etc\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py" %*'
+ FileClose $0
+ done_create_grass_command.bat:
+ ;Create the grass_command_msys.bat
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}_msys.bat w
+ IfErrors done_create_grass_command_msys.bat
+ FileWrite $0 'rem # GRASS Initialization (MSYS)$\r$\n'
+ FileWrite $0 'set GRASS_SH=%GISBASE%\msys\bin\sh.exe$\r$\n'
+ ${EndIf}
+ ${EndIf}
+ FileClose $0
+ done_create_grass_command_msys.bat:
+ ;Set the UNIX_LIKE GRASS Path
+ Var /GLOBAL UNIX_LIKE_DRIVE
+ Var /GLOBAL UNIX_LIKE_GRASS_PATH
+ StrCpy $UNIX_LIKE_DRIVE "$INSTALL_DIR" 3
+ StrCpy $UNIX_LIKE_GRASS_PATH "$INSTALL_DIR" "" 3
+ ;replace "\" with "/" in $UNIX_LIKE_DRIVE
+ ${StrReplace} "$UNIX_LIKE_DRIVE" "\" "/" "$UNIX_LIKE_DRIVE"
+ ;replace ":" with "" in $UNIX_LIKE_DRIVE
+ ${StrReplace} "$UNIX_LIKE_DRIVE" ":" "" "$UNIX_LIKE_DRIVE"
+ ;replace "\" with "/" in $UNIX_LIKE_GRASS_PATH
+ ${StrReplace} "$UNIX_LIKE_GRASS_PATH" "\" "/" "$UNIX_LIKE_GRASS_PATH"
+ ;Set the USERNAME variable
+ Var /GLOBAL USERNAME
+ Var /GLOBAL PROFILE_DRIVE
+ Var /GLOBAL PROFILE_ROOT
+ ;It first searches for the Key Regestry value "Logon User Name" in HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer"
+ ReadRegStr $USERNAME HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer" "Logon User Name"
+ ;If the Key Registry value is empty, it uses a work around, retrieving the Username string from the System User Profile variable ($PROFILE)
+ ;It first read the $PROFILE variable, to scan the OS version:
+ ;If equal to "drive:\Users\UserName", the OS is Vista, and the $USERNAME variable set to $PROFILE - "drive:\Users\"
+ ;If not, the OS is XP or previous, and the $USERNAME variable set to $PROFILE - "drive:\Documents and Settings\"
+ ${If} $USERNAME == ""
+ StrCpy $PROFILE_DRIVE "$PROFILE" 2
+ StrCpy $PROFILE_ROOT "$PROFILE" 5 -3
+ ${If} $USERNAME = "Users"
+ ${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Users\" "" "$PROFILE"
+ ${Else}
+ ${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Documents and Settings\" "" "$PROFILE"
+ ${EndIf}
+ ${EndIf}
+ ;create the $INSTALL_DIR\bin grass_command
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.sh w
+ FileWrite $0 '#! /bin/sh$\r$\n'
+ FileWrite $0 '#########################################################################$\r$\n'
+ FileWrite $0 '#$\r$\n'
+ FileWrite $0 '# File dynamically created by NSIS installer script;$\r$\n'
+ FileWrite $0 '# Written by Marco Pasetti;$\r$\n'
+ FileWrite $0 '# MODULE: GRASS Initialization$\r$\n'
+ FileWrite $0 '# AUTHOR(S): Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th$\r$\n'
+ FileWrite $0 '# PURPOSE: The source file for this shell script is in$\r$\n'
+ FileWrite $0 '# lib/init/grass.src and is the grass startup script. It$\r$\n'
+ FileWrite $0 '# requires a source file because the definition of GISBASE$\r$\n'
+ FileWrite $0 '# is not known until compile time and is substituted from the$\r$\n'
+ FileWrite $0 '# Makefile. Any command line options are passed to Init.sh.$\r$\n'
