[GRASS-SVN] r50879 - grass/branches/releasebranch_6_4
svn_grass at osgeo.org
Sun Feb 19 13:44:12 EST 2012
Author: neteler
Date: 2012-02-19 10:44:12 -0800 (Sun, 19 Feb 2012)
New Revision: 50879
grass/branches/releasebranch_6_4/config.guess
grass/branches/releasebranch_6_4/config.sub
updated from master git repository
Modified: grass/branches/releasebranch_6_4/config.guess
--- grass/branches/releasebranch_6_4/config.guess 2012-02-19 18:01:03 UTC (rev 50878)
+++ grass/branches/releasebranch_6_4/config.guess 2012-02-19 18:44:12 UTC (rev 50879)
@@ -1,10 +1,10 @@
#! /bin/sh
# Attempt to guess a canonical system name.
# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-# 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008
-# Free Software Foundation, Inc.
+# 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010,
+# 2011, 2012 Free Software Foundation, Inc.
-timestamp='2008-04-14'
+timestamp='2012-02-10'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
@@ -17,9 +17,7 @@
# General Public License for more details.
# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 51 Franklin Street - Fifth Floor, Boston, MA
-# 02110-1301, USA.
+# along with this program; if not, see <http://www.gnu.org/licenses/>.
# As a special exception to the GNU General Public License, if you
# distribute this file as part of a program that contains a
@@ -27,16 +25,16 @@
# the same distribution terms that you use for the rest of that program.
-# Originally written by Per Bothner <per at bothner.com>.
-# Please send patches to <config-patches at gnu.org>. Submit a context
-# diff and a properly formatted ChangeLog entry.
+# Originally written by Per Bothner. Please send patches (context
+# diff format) to <config-patches at gnu.org> and include a ChangeLog
+# entry.
# This script attempts to guess a canonical system name similar to
# config.sub. If it succeeds, it prints the system name on stdout, and
# exits with 0. Otherwise, it exits with 1.
-# The plan is that this can be called by configure scripts if you
-# don't specify an explicit build system type.
+# You can get the latest version of this script from:
+# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
me=`echo "$0" | sed -e 's,.*/,,'`
@@ -56,8 +54,9 @@
GNU config.guess ($timestamp)
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001,
-2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000,
+2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
+Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -144,7 +143,7 @@
case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
*:NetBSD:*:*)
# NetBSD (nbsd) targets should (where applicable) match one or
- # more of the tupples: *-*-netbsdelf*, *-*-netbsdaout*,
+ # more of the tuples: *-*-netbsdelf*, *-*-netbsdaout*,
# *-*-netbsdecoff* and *-*-netbsd*. For targets that recently
# switched to ELF, *-*-netbsd* would select the old
# object file format. This provides both forward
@@ -170,7 +169,7 @@
arm*|i386|m68k|ns32k|sh3*|sparc|vax)
eval $set_cc_for_build
if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
- | grep __ELF__ >/dev/null
+ | grep -q __ELF__
then
# Once all utilities can be ECOFF (netbsdecoff) or a.out (netbsdaout).
# Return netbsd for either. FIX?
@@ -180,7 +179,7 @@
fi
- os=netbsd
+ os=netbsd
esac
# The OS release
@@ -223,7 +222,7 @@
UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $3}'`
*5.*)
- UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $4}'`
+ UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $4}'`
esac
# According to Compaq, /usr/sbin/psrinfo has been available on
@@ -269,7 +268,10 @@
# A Xn.n version is an unreleased experimental baselevel.
# 1.2 uses "1.2" for uname -r.
echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[PVTX]//' | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
- exit ;;
+ # Reset EXIT trap before exiting to avoid spurious non-zero exit code.
+ exitcode=$?
+ trap '' 0
+ exit $exitcode ;;
Alpha\ *:Windows_NT*:*)
# How do we know it's Interix rather than the generic POSIX subsystem?
# Should we change UNAME_MACHINE based on the output of uname instead
@@ -295,7 +297,7 @@
echo s390-ibm-zvmoe
exit ;;
*:OS400:*:*)
- echo powerpc-ibm-os400
+ echo powerpc-ibm-os400
exit ;;
arm:RISC*:1.[012]*:*|arm:riscix:1.[012]*:*)
echo arm-acorn-riscix${UNAME_RELEASE}
@@ -324,14 +326,33 @@
case `/usr/bin/uname -p` in
sparc) echo sparc-icl-nx7; exit ;;
esac ;;
+ s390x:SunOS:*:*)
+ echo ${UNAME_MACHINE}-ibm-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+ exit ;;
sun4H:SunOS:5.*:*)
echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
exit ;;
sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
exit ;;
+ i86pc:AuroraUX:5.*:* | i86xen:AuroraUX:5.*:*)
+ echo i386-pc-auroraux${UNAME_RELEASE}
+ exit ;;
i86pc:SunOS:5.*:* | i86xen:SunOS:5.*:*)
- echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+ eval $set_cc_for_build
+ SUN_ARCH="i386"
+ # If there is a compiler, see if it is configured for 64-bit objects.
+ # Note that the Sun cc does not turn __LP64__ into 1 like gcc does.
+ # This test works for both compilers.
