[GRASS-SVN] r50895 - in grass/branches/releasebranch_6_4:
gui/wxpython/nviz include lib/nviz lib/ogsf misc/m.nviz.image
svn_grass at osgeo.org
Mon Feb 20 04:41:51 EST 2012
Author: annakrat
Date: 2012-02-20 01:41:50 -0800 (Mon, 20 Feb 2012)
New Revision: 50895
Added:
grass/branches/releasebranch_6_4/misc/m.nviz.image/cplane.c
grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
grass/branches/releasebranch_6_4/include/gstypes.h
grass/branches/releasebranch_6_4/include/nviz.h
grass/branches/releasebranch_6_4/include/ogsf_proto.h
grass/branches/releasebranch_6_4/lib/nviz/change_view.c
grass/branches/releasebranch_6_4/lib/nviz/cplanes_obj.c
grass/branches/releasebranch_6_4/lib/nviz/draw.c
grass/branches/releasebranch_6_4/lib/nviz/lights.c
grass/branches/releasebranch_6_4/lib/nviz/nviz.c
grass/branches/releasebranch_6_4/lib/nviz/position.c
grass/branches/releasebranch_6_4/lib/ogsf/GS2.c
grass/branches/releasebranch_6_4/lib/ogsf/Gp3.c
grass/branches/releasebranch_6_4/lib/ogsf/gs.c
grass/branches/releasebranch_6_4/lib/ogsf/gsd_objs.c
grass/branches/releasebranch_6_4/lib/ogsf/gsd_views.c
grass/branches/releasebranch_6_4/lib/ogsf/gvld.c
grass/branches/releasebranch_6_4/misc/m.nviz.image/args.c
grass/branches/releasebranch_6_4/misc/m.nviz.image/description.html
grass/branches/releasebranch_6_4/misc/m.nviz.image/local_proto.h
grass/branches/releasebranch_6_4/misc/m.nviz.image/main.c
grass/branches/releasebranch_6_4/misc/m.nviz.image/surface.c
grass/branches/releasebranch_6_4/misc/m.nviz.image/vector.c
grass/branches/releasebranch_6_4/misc/m.nviz.image/volume.c
ogsflib, nvizlib, m.nviz.image: synchronize with devbr6
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py 2012-02-20 09:41:50 UTC (rev 50895)
@@ -24,6 +24,7 @@
import copy
import math
import types
+import tempfile
from threading import Thread
Modified: grass/branches/releasebranch_6_4/include/gstypes.h
--- grass/branches/releasebranch_6_4/include/gstypes.h 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/include/gstypes.h 2012-02-20 09:41:50 UTC (rev 50895)
@@ -326,12 +326,21 @@
float shine; /* 0. to 128. */
+struct georot
+ int do_rot; /* do rotation */
+ double rot_angle; /* rotation angle */
+ double rot_axes[3]; /* rotation axis */
+ GLdouble rotMatrix[16]; /* rotation matrix */
typedef struct
int coord_sys; /* latlon, equal area, etc */
int view_proj; /* perspective, ortho */
int infocus; /* fixed center of view - true or false */
float from_to[2][4];
+ struct georot rotate;
int twist, fov, incl, look; /* 10ths of degrees */
float real_to[4], vert_exag; /* a global Z exag */
float scale;
Modified: grass/branches/releasebranch_6_4/include/nviz.h
--- grass/branches/releasebranch_6_4/include/nviz.h 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/include/nviz.h 2012-02-20 09:41:50 UTC (rev 50895)
@@ -84,6 +84,21 @@
int where[4];
+struct arrow_data
+ unsigned long color;
+ float size;
+ float where[3];
+struct scalebar_data
+ int id;
+ float size;
+ float where[3];
typedef struct
/* ranges */
@@ -101,7 +116,15 @@
/* fringe */
int num_fringes;
struct fringe_data **fringe;
+ /* north arrow */
+ int draw_arrow;
+ struct arrow_data *arrow;
+ /* scalebar */
+ int num_scalebars;
+ struct scalebar_data **scalebar;
/* background color */
int bgcolor;
@@ -129,16 +152,34 @@
int Nviz_resize_window(int, int);
int Nviz_update_ranges(nv_data *);
int Nviz_set_viewpoint_position(double, double);
+void Nviz_get_viewpoint_position(double *, double *);
int Nviz_set_viewpoint_height(double);
+void Nviz_get_viewpoint_height(double *);
int Nviz_set_viewpoint_persp(int);
int Nviz_set_viewpoint_twist(int);
int Nviz_change_exag(nv_data *, double);
+int Nviz_look_here(double, double);
+void Nviz_get_modelview(double *);
+void Nviz_set_rotation(double, double, double, double);
+void Nviz_unset_rotation(void);
+void Nviz_init_rotation(void);
+void Nviz_flythrough(nv_data *, float *, int *, int);
/* cplanes_obj.c */
int Nviz_new_cplane(nv_data *, int);
+int Nviz_on_cplane(nv_data *, int);
int Nviz_off_cplane(nv_data *, int);
int Nviz_draw_cplane(nv_data *, int, int);
+int Nviz_num_cplanes(nv_data *);
+int Nviz_get_current_cplane(nv_data *);
+int Nviz_set_cplane_rotation(nv_data *, int, float, float, float);
+int Nviz_get_cplane_rotation(nv_data *, int, float *, float *, float *);
+int Nviz_set_cplane_translation(nv_data *, int, float, float, float);
+int Nviz_get_cplane_translation(nv_data *, int, float *, float *, float *);
+int Nviz_set_fence_color(nv_data *, int);
+int Nviz_set_cplane_here(nv_data *, int, float, float);
/* draw.c */
int Nviz_draw_all_surf(nv_data *);
int Nviz_draw_all_vect();
@@ -146,6 +187,11 @@
int Nviz_draw_all_vol();
int Nviz_draw_all(nv_data *);
int Nviz_draw_quick(nv_data *, int);
+int Nviz_load_image(GLubyte *, int, int, int);
+void Nviz_draw_image(int, int, int, int, int);
+void Nviz_set_2D(int, int);
+void Nviz_del_texture(int);
+void Nviz_get_max_texture(int *);
/* exag.c */
int Nviz_get_exag_height(double *, double *, double *);
@@ -158,6 +204,7 @@
int Nviz_set_light_ambient(nv_data *, int, double);
int Nviz_init_light(nv_data *, int);
int Nviz_new_light(nv_data *);
+void Nviz_draw_model(nv_data *);
/* map_obj.c */
int Nviz_new_map_obj(int, const char *, double, nv_data *);
@@ -177,11 +224,25 @@
double, int, int, int, int);
struct fringe_data *Nviz_set_fringe(nv_data *, int, unsigned long,
+void Nviz_draw_fringe(nv_data *data);
+int Nviz_draw_arrow(nv_data *);
+int Nviz_set_arrow(nv_data *, int, int, float, unsigned int);
+void Nviz_delete_arrow(nv_data *);
+struct scalebar_data * Nviz_new_scalebar(nv_data *, int, float *, float, unsigned int);
+struct scalebar_data * Nviz_set_scalebar(nv_data *, int , int, int, float, unsigned int);
+void Nviz_draw_scalebar(nv_data *);
+void Nviz_delete_scalebar(nv_data *, int);
/* position.c */
void Nviz_init_view(nv_data *);
int Nviz_set_focus_state(int);
int Nviz_set_focus_map(int, int);
+int Nviz_has_focus(nv_data *);
+int Nviz_set_focus(nv_data *, float, float, float);
+int Nviz_get_focus(nv_data *, float *, float *, float *);
+float Nviz_get_xyrange(nv_data *);
+int Nviz_get_zrange(nv_data *, float *, float *);
+float Nviz_get_longdim(nv_data *);
/* render.c */
struct render_window *Nviz_new_render_window();
Modified: grass/branches/releasebranch_6_4/include/ogsf_proto.h
--- grass/branches/releasebranch_6_4/include/ogsf_proto.h 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/include/ogsf_proto.h 2012-02-20 09:41:50 UTC (rev 50895)
@@ -86,6 +86,8 @@
int GS_surf_exists(int);
int GS_new_surface(void);
int GS_new_light(void);
+void GS_set_light_reset(int);
+int GS_get_light_reset(void);
void GS_setlight_position(int, float, float, float, int);
void GS_setlight_color(int, float, float, float);
void GS_setlight_ambient(int, float, float, float);
@@ -166,6 +168,11 @@
void GS_get_viewdir(float *);
void GS_set_viewdir(float *);
void GS_set_fov(int);
+void GS_set_rotation(double, double, double, double);
+void GS_get_rotation_matrix(double *);
+void GS_set_rotation_matrix(double *);
+void GS_init_rotation(void);
+void GS_unset_rotation(void);
int GS_get_fov(void);
int GS_get_twist(void);
void GS_set_twist(int);
@@ -498,6 +505,7 @@
int gsd_arrow_onsurf(float *, float *, unsigned long, int, geosurf *);
void gsd_3darrow(float *, unsigned long, float, float, float *, float);
int gsd_scalebar(float *, float, GLuint, unsigned long, unsigned long);
+int gsd_scalebar_v2(float *, float, GLuint, unsigned long, unsigned long);
void primitive_cone(unsigned long);
void primitive_cylinder(unsigned long, int);
@@ -583,6 +591,7 @@
void gsd_real2model(Point3);
void gsd_model2real(Point3);
void gsd_model2surf(geosurf *, Point3);
+void gsd_surf2model(Point3);
void gsd_surf2real(geosurf *, Point3);
void gsd_real2surf(geosurf *, Point3);
Modified: grass/branches/releasebranch_6_4/lib/nviz/change_view.c
--- grass/branches/releasebranch_6_4/lib/nviz/change_view.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/nviz/change_view.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -12,6 +12,8 @@
\author Updated/modified by Martin Landa <landa.martin gmail.com> (Google SoC 2008/2010)
+#include <math.h>
#include <grass/glocale.h>
#include <grass/nviz.h>
@@ -125,6 +127,25 @@
return 1;
+void Nviz_get_viewpoint_position(double *x_pos, double *y_pos)
+ float from[3];
+ double xpos, ypos;
+ GS_get_from(from);
+ xpos = (from[X] + RANGE_OFFSET) / RANGE;
+ ypos = (from[Y] + RANGE_OFFSET) / RANGE;
+ *x_pos = xpos;
+ *x_pos = (*x_pos < 0) ? 0 : (*x_pos > 1.0) ? 1.0 : *x_pos;
+ *y_pos = 1.0 - ypos;
+ *y_pos = (*y_pos < 0) ? 0 : (*y_pos > 1.0) ? 1.0 : *y_pos;
+ if (xpos < 0.0 || xpos > 1.0 || ypos < 0.0 || ypos > 1.0) {
+ G_debug(3, "Invalid view position coordinates, using %f,%f",
+ *x_pos, 1.0 - *y_pos);
\brief Change viewpoint height
@@ -157,6 +178,16 @@
return 1;
+void Nviz_get_viewpoint_height(double *height)
+ float from[3];
+ G_debug(1, "Nviz_get_viewpoint_height():");
+ GS_get_from_real(from);
+ *height = from[Z];
\brief Change viewpoint perspective (field of view)
@@ -221,3 +252,127 @@
return 1;
+ \brief Change focused point
+ \param sx,sy screen coordinates
+ \return 1
+int Nviz_look_here(double sx, double sy)
+ G_debug(1, "Nviz_look_here(): screen coordinates = %f %f", sx, sy);
+ GS_look_here(sx, sy);
+ return 1;
+ \brief Get current modelview matrix
+void Nviz_get_modelview(double *modelMatrix)
+ glGetDoublev(GL_MODELVIEW_MATRIX, modelMatrix);
+ \brief Set rotation parameters
+ Rotate scene by given parameters related to mouse drag event
+ (difference from current state).
+ Coordinates determine the second point of rotation axis,
+ the first point is (0, 0, 0).
+ \param angle angle
+ \param x,y,z axis coordinate
+void Nviz_set_rotation(double angle, double x, double y, double z)
+ G_debug(3, "Nviz_set_rotation(): angle = %f, x = %f, y = %f, z = %f", angle, x, y, z);
+ GS_set_rotation(angle, x, y, z);
+ \brief Stop scene rotation
+ GS_unset_rotation();
+ GS_init_rotation();
+ \brief Fly through the scene
+ Computes parameters needed for moving scene.
+ Changes viewpoint and viewdir.
+ Based on visualization/nviz/src/togl_flythrough.c and simplified.
+ \param fly_info values computed from mouse movement
+ \param scale rate of movement
+ \param lateral type of movement
+void Nviz_flythrough(nv_data *data, float *fly_info, int *scale, int lateral)
+ float dir[3], from[4], cur_from[4], cur_dir[4];
+ float speed, h, p, sh, ch, sp, cp;
+ float diff_x, diff_y, diff_z;
+ float quasi_zero;
+ quasi_zero = 0.0001;
+ GS_get_from(cur_from);
+ GS_get_viewdir(cur_dir);
+ p = asin(cur_dir[Z]);
+ h = atan2(- cur_dir[X], - cur_dir[Y]);
+ speed = scale[0] * fly_info[0];
+ h += scale[1] * fly_info[1]; /* change heading */
+ if (!lateral) /* in case of "lateral" doesn't change pitch */
+ p -= scale[1] * fly_info[2];
+ h = fmod(h + M_PI, 2 * M_PI) - M_PI;
+ sh = sin(h);
+ ch = cos(h);
+ sp = sin(p);
+ cp = cos(p);
+ dir[X] = -sh * cp;
+ dir[Y] = -ch * cp;
+ dir[Z] = sp;
+ if (lateral) {
+ from[X] = cur_from[X] + speed * dir[Y];
+ from[Y] = cur_from[Y] - speed * dir[X];
+ from[Z] = cur_from[Z] + scale[0] * fly_info[2];
+ else {
+ from[X] = cur_from[X] + speed * dir[X];
+ from[Y] = cur_from[Y] + speed * dir[Y];
+ /* not sure how this should behave (change Z coord or not ?)*/
+ from[Z] = cur_from[Z]; /* + speed * dir[Z]*/
+ diff_x = fabs(cur_dir[X] - dir[X]);
+ diff_y = fabs(cur_dir[Y] - dir[Y]);
+ diff_z = fabs(cur_dir[Z] - dir[Z]);
+ if ( /* something has changed */
+ (diff_x > quasi_zero) || (diff_y > quasi_zero) ||
+ (diff_z > quasi_zero) || (cur_from[X] != from[X]) ||
+ (cur_from[Y] != from[Y]) || (cur_from[Z] != from[Z])
+ GS_moveto(from);
+ GS_set_viewdir(dir); /* calls gsd_set_view */
Modified: grass/branches/releasebranch_6_4/lib/nviz/cplanes_obj.c
--- grass/branches/releasebranch_6_4/lib/nviz/cplanes_obj.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/nviz/cplanes_obj.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -15,6 +15,7 @@
static void cp_draw(nv_data *, int, int, int);
+static geoview Gv;
\brief Creates a clip plane object
@@ -36,6 +37,21 @@
+ \brief Turn on (make current) the given clip plane.
+ \param data nviz data
+ \param cplane id
+int Nviz_on_cplane(nv_data * data, int id)
+ data->cur_cplane = id;
+ data->cp_on[id] = 1;
+ GS_set_cplane(id);
+ return 1;
\brief Turn off (make inactive) the given clip plane
@@ -118,3 +134,153 @@
return;
+ \brief Return the number of clip planes objects currently allocated.
+int Nviz_num_cplanes(nv_data * data)
+ return data->num_cplanes;
+ \brief Get the current active cutplane.
+int Nviz_get_current_cplane(nv_data * data)
+ return data->cur_cplane;
+ \brief Set the rotation for the current clip plane.
+ \param id id of current clip plane
+ \param dx,dy,dz rotation parameters
+ \return 1
+int Nviz_set_cplane_rotation(nv_data * data, int id, float dx, float dy, float dz)
+ data->cp_rot[id][X] = dx;
+ data->cp_rot[id][Y] = dy;
+ data->cp_rot[id][Z] = dz;
+ GS_set_cplane_rot(id, data->cp_rot[id][X], data->cp_rot[id][Y],
+ data->cp_rot[id][Z]);
+ cp_draw(data, data->cur_cplane, -1, -1);
+ return 1;
+ \brief Get the rotation values for the current clip plane.
+ \return 1
+int Nviz_get_cplane_rotation(nv_data * data, int id, float *dx, float *dy, float *dz)
+ *dx = data->cp_rot[id][X];
+ *dy = data->cp_rot[id][Y];
+ *dz = data->cp_rot[id][Z];
+ return 1;
+ \brief Set the translation for the current clip plane.
+ \param dx,dy,dz values for setting translation
+ \return 1
+int Nviz_set_cplane_translation(nv_data * data, int id, float dx, float dy, float dz)
+ data->cp_trans[id][X] = dx;
+ data->cp_trans[id][Y] = dy;
+ data->cp_trans[id][Z] = dz;
+ GS_set_cplane_trans(id, data->cp_trans[id][X], data->cp_trans[id][Y],
+ data->cp_trans[id][Z]);
+ return 1;
+ \brief Get the translation values for the current clip plane.
+ \param dx,dy,dz translation parameters
+int Nviz_get_cplane_translation(nv_data * data, int id, float *dx, float *dy, float *dz)
+ *dx = data->cp_trans[id][X];
+ *dy = data->cp_trans[id][Y];
+ *dz = data->cp_trans[id][Z];
+ return 1;
+ \brief Set appropriate fence color
+ \param type type of fence (FC_ABOVE, FC_BELOW, FC_BLEND, FC_GREY, FC_OFF)
+int Nviz_set_fence_color(nv_data * data, int type)
+ GS_set_fencecolor(type);
+ return 1;
+int Nviz_set_cplane_here(nv_data *data, int cplane, float sx, float sy)
+ float x, y, z, len, los[2][3];
+ float dx, dy, dz;
+ float n, s, w, e;
+ Point3 realto, dir;
+ int id;
+ geosurf *gs;
+ if (GS_get_selected_point_on_surface(sx, sy, &id, &x, &y, &z)) {
+ gs = gs_get_surf(id);
+ if (gs) {
+ realto[X] = x - gs->ox + gs->x_trans;
+ realto[Y] = y - gs->oy + gs->y_trans;
+ realto[Z] = z + gs->z_trans;
+ else
+ return 0;
+ else {
+ if (gsd_get_los(los, (short)sx, (short)sy)) {
+ len = GS_distance(Gv.from_to[FROM], Gv.real_to);
+ GS_v3dir(los[FROM], los[TO], dir);
+ GS_v3mult(dir, len);
+ realto[X] = Gv.from_to[FROM][X] + dir[X];
+ realto[Y] = Gv.from_to[FROM][Y] + dir[Y];
+ realto[Z] = Gv.from_to[FROM][Z] + dir[Z];
+ else
+ return 0;
+ Nviz_get_cplane_translation(data, cplane, &dx, &dy, &dz);
+ GS_get_region(&n, &s, &w, &e);
+ dx = realto[X] - (e - w) / 2.;
+ dy = realto[Y] - (n - s) / 2.;
+ Nviz_set_cplane_translation(data, cplane, dx, dy, dz);
+ return 1;
Modified: grass/branches/releasebranch_6_4/lib/nviz/draw.c
--- grass/branches/releasebranch_6_4/lib/nviz/draw.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/nviz/draw.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -6,15 +6,20 @@
Based on visualization/nviz/src/draw.c and
- (C) 2008, 2010 by the GRASS Development Team
+ (C) 2008, 2010-2011 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Textures by Anna Kratochvilova
+#ifndef GL_CLAMP_TO_EDGE
+#define GL_CLAMP_TO_EDGE 0x812F
+#endif
static int sort_surfs_max(int *, int *, int *, int);
@@ -232,11 +237,23 @@
if (draw_vol)
Nviz_draw_all_vol(data);
for(i = 0; i < data->num_fringes; i++) {
struct fringe_data * f = data->fringe[i];
GS_draw_fringe(f->id, f->color, f->elev, f->where);
+ /* North Arrow */
+ if (data->draw_arrow) {
+ gsd_north_arrow(data->arrow->where, data->arrow->size,
+ (GLuint)NULL, data->arrow->color, data->arrow->color);
+ /* scale bar */
+ for (i = 0; i < data->num_scalebars; i++) {
+ struct scalebar_data *s = data->scalebar[i];
+ gsd_scalebar_v2(s->where, s->size, 0, s->color, s->color);
GS_done_draw();
GS_set_draw(GSD_BACK);
@@ -287,3 +304,119 @@
return 1;
+ \brief Load image into texture
+ \param image_data image data
+ \param width, height image screen size
+ \param alpha has alpha channel
+int Nviz_load_image(GLubyte *image_data, int width, int height, int alpha)
+ unsigned int texture_id;
+ int in_format;
+ GLenum format;
+ if (alpha)
+ in_format = 4;
+ format = GL_RGBA;
+ else
+ in_format = 3;
+ format = GL_RGB;
+ glGenTextures( 1, &texture_id);
+ glBindTexture(GL_TEXTURE_2D, texture_id);
+ glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
+ glTexImage2D(GL_TEXTURE_2D, 0, in_format, width, height, 0,format,
+ GL_UNSIGNED_BYTE, image_data);
+ glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
+ glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
+ glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
+ glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
+ glTexEnvi(GL_TEXTURE_ENV, GL_TEXTURE_ENV_MODE, GL_REPLACE);
+ return texture_id;
+ \brief Set ortho view for drawing images
+void Nviz_set_2D(int width, int height)
+ glEnable(GL_BLEND); // images are transparent
+ glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
+ glMatrixMode(GL_PROJECTION);
+ glLoadIdentity();
+ glOrtho(0, width, 0, height, -1, 1);
+ // set coordinate system from upper left corner
+ glScalef(1, -1, 1);
+ glTranslatef(0, -height, 0);
+ glMatrixMode(GL_MODELVIEW);
+ glLoadIdentity();
+ \brief Draw image as texture
+ \param x, y image coordinates
+ \param width, height image size
+ \param texture_id texture id
+void Nviz_draw_image(int x, int y, int width, int height, int texture_id)
+ GS_set_draw(GSD_FRONT);
+ glEnable(GL_TEXTURE_2D);
+ glBegin(GL_QUADS);
+ glTexCoord2d(0.0,1.0);
+ glVertex2d(x, y);
+ glTexCoord2d(0.0,0.0);
+ glVertex2d(x, y + height);
+ glTexCoord2d(1.0,0.0);
+ glVertex2d(x + width, y + height);
+ glTexCoord2d(1.0,1.0);
+ glVertex2d(x + width, y);
+ glEnd();
+ GS_done_draw();
+ glDisable(GL_TEXTURE_2D);
+ \brief Delete texture
+void Nviz_del_texture(int texture_id)
+ GLuint t[1];
+ t[0] = texture_id;
+ glDeleteTextures(1, t);
+ \brief Get maximum texture size
+void Nviz_get_max_texture(int *size)
+ glGetIntegerv(GL_MAX_TEXTURE_SIZE, size);
Modified: grass/branches/releasebranch_6_4/lib/nviz/lights.c
--- grass/branches/releasebranch_6_4/lib/nviz/lights.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/nviz/lights.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -39,16 +39,16 @@
x, y, xpos, 1.0 - ypos);
- num--;
- data->light[num].id = num + 1;
+ data->light[num].id = num;
data->light[num].x = x;
data->light[num].y = y;
data->light[num].z = z;
data->light[num].w = w;
G_debug(1, "Nviz_set_light_position(): num = %d x = %f y = %f z = %f w = %f",
- num + 1, x, y, z, w);
- GS_setlight_position(num + 1, x, y, z, w);
+ num, x, y, z, w);
+ GS_setlight_position(num, x, y, z, w);
return 1;
@@ -64,7 +64,6 @@
double r, g, b;
- num--;
data->light[num].brt = value;
r = data->light[num].r * data->light[num].brt;
@@ -72,8 +71,8 @@
b = data->light[num].b * data->light[num].brt;
G_debug(1, "Nviz_set_light_bright(): num = %d value = %f r = %f g = %f b = %f",
- num + 1, value, r, g, b);
- GS_setlight_color(num + 1, r, g, b);
+ num, value, r, g, b);
+ GS_setlight_color(num, r, g, b);
return 1;
@@ -90,7 +89,6 @@
double r, g, b;
- num--;
data->light[num].r = red / 255.;
data->light[num].g = green / 255.;
data->light[num].b = blue / 255.;
@@ -100,8 +98,8 @@
G_debug(1, "Nviz_set_light_color(): num = %d r = %d/%f g = %d/%f b = %d/%f",
- num + 1, red, r, green, g, blue, b);
+ num, red, r, green, g, blue, b);
return 1;
@@ -115,14 +113,13 @@
int Nviz_set_light_ambient(nv_data * data, int num, double value)
- num--;
data->light[num].ar = value;
data->light[num].ag = value;
data->light[num].ab = value;
G_debug(1, "Nviz_set_light_ambient(): num = %d value = %f",
- num + 1, value);
- GS_setlight_ambient(num + 1, value, value, value);
+ num, value);
+ GS_setlight_ambient(num, value, value, value);
return 1;
@@ -135,8 +132,8 @@
int Nviz_init_light(nv_data * data, int num)
- num--;
- if (num >= MAX_LIGHTS) {
+ G_debug(1, "Nviz_init_light(): num = %d", num);
+ if (num > MAX_LIGHTS) {
return 0;
@@ -180,3 +177,16 @@
return 1;
+ \brief Draw lighting model
+void Nviz_draw_model(nv_data * data)
+ GS_ready_draw();
+ GS_draw_lighting_model();
+ GS_done_draw();
+ GS_set_draw(GSD_BACK);
Modified: grass/branches/releasebranch_6_4/lib/nviz/nviz.c
--- grass/branches/releasebranch_6_4/lib/nviz/nviz.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/nviz/nviz.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -37,14 +37,24 @@
/* lights */
- for (i = 0; i < MAX_LIGHTS; i++) {
+ GS_set_light_reset(1);
+ for (i = 0; i < MAX_LIGHTS - 1; i++) {
Nviz_new_light(data);
/* fringe */
data->num_fringes = 0;
data->fringe = NULL;
+ /* north arrow */
+ data->draw_arrow = 0;
+ data->arrow = NULL;
+ /* scale bar*/
+ data->num_scalebars = 0;
+ data->scalebar = NULL;
return;
@@ -61,6 +71,19 @@
+ if (data->arrow) {
+ G_free(data->arrow);
+ for (i = 0; data->num_scalebars; i++) {
+ G_free(data->scalebar[i]);
+ data->scalebar[i] = NULL;
@@ -134,6 +157,7 @@
if (num < 1)
return NULL;
id = surf[0];
+ G_free(surf);
@@ -177,6 +201,7 @@
if (num < 1)
return NULL;
id = surf[0];
+ G_free(surf);
for (i = 0; i < data->num_fringes; i++) {
@@ -199,3 +224,211 @@
return f;
+/*! Draw fringe
+ int i;
+ for (i = 0; i < data->num_fringes; i++) {
+ struct fringe_data *f = data->fringe[i];
+ GS_draw_fringe(f->id, f->color, f->elev, f->where);
+ \brief Sets the North Arrow position and return world coords
+ \param size arrow length
+ \param color arrow/text color
+int Nviz_set_arrow(nv_data *data,
+ int sx, int sy, float size,
+ unsigned int color)
+ int id, pt[2];
+ int *surf_list, num_surfs;
+ float coords[3];
+ struct arrow_data *arw;
+ if (GS_num_surfs() > 0) {
+ surf_list = GS_get_surf_list(&num_surfs);
+ id = surf_list[0];
+ G_free(surf_list);
+ pt[0] = sx;
+ pt[1] = sy;
+ GS_set_Narrow(pt, id, coords);
+ data->arrow->color = color;
+ data->arrow->size = size;
+ data->arrow->where[0] = coords[0];
+ data->arrow->where[1] = coords[1];
+ data->arrow->where[2] = coords[2];
+ else {
+ arw = (struct arrow_data *) G_malloc(sizeof(struct arrow_data));
+ arw->color = color;
+ arw->size = size;
+ arw->where[0] = coords[0];
+ arw->where[1] = coords[1];
+ arw->where[2] = coords[2];
+ data->arrow = arw;
+ return 1;
+ return 0;
+ \brief Draws the North Arrow
+int Nviz_draw_arrow(nv_data *data)
+ struct arrow_data *arw = data->arrow;
+ GLuint FontBase = 0; /* don't know how to get fontbase*/
+ data->draw_arrow = 1;
+ gsd_north_arrow(arw->where, arw->size, FontBase, arw->color, arw->color);
+ return 1;
+ \brief Deletes the North Arrow
+void Nviz_delete_arrow(nv_data *data)
+ return;
+/*! Add new scalebar
+ \param bar_id scale bar id
+ \param coords real(?) coordinates
+ \param size scale bar length
+ \param color scalebar/text color
+ \return pointer to allocated scalebar_data structure
+ \return NULL on error
+struct scalebar_data *Nviz_new_scalebar(nv_data *data,
+ int bar_id, float *coords, float size,
+ struct scalebar_data *s;
+ s = (struct scalebar_data *) G_malloc(sizeof(struct scalebar_data));
+ s->id = bar_id;
+ s->color = color;
+ s->size = size;
+ s->where[0] = coords[0];
+ s->where[1] = coords[1];
+ s->where[2] = coords[2];
+ data->scalebar = (struct scalebar_data **) G_realloc(data->scalebar,
+ data->num_scalebars + 1 * sizeof(struct scalebar_data *));
+ data->scalebar[data->num_scalebars++] = s;
+ return s;
+ \brief Sets the scale bar position and return world coords
+ \return NULL when there's no surface
+struct scalebar_data *Nviz_set_scalebar(nv_data *data, int bar_id,
+ int i, id, pt[2];
+ float coords[3];
+ pt[0] = sx;
+ pt[1] = sy;
+ GS_set_Narrow(pt, id, coords); /* the same like arrow */
+ s = data->scalebar[i];
+ if (s->id == bar_id) {
+ s->color = color;
+ s->size = size;
+ return s;
+ s = Nviz_new_scalebar(data, bar_id, coords, size, color);
+ return s;
+ return NULL;
+ \brief Draws the Scale bar
+void Nviz_draw_scalebar(nv_data *data)
+ int i;
+ gsd_scalebar_v2(s->where, s->size, FontBase, s->color, s->color);
+ \brief Deletes scale bar
+void Nviz_delete_scalebar(nv_data *data, int bar_id)
+ if (bar_id < data->num_scalebars) {
+ G_free(data->scalebar[bar_id]);
+ data->scalebar[bar_id] = NULL;
+ data->num_scalebars--;
Modified: grass/branches/releasebranch_6_4/lib/nviz/position.c
--- grass/branches/releasebranch_6_4/lib/nviz/position.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/nviz/position.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -1,10 +1,10 @@
\file lib/nviz/position.c
\brief Nviz library -- Position, focus settings
Based on visualization/nviz/src/position.c
@@ -20,21 +20,21 @@
Set position to center of view
-void Nviz_init_view(nv_data *data)
+void Nviz_init_view(nv_data * data)
GS_init_view();
Nviz_set_focus_state(1); /* center of view */
/* set default lights (1 & 2) */
Nviz_set_light_position(data, 1, 0.68, -0.68, 0.80, 0.0);
- Nviz_set_light_bright(data, 1, 0.8);
- Nviz_set_light_color(data, 1, 255, 255, 255);
- Nviz_set_light_ambient(data, 1, 0.2);
+ Nviz_set_light_bright(data, 1, 0.8);
+ Nviz_set_light_color(data, 1, 255, 255, 255);
+ Nviz_set_light_ambient(data, 1, 0.2);
Nviz_set_light_position(data, 2, 0.0, 0.0, 1.0, 0.0);
- Nviz_set_light_bright(data, 2, 0.5);
- Nviz_set_light_color(data, 2, 255, 255, 255);
- Nviz_set_light_ambient(data, 2, 0.3);
+ Nviz_set_light_bright(data, 2, 0.5);
+ Nviz_set_light_color(data, 2, 255, 255, 255);
+ Nviz_set_light_ambient(data, 2, 0.3);
return;
@@ -109,3 +109,97 @@
return id;
+ \brief Get focus
+ \param x,y,z focus coordinates
+int Nviz_get_focus(nv_data * data, float *x, float *y, float *z)
+ float realto[3];
+ /* Get current center */
+ GS_get_focus(realto);
+ *x = realto[0];
+ *y = realto[1];
+ *z = realto[2];
+ // old nviz code is more complicated and it doesn't work properly,
+ // no idea why
+ return 1;
+ \brief Set focus
+ \param x, y, z focus coordinates
+int Nviz_set_focus(nv_data * data, float x, float y, float z)
+ float realto[3];
+ realto[0] = x;
+ realto[1] = y;
+ realto[2] = z;
+ GS_set_focus(realto);
+ // no idea why
+ return 1;
+ \brief Test focus
+int Nviz_has_focus(nv_data * data)
+ float realto[3];
+ if (GS_get_focus(realto))
+ return 1;
+ else
+ return 0;
+ \brief Get xy range
+float Nviz_get_xyrange(nv_data * data)
+ return data->xyrange;
+ \brief Get z range
+ \param min,max z range
+int Nviz_get_zrange(nv_data * data, float *min, float *max)
+ GS_get_zrange_nz(min, max);
+ return 1;
+ \brief Get largest dimension
+float Nviz_get_longdim(nv_data * data)
+ float dim;
+ GS_get_longdim(&dim);
+ return dim;
Modified: grass/branches/releasebranch_6_4/lib/ogsf/GS2.c
--- grass/branches/releasebranch_6_4/lib/ogsf/GS2.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/ogsf/GS2.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -78,6 +78,7 @@
static struct Cell_head wind;
static int Buffermode;
static int Numlights = 0;
+static int Resetlight = 1;
static int Modelshowing = 0;
void void_func(void)
@@ -113,9 +114,13 @@
Gv.scale = GS_UNIT_SIZE / Longdim;
+ G_debug(1, "GS_libinit(): n=%f s=%f w=%f e=%f scale=%f first=%d",
+ Region[0], Region[1], Region[2], Region[3], Gv.scale, first);
Cxl_func = void_func;
Swap_func = void_func;
if (first) {
gs_init();
@@ -244,7 +249,16 @@
return (-1);
+void GS_set_light_reset(int i)
+ Resetlight = i;
+ if (i)
+ Numlights = 0;
+ return Resetlight;
\brief Add new model light
@@ -253,12 +267,12 @@
- static int first = 1;
int i;
- if (first) {
- first = 0;
+ if (GS_get_light_reset()) {
+ GS_set_light_reset(0);
Gv.lights[i].position[X] = Gv.lights[i].position[Y] = 0.0;
Gv.lights[i].position[Z] = 1.0;
@@ -277,10 +291,10 @@
gsd_deflight(Numlights + 1, &(Gv.lights[Numlights]));
gsd_switchlight(Numlights + 1, 1);
- return (++Numlights);
+ return ++Numlights;
- return (-1);
+ return -1;
@@ -1548,32 +1562,33 @@
int GS_delete_surface(int id)
- int i, j, found = 0;
- G_debug(3, "GS_delete_surface");
+ int i, j, found;
+ found = FALSE;
+ G_debug(1, "GS_delete_surface(): id=%d", id);
if (GS_surf_exists(id)) {
gs_delete_surf(id);
for (i = 0; i < Next_surf && !found; i++) {
if (Surf_ID[i] == id) {
- found = 1;
+ found = TRUE;
for (j = i; j < Next_surf; j++) {
Surf_ID[j] = Surf_ID[j + 1];
gv_update_drapesurfs();
if (found) {
--Next_surf;
- return (1);
+ return 1;
- return (-1);
+ return -1;
@@ -2864,6 +2879,72 @@
+ \brief Set rotation params
+void GS_set_rotation(double angle, double x, double y, double z)
+ Gv.rotate.rot_angle = angle;
+ Gv.rotate.rot_axes[0] = x;
+ Gv.rotate.rot_axes[1] = y;
+ Gv.rotate.rot_axes[2] = z;
+ Gv.rotate.do_rot = 1;
+ return;
+ Gv.rotate.do_rot = 0;
+ \brief Reset scene rotation
+ int i;
+ for (i = 0; i < 16; i++) {
+ if (i == 0 || i == 5 || i == 10 || i == 15)
+ Gv.rotate.rotMatrix[i] = 1.0;
+ else
+ Gv.rotate.rotMatrix[i] = 0.0;
+ Gv.rotate.rot_angle = 0.0;
+ Gv.rotate.rot_axes[0] = 0.0;
+ Gv.rotate.rot_axes[1] = 0.0;
+ Gv.rotate.rot_axes[2] = 0.0;
+ * \brief Get rotation matrix
+void GS_get_rotation_matrix(double *matrix)
+ int i;
+ matrix[i] = Gv.rotate.rotMatrix[i];
+ * \brief Set rotation matrix
+void GS_set_rotation_matrix(double *matrix)
+ int i;
+ Gv.rotate.rotMatrix[i] = matrix[i];
\brief Unset focus
void GS_set_nofocus(void)
@@ -3262,6 +3343,7 @@
void GS_init_view(void)
+ int i;
G_debug(3, "GS_init_view");
@@ -3295,6 +3377,9 @@
/* replace these with something meaningful */
Gv.fov = 450;
Gv.twist = 0;
Gv.from_to[FROM][X] = Gv.from_to[FROM][Y] =
Gv.from_to[FROM][Z] = GS_UNIT_SIZE / 2.;
Modified: grass/branches/releasebranch_6_4/lib/ogsf/Gp3.c
--- grass/branches/releasebranch_6_4/lib/ogsf/Gp3.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/ogsf/Gp3.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -125,6 +125,8 @@
G_get_set_window(&wind);
+ Vect_set_constraint_region(&map, wind.north, wind.south, wind.east,
+ wind.west, PORT_DOUBLE_MAX, -PORT_DOUBLE_MAX);
/* get ndim */
ndim = 2;
Modified: grass/branches/releasebranch_6_4/lib/ogsf/gs.c
--- grass/branches/releasebranch_6_4/lib/ogsf/gs.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/ogsf/gs.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -572,7 +572,7 @@
/* for ea att of all other surfs */
for (gs = Surf_top; gs; gs = gs->next) {
for (j = 0; j < MAX_ATTS; j++) {
- if (old_datah == gs->att[j].hdata) {
+ if ((old_datah == gs->att[j].hdata) && (fs != gs)) {
same = 1;
Modified: grass/branches/releasebranch_6_4/lib/ogsf/gsd_objs.c
--- grass/branches/releasebranch_6_4/lib/ogsf/gsd_objs.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/ogsf/gsd_objs.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -1234,6 +1234,74 @@
+ \brief Draw Scalebar (as lines)
+ Adapted from gsd_scalebar A.Kratochvilova 2011
+ \param pos2 scalebar position
+ \param fontbase font-base (unused)
+ \param bar_clr barscale color
+ \param text_clr text color (unused)
+ \return 1
+int gsd_scalebar_v2(float *pos, float len, GLuint fontbase,
+ unsigned long bar_clr, unsigned long text_clr)
+ float base[6][3];
+ float Ntop[] = { 0.0, 0.0, 1.0 };
+ base[0][Z] = base[1][Z] = base[2][Z] = pos[Z];
+ base[3][Z] = base[4][Z] = base[5][Z] = pos[Z];
+ /* simple scalebar: |------| */
+ base[0][X] = base[2][X] = base[3][X] = pos[X] - len / 2.;
+ base[1][X] = base[4][X] = base[5][X] = pos[X] + len / 2.;
+ base[0][Y] = base[1][Y] = pos[Y];
+ base[2][Y] = base[4][Y] = pos[Y] - len / 12;
+ base[3][Y] = base[5][Y] = pos[Y] + len / 12;
+ /* make sure we are drawing in front buffer */
+ gsd_pushmatrix();
+ gsd_do_scale(1); /* get map scale factor */
+ glNormal3fv(Ntop);
+ gsd_color_func(bar_clr);
+ gsd_linewidth(3); /* could be optional */
+ gsd_bgnline();
+ gsd_vert_func(base[0]);
+ gsd_vert_func(base[1]);
+ gsd_endline();
+ gsd_bgnline();
+ gsd_vert_func(base[2]);
+ gsd_vert_func(base[3]);
+ gsd_endline();
+ gsd_bgnline();
+ gsd_vert_func(base[4]);
+ gsd_vert_func(base[5]);
+ gsd_endline();
+ /* TODO -- draw units */
+ GS_done_draw();
+ gsd_popmatrix();
+ gsd_flush();
+ return 1;
\brief Primitives only called after transforms
Center is actually center at base of 8 sided cone
Modified: grass/branches/releasebranch_6_4/lib/ogsf/gsd_views.c
--- grass/branches/releasebranch_6_4/lib/ogsf/gsd_views.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/ogsf/gsd_views.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -88,7 +88,7 @@
return (1);
+#if 0
\brief Set view
@@ -134,7 +134,79 @@
return;
+#endif
+ \brief Set view
+ Establishes viewing & projection matrices
+ \param gv view (geoview)
+ \param dp display (geodisplay)
+void gsd_set_view(geoview * gv, geodisplay * gd)
+ double up[3];
+ float pos[3];
+ int i;
+ GLdouble modelMatrix[16];
+ GLint mm;
+ /* will expand when need to check for in focus, ortho, etc. */
+ gsd_check_focus(gv);
+ gsd_get_zup(gv, up);
+ gd->aspect = GS_get_aspect();
+ glGetIntegerv(GL_MATRIX_MODE, &mm);
+ glLoadIdentity();
+ gluPerspective((double).1 * (gv->fov), (double)gd->aspect,
+ (double)gd->nearclip, (double)gd->farclip);
+ glMatrixMode(mm);
+ glLoadIdentity();
+ /* update twist parm */
+ glRotatef((float)(gv->twist / 10.), 0.0, 0.0, 1.0);
+ /* OGLXXX lookat: replace UPx with vector */
+ gluLookAt((double)gv->from_to[FROM][X], (double)gv->from_to[FROM][Y],
+ (double)gv->from_to[FROM][Z], (double)gv->from_to[TO][X],
+ (double)gv->from_to[TO][Y], (double)gv->from_to[TO][Z],
+ (double)up[X], (double)up[Y], (double)up[Z]);
+ /* rotate to get rotation matrix and then save it*/
+ if (gv->rotate.do_rot) {
+ glPushMatrix();
+ glLoadMatrixd(gv->rotate.rotMatrix);
+ glRotated(gv->rotate.rot_angle, gv->rotate.rot_axes[0],
+ gv->rotate.rot_axes[1], gv->rotate.rot_axes[2]);
+ gv->rotate.rotMatrix[i] = modelMatrix[i];
+ glPopMatrix();
+ gs_get_datacenter(pos);
+ gsd_surf2model(pos);
+ /* translate rotation center to view center, rotate and translate back */
+ glTranslatef(pos[0], pos[1], pos[2]);
+ glMultMatrixd(gv->rotate.rotMatrix);
+ glTranslatef(-pos[0], -pos[1], -pos[2]);
+ /* have to redefine clipping planes when view changes */
+ gsd_update_cplanes();
+ return;
\brief Check focus
@@ -361,7 +433,28 @@
return;
+ \brief Convert surface to model coordinates
+ \param point 3d point (Point3)
+void gsd_surf2model(Point3 point)
+ float min, max, sx, sy, sz;
+ /* need to undo z scaling & translate */
+ GS_get_scale(&sx, &sy, &sz, 1);
+ GS_get_zrange(&min, &max, 0);
+ point[Z] = (sz ? (point[Z] - min) * sz : 0.0);
+ /* need to unscale x & y */
+ point[X] = (sx ? point[X] * sx : 0.0);
+ point[Y] = (sy ? point[Y] * sy : 0.0);
+ return;
\brief Convert surface to real coordinates
Modified: grass/branches/releasebranch_6_4/lib/ogsf/gvld.c
--- grass/branches/releasebranch_6_4/lib/ogsf/gvld.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/lib/ogsf/gvld.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -491,7 +491,8 @@
float x, nextx, y, nexty, z, stepx, stepy, stepz;
int cols, rows, c, r;
float f_cols, f_rows, distxy, distz, modx, mody, modz, modxy;
- int ptX, ptY, ptZ, resx, resy, resz;
+ int ptX, ptY, ptZ;
+ double resx, resy, resz;
/* current slice */
slice = gvl->slice[ndx];
@@ -664,7 +665,8 @@
float pt[3];
int i;
geovol_slice *slice;
Modified: grass/branches/releasebranch_6_4/misc/m.nviz.image/args.c
--- grass/branches/releasebranch_6_4/misc/m.nviz.image/args.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/misc/m.nviz.image/args.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -31,6 +31,8 @@
static void args_volume(struct GParams *);
static void args_lighting(struct GParams *);
static void args_fringe(struct GParams *);
+static void args_cplane(struct GParams *);
+static void args_arrow(struct GParams *);
\brief Parse command
@@ -73,7 +75,13 @@
/*** fringe ***/
args_fringe(params);
+ /*** cutting plane ***/
+ args_cplane(params);
+ /*** north arrow ***/
+ args_arrow(params);
/*** output image ***/
/* output */
params->output = G_define_standard_option(G_OPT_F_OUTPUT);
@@ -377,7 +385,7 @@
params->vpoint_size->multiple = YES;
params->vpoint_size->description = _("Icon size");
params->vpoint_size->guisection = _("Vector points");
- params->vpoint_size->options = "1-1000";
+ params->vpoint_size->options = "1-10000";
params->vpoint_size->answer = "100";
/* point width */
@@ -485,6 +493,16 @@
params->exag->multiple = NO;
params->exag->description = _("Vertical exaggeration");
+ /* focus */
+ params->focus = G_define_option();
+ params->focus->key = "focus";
+ params->focus->key_desc = "x,y,z";
+ params->focus->type = TYPE_DOUBLE;
+ params->focus->required = NO;
+ params->focus->multiple = NO;
+ params->focus->description = _("Focus to point on surface (from SW corner in map units)");
+ params->focus->guisection = _("Viewpoint");
return;
@@ -551,9 +569,152 @@
params->isosurf_level->description = _("Isosurface level");
params->isosurf_level->guisection = _("Volumes");
+ /* isosurface color map */
+ params->isosurf_color_map = G_define_standard_option(G_OPT_R3_MAPS);
+ params->isosurf_color_map->key = "isosurf_color_map";
+ params->isosurf_color_map->required = NO;
+ params->isosurf_color_map->multiple = YES;
+ params->isosurf_color_map->description = _("Name of volume for isosurface color");
+ params->isosurf_color_map->guisection = _("Volumes");
+ /* isosurface color value */
+ params->isosurf_color_const = G_define_standard_option(G_OPT_C_FG);
+ params->isosurf_color_const->key = "isosurf_color_value";
+ params->isosurf_color_const->required = NO;
+ params->isosurf_color_const->multiple = YES;
+ params->isosurf_color_const->label = _("Isosurface color");
+ params->isosurf_color_const->guisection = _("Volumes");
+ params->isosurf_color_const->answer = NULL;
+ /* isosurface transparency */
+ params->isosurf_transp_map = G_define_standard_option(G_OPT_R3_MAP);
+ params->isosurf_transp_map->multiple = YES;
+ params->isosurf_transp_map->required = NO;
+ params->isosurf_transp_map->description =
+ _("Name of 3D raster map(s) for isosurface transparency");
+ params->isosurf_transp_map->guisection = _("Volumes");
+ params->isosurf_transp_map->key = "isosurf_transparency_map";
+ params->isosurf_transp_const = G_define_option();