+ FileWrite $0 '# COPYRIGHT: (C) 2000-2010 by the GRASS Development Team$\r$\n'
+ FileWrite $0 '# This program is free software under the GNU General Public$\r$\n'
+ FileWrite $0 '# License (>=v2). Read the file COPYING that comes with GRASS$\r$\n'
+ FileWrite $0 '# for details.$\r$\n'
+ FileWrite $0 '# Modified by Marco Pasetti$\r$\n'
+ FileWrite $0 '# added the export PATH instruction to let GRASS work from$\r$\n'
+ FileWrite $0 '# the MSYS environment in the dynamic NSIS installation$\r$\n'
+ FileWrite $0 'trap "echo '
+ FileWrite $0 "'User break!' ; "
+ FileWrite $0 'exit" 2 3 9 15$\r$\n'
+ FileWrite $0 '# Set the GISBASE variable$\r$\n'
+ FileWrite $0 'GISBASE="/$UNIX_LIKE_DRIVE$UNIX_LIKE_GRASS_PATH"$\r$\n'
+ FileWrite $0 'export GISBASE$\r$\n'
+ FileWrite $0 '# Set the PATH variable$\r$\n'
+ FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
+ FileWrite $0 'PATH="$$GISBASE/tcl-tk/bin:$$GISBASE/sqlite/bin:$$GISBASE/gpsbabel:$$PATH"$\r$\n'
+ FileWrite $0 'export PATH$\r$\n'
+ FileWrite $0 '# Set the PYTHONPATH variable$\r$\n'
+ FileWrite $0 'PYTHONPATH="$$GISBASE/etc/python:$$GISBASE/Python27:$$PYTHONPATH"$\r$\n'
+ FileWrite $0 'export PYTHONPATH$\r$\n'
+ FileWrite $0 'PYTHONHOME="$INSTALL_DIR\Python27"$\r$\n'
+ FileWrite $0 'export PYTHONHOME$\r$\n'
+ FileWrite $0 'if [ -z "$$GRASS_PYTHON" ] ; then$\r$\n'
+ FileWrite $0 ' GRASS_PYTHON=python$\r$\n'
+ FileWrite $0 ' export GRASS_PYTHON$\r$\n'
+ FileWrite $0 'fi$\r$\n'
+ FileWrite $0 '# Set the GRASS_PROJSHARE variable$\r$\n'
+ FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
+ FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
+ FileWrite $0 '# Set the GDAL_DATA variable$\r$\n'
+ FileWrite $0 'GDAL_DATA="$INSTALL_DIR\share\gdal"$\r$\n'
+ FileWrite $0 'export GDAL_DATA$\r$\n'
+ FileWrite $0 '# Set the PROJ_LIB variable$\r$\n'
+ FileWrite $0 'PROJ_LIB="$INSTALL_DIR\proj"$\r$\n'
+ FileWrite $0 'export PROJ_LIB $\r$\n'
+ FileWrite $0 '# Set the GEOTIFF_CSV variable$\r$\n'
+ FileWrite $0 'GEOTIFF_CSV="$INSTALL_DIR\share\epsg_csv"$\r$\n'
+ FileWrite $0 'export GEOTIFF_CSV$\r$\n'
+ FileWrite $0 '"$$GRASS_PYTHON $$GISBASE/etc/grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py" "$$@"'
+ FileClose $0
+ done_create_grass_command:
+ ;Get the short form of the install path (to allow for paths with spaces)
+ VAR /GLOBAL INST_DIR_SHORT
+ GetFullPathName /SHORT $INST_DIR_SHORT $INSTALL_DIR
+ ;create the $INSTALL_DIR\msys\etc\fstab with the main grass dir mount info
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\msys\etc\fstab w
+ IfErrors done_create_fstab
+ FileWrite $0 '$INST_DIR_SHORT /grass$\r$\n'
+ FileClose $0
+ done_create_fstab:
+ ;Set the Unix-Like GIS_DATABASE Path
+ ;Var /GLOBAL UNIX_LIKE_GIS_DATABASE_PATH
+ ;replace \ with / in $GIS_DATABASE
+ ;${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
+ ${If} ${FileExists} "$APPDATA\GRASS at GRASS_VERSION_MAJOR@\rc"
+ DetailPrint "File $APPDATA\GRASS at GRASS_VERSION_MAJOR@\rc already exists. Skipping."
+ ${Else}
+ ;create $APPDATA\GRASS at GRASS_VERSION_MAJOR@\rc
+ ClearErrors
+ CreateDirectory $APPDATA\GRASS at GRASS_VERSION_MAJOR@
+ FileOpen $0 $APPDATA\GRASS at GRASS_VERSION_MAJOR@\rc w
+ IfErrors done_create_grass_rc
+ FileWrite $0 'GISDBASE: $GIS_DATABASE$\r$\n'
+ FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
+ FileWrite $0 'MAPSET: PERMANENT$\r$\n'
+ FileClose $0
+ done_create_grass_rc:
+ ${EndIf}
+ ;replace gisbase = "/c/OSGeo4W/apps/grass/grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@" in grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py with $INSTDIR
+ Push "$INSTDIR\etc\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py" ; file to modify
+ Push 'gisbase = "/c/OSGeo4W/apps/grass/grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@"' ; string that a line must begin with *WS Sensitive*
+ Push 'gisbase = "$INSTDIR"' ; string to replace whole line with
+ Call ReplaceLineStr
+ ;replace config_projshare = "/c/OSGeo4W/share/proj" i n grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py with $INSTDIR\proj
+ Push 'config_projshare = "/c/OSGeo4W/share/proj"' ; string that a line must begin with *WS Sensitive*
+ Push 'config_projshare = "$INSTDIR\proj"' ; string to replace whole line with
+SectionEnd
+Function DownloadDataSet
+ IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
+ StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the GRASS"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
+ MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
+ download:
+ InitPluginsDir
+ NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
+ Pop $0
+ StrCmp $0 "success" download_ok download_failed
+ download_ok:
+ InitPluginsDir
+ untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
+ Pop $0
+ StrCmp $0 "success" untar_ok untar_failed
+ untar_ok:
+ Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
+ Delete "$TEMP\$ARCHIVE_NAME"
+ Goto end
+ download_failed:
+ DetailPrint "$0" ;print error message to log
+ MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+ Goto end
+ cancel_download:
+ MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+ Goto end
+ untar_failed:
+ end:
+FunctionEnd
+Section /O "North Carolina (Wake County) Data Set" SecNorthCarolinaSDB
+ ;Set the size (in KB) of the archive file
+ StrCpy $ARCHIVE_SIZE_KB 138629
+ ;Set the size (in KB) of the unpacked archive file
+ AddSize 293314
+ StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
+ StrCpy $ARCHIVE_NAME "nc_spm_latest.tar.gz"
+ StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina (Wake County)"
+ StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08"
+ StrCpy $CUSTOM_UNTAR_FOLDER "North-Carolina"
+ Call DownloadDataSet
+SectionEnd
+Section /O "South Dakota (Spearfish County) Data Set" SecSpearfishSDB
+ StrCpy $ARCHIVE_SIZE_KB 20803
+ AddSize 42171
+ StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
+ StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish County)"
+ StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
+ StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
+SectionEnd
+;Uninstaller Section
+Section "Uninstall"
+ ;remove files & folders
+ RMDir /r "$INSTDIR"
+ ;remove the Desktop ShortCut
+ Delete "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
+ Delete "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk"
+ ;remove the Programs Start ShortCuts
+ RMDir /r "$SMPROGRAMS\${GRASS_BASE}"
+ ;remove the $APPDATA\GRASS at GRASS_VERSION_MAJOR@ folder
+ ;disabled, don't remove user settings
+ ; SetShellVarContext current
+ ;RMDir /r "$APPDATA\GRASS at GRASS_VERSION_MAJOR@"
+ ;${If} ${FileExists} "$APPDATA\GRASS at GRASS_VERSION_MAJOR@\addons\*.*"
+ ; RMDir /r "$APPDATA\GRASS at GRASS_VERSION_MAJOR@\addons"
+ ;${EndIf}
+ ;remove the Registry Entries
+ DeleteRegKey HKLM "Software\${GRASS_BASE}"
+ DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
+SectionEnd
+;Installer Section Descriptions
+!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina (Wake County) sample data set"
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish County) sample data set"
+!insertmacro MUI_FUNCTION_DESCRIPTION_END
Deleted: grass/trunk/mswindows/GRASS-Packager.bat
--- grass/trunk/mswindows/GRASS-Packager.bat 2012-02-17 21:23:59 UTC (rev 50853)
+++ grass/trunk/mswindows/GRASS-Packager.bat 2012-02-17 22:53:08 UTC (rev 50854)
@@ -1,236 +0,0 @@
-rem -----------------------------------------------------------------------------------------------------------------------
-rem Self Contained GRASS Automated Packager
-rem Edited by: Marco Pasetti
-rem Revised for OSGeo4W by: Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
-rem Last Update: $Id$
- at echo off
-rem --------------------------------------------------------------------------------------------------------------------------
-rem Set the script variables
-set PACKAGE_DIR=.\GRASS-70-Package
-set OSGEO4W_DIR=c:\osgeo4w
-set GRASS_PREFIX=%OSGEO4W_DIR%\apps\grass\grass-7.0.svn
-set GRASS_BIN_PREFIX=%OSGEO4W_DIR%\bin
-set SVN_PATH=c:\Subversion
- at echo.