+ if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
+ if (echo '#ifdef __amd64'; echo IS_64BIT_ARCH; echo '#endif') | \
+ (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
+ grep IS_64BIT_ARCH >/dev/null
+ then
+ SUN_ARCH="x86_64"
+ fi
+ fi
+ echo ${SUN_ARCH}-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
exit ;;
sun4*:SunOS:6*:*)
# According to config.sub, this is the proper way to canonicalize
@@ -375,23 +396,23 @@
# MiNT. But MiNT is downward compatible to TOS, so this should
# be no problem.
atarist[e]:*MiNT:*:* | atarist[e]:*mint:*:* | atarist[e]:*TOS:*:*)
- echo m68k-atari-mint${UNAME_RELEASE}
+ echo m68k-atari-mint${UNAME_RELEASE}
exit ;;
atari*:*MiNT:*:* | atari*:*mint:*:* | atarist[e]:*TOS:*:*)
- exit ;;
+ exit ;;
*falcon*:*MiNT:*:* | *falcon*:*mint:*:* | *falcon*:*TOS:*:*)
exit ;;
milan*:*MiNT:*:* | milan*:*mint:*:* | *milan*:*TOS:*:*)
- echo m68k-milan-mint${UNAME_RELEASE}
- exit ;;
+ echo m68k-milan-mint${UNAME_RELEASE}
+ exit ;;
hades*:*MiNT:*:* | hades*:*mint:*:* | *hades*:*TOS:*:*)
- echo m68k-hades-mint${UNAME_RELEASE}
- exit ;;
+ echo m68k-hades-mint${UNAME_RELEASE}
+ exit ;;
*:*MiNT:*:* | *:*mint:*:* | *:*TOS:*:*)
- echo m68k-unknown-mint${UNAME_RELEASE}
- exit ;;
+ echo m68k-unknown-mint${UNAME_RELEASE}
+ exit ;;
m68k:machten:*:*)
echo m68k-apple-machten${UNAME_RELEASE}
exit ;;
@@ -461,8 +482,8 @@
echo m88k-motorola-sysv3
exit ;;
AViiON:dgux:*:*)
- # DG/UX returns AViiON for all architectures
- UNAME_PROCESSOR=`/usr/bin/uname -p`
+ # DG/UX returns AViiON for all architectures
+ UNAME_PROCESSOR=`/usr/bin/uname -p`
if [ $UNAME_PROCESSOR = mc88100 ] || [ $UNAME_PROCESSOR = mc88110 ]
then
if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx ] || \
@@ -475,7 +496,7 @@
else
echo i586-dg-dgux${UNAME_RELEASE}
fi
- exit ;;
+ exit ;;
M88*:DolphinOS:*:*) # DolphinOS (SVR3)
echo m88k-dolphin-sysv3
exit ;;
@@ -532,7 +553,7 @@
echo rs6000-ibm-aix3.2
fi
exit ;;
- *:AIX:*:[456])
+ *:AIX:*:[4567])
IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
IBM_ARCH=rs6000
@@ -575,52 +596,52 @@
9000/[678][0-9][0-9])
if [ -x /usr/bin/getconf ]; then
sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
- sc_kernel_bits=`/usr/bin/getconf SC_KERNEL_BITS 2>/dev/null`
- case "${sc_cpu_version}" in
- 523) HP_ARCH="hppa1.0" ;; # CPU_PA_RISC1_0
- 528) HP_ARCH="hppa1.1" ;; # CPU_PA_RISC1_1
- 532) # CPU_PA_RISC2_0
- case "${sc_kernel_bits}" in
- 32) HP_ARCH="hppa2.0n" ;;
- 64) HP_ARCH="hppa2.0w" ;;
+ sc_kernel_bits=`/usr/bin/getconf SC_KERNEL_BITS 2>/dev/null`
+ case "${sc_cpu_version}" in
+ 523) HP_ARCH="hppa1.0" ;; # CPU_PA_RISC1_0
+ 528) HP_ARCH="hppa1.1" ;; # CPU_PA_RISC1_1
+ 532) # CPU_PA_RISC2_0
+ case "${sc_kernel_bits}" in
+ 32) HP_ARCH="hppa2.0n" ;;
+ 64) HP_ARCH="hppa2.0w" ;;
'') HP_ARCH="hppa2.0" ;; # HP-UX 10.20
- esac ;;
- esac
+ esac ;;
+ esac
fi
if [ "${HP_ARCH}" = "" ]; then
- sed 's/^ //' << EOF >$dummy.c
+ sed 's/^ //' << EOF >$dummy.c
- #define _HPUX_SOURCE
- #include <stdlib.h>
- #include <unistd.h>
+ #define _HPUX_SOURCE
+ #include <stdlib.h>
+ #include <unistd.h>
- int main ()
- #if defined(_SC_KERNEL_BITS)
- long bits = sysconf(_SC_KERNEL_BITS);
- #endif
- long cpu = sysconf (_SC_CPU_VERSION);
+ int main ()
+ #if defined(_SC_KERNEL_BITS)
+ long bits = sysconf(_SC_KERNEL_BITS);
+ #endif
+ long cpu = sysconf (_SC_CPU_VERSION);
- switch (cpu)
- case CPU_PA_RISC1_0: puts ("hppa1.0"); break;
- case CPU_PA_RISC1_1: puts ("hppa1.1"); break;
- case CPU_PA_RISC2_0:
- switch (bits)
- case 64: puts ("hppa2.0w"); break;
- case 32: puts ("hppa2.0n"); break;
- default: puts ("hppa2.0"); break;
- } break;
- #else /* !defined(_SC_KERNEL_BITS) */
- puts ("hppa2.0"); break;
- #endif
- default: puts ("hppa1.0"); break;
- exit (0);
+ switch (cpu)
+ case CPU_PA_RISC1_0: puts ("hppa1.0"); break;
+ case CPU_PA_RISC1_1: puts ("hppa1.1"); break;
+ case CPU_PA_RISC2_0:
+ switch (bits)
+ case 64: puts ("hppa2.0w"); break;
+ case 32: puts ("hppa2.0n"); break;
+ default: puts ("hppa2.0"); break;
+ } break;
+ #else /* !defined(_SC_KERNEL_BITS) */
+ puts ("hppa2.0"); break;
+ #endif
+ default: puts ("hppa1.0"); break;
+ exit (0);
EOF
(CCOPTS= $CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null) && HP_ARCH=`$dummy`
test -z "$HP_ARCH" && HP_ARCH=hppa
@@ -640,7 +661,7 @@
# => hppa64-hp-hpux11.23
if echo __LP64__ | (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) |
- grep __LP64__ >/dev/null
+ grep -q __LP64__
then
HP_ARCH="hppa2.0w"
else
@@ -711,22 +732,22 @@
exit ;;
C1*:ConvexOS:*:* | convex:ConvexOS:C1*:*)
echo c1-convex-bsd
- exit ;;
+ exit ;;
C2*:ConvexOS:*:* | convex:ConvexOS:C2*:*)
if getsysinfo -f scalar_acc
then echo c32-convex-bsd
else echo c2-convex-bsd
fi
- exit ;;
+ exit ;;
C34*:ConvexOS:*:* | convex:ConvexOS:C34*:*)
echo c34-convex-bsd
- exit ;;
+ exit ;;
C38*:ConvexOS:*:* | convex:ConvexOS:C38*:*)
echo c38-convex-bsd
- exit ;;
+ exit ;;
C4*:ConvexOS:*:* | convex:ConvexOS:C4*:*)
echo c4-convex-bsd
- exit ;;
+ exit ;;
CRAY*Y-MP:*:*:*)
echo ymp-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
exit ;;
@@ -750,14 +771,14 @@
exit ;;
F30[01]:UNIX_System_V:*:* | F700:UNIX_System_V:*:*)
FUJITSU_PROC=`uname -m | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
- FUJITSU_SYS=`uname -p | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/\///'`
- FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
- echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
- exit ;;
+ FUJITSU_SYS=`uname -p | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/\///'`
+ FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
+ echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
+ exit ;;
5000:UNIX_System_V:4.*:*)
- FUJITSU_REL=`echo ${UNAME_RELEASE} | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/ /_/'`
- echo "sparc-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
+ FUJITSU_REL=`echo ${UNAME_RELEASE} | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/ /_/'`
+ echo "sparc-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
exit ;;
i*86:BSD/386:*:* | i*86:BSD/OS:*:* | *:Ascend\ Embedded/OS:*:*)
echo ${UNAME_MACHINE}-pc-bsdi${UNAME_RELEASE}
@@ -769,13 +790,12 @@
echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
exit ;;
*:FreeBSD:*:*)
- case ${UNAME_MACHINE} in
- pc98)
- echo i386-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+ case ${UNAME_PROCESSOR} in
amd64)
echo x86_64-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
- echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+ echo ${UNAME_PROCESSOR}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
esac
exit ;;
i*:CYGWIN*:*)
@@ -784,19 +804,22 @@
*:MINGW*:*)
echo ${UNAME_MACHINE}-pc-mingw32
exit ;;
+ i*:MSYS*:*)
+ echo ${UNAME_MACHINE}-pc-msys
+ exit ;;
i*:windows32*:*)
- # uname -m includes "-pc" on this system.
- echo ${UNAME_MACHINE}-mingw32
+ # uname -m includes "-pc" on this system.
+ echo ${UNAME_MACHINE}-mingw32
exit ;;
i*:PW*:*)
echo ${UNAME_MACHINE}-pc-pw32
exit ;;
- *:Interix*:[3456]*)
+ *:Interix*:*)
+ case ${UNAME_MACHINE} in
x86)
echo i586-pc-interix${UNAME_RELEASE}
exit ;;
- EM64T | authenticamd)
+ authenticamd | genuineintel | EM64T)
echo x86_64-unknown-interix${UNAME_RELEASE}
exit ;;
IA64)
@@ -806,6 +829,9 @@
[345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
echo i${UNAME_MACHINE}-pc-mks
exit ;;
+ 8664:Windows_NT:*)
+ echo x86_64-pc-mks
+ exit ;;
i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
# It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
@@ -835,6 +861,27 @@
i*86:Minix:*:*)
echo ${UNAME_MACHINE}-pc-minix
exit ;;
+ aarch64:Linux:*:*)
+ echo ${UNAME_MACHINE}-unknown-linux-gnu
+ exit ;;
+ aarch64_be:Linux:*:*)
+ UNAME_MACHINE=aarch64_be
+ exit ;;
+ alpha:Linux:*:*)
+ case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
+ EV5) UNAME_MACHINE=alphaev5 ;;
+ EV56) UNAME_MACHINE=alphaev56 ;;
+ PCA56) UNAME_MACHINE=alphapca56 ;;
+ PCA57) UNAME_MACHINE=alphapca56 ;;
+ EV6) UNAME_MACHINE=alphaev6 ;;
+ EV67) UNAME_MACHINE=alphaev67 ;;
+ EV68*) UNAME_MACHINE=alphaev68 ;;
+ esac
+ objdump --private-headers /bin/sh | grep -q ld.so.1
+ if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
+ echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
+ exit ;;
arm*:Linux:*:*)
if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
@@ -842,21 +889,41 @@
then
else
- echo ${UNAME_MACHINE}-unknown-linux-gnueabi
+ if echo __ARM_PCS_VFP | $CC_FOR_BUILD -E - 2>/dev/null \
+ | grep -q __ARM_PCS_VFP
+ then
+ echo ${UNAME_MACHINE}-unknown-linux-gnueabi
+ else
+ echo ${UNAME_MACHINE}-unknown-linux-gnueabihf
+ fi
fi
exit ;;
avr32*:Linux:*:*)
exit ;;
cris:Linux:*:*)
- echo cris-axis-linux-gnu
+ echo ${UNAME_MACHINE}-axis-linux-gnu
exit ;;
crisv32:Linux:*:*)
- echo crisv32-axis-linux-gnu
exit ;;
frv:Linux:*:*)
- echo frv-unknown-linux-gnu
exit ;;
+ hexagon:Linux:*:*)
+ exit ;;
+ i*86:Linux:*:*)
+ LIBC=gnu
+ #ifdef __dietlibc__
+ LIBC=dietlibc
+ #endif
+EOF
+ eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC'`
+ echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
+ exit ;;
ia64:Linux:*:*)
exit ;;
@@ -866,75 +933,34 @@
m68*:Linux:*:*)
exit ;;
- mips:Linux:*:*)
+ mips:Linux:*:* | mips64:Linux:*:*)
#undef CPU
- #undef mips
- #undef mipsel
+ #undef ${UNAME_MACHINE}
+ #undef ${UNAME_MACHINE}el
#if defined(__MIPSEL__) || defined(__MIPSEL) || defined(_MIPSEL) || defined(MIPSEL)
- CPU=mipsel
+ CPU=${UNAME_MACHINE}el
#else
#if defined(__MIPSEB__) || defined(__MIPSEB) || defined(_MIPSEB) || defined(MIPSEB)
- CPU=mips
#else
CPU=
#endif
#endif
EOF
- eval "`$CC_FOR_BUILD -E $dummy.c 2>/dev/null | sed -n '
- /^CPU/{
- s: ::g
- p
+ eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^CPU'`
test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
- mips64:Linux:*:*)
- eval $set_cc_for_build
- #undef CPU
- #undef mips64
- #undef mips64el
- #if defined(__MIPSEL__) || defined(__MIPSEL) || defined(_MIPSEL) || defined(MIPSEL)
- CPU=mips64el
- #else
- #if defined(__MIPSEB__) || defined(__MIPSEB) || defined(_MIPSEB) || defined(MIPSEB)
- CPU=mips64
- #else
- CPU=
- #endif
- #endif
-EOF
- /^CPU/{
- s: ::g
- p
- test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
or32:Linux:*:*)
- echo or32-unknown-linux-gnu
exit ;;
- ppc:Linux:*:*)
- echo powerpc-unknown-linux-gnu
+ padre:Linux:*:*)
+ echo sparc-unknown-linux-gnu
exit ;;
- ppc64:Linux:*:*)
- echo powerpc64-unknown-linux-gnu
+ parisc64:Linux:*:* | hppa64:Linux:*:*)
+ echo hppa64-unknown-linux-gnu
exit ;;
- alpha:Linux:*:*)
- case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
- EV5) UNAME_MACHINE=alphaev5 ;;
- EV56) UNAME_MACHINE=alphaev56 ;;
- PCA56) UNAME_MACHINE=alphapca56 ;;
- PCA57) UNAME_MACHINE=alphapca56 ;;
- EV6) UNAME_MACHINE=alphaev6 ;;
- EV67) UNAME_MACHINE=alphaev67 ;;
- EV68*) UNAME_MACHINE=alphaev68 ;;
- esac
- objdump --private-headers /bin/sh | grep ld.so.1 >/dev/null
- if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
- echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
- exit ;;
parisc:Linux:*:* | hppa:Linux:*:*)
# Look for CPU level
case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
@@ -943,14 +969,17 @@
*) echo hppa-unknown-linux-gnu ;;
esac
exit ;;
- parisc64:Linux:*:* | hppa64:Linux:*:*)
- echo hppa64-unknown-linux-gnu
+ ppc64:Linux:*:*)
+ echo powerpc64-unknown-linux-gnu
exit ;;
+ ppc:Linux:*:*)
+ echo powerpc-unknown-linux-gnu
+ exit ;;
s390:Linux:*:* | s390x:Linux:*:*)
echo ${UNAME_MACHINE}-ibm-linux
exit ;;
sh64*:Linux:*:*)
exit ;;
sh*:Linux:*:*)
@@ -958,75 +987,18 @@
sparc:Linux:*:* | sparc64:Linux:*:*)
exit ;;
+ tile*:Linux:*:*)
+ exit ;;
vax:Linux:*:*)
echo ${UNAME_MACHINE}-dec-linux-gnu
exit ;;
x86_64:Linux:*:*)
- echo x86_64-unknown-linux-gnu
exit ;;
xtensa*:Linux:*:*)
exit ;;
- i*86:Linux:*:*)
- # The BFD linker knows what the default object file format is, so
- # first see if it will tell us. cd to the root directory to prevent
- # problems with other programs or directories called `ld' in the path.
- # Set LC_ALL=C to ensure ld outputs messages in English.
- ld_supported_targets=`cd /; LC_ALL=C ld --help 2>&1 \
- | sed -ne '/supported targets:/!d
- s/[ ][ ]*/ /g
- s/.*supported targets: *//
- s/ .*//
- p'`
- case "$ld_supported_targets" in
- elf32-i386)
- TENTATIVE="${UNAME_MACHINE}-pc-linux-gnu"
- a.out-i386-linux)
- echo "${UNAME_MACHINE}-pc-linux-gnuaout"
- exit ;;
- # Either a pre-BFD a.out linker (linux-gnuoldld) or
- # one that does not give us useful --help.
- echo "${UNAME_MACHINE}-pc-linux-gnuoldld"
- exit ;;
- esac
- # Determine whether the default compiler is a.out or elf
- #include <features.h>
- #ifdef __ELF__
- # ifdef __GLIBC__
- # if __GLIBC__ >= 2
- LIBC=gnu
- # else
- LIBC=gnulibc1
- # endif
- # else
- LIBC=gnulibc1
- # endif
- #else
- #if defined(__INTEL_COMPILER) || defined(__PGI) || defined(__SUNPRO_C) || defined(__SUNPRO_CC)
- LIBC=gnu
- #else
- LIBC=gnuaout
- #endif
- #endif
- #ifdef __dietlibc__
- LIBC=dietlibc
- #endif
-EOF
- /^LIBC/{
- s: ::g
- p
- test x"${LIBC}" != x && {
- echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
- exit
- test x"${TENTATIVE}" != x && { echo "${TENTATIVE}"; exit; }
i*86:DYNIX/ptx:4*:*)
# ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
# earlier versions are messed up and put the nodename in both
@@ -1034,11 +1006,11 @@
echo i386-sequent-sysv4
exit ;;
i*86:UNIX_SV:4.2MP:2.*)
- # Unixware is an offshoot of SVR4, but it has its own version
- # number series starting with 2...
- # I am not positive that other SVR4 systems won't match this,
+ # Unixware is an offshoot of SVR4, but it has its own version
+ # number series starting with 2...
+ # I am not positive that other SVR4 systems won't match this,
# I just have to hope. -- rms.
- # Use sysv4.2uw... so that sysv4* matches it.
+ # Use sysv4.2uw... so that sysv4* matches it.
echo ${UNAME_MACHINE}-pc-sysv4.2uw${UNAME_VERSION}
exit ;;
i*86:OS/2:*:*)
@@ -1055,7 +1027,7 @@
i*86:syllable:*:*)
echo ${UNAME_MACHINE}-pc-syllable
exit ;;
- i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.0*:*)
+ i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.[02]*:*)
echo i386-unknown-lynxos${UNAME_RELEASE}
exit ;;
i*86:*DOS:*:*)
@@ -1070,7 +1042,7 @@
fi
exit ;;
i*86:*:5:[678]*)
- # UnixWare 7.x, OpenUNIX and OpenServer 6.
+ # UnixWare 7.x, OpenUNIX and OpenServer 6.
case `/bin/uname -X | grep "^Machine"` in
*486*) UNAME_MACHINE=i486 ;;
*Pentium) UNAME_MACHINE=i586 ;;
@@ -1098,10 +1070,13 @@
exit ;;
pc:*:*:*)
# Left here for compatibility:
- # uname -m prints for DJGPP always 'pc', but it prints nothing about
- # the processor, so we play safe by assuming i386.
- echo i386-pc-msdosdjgpp
- exit ;;
+ # uname -m prints for DJGPP always 'pc', but it prints nothing about
+ # the processor, so we play safe by assuming i586.
+ # Note: whatever this is, it MUST be the same as what config.sub
+ # prints for the "djgpp" host, or else GDB configury will decide that
+ # this is a cross-build.
+ echo i586-pc-msdosdjgpp
+ exit ;;
Intel:Mach:3*:*)
echo i386-pc-mach3
exit ;;
@@ -1136,8 +1111,18 @@
/bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
&& { echo i586-ncr-sysv4.3${OS_REL}; exit; } ;;
3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
- /bin/uname -p 2>/dev/null | grep 86 >/dev/null \
- && { echo i486-ncr-sysv4; exit; } ;;
+ /bin/uname -p 2>/dev/null | grep 86 >/dev/null \
+ && { echo i486-ncr-sysv4; exit; } ;;
+ NCR*:*:4.2:* | MPRAS*:*:4.2:*)
+ OS_REL='.3'
+ test -r /etc/.relid \
+ && OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
+ && { echo i486-ncr-sysv4.3${OS_REL}; exit; }
+ /bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
+ && { echo i586-ncr-sysv4.3${OS_REL}; exit; }
+ /bin/uname -p 2>/dev/null | /bin/grep pteron >/dev/null \
+ && { echo i586-ncr-sysv4.3${OS_REL}; exit; } ;;
m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
echo m68k-unknown-lynxos${UNAME_RELEASE}
exit ;;
@@ -1150,7 +1135,7 @@
rs6000:LynxOS:2.*:*)
echo rs6000-unknown-lynxos${UNAME_RELEASE}
exit ;;
- PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.0*:*)
+ PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.[02]*:*)
echo powerpc-unknown-lynxos${UNAME_RELEASE}
exit ;;
SM[BE]S:UNIX_SV:*:*)
@@ -1170,10 +1155,10 @@
echo ns32k-sni-sysv
fi
exit ;;
- PENTIUM:*:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
- # says <Richard.M.Bartel at ccMail.Census.GOV>
- echo i586-unisys-sysv4
- exit ;;
+ PENTIUM:*:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
+ # says <Richard.M.Bartel at ccMail.Census.GOV>
+ echo i586-unisys-sysv4
+ exit ;;
*:UNIX_System_V:4*:FTX*)
# From Gerald Hewes <hewes at openmarket.com>.
# How about differentiating between stratus architectures? -djm
@@ -1199,11 +1184,11 @@
exit ;;
R[34]000:*System_V*:*:* | R4000:UNIX_SYSV:*:* | R*000:UNIX_SV:*:*)
if [ -d /usr/nec ]; then
- echo mips-nec-sysv${UNAME_RELEASE}
+ echo mips-nec-sysv${UNAME_RELEASE}
else
- echo mips-unknown-sysv${UNAME_RELEASE}
+ echo mips-unknown-sysv${UNAME_RELEASE}
fi
- exit ;;
+ exit ;;
BeBox:BeOS:*:*) # BeOS running on hardware made by Be, PPC only.
echo powerpc-be-beos
exit ;;
@@ -1243,6 +1228,16 @@
*:Darwin:*:*)
UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
case $UNAME_PROCESSOR in
+ i386)
+ if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
+ then
+ UNAME_PROCESSOR="x86_64"
+ fi
+ fi ;;
unknown) UNAME_PROCESSOR=powerpc ;;
esac
echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
@@ -1258,6 +1253,9 @@
*:QNX:*:4*)
echo i386-pc-qnx
exit ;;
+ NEO-?:NONSTOP_KERNEL:*:*)
+ echo neo-tandem-nsk${UNAME_RELEASE}
+ exit ;;
NSE-?:NONSTOP_KERNEL:*:*)
echo nse-tandem-nsk${UNAME_RELEASE}
exit ;;
@@ -1303,13 +1301,13 @@
echo pdp10-unknown-its
exit ;;
SEI:*:*:SEIUX)
- echo mips-sei-seiux${UNAME_RELEASE}
+ echo mips-sei-seiux${UNAME_RELEASE}
exit ;;
*:DragonFly:*:*)
echo ${UNAME_MACHINE}-unknown-dragonfly`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
exit ;;
*:*VMS:*:*)
- UNAME_MACHINE=`(uname -p) 2>/dev/null`
+ UNAME_MACHINE=`(uname -p) 2>/dev/null`
case "${UNAME_MACHINE}" in
A*) echo alpha-dec-vms ; exit ;;
I*) echo ia64-dec-vms ; exit ;;
@@ -1324,6 +1322,12 @@
i*86:rdos:*:*)
echo ${UNAME_MACHINE}-pc-rdos
exit ;;
+ i*86:AROS:*:*)
+ echo ${UNAME_MACHINE}-pc-aros
+ exit ;;
+ x86_64:VMkernel:*:*)
+ echo ${UNAME_MACHINE}-unknown-esx
+ exit ;;
esac
#echo '(No uname command or uname output not recognized.)' 1>&2
@@ -1346,11 +1350,11 @@
#include <sys/param.h>
printf ("m68k-sony-newsos%s\n",
#ifdef NEWSOS4
- "4"
+ "4"
#else
#endif
- ); exit (0);
+ ); exit (0);
#endif
#endif
Modified: grass/branches/releasebranch_6_4/config.sub
--- grass/branches/releasebranch_6_4/config.sub 2012-02-19 18:01:03 UTC (rev 50878)
+++ grass/branches/releasebranch_6_4/config.sub 2012-02-19 18:44:12 UTC (rev 50879)