+ params->isosurf_transp_const->key = "isosurf_transparency_value";
+ params->isosurf_transp_const->key_desc = "value";
+ params->isosurf_transp_const->type = TYPE_INTEGER;
+ params->isosurf_transp_const->required = NO;
+ params->isosurf_transp_const->multiple = YES;
+ params->isosurf_transp_const->description = _("Transparency value(s)for isosurfaces");
+ params->isosurf_transp_const->guisection = _("Volumes");
+ params->isosurf_transp_const->options = "0-255";
+ /* isosurface shininess */
+ params->isosurf_shine_map = G_define_standard_option(G_OPT_R3_MAP);
+ params->isosurf_shine_map->multiple = YES;
+ params->isosurf_shine_map->required = NO;
+ params->isosurf_shine_map->description = _("Name of 3D raster map(s) for shininess");
+ params->isosurf_shine_map->guisection = _("Volumes");
+ params->isosurf_shine_map->key = "isosurf_shininess_map";
+ params->isosurf_shine_const = G_define_option();
+ params->isosurf_shine_const->key = "isosurf_shininess_value";
+ params->isosurf_shine_const->key_desc = "value";
+ params->isosurf_shine_const->type = TYPE_INTEGER;
+ params->isosurf_shine_const->required = NO;
+ params->isosurf_shine_const->multiple = YES;
+ params->isosurf_shine_const->description = _("Shininess value(s) for isosurfaces");
+ params->isosurf_shine_const->guisection = _("Volumes");
+ params->isosurf_shine_const->options = "0-255";
+ /* slices */
+ /* slice axis */
+ params->slice = G_define_option();
+ params->slice->key = "slice";
+ params->slice->key_desc = "volume:axis";
+ params->slice->type = TYPE_STRING;
+ params->slice->required = NO;
+ params->slice->multiple = YES;
+ params->slice->description = _("Volume slice parallel to given axis (x, y, z)");
+ params->slice->guisection = _("Volumes");
+ /* slice position */
+ params->slice_pos = G_define_option();
+ params->slice_pos->key = "slice_position";
+ params->slice_pos->key_desc = "x1,x2,y1,y2,z1,z2";
+ params->slice_pos->type = TYPE_DOUBLE;
+ params->slice_pos->required = NO;
+ params->slice_pos->multiple = YES;
+ params->slice_pos->description = _("Volume slice position");
+ params->slice_pos->guisection = _("Volumes");
+ params->slice_pos->answer = "0,1,0,1,0,1";
+ /* slice transparency */
+ params->slice_transp = G_define_option();
+ params->slice_transp->key = "slice_transparency";
+ params->slice_transp->key_desc = "value";
+ params->slice_transp->type = TYPE_INTEGER;
+ params->slice_transp->required = NO;
+ params->slice_transp->multiple = YES;
+ params->slice_transp->description = _("Volume slice transparency");
+ params->slice_transp->guisection = _("Volumes");
+ params->slice_transp->answer = "0";
+ params->slice_transp->options = "0-255";
return;
+void args_cplane(struct GParams *params)
+ params->cplane = G_define_option();
+ params->cplane->key = "cplane";
+ params->cplane->key_desc = "value";
+ params->cplane->type = TYPE_INTEGER;
+ params->cplane->required = NO;
+ params->cplane->multiple = YES;
+ params->cplane->description = _("Cutting plane index (0-5)");
+ params->cplane->guisection = _("Cutting planes");
+ params->cplane_pos = G_define_option();
+ params->cplane_pos->key = "cplane_position";
+ params->cplane_pos->key_desc = "x,y,z";
+ params->cplane_pos->type = TYPE_DOUBLE;
+ params->cplane_pos->required = NO;
+ params->cplane_pos->multiple = YES;
+ params->cplane_pos->description = _("Cutting plane x,y,z coordinates");
+ params->cplane_pos->guisection = _("Cutting planes");
+ params->cplane_pos->answer = "0,0,0";
+ params->cplane_rot = G_define_option();
+ params->cplane_rot->key = "cplane_rotation";
+ params->cplane_rot->key_desc = "value";
+ params->cplane_rot->type = TYPE_DOUBLE;
+ params->cplane_rot->multiple = YES;
+ params->cplane_rot->required = NO;
+ params->cplane_rot->guisection = _("Cutting planes");
+ params->cplane_rot->description = _("Cutting plane rotation along the vertical axis");
+ params->cplane_rot->answer = "0";
+ params->cplane_rot->options="0-360";
+ params->cplane_tilt = G_define_option();
+ params->cplane_tilt->key = "cplane_tilt";
+ params->cplane_tilt->key_desc = "value";
+ params->cplane_tilt->type = TYPE_DOUBLE;
+ params->cplane_tilt->multiple = YES;
+ params->cplane_tilt->required = NO;
+ params->cplane_tilt->guisection = _("Cutting planes");
+ params->cplane_tilt->description = _("Cutting plane tilt");
+ params->cplane_tilt->answer = "0";
+ params->cplane_tilt->options="0-360";
+ params->cplane_shading = G_define_option();
+ params->cplane_shading->key = "cplane_shading";
+ params->cplane_shading->key_desc = "string";
+ params->cplane_shading->type = TYPE_STRING;
+ params->cplane_shading->multiple = NO;
+ params->cplane_shading->required = NO;
+ params->cplane_shading->guisection = _("Cutting planes");
+ params->cplane_shading->description = _("Cutting plane color (between two surfaces)");
+ params->cplane_shading->answer = "clear";
+ params->cplane_shading->options= "clear,top,bottom,blend,shaded";
void args_lighting(struct GParams *params)
params->light_pos = G_define_option();
@@ -624,6 +785,36 @@
params->fringe_elev->answer = "55";
+void args_arrow(struct GParams *params)
+ params->north_arrow = G_define_option();
+ params->north_arrow->key = "arrow_position";
+ params->north_arrow->key_desc = "x,y";
+ params->north_arrow->type = TYPE_INTEGER;
+ params->north_arrow->required = NO;
+ params->north_arrow->multiple = NO;
+ params->north_arrow->description = _("Place north arrow at given position \
+ (in screen coordinates from bottom left corner)");
+ params->north_arrow->guisection = _("Decoration");
+ params->north_arrow_size = G_define_option();
+ params->north_arrow_size->key = "arrow_size";
+ params->north_arrow_size->key_desc = "value";
+ params->north_arrow_size->type = TYPE_DOUBLE;
+ params->north_arrow_size->required = NO;
+ params->north_arrow_size->multiple = NO;
+ params->north_arrow_size->description = _("North arrow size (in map units)");
+ params->north_arrow_size->guisection = _("Decoration");
+ params->north_arrow_color = G_define_standard_option(G_OPT_C_FG);
+ params->north_arrow_color->key = "arrow_color";
+ params->north_arrow_color->required = NO;
+ params->north_arrow_color->multiple = NO;
+ params->north_arrow_color->label = _("North arrow color");
+ params->north_arrow_color->guisection = _("Decoration");
+ params->north_arrow_color->answer = "black";
\brief Get number of answers of given option
@@ -642,6 +833,8 @@
i++;
+ G_debug(3, "opt_get_num_answers(): opt=%s num=%d", opt->key, i);
return i;
@@ -654,10 +847,12 @@
void check_parameters(const struct GParams *params)
int nelev_map, nelev_const, nelevs;
- int nmaps, nconsts;
+ int nmaps, nconsts, ncoords, ncplanes;
int nvects;
+ int nvolumes, nisosurf, nslices;
/* topography */
nelev_map = opt_get_num_answers(params->elev_map);
nelev_const = opt_get_num_answers(params->elev_const);
@@ -742,6 +937,25 @@
params->elev_map->key, params->elev_const->key,
nelevs, params->wire_color->key, nconsts);
+ * Cutting planes
+ ncplanes = opt_get_num_answers(params->cplane);
+ ncoords = opt_get_num_answers(params->cplane_pos);
+ if (ncplanes > 0 && ncplanes * 3 != ncoords)
+ G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"),
+ params->cplane->key, ncplanes, params->cplane_pos->key, ncoords/3);
+ nconsts = opt_get_num_answers(params->cplane_rot);
+ if (ncplanes > 0 && ncplanes != nconsts)
+ G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
+ params->cplane->key, ncplanes, params->cplane_rot->key, nconsts);
+ nconsts = opt_get_num_answers(params->cplane_tilt);
+ params->cplane->key, ncplanes, params->cplane_tilt->key, nconsts);
* vector
@@ -776,6 +990,50 @@
params->vlines->key, nvects, params->vline_height->key,
nconsts);
+ /* position */
+ nconsts = opt_get_num_answers(params->vline_pos);
+ if (nvects > 0 && nconsts != 3 * nvects)
+ params->vlines->key, nvects, params->vline_pos->key,
+ nconsts);
+ * volumes
+ nvolumes = opt_get_num_answers(params->volume);
+ nisosurf = opt_get_num_answers(params->isosurf_level);
+ nslices = opt_get_num_answers(params->slice);
+ nmaps = opt_get_num_answers(params->isosurf_transp_map);
+ nconsts = opt_get_num_answers(params->isosurf_transp_const);
+ if ((nmaps + nconsts > 0) && (nisosurf != nmaps + nconsts))
+ G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d"),