- at echo -----------------------------------------------------------------------------------------------------------------------
- at echo Remove the previous Selected Package and create a new PACKAGE_DIR
- at echo.
-if exist %PACKAGE_DIR% rmdir /S/Q %PACKAGE_DIR%
-mkdir %PACKAGE_DIR%
- at echo.
- at echo Copy %GRASS_PREFIX% & %GRASS_BIN_PREFIX% content to PACKAGE_DIR
- at echo.
-rem xcopy %GRASS_BIN_PREFIX%\grass70.py %PACKAGE_DIR% /S/V/F
-xcopy %GRASS_PREFIX% %PACKAGE_DIR% /S/V/F
- at echo.
- at echo Copy Extralibs to PACKAGE_DIR\extralib
- at echo.
-mkdir %PACKAGE_DIR%\extralib
-copy %OSGEO4W_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
-del %PACKAGE_DIR%\extralib\libgrass_*6.4*.dll
-del %PACKAGE_DIR%\extralib\libgrass_*6.5*.dll
-del %PACKAGE_DIR%\extralib\Qt*4.dll
-rem copy %OSGEO4W_DIR%\pgsql\lib\libpq.dll %PACKAGE_DIR%\extralib
- at echo.
- at echo Move GRASS libs from extralib to lib
- at echo.
-move %PACKAGE_DIR%\extralib\libgrass_*.dll %PACKAGE_DIR%\lib
- at echo.
- at echo Copy Extrabins to PACKAGE_DIR\extrabin
- at echo.
-mkdir %PACKAGE_DIR%\extrabin
-mkdir %PACKAGE_DIR%\extrabin\gdalplugins
-copy %OSGEO4W_DIR%\bin\*.exe %PACKAGE_DIR%\extrabin
- at echo.
- at echo Copy SQLite content to PACKAGE_DIR\sqlite
- at echo.
-mkdir %PACKAGE_DIR%\sqlite
-mkdir %PACKAGE_DIR%\sqlite\bin
-mkdir %PACKAGE_DIR%\sqlite\include
-mkdir %PACKAGE_DIR%\sqlite\lib
-xcopy %OSGEO4W_DIR%\bin\sqlite3.dll %PACKAGE_DIR%\sqlite\bin /S/V/F/I
-copy %OSGEO4W_DIR%\include\btree.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\fts1*.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\hash.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\keywordhash.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\opcodes.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\os.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\os_common.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\pager.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\parse.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\sqlite*.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\vdbe.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\vdbeInt.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\lib\sqlite3_i.lib %PACKAGE_DIR%\sqlite\lib
- at echo.
- at echo Copy GPSBABEL executable and dll to PACKAGE_DIR\gpsbabel
- at echo.
-mkdir %PACKAGE_DIR%\gpsbabel
-copy %OSGEO4W_DIR%\gpsbabel.exe %PACKAGE_DIR%\gpsbabel
-rem copy %OSGEO4W_DIR%\libexpat.dll %PACKAGE_DIR%\gpsbabel
- at echo.
- at echo Copy shared PROJ.4 files to PACKAGE_DIR\proj
- at echo.
-xcopy %OSGEO4W_DIR%\share\proj %PACKAGE_DIR%\proj /S/V/F/I
- at echo.
- at echo Copy shared GDAL files to PACKAGE_DIR\share\gdal
- at echo.
-mkdir %PACKAGE_DIR%\share
-mkdir %PACKAGE_DIR%\share\gdal
-xcopy %OSGEO4W_DIR%\share\gdal %PACKAGE_DIR%\share\gdal /S/V/F/I
- at echo.
- at echo Copy shared GEOTIFF files to PACKAGE_DIR\share\epsg_csv
- at echo.
-mkdir %PACKAGE_DIR%\share\epsg_csv
-xcopy %OSGEO4W_DIR%\share\epsg_csv %PACKAGE_DIR%\share\epsg_csv /S/V/F/I
- at echo.