@@ -1,10 +1,10 @@
#! /bin/sh
# Configuration validation subroutine script.
# This file is (in principle) common to ALL GNU software.
# The presence of a machine in this file suggests that SOME GNU software
@@ -21,9 +21,7 @@
# GNU General Public License for more details.
-# 02110-1301, USA.
@@ -32,13 +30,16 @@
+# diff and a properly formatted GNU ChangeLog entry.
# Configuration subroutine to validate and canonicalize a configuration type.
# Supply the specified configuration type as an argument.
# If it is invalid, we print an error message on stderr and exit with code 1.
# Otherwise, we print the canonical config type on stdout and succeed.
+# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
# This file is supposed to be the same for all GNU packages
# and recognize all the CPU types, system types and aliases
# that are meaningful with *any* GNU software.
@@ -72,8 +73,9 @@
version="\
GNU config.sub ($timestamp)
@@ -120,12 +122,18 @@
# Here we must recognize all the valid KERNEL-OS combinations.
maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
case $maybe_os in
- nto-qnx* | linux-gnu* | linux-dietlibc | linux-newlib* | linux-uclibc* | \
- uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | \
+ nto-qnx* | linux-gnu* | linux-android* | linux-dietlibc | linux-newlib* | \
+ linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | \
+ knetbsd*-gnu* | netbsd*-gnu* | \
+ kopensolaris*-gnu* | \
storm-chaos* | os2-emx* | rtmk-nova*)
os=-$maybe_os
basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
+ android-linux)
+ os=-linux-android
+ basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`-unknown
basic_machine=`echo $1 | sed 's/-[^-]*$//'`
if [ $basic_machine != $1 ]
@@ -148,10 +156,13 @@
-convergent* | -ncr* | -news | -32* | -3600* | -3100* | -hitachi* |\
-c[123]* | -convex* | -sun | -crds | -omron* | -dg | -ultra | -tti* | \
-harris | -dolphin | -highlevel | -gould | -cbm | -ns | -masscomp | \
- -apple | -axis | -knuth | -cray)
+ -apple | -axis | -knuth | -cray | -microblaze)
os=
basic_machine=$1
+ -bluegene*)
+ os=-cnk
-sim | -cisco | -oki | -wec | -winbond)
os=
basic_machine=$1
@@ -166,10 +177,10 @@
os=-chorusos
basic_machine=$1
- -chorusrdb)
- os=-chorusrdb
+ -chorusrdb)
+ os=-chorusrdb
basic_machine=$1
-hiux*)
os=-hiuxwe2
@@ -238,17 +249,23 @@
# Some are omitted here because they have special meanings below.
1750a | 580 \
| a29k \
+ | aarch64 | aarch64_be \
| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
| am33_2.0 \
| arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr | avr32 \
+ | be32 | be64 \
| bfin \
| c4x | clipper \
| d10v | d30v | dlx | dsp16xx \
+ | epiphany \
| fido | fr30 | frv \
| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
+ | hexagon \
| i370 | i860 | i960 | ia64 \
| ip2k | iq2000 \
+ | le32 | le64 \
+ | lm32 \
| m32c | m32r | m32rle | m68000 | m68k | m88k \
| maxq | mb | microblaze | mcore | mep | metag \
| mips | mipsbe | mipseb | mipsel | mipsle \
@@ -270,29 +287,42 @@
| mipsisa64sr71k | mipsisa64sr71kel \
| mipstx39 | mipstx39el \
| mn10200 | mn10300 \
+ | moxie \
| mt \
| msp430 \
+ | nds32 | nds32le | nds32be \
| nios | nios2 \
| ns16k | ns32k \
+ | open8 \
| or32 \
| pdp10 | pdp11 | pj | pjl \
- | powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
+ | powerpc | powerpc64 | powerpc64le | powerpcle \
| pyramid \
+ | rl78 | rx \
| score \
- | sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
+ | sh | sh[1234] | sh[24]a | sh[24]aeb | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
| sh64 | sh64le \
| sparc | sparc64 | sparc64b | sparc64v | sparc86x | sparclet | sparclite \
| sparcv8 | sparcv9 | sparcv9b | sparcv9v \
- | spu | strongarm \
- | tahoe | thumb | tic4x | tic80 | tron \
- | v850 | v850e \
+ | spu \
+ | tahoe | tic4x | tic54x | tic55x | tic6x | tic80 | tron \
+ | ubicom32 \
+ | v850 | v850e | v850e1 | v850e2 | v850es | v850e2v3 \
| we32k \
- | x86 | xc16x | xscale | xscalee[bl] | xstormy16 | xtensa \
- | z8k)
+ | x86 | xc16x | xstormy16 | xtensa \
+ | z8k | z80)
basic_machine=$basic_machine-unknown
- m6811 | m68hc11 | m6812 | m68hc12)
- # Motorola 68HC11/12.
+ c54x)
+ basic_machine=tic54x-unknown
+ c55x)
+ basic_machine=tic55x-unknown
+ c6x)
+ basic_machine=tic6x-unknown
+ m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | picochip)
os=-none
@@ -302,6 +332,21 @@
basic_machine=mt-unknown
+ strongarm | thumb | xscale)
+ basic_machine=arm-unknown
+ xgate)
+ basic_machine=$basic_machine-unknown
+ os=-none
+ xscaleeb)
+ basic_machine=armeb-unknown
+ xscaleel)
+ basic_machine=armel-unknown
# We use `pc' rather than `unknown'
# because (1) that's what they normally are, and
# (2) the word "unknown" tends to confuse beginning users.
@@ -316,24 +361,29 @@
# Recognize the basic CPU types with company name.
580-* \
| a29k-* \
+ | aarch64-* | aarch64_be-* \
| alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
| alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
| arm-* | armbe-* | armle-* | armeb-* | armv*-* \
| avr-* | avr32-* \
+ | be32-* | be64-* \
| bfin-* | bs2000-* \
- | c[123]* | c30-* | [cjt]90-* | c4x-* | c54x-* | c55x-* | c6x-* \
+ | c[123]* | c30-* | [cjt]90-* | c4x-* \
| clipper-* | craynv-* | cydra-* \
| d10v-* | d30v-* | dlx-* \
| elxsi-* \
| f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
| h8300-* | h8500-* \
| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
+ | hexagon-* \
| i*86-* | i860-* | i960-* | ia64-* \
| ip2k-* | iq2000-* \
+ | le32-* | le64-* \
+ | lm32-* \
| m32c-* | m32r-* | m32rle-* \
| m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
- | m88110-* | m88k-* | maxq-* | mcore-* | metag-* \
+ | m88110-* | m88k-* | maxq-* | mcore-* | metag-* | microblaze-* \
| mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
| mips16-* \
| mips64-* | mips64el-* \
@@ -355,27 +405,32 @@
| mmix-* \
| mt-* \
| msp430-* \
+ | nds32-* | nds32le-* | nds32be-* \
| nios-* | nios2-* \
| none-* | np1-* | ns16k-* | ns32k-* \
+ | open8-* \
| orion-* \
| pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
- | powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
+ | powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* \
| pyramid-* \
- | romp-* | rs6000-* \
- | sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
+ | rl78-* | romp-* | rs6000-* | rx-* \
+ | sh-* | sh[1234]-* | sh[24]a-* | sh[24]aeb-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
| shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
| sparc-* | sparc64-* | sparc64b-* | sparc64v-* | sparc86x-* | sparclet-* \
| sparclite-* \
- | sparcv8-* | sparcv9-* | sparcv9b-* | sparcv9v-* | strongarm-* | sv1-* | sx?-* \
- | tahoe-* | thumb-* \
- | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* | tile-* \
+ | sparcv8-* | sparcv9-* | sparcv9b-* | sparcv9v-* | sv1-* | sx?-* \
+ | tahoe-* \
+ | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* \
+ | tile*-* \
| tron-* \
- | v850-* | v850e-* | vax-* \
+ | ubicom32-* \
+ | v850-* | v850e-* | v850e1-* | v850es-* | v850e2-* | v850e2v3-* \
+ | vax-* \
| we32k-* \
- | x86-* | x86_64-* | xc16x-* | xps100-* | xscale-* | xscalee[bl]-* \
+ | x86-* | x86_64-* | xc16x-* | xps100-* \
| xstormy16-* | xtensa*-* \
| ymp-* \
- | z8k-*)
+ | z8k-* | z80-*)
# Recognize the basic CPU types without company name, with glob match.
xtensa*)
@@ -397,7 +452,7 @@
basic_machine=a29k-amd
os=-udi
- abacus)
+ abacus)
basic_machine=abacus-unknown
adobe68k)
@@ -443,6 +498,10 @@
basic_machine=m68k-apollo
os=-bsd
+ aros)
+ basic_machine=i386-pc
+ os=-aros
aux)
basic_machine=m68k-apple
os=-aux
@@ -459,10 +518,27 @@
basic_machine=bfin-`echo $basic_machine | sed 's/^[^-]*-//'`
os=-linux
+ bluegene*)
+ basic_machine=powerpc-ibm
+ os=-cnk
+ c54x-*)
+ basic_machine=tic54x-`echo $basic_machine | sed 's/^[^-]*-//'`
+ c55x-*)
+ basic_machine=tic55x-`echo $basic_machine | sed 's/^[^-]*-//'`
+ c6x-*)
+ basic_machine=tic6x-`echo $basic_machine | sed 's/^[^-]*-//'`
c90)
basic_machine=c90-cray
os=-unicos
+ cegcc)
+ os=-cegcc
convex-c1)
basic_machine=c1-convex
os=-bsd
@@ -491,7 +567,7 @@
basic_machine=craynv-cray
os=-unicosmp
- cr16)
+ cr16 | cr16-*)
basic_machine=cr16-unknown
os=-elf
@@ -649,7 +725,6 @@
i370-ibm* | ibm*)
basic_machine=i370-ibm
-# I'm not sure what "Sysv32" means. Should this be sysv3.2?
i*86v32)
basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
os=-sysv32
@@ -707,6 +782,9 @@
basic_machine=ns32k-utek
os=-sysv
+ microblaze)
+ basic_machine=microblaze-xilinx
mingw32)
os=-mingw32
@@ -743,10 +821,18 @@
ms1-*)
basic_machine=`echo $basic_machine | sed -e 's/ms1-/mt-/'`
+ msys)
+ os=-msys
mvs)
os=-mvs
+ nacl)
+ basic_machine=le32-unknown
+ os=-nacl
ncr3000)
basic_machine=i486-ncr
os=-sysv4
@@ -811,6 +897,12 @@
np1)
basic_machine=np1-gould
+ neo-tandem)
+ basic_machine=neo-tandem
+ nse-tandem)
+ basic_machine=nse-tandem
nsr-tandem)
basic_machine=nsr-tandem
@@ -893,9 +985,10 @@
power) basic_machine=power-ibm
- ppc) basic_machine=powerpc-unknown
+ ppc | ppcbe) basic_machine=powerpc-unknown
- ppc-*) basic_machine=powerpc-`echo $basic_machine | sed 's/^[^-]*-//'`
+ ppc-* | ppcbe-*)
+ basic_machine=powerpc-`echo $basic_machine | sed 's/^[^-]*-//'`
ppcle | powerpclittle | ppc-le | powerpc-little)
basic_machine=powerpcle-unknown
@@ -989,6 +1082,9 @@
basic_machine=i860-stratus
os=-sysv4
+ strongarm-* | thumb-*)
+ basic_machine=arm-`echo $basic_machine | sed 's/^[^-]*-//'`
sun2)
basic_machine=m68000-sun
@@ -1045,20 +1141,8 @@
basic_machine=t90-cray
os=-unicos
- tic54x | c54x*)
- basic_machine=tic54x-unknown
- os=-coff
- tic55x | c55x*)
- basic_machine=tic55x-unknown
- os=-coff
- tic6x | c6x*)
- basic_machine=tic6x-unknown
- os=-coff
tile*)
- basic_machine=tile-unknown
os=-linux-gnu
tx39)
@@ -1128,6 +1212,9 @@
xps | xps100)
basic_machine=xps100-honeywell
+ xscale-* | xscalee[bl]-*)
+ basic_machine=`echo $basic_machine | sed 's/^xscale/arm/'`
ymp)
basic_machine=ymp-cray
os=-unicos
@@ -1136,6 +1223,10 @@
basic_machine=z8k-unknown
os=-sim
+ z80-*-coff)
+ basic_machine=z80-unknown
+ os=-sim
none)
basic_machine=none-none
os=-none
@@ -1174,7 +1265,7 @@
we32k)
basic_machine=we32k-att
- sh[1234] | sh[24]a | sh[34]eb | sh[1234]le | sh[23]ele)
+ sh[1234] | sh[24]a | sh[24]aeb | sh[34]eb | sh[1234]le | sh[23]ele)
basic_machine=sh-unknown
sparc | sparcv8 | sparcv9 | sparcv9b | sparcv9v)
@@ -1221,9 +1312,12 @@
if [ x"$os" != x"" ]
then
case $os in
- # First match some system type aliases
- # that might get confused with valid system types.
+ # First match some system type aliases
+ # that might get confused with valid system types.
# -solaris* is a basic system type, with this one exception.
+ -auroraux)
+ os=-auroraux
-solaris1 | -solaris1.*)
os=`echo $os | sed -e 's|solaris1|sunos4|'`
@@ -1244,10 +1338,11 @@
# Each alternative MUST END IN A *, to match a version number.
# -sysv* is not here because it comes later, after sysvr4.
-gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
- | -*vms* | -sco* | -esix* | -isc* | -aix* | -sunos | -sunos[34]*\
- | -hpux* | -unos* | -osf* | -luna* | -dgux* | -solaris* | -sym* \
+ | -*vms* | -sco* | -esix* | -isc* | -aix* | -cnk* | -sunos | -sunos[34]*\
+ | -hpux* | -unos* | -osf* | -luna* | -dgux* | -auroraux* | -solaris* \
+ | -sym* | -kopensolaris* \
| -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
- | -aos* \
+ | -aos* | -aros* \
| -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
| -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
| -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
@@ -1256,9 +1351,10 @@
| -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
| -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
| -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
- | -chorusos* | -chorusrdb* \
- | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
- | -mingw32* | -linux-gnu* | -linux-newlib* | -linux-uclibc* \
+ | -chorusos* | -chorusrdb* | -cegcc* \
+ | -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
+ | -mingw32* | -linux-gnu* | -linux-android* \
+ | -linux-newlib* | -linux-uclibc* \
| -uxpv* | -beos* | -mpeix* | -udk* \
| -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
| -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
@@ -1266,7 +1362,7 @@
| -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
| -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
| -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
- | -skyos* | -haiku* | -rdos* | -toppers* | -drops*)
+ | -skyos* | -haiku* | -rdos* | -toppers* | -drops* | -es*)
# Remember, each alternative MUST END IN *, to match a version number.
-qnx*)
@@ -1305,7 +1401,7 @@
-opened*)
os=-openedition
- -os400*)
+ -os400*)
os=-os400
-wince*)
@@ -1354,7 +1450,7 @@
-sinix*)
os=-sysv4
- -tpf*)
+ -tpf*)
os=-tpf
-triton*)
@@ -1399,6 +1495,8 @@
-dicos*)
os=-dicos
+ -nacl*)
-none)
@@ -1421,10 +1519,10 @@
# system, and we'll never get to this point.
case $basic_machine in
- score-*)
+ score-*)
os=-elf
- spu-*)
+ spu-*)
os=-elf
*-acorn)
@@ -1436,9 +1534,18 @@
arm*-semi)
os=-aout
- c4x-* | tic4x-*)
- os=-coff
+ c4x-* | tic4x-*)
+ os=-coff
+ tic54x-*)
+ os=-coff
+ tic55x-*)
+ os=-coff
+ tic6x-*)
+ os=-coff
# This must come before the *-dec entry.
pdp10-*)
os=-tops20
@@ -1457,14 +1564,11 @@
m68000-sun)
os=-sunos3
- # This also exists in the configure program, but was not the
- # default.
- # os=-sunos4
m68*-cisco)
os=-aout
- mep-*)
+ mep-*)
os=-elf
mips*-cisco)
@@ -1491,7 +1595,7 @@
*-ibm)
os=-aix
- *-knuth)
+ *-knuth)
os=-mmixware
*-wec)
@@ -1596,7 +1700,7 @@
-sunos*)
vendor=sun
- -aix*)
+ -cnk*|-aix*)
vendor=ibm
-beos*)