+ params->isosurf_level->key, nisosurf, params->isosurf_transp_map->key, nmaps,
+ params->isosurf_transp_const->key, nconsts);
+ nmaps = opt_get_num_answers(params->isosurf_shine_map);
+ nconsts = opt_get_num_answers(params->isosurf_shine_const);
+ params->isosurf_level->key, nisosurf, params->isosurf_shine_map->key, nmaps,
+ params->isosurf_shine_const->key, nconsts);
+ nconsts = opt_get_num_answers(params->slice_transp);
+ if (nslices > 0 && nslices != nconsts)
+ params->slice->key, nslices, params->slice_transp->key, nconsts);
+ ncoords = opt_get_num_answers(params->slice_pos);
+ if (nslices > 0 && ncoords != 6 * nslices)
+ G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d x 6)"),
+ params->slice->key, nslices, params->slice_pos->key, ncoords/6);
return;
@@ -783,7 +1041,7 @@
const char *elev_map, const char *elev_const,
const char *map_name, const char *const_name)
- if ((nmaps > 0 && nelevs != nmaps) || (nconsts > 0 && nelevs != nconsts))
+ if ((nmaps + nconsts > 0) && (nelevs != nmaps + nconsts))
G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"),
elev_map, elev_const, nelevs, map_name, nmaps,
const_name, nconsts);
Copied: grass/branches/releasebranch_6_4/misc/m.nviz.image/cplane.c (from rev 49357, grass/branches/develbranch_6/misc/m.nviz.image/cplane.c)
--- grass/branches/releasebranch_6_4/misc/m.nviz.image/cplane.c (rev 0)
+++ grass/branches/releasebranch_6_4/misc/m.nviz.image/cplane.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -0,0 +1,72 @@
+ \file cplane.c
+ \brief Cutting plane subroutine
+ (C) 2011 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \author Anna Kratochvilova <kratochanna gmail.com> (Google SoC 2010/2011)
+#include <stdlib.h>
+#include <string.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+ \brief Draw cutting planes and set their attributes
+ \param params module parameters
+void draw_cplane(const struct GParams *params, nv_data * data)
+ int i, id, ncplanes;
+ float trans_x, trans_y, trans_z;
+ float rot_x, rot_y, rot_z;
+ int fence;
+ for (i = 0; i < ncplanes; i++) {
+ id = atoi(params->cplane->answers[i]);
+ if (id < 0 || id > Nviz_num_cplanes(data))
+ G_fatal_error(_("Cutting plane number <%d> not found"), id);
+ Nviz_on_cplane(data, id);
+ trans_x = atof(params->cplane_pos->answers[i * 3 + 0]);
+ trans_y = atof(params->cplane_pos->answers[i * 3 + 1]);
+ trans_z = atof(params->cplane_pos->answers[i * 3 + 2]);
+ Nviz_set_cplane_translation(data, id, trans_x, trans_y, trans_z);
+ rot_x = 0;
+ rot_y = atof(params->cplane_tilt->answers[i]);
+ rot_z = atof(params->cplane_rot->answers[i]);
+ Nviz_set_cplane_rotation(data, id, rot_x, rot_y, rot_z);
+ const char *shading = params->cplane_shading->answers[0];
+ if (strcmp(shading, "clear") == 0)
+ fence = 0;
+ else if (strcmp(shading, "top") == 0)
+ fence = 1;
+ else if (strcmp(shading, "bottom") == 0)
+ fence = 2;
+ else if (strcmp(shading, "blend") == 0)
+ fence = 3;
+ else if (strcmp(shading, "shaded") == 0)
+ fence = 4;
+ else
+ fence = 0;
+ Nviz_set_fence_color(data, fence);
+ return;
Modified: grass/branches/releasebranch_6_4/misc/m.nviz.image/description.html
--- grass/branches/releasebranch_6_4/misc/m.nviz.image/description.html 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/misc/m.nviz.image/description.html 2012-02-20 09:41:50 UTC (rev 50895)
@@ -23,7 +23,13 @@
<h2>AUTHOR</h2>
-Martin Landa (Google Summer of Code 2008/2010)
+<a href="http://geo.fsv.cvut.cz/gwiki/Landa">Martin
+Landa</a>, <a href="http://grass.osgeo.org/wiki/WxNviz_GSoC_2008">Google
+Summer of Code 2008</a> (mentor: Michael Barton)
+and <a href="http://grass.osgeo.org/wiki/WxNviz_GSoC_2010">Google
+Summer of Code 2010</a> (mentor: Helena Mitasova)<br>
+Anna Kratochvilova, <a href="http://grass.osgeo.org/wiki/WxNviz_GSoC_2011">Google
+Summer of Code 2011</a> (mentor: Martin Landa)
<p>
<i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_6_4/misc/m.nviz.image/local_proto.h
--- grass/branches/releasebranch_6_4/misc/m.nviz.image/local_proto.h 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/misc/m.nviz.image/local_proto.h 2012-02-20 09:41:50 UTC (rev 50895)
@@ -21,16 +21,22 @@
*vpoints, *vpoint_size, *vpoint_marker, *vpoint_color, *vpoint_width, *vpoint_pos,
/* volumes */
*volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
+ *isosurf_color_map, *isosurf_color_const, *isosurf_transp_map, *isosurf_transp_const,
+ *isosurf_shine_map, *isosurf_shine_const, *slice_pos, *slice, *slice_transp,
/* misc */
*exag, *bgcolor,
+ /* cutting planes */
+ *cplane, *cplane_pos, *cplane_rot, *cplane_tilt, *cplane_shading,
/* viewpoint */
- *pos, *height, *persp, *twist,
+ *pos, *height, *persp, *twist, *focus,
/* output */
*output, *format, *size,
/* lighting */
*light_pos, *light_color, *light_bright, *light_ambient,
/* fringe */
- *fringe, *fringe_color, *fringe_elev;
+ *fringe, *fringe_color, *fringe_elev,
+ /* north arrow */
+ *north_arrow, *north_arrow_size, *north_arrow_color;
/* args.c */
@@ -52,7 +58,11 @@
/* volume.c */
int load_rasters3d(const struct GParams *, nv_data *);
int add_isosurfs(const struct GParams *, nv_data *);
+int add_slices(const struct GParams *, nv_data *);
+/* cutting planes */
+void draw_cplane(const struct GParams *, nv_data *);
/* write_img.c */
int write_img(const char *, int);
Modified: grass/branches/releasebranch_6_4/misc/m.nviz.image/main.c
--- grass/branches/releasebranch_6_4/misc/m.nviz.image/main.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/misc/m.nviz.image/main.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -34,6 +34,7 @@
int i, ret;
int red, grn, blu;
+ float size;
double vp_height, z_exag; /* calculated viewpoint height, z-exag */
int width, height; /* output image size */
char *output_name;
@@ -116,6 +117,11 @@
add_isosurfs(params, &data);
+ /* define slices for displaying volumes */
+ if (params->slice->answer) {
+ add_slices(params, &data);
/* focus on loaded data */
Nviz_set_focus_map(MAP_OBJ_UNDEFINED, -1);
@@ -147,6 +153,11 @@
atof(params->pos->answers[1]));
Nviz_set_viewpoint_twist(atoi(params->twist->answer));
Nviz_set_viewpoint_persp(atoi(params->persp->answer));
+ if (params->focus->answer) {
+ Nviz_set_focus(&data, atof(params->focus->answers[0]),
+ atof(params->focus->answers[1]),
+ atof(params->focus->answers[2]));
/* set lights */
Nviz_set_light_position(&data, 1,
@@ -183,11 +194,28 @@
Nviz_new_fringe(&data, -1, Nviz_color_from_str(params->fringe_color->answer),
atof(params->fringe_elev->answer), nw, ne, sw, se);
+/* draw north arrow */
+ if (params->north_arrow->answer) {
+ if (!params->north_arrow_size->answer)
+ size = Nviz_get_longdim(&data) / 8.;
+ else
+ size = atof(params->north_arrow_size->answer);
+ Nviz_set_arrow(&data, atoi(params->north_arrow->answers[0]),
+ atoi(params->north_arrow->answers[1]),
+ size, Nviz_color_from_str(params->north_arrow_color->answer));
+ Nviz_draw_arrow(&data);
GS_clear(data.bgcolor);
+ if(params->cplane->answer)
+ draw_cplane(params, &data);
/* draw */
- Nviz_draw_cplane(&data, -1, -1);
Nviz_draw_all(&data);
/* write to image */
Modified: grass/branches/releasebranch_6_4/misc/m.nviz.image/surface.c
--- grass/branches/releasebranch_6_4/misc/m.nviz.image/surface.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/misc/m.nviz.image/surface.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -40,10 +40,7 @@
- if (nelev_map > 0)
- nelevs = nelev_map;
- else
- nelevs = nelev_const;
+ nelevs = nelev_const + nelev_map;
/* topography (required) */
for (i = 0; i < nelevs; i++) {
@@ -61,10 +58,10 @@
0.0, data);
else {
- if (i < nelev_const && strcmp(params->elev_const->answers[i], "")) {
+ if (i-nelev_map < nelev_const && strcmp(params->elev_const->answers[i-nelev_map], "")) {
id = Nviz_new_map_obj(MAP_OBJ_SURF,
NULL,
- atof(params->elev_const->answers[i]),
+ atof(params->elev_const->answers[i-nelev_map]),
data);
else {
@@ -74,16 +71,17 @@
/* set position */
- if (params->mode_all->answer) { /* use one mode for all surfaces */
- x = atof(params->surface_pos->answers[0]);
- y = atof(params->surface_pos->answers[1]);
- z = atof(params->surface_pos->answers[2]);
- else {
- x = atof(params->surface_pos->answers[i]);
- y = atof(params->surface_pos->answers[i+1]);