- at echo Copy Tcl/Tk content to PACKAGE_DIR\tcl-tk
- at echo.
-mkdir %PACKAGE_DIR%\tcl-tk
-mkdir %PACKAGE_DIR%\tcl-tk\bin
-mkdir %PACKAGE_DIR%\tcl-tk\include
-mkdir %PACKAGE_DIR%\tcl-tk\lib
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5
-xcopy %OSGEO4W_DIR%\bin\tclpip85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tcl85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tclsh.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tclsh85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tk85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\wish.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\wish85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-copy %OSGEO4W_DIR%\include\tcl*.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tk*.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tommath_class.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tommath_superclass.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\ttkDecls.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\lib\tcl8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-copy %OSGEO4W_DIR%\lib\tcl8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-copy %OSGEO4W_DIR%\lib\tk8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-copy %OSGEO4W_DIR%\lib\tk8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-xcopy %OSGEO4W_DIR%\lib\tk8.5\ttk %PACKAGE_DIR%\tcl-tk\lib\tk8.5\ttk /S/V/F/I
-xcopy %OSGEO4W_DIR%\lib\tcl8\8.5 %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5 /S/V/F/I
- at echo.
- at echo Copy MSYS files to PACKAGE_DIR\msys
- at echo.
-mkdir %PACKAGE_DIR%\msys
-copy %OSGEO4W_DIR%\apps\msys\* %PACKAGE_DIR%\msys
-xcopy %OSGEO4W_DIR%\apps\msys\bin %PACKAGE_DIR%\msys\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\doc %PACKAGE_DIR%\msys\doc /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\etc %PACKAGE_DIR%\msys\etc /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\info %PACKAGE_DIR%\msys\info /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\lib %PACKAGE_DIR%\msys\lib /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\man %PACKAGE_DIR%\msys\man /S/V/F/I
-del %PACKAGE_DIR%\msys\etc\fstab
-rem delete msys.bat from osgeo4w because there is an adaption (for spaces in installation path) written by GRASS-Installer.nsi
-del %PACKAGE_DIR%\msys\msys.bat
- at echo.
- at echo Copy Python content to PACKAGE_DIR\Python27
- at echo.
-mkdir %PACKAGE_DIR%\Python27
-copy %OSGEO4W_DIR%\apps\Python27\* %PACKAGE_DIR%\Python27
-xcopy %OSGEO4W_DIR%\apps\Python27\DLLs %PACKAGE_DIR%\Python27\DLLs /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\include %PACKAGE_DIR%\Python27\include /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\Lib %PACKAGE_DIR%\Python27\Lib /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\libs %PACKAGE_DIR%\Python27\libs /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\Scripts %PACKAGE_DIR%\Python27\Scripts /S/V/F/I
- at echo.
- at echo Copy Subversion content to PACKAGE_DIR\extrabin & PACKAGE_DIR\extralib
- at echo.
-copy %SVN_PATH%\svn.exe %PACKAGE_DIR%\extrabin
-copy %SVN_PATH%\*.dll %PACKAGE_DIR%\extralib
- at echo.
- at echo Copy env.bat
- at echo.
-copy env.bat %PACKAGE_DIR%\etc
- at echo.
- at echo Packaging Completed
- at echo.
Copied: grass/trunk/mswindows/GRASS-Packager.bat.tmpl (from rev 50843, grass/trunk/mswindows/GRASS-Packager.bat)
--- grass/trunk/mswindows/GRASS-Packager.bat.tmpl (rev 0)
+++ grass/trunk/mswindows/GRASS-Packager.bat.tmpl 2012-02-17 22:53:08 UTC (rev 50854)
@@ -0,0 +1,236 @@
+rem -----------------------------------------------------------------------------------------------------------------------
+rem Self Contained GRASS Automated Packager
+rem Edited by: Marco Pasetti
+rem Revised for OSGeo4W by: Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
+rem Last Update: $Id$
+ at echo off
+rem --------------------------------------------------------------------------------------------------------------------------
+rem Set the script variables
+set PACKAGE_DIR=.\GRASS- at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at -Package
+set OSGEO4W_DIR=c:\osgeo4w
+set GRASS_PREFIX=%OSGEO4W_DIR%\apps\grass\grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@
+set GRASS_BIN_PREFIX=%OSGEO4W_DIR%\bin
+set SVN_PATH=c:\Subversion
+ at echo.
