[GRASS-SVN] r50862 - grass/branches/develbranch_6/mswindows
svn_grass at osgeo.org
Sat Feb 18 06:42:46 EST 2012
Author: martinl
Date: 2012-02-18 03:42:46 -0800 (Sat, 18 Feb 2012)
New Revision: 50862
grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl
wingrass: fix GRASS-Installer (start-up scripts)
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl 2012-02-18 06:05:14 UTC (rev 50861)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl 2012-02-18 11:42:46 UTC (rev 50862)
@@ -688,44 +688,10 @@
FileWrite $0 '$\r$\n'
FileWrite $0 'cd "%USERPROFILE%"'
- FileWrite $0 '%GRASS_PYTHON% "%GISBASE%\etc\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py" %*'
+ FileWrite $0 '"%GISBASE%\etc\Init.bat" %*'
FileClose $0
done_create_grass_command.bat:
- ;Create the grass_command_msys.bat
- ClearErrors
- FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}_msys.bat w
- IfErrors done_create_grass_command_msys.bat
- FileWrite $0 '@echo off$\r$\n'
- FileWrite $0 'rem #########################################################################$\r$\n'
- FileWrite $0 'rem #$\r$\n'
- FileWrite $0 'rem # File dynamically created by NSIS installer script;$\r$\n'
- FileWrite $0 'rem # GRASS Initialization (MSYS)$\r$\n'
- FileWrite $0 '$\r$\n'
- FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
- FileWrite $0 'set GRASS_SH=%GISBASE%\msys\bin\sh.exe$\r$\n'
- ${If} $R_HKLM_INSTALL_PATH != ""
- FileWrite $0 'set PATH=$R_HKLM_INSTALL_PATH\bin;%PATH%$\r$\n'
- ${EndIf}
- ${If} $R_HKCU_INSTALL_PATH != ""
- FileWrite $0 'set PATH=$R_HKCU_INSTALL_PATH\bin;%PATH%$\r$\n'
- ${EndIf}
- FileWrite $0 'call "%GISBASE%\etc\env.bat"$\r$\n'
- FileWrite $0 'cd "%USERPROFILE%"'
- FileClose $0
- done_create_grass_command_msys.bat:
;Set the UNIX_LIKE GRASS Path
Var /GLOBAL UNIX_LIKE_DRIVE
Var /GLOBAL UNIX_LIKE_GRASS_PATH
@@ -765,7 +731,7 @@
${EndIf}
${EndIf}
- ;create the $INSTALL_DIR\bin grass_command
+ ;create the grass_command.sh
ClearErrors
FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.sh w
@@ -820,6 +786,10 @@
FileWrite $0 ' export GRASS_PYTHON$\r$\n'
FileWrite $0 'fi$\r$\n'
+ FileWrite $0 '# Set to default web browser$\r$\n'
+ FileWrite $0 'GRASS_HTML_BROWSER=explorer$\r$\n'
+ FileWrite $0 'export GRASS_HTML_BROWSER$\r$\n'
+ FileWrite $0 '$\r$\n'
FileWrite $0 '# Set the GRASS_PROJSHARE variable$\r$\n'
FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
@@ -836,7 +806,9 @@
FileWrite $0 'GEOTIFF_CSV="$INSTALL_DIR\share\epsg_csv"$\r$\n'
FileWrite $0 'export GEOTIFF_CSV$\r$\n'
- FileWrite $0 '"$$GRASS_PYTHON $$GISBASE/etc/grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py" "$$@"'
+ FileWrite $0 'cd "$USERPROFILE"'
+ FileWrite $0 'exec "$$GISBASE/etc/Init.sh" "$$@"'
FileClose $0
done_create_grass_command:
