[GRASS-SVN] r50884 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Sun Feb 19 16:32:40 EST 2012
Author: martinl
Date: 2012-02-19 13:32:40 -0800 (Sun, 19 Feb 2012)
New Revision: 50884
grass/branches/releasebranch_6_4/lib/python/core.py
grass/branches/releasebranch_6_4/lib/python/task.py
pythonlib: sync'ed with devbr6
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py 2012-02-19 20:44:13 UTC (rev 50883)
+++ grass/branches/releasebranch_6_4/lib/python/core.py 2012-02-19 21:32:40 UTC (rev 50884)
@@ -61,9 +61,9 @@
class ScriptError(Exception):
def __init__(self, msg):
self.value = msg
def __str__(self):
- return repr(self.value)
+ return self.value
raise_on_error = False # raise exception instead of calling fatal()
debug_level = 0 # DEBUG level
@@ -710,7 +710,7 @@
result[mapset] = []
mapset = None
- for line in read_command("g.mlist", flags = "m",
+ for line in read_command("g.mlist", quiet = True, flags = "m",
type = type, pattern = pattern).splitlines():
try:
name, mapset = line.split('@')
@@ -1027,8 +1027,8 @@
@code
print version()
- {'date': '2011', 'libgis_date': '2011-04-13 13:19:03 +0200 (Wed, 13 Apr 2011)',
- 'version': '6.4.2svn', 'libgis_revision': '45934', 'revision': '47445'}
+ {'date': '2011', 'libgis_date': '2011-02-26 21:31:24 +0100 (Sat, 26 Feb 2011)',
+ 'version': '6.4.3', 'libgis_revision': '45467', 'revision': '47305'}
@endcode
data = parse_command('g.version',
Modified: grass/branches/releasebranch_6_4/lib/python/task.py
--- grass/branches/releasebranch_6_4/lib/python/task.py 2012-02-19 20:44:13 UTC (rev 50883)
+++ grass/branches/releasebranch_6_4/lib/python/task.py 2012-02-19 21:32:40 UTC (rev 50884)
@@ -169,8 +169,8 @@
return f
raise ValueError, _("Flag not found: %s") % aFlag
- def getCmdError(self):
- """!Get error string produced by getCmd(ignoreErrors = False)
+ def get_cmd_error(self):
+ """!Get error string produced by get_cmd(ignoreErrors = False)
@return list of errors
@@ -191,7 +191,7 @@
return errorList
- def getCmd(self, ignoreErrors = False, ignoreRequired = False):
+ def get_cmd(self, ignoreErrors = False, ignoreRequired = False, ignoreDefault = True):
"""!Produce an array of command name and arguments for feeding
into some execve-like command processor.
@@ -199,6 +199,7 @@
far, even though it would not be a correct command for GRASS
@param ignoreRequired True to ignore required flags, otherwise
'<required>' is shown
+ @param ignoreDefault True to ignore parameters with default values
cmd = [self.name]
@@ -212,16 +213,19 @@
if flag['suppress_required']:
suppress_required = True
for p in self.params:
- if p.get('value','') == '' and p.get('required', False):
+ if p.get('value', '') == '' and p.get('required', False):
if p.get('default', '') != '':
cmd += [ '%s=%s' % (p['name'], p['default']) ]
elif ignoreErrors and not suppress_required and not ignoreRequired:
cmd += [ '%s=%s' % (p['name'], _('<required>')) ]
- elif p.get('value','') != '' and p['value'] != p.get('default','') :
- # Output only values that have been set, and different from defaults
+ elif p.get('value', '') == '' and p.get('default', '') != '' and not ignoreDefault:
+ cmd += [ '%s=%s' % (p['name'], p['default']) ]
+ elif p.get('value', '') != '' and \
+ (p['value'] != p.get('default', '') or not ignoreDefault):
+ # output only values that have been set, and different from defaults
cmd += [ '%s=%s' % (p['name'], p['value']) ]
- errList = self.getCmdError()
+ errList = self.get_cmd_error()
if ignoreErrors is False and errList:
raise ValueError, '\n'.join(errList)
@@ -435,7 +439,9 @@
cmdout, cmderr = Popen(args, stdout = PIPE,
stderr = PIPE).communicate()
+ if cmderr:
+ raise ScriptError, _("Unable to fetch interface description for command '%(cmd)s'."
+ "\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' : decode(cmderr) }
except OSError, e:
"\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' : e }