+ at echo -----------------------------------------------------------------------------------------------------------------------
+ at echo Remove the previous Selected Package and create a new PACKAGE_DIR
+ at echo.
+if exist %PACKAGE_DIR% rmdir /S/Q %PACKAGE_DIR%
+mkdir %PACKAGE_DIR%
+ at echo.
+ at echo Copy %GRASS_PREFIX% & %GRASS_BIN_PREFIX% content to PACKAGE_DIR
+ at echo.
+rem xcopy %GRASS_BIN_PREFIX%\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py %PACKAGE_DIR% /S/V/F
+xcopy %GRASS_PREFIX% %PACKAGE_DIR% /S/V/F
+ at echo.
+ at echo Copy Extralibs to PACKAGE_DIR\extralib
+ at echo.
+mkdir %PACKAGE_DIR%\extralib
+copy %OSGEO4W_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
+del %PACKAGE_DIR%\extralib\libgrass_*6.4*.dll
+del %PACKAGE_DIR%\extralib\libgrass_*6.5*.dll
+del %PACKAGE_DIR%\extralib\Qt*4.dll
+rem copy %OSGEO4W_DIR%\pgsql\lib\libpq.dll %PACKAGE_DIR%\extralib
+ at echo.
+ at echo Move GRASS libs from extralib to lib
+ at echo.
+move %PACKAGE_DIR%\extralib\libgrass_*.dll %PACKAGE_DIR%\lib
+ at echo.
+ at echo Copy Extrabins to PACKAGE_DIR\extrabin
+ at echo.
+mkdir %PACKAGE_DIR%\extrabin
+mkdir %PACKAGE_DIR%\extrabin\gdalplugins
+copy %OSGEO4W_DIR%\bin\*.exe %PACKAGE_DIR%\extrabin
+ at echo.
+ at echo Copy SQLite content to PACKAGE_DIR\sqlite
+ at echo.
+mkdir %PACKAGE_DIR%\sqlite
+mkdir %PACKAGE_DIR%\sqlite\bin
+mkdir %PACKAGE_DIR%\sqlite\include
+mkdir %PACKAGE_DIR%\sqlite\lib
+xcopy %OSGEO4W_DIR%\bin\sqlite3.dll %PACKAGE_DIR%\sqlite\bin /S/V/F/I
+copy %OSGEO4W_DIR%\include\btree.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\fts1*.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\hash.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\keywordhash.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\opcodes.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\os.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\os_common.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\pager.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\parse.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\sqlite*.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\vdbe.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\vdbeInt.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\lib\sqlite3_i.lib %PACKAGE_DIR%\sqlite\lib
+ at echo.
+ at echo Copy GPSBABEL executable and dll to PACKAGE_DIR\gpsbabel
+ at echo.
+mkdir %PACKAGE_DIR%\gpsbabel
+copy %OSGEO4W_DIR%\gpsbabel.exe %PACKAGE_DIR%\gpsbabel
+rem copy %OSGEO4W_DIR%\libexpat.dll %PACKAGE_DIR%\gpsbabel
+ at echo.
+ at echo Copy shared PROJ.4 files to PACKAGE_DIR\proj
+ at echo.
+xcopy %OSGEO4W_DIR%\share\proj %PACKAGE_DIR%\proj /S/V/F/I
+ at echo.
+ at echo Copy shared GDAL files to PACKAGE_DIR\share\gdal
+ at echo.
+mkdir %PACKAGE_DIR%\share
+mkdir %PACKAGE_DIR%\share\gdal
+xcopy %OSGEO4W_DIR%\share\gdal %PACKAGE_DIR%\share\gdal /S/V/F/I
+ at echo.
+ at echo Copy shared GEOTIFF files to PACKAGE_DIR\share\epsg_csv
+ at echo.
+mkdir %PACKAGE_DIR%\share\epsg_csv
+xcopy %OSGEO4W_DIR%\share\epsg_csv %PACKAGE_DIR%\share\epsg_csv /S/V/F/I
+ at echo.
+ at echo Copy Tcl/Tk content to PACKAGE_DIR\tcl-tk
+ at echo.
+mkdir %PACKAGE_DIR%\tcl-tk
+mkdir %PACKAGE_DIR%\tcl-tk\bin
+mkdir %PACKAGE_DIR%\tcl-tk\include
+mkdir %PACKAGE_DIR%\tcl-tk\lib
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5
+xcopy %OSGEO4W_DIR%\bin\tclpip85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tcl85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tclsh.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tclsh85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tk85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\wish.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\wish85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+copy %OSGEO4W_DIR%\include\tcl*.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tk*.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tommath_class.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tommath_superclass.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\ttkDecls.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\lib\tcl8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+copy %OSGEO4W_DIR%\lib\tcl8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+copy %OSGEO4W_DIR%\lib\tk8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+copy %OSGEO4W_DIR%\lib\tk8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+xcopy %OSGEO4W_DIR%\lib\tk8.5\ttk %PACKAGE_DIR%\tcl-tk\lib\tk8.5\ttk /S/V/F/I
+xcopy %OSGEO4W_DIR%\lib\tcl8\8.5 %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5 /S/V/F/I
+ at echo.
+ at echo Copy MSYS files to PACKAGE_DIR\msys
+ at echo.
+mkdir %PACKAGE_DIR%\msys
+copy %OSGEO4W_DIR%\apps\msys\* %PACKAGE_DIR%\msys
+xcopy %OSGEO4W_DIR%\apps\msys\bin %PACKAGE_DIR%\msys\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\doc %PACKAGE_DIR%\msys\doc /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\etc %PACKAGE_DIR%\msys\etc /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\info %PACKAGE_DIR%\msys\info /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\lib %PACKAGE_DIR%\msys\lib /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\man %PACKAGE_DIR%\msys\man /S/V/F/I
+del %PACKAGE_DIR%\msys\etc\fstab
+rem delete msys.bat from osgeo4w because there is an adaption (for spaces in installation path) written by GRASS-Installer.nsi
+del %PACKAGE_DIR%\msys\msys.bat
+ at echo.
+ at echo Copy Python content to PACKAGE_DIR\Python27
+ at echo.
+mkdir %PACKAGE_DIR%\Python27
+copy %OSGEO4W_DIR%\apps\Python27\* %PACKAGE_DIR%\Python27
+xcopy %OSGEO4W_DIR%\apps\Python27\DLLs %PACKAGE_DIR%\Python27\DLLs /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python27\include %PACKAGE_DIR%\Python27\include /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python27\Lib %PACKAGE_DIR%\Python27\Lib /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python27\libs %PACKAGE_DIR%\Python27\libs /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python27\Scripts %PACKAGE_DIR%\Python27\Scripts /S/V/F/I
+ at echo.
+ at echo Copy Subversion content to PACKAGE_DIR\extrabin & PACKAGE_DIR\extralib
+ at echo.
+copy %SVN_PATH%\svn.exe %PACKAGE_DIR%\extrabin
+copy %SVN_PATH%\*.dll %PACKAGE_DIR%\extralib
+ at echo.
+ at echo Copy env.bat
+ at echo.
+copy env.bat %PACKAGE_DIR%\etc
+ at echo.
+ at echo Packaging Completed
+ at echo.
Added: grass/trunk/mswindows/Makefile
--- grass/trunk/mswindows/Makefile (rev 0)
+++ grass/trunk/mswindows/Makefile 2012-02-17 22:53:08 UTC (rev 50854)
@@ -0,0 +1,25 @@
+MODULE_TOPDIR = ..
+include $(MODULE_TOPDIR)/include/Make/Other.make
+EXTRA_CLEAN_FILES = GRASS-Packager.bat GRASS-Installer.bat
+SUBDIRS =
+ifneq ($(MINGW),)
+ default: GRASS-Packager.bat GRASS-Installer.nsi
+endif
+GRASS-Packager.bat: GRASS-Packager.bat.tmpl
+ sed \
+ -e 's#@GRASS_VERSION_MAJOR@#$(GRASS_VERSION_MAJOR)#' \
+ -e 's#@GRASS_VERSION_MINOR@#$(GRASS_VERSION_MINOR)#' \
+ -e 's#@GRASS_VERSION_RELEASE@#$(GRASS_VERSION_RELEASE)#' \
+GRASS-Installer.bat: GRASS-Installer.bat.tmpl
+ sed \
+ -e 's#@GRASS_VERSION_SVN@#$(GRASS_VERSION_SVN)#' \
Property changes on: grass/trunk/mswindows/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