- z = atof(params->surface_pos->answers[i+2]);
+ if (opt_get_num_answers(params->surface_pos) != 3 * nelevs){
+ x = atof(params->surface_pos->answers[0]);
+ y = atof(params->surface_pos->answers[1]);
+ z = atof(params->surface_pos->answers[2]);
+ else {
+ x = atof(params->surface_pos->answers[i*3+0]);
+ y = atof(params->surface_pos->answers[i*3+1]);
+ z = atof(params->surface_pos->answers[i*3+2]);
GS_set_trans(id, x, y, z);
@@ -117,19 +115,25 @@
data);
/* check for color value */
- else if (i < ncolor_const &&
- strcmp(params->color_const->answers[i], "")) {
+ else if (i-ncolor_map < ncolor_const &&
+ strcmp(params->color_const->answers[i-ncolor_map], "")) {
Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, CONST_ATT, NULL,
Nviz_color_from_str(params->color_const->
- answers[i]), data);
+ answers[i-ncolor_map]), data);
else { /* use by default elevation map for coloring */
- Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
- G_fully_qualified_name(params->elev_map->answers[i],
- mapset), -1.0, data);
- G_verbose_message(_("Color attribute not defined, using default <%s>"),
- answers[i], mapset));
+ if (nelev_map > 0){
+ Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
+ G_fully_qualified_name(params->elev_map->answers[i],
+ mapset), -1.0, data);
+ G_verbose_message(_("Color attribute not defined, using default <%s>"),
+ answers[i], mapset));
+ else{
+ G_fatal_error(_("Missing color attribute for surface %d"),
+ i + 1);
/* mask */
if (i < nmask_map && strcmp(params->mask_map->answers[i], "")) {
@@ -145,10 +149,10 @@
answers[i], mapset), -1.0,
data);
- else if (i < ntransp_const &&
- strcmp(params->transp_const->answers[i], "")) {
+ else if (i-ntransp_map < ntransp_const &&
+ strcmp(params->transp_const->answers[i-ntransp_map], "")) {
Nviz_set_attr(id, MAP_OBJ_SURF, ATT_TRANSP, CONST_ATT, NULL,
- atof(params->transp_const->answers[i]), data);
+ atof(params->transp_const->answers[i-ntransp_map]), data);
/* shininess */
@@ -158,10 +162,10 @@
data);
- else if (i < nshine_const &&
- strcmp(params->shine_const->answers[i], "")) {
+ else if (i-nshine_map < nshine_const &&
+ strcmp(params->shine_const->answers[i-nshine_map], "")) {
Nviz_set_attr(id, MAP_OBJ_SURF, ATT_SHINE, CONST_ATT, NULL,
- atof(params->shine_const->answers[i]), data);
+ atof(params->shine_const->answers[i-nshine_map]), data);
/* emission */
@@ -170,10 +174,10 @@
G_fully_qualified_name(params->emit_map->answers[i],
- else if (i < nemit_const &&
- strcmp(params->emit_const->answers[i], "")) {
+ else if (i-nemit_map < nemit_const &&
+ strcmp(params->emit_const->answers[i-nemit_map], "")) {
Nviz_set_attr(id, MAP_OBJ_SURF, ATT_EMIT, CONST_ATT, NULL,
- atof(params->emit_const->answers[i]), data);
+ atof(params->emit_const->answers[i-nemit_map]), data);
@@ -192,7 +196,7 @@
void surface_set_draw_mode(const struct GParams *params)
- int *surf_list, nsurfs, idx;
+ int *surf_list, nsurfs;
int i, id, draw_mode;
int resol_fine, resol_coarse;
@@ -200,26 +204,29 @@
surf_list = GS_get_surf_list(&nsurfs);
- /* use one mode for all surfaces */
- idx = 0;
for (i = 0; i < nsurfs; i++) {
draw_mode = 0;
id = surf_list[i];
if (!GS_surf_exists(id))
G_fatal_error(_("Surface id %d doesn't exist"), id);
- if (!params->mode_all->answer)
- idx = i;
+ if (params->mode_all->answer) { /* use one mode for all surfaces */
+ mode = params->mode->answers[0];
+ style = params->style->answers[0];
+ shade = params->shade->answers[0];
+ res_fine = params->res_fine->answers[0];
+ res_coarse = params->res_coarse->answers[0];
+ wire_color = params->wire_color->answers[0];
+ else {
+ mode = params->mode->answers[i];
+ style = params->style->answers[i];
+ shade = params->shade->answers[i];
+ res_fine = params->res_fine->answers[i];
+ res_coarse = params->res_coarse->answers[i];
+ wire_color = params->wire_color->answers[i];
- mode = params->mode->answers[idx];
- style = params->style->answers[idx];
- shade = params->shade->answers[idx];
- res_fine = params->res_fine->answers[idx];
- res_coarse = params->res_coarse->answers[idx];
- wire_color = params->wire_color->answers[idx];
/* mode */
if (strcmp(mode, "coarse") == 0) {
draw_mode |= DM_WIRE;
@@ -232,7 +239,7 @@
/* style */
- if (strcmp(params->style->answers[idx], "wire") == 0) {
+ if (strcmp(style, "wire") == 0) {
draw_mode |= DM_GRID_WIRE;
else { /* surface */
@@ -240,7 +247,7 @@
/* shading */
- if (strcmp(params->shade->answers[idx], "flat") == 0) {
+ if (strcmp(shade, "flat") == 0) {
draw_mode |= DM_FLAT;
else { /* gouraud */
Modified: grass/branches/releasebranch_6_4/misc/m.nviz.image/vector.c
--- grass/branches/releasebranch_6_4/misc/m.nviz.image/vector.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/misc/m.nviz.image/vector.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -85,9 +85,9 @@
0.0, data);
/* set position */
- x = atof(position->answers[i]);
- y = atof(position->answers[i+1]);
- z = atof(position->answers[i+2]);
+ x = atof(position->answers[i*3+0]);
+ y = atof(position->answers[i*3+1]);
+ z = atof(position->answers[i*3+2]);
if (map_obj_type == MAP_OBJ_VECT)
GV_set_trans(id, x, y, z);
Modified: grass/branches/releasebranch_6_4/misc/m.nviz.image/volume.c
--- grass/branches/releasebranch_6_4/misc/m.nviz.image/volume.c 2012-02-20 04:29:26 UTC (rev 50894)
+++ grass/branches/releasebranch_6_4/misc/m.nviz.image/volume.c 2012-02-20 09:41:50 UTC (rev 50895)
@@ -13,6 +13,7 @@
#include <stdlib.h>
#include <grass/G3d.h>
@@ -29,7 +30,8 @@
int load_rasters3d(const struct GParams *params, nv_data *data)
- int i, nvol, id;
+ int i, nvol, id;
+ float x, y, z;
char *mapset;
nvol = opt_get_num_answers(params->volume);
@@ -45,6 +47,20 @@
G_fully_qualified_name(params->volume->answers[i],
mapset),
0.0, data);
+ /* set position */
+ if (opt_get_num_answers(params->volume_pos) != 3 * nvol) {
+ x = atof(params->volume_pos->answers[0]);
+ y = atof(params->volume_pos->answers[1]);
+ z = atof(params->volume_pos->answers[2]);
+ else {
+ x = atof(params->volume_pos->answers[i*3+0]);
+ y = atof(params->volume_pos->answers[i*3+1]);
+ z = atof(params->volume_pos->answers[i*3+2]);
+ GVL_set_trans(id, x, y, z);
return 1;
@@ -61,8 +77,12 @@
int add_isosurfs(const struct GParams *params, nv_data *data)
int i;
- int num, level, nvols, *vol_list, id, nisosurfs;
+ float level;
+ int num, nvols, *vol_list, id, nisosurfs;
+ int ncolor_map, ncolor_const, ntransp_map, ntransp_const, nshine_map, nshine_const;
+ int res, draw_mode;
char **tokens;
+ const char *mapset, *style;
vol_list = GVL_get_vol_list(&nvols);
@@ -72,7 +92,7 @@
G_fatal_error(_("Error tokenize '%s'"),
params->isosurf_level->answers[i]);
num = atoi(tokens[0]);
- level = atoi(tokens[1]);
+ level = atof(tokens[1]);
G_free_tokens(tokens);
if (num > nvols) {
@@ -95,11 +115,192 @@
/* color */
- if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_COLOR, params->volume->answers[0]) < 0) {
- G_fatal_error(_("Unable to set isosurface (%d) attribute (%d) of volume %d"),
- nisosurfs-1, ATT_COLOR, id);
+ ncolor_map = opt_get_num_answers(params->isosurf_color_map);
+ ncolor_const = opt_get_num_answers(params->isosurf_color_const);
+ if (i < ncolor_map && strcmp(params->isosurf_color_map->answers[i], "")) {
+ mapset = G_find_grid3(params->isosurf_color_map->answers[i], "");
+ if (mapset == NULL) {
+ G_fatal_error(_("3d raster map <%s> not found"),
+ params->isosurf_color_map->answers[i]);
+ if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_COLOR,
+ params->isosurf_color_map->answers[i]) < 0)
+ G_fatal_error(_("Unable to set isosurface (%d) attribute (%d) of volume %d"),
+ nisosurfs-1, ATT_COLOR, id);
+ strcmp(params->isosurf_color_const->answers[i-ncolor_map], "")) {
+ if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_COLOR,
+ Nviz_color_from_str(params->isosurf_color_const->answers[i-ncolor_map])) < 0)
+ else { /* use by default 3d raster map for coloring */
+ GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_COLOR, params->volume->answers[num-1]);
+ params->volume->answers[num-1]);
+ /* transparency */
+ ntransp_map = opt_get_num_answers(params->isosurf_transp_map);
+ ntransp_const = opt_get_num_answers(params->isosurf_transp_const);
+ if (i < ntransp_map && strcmp(params->isosurf_transp_map->answers[i], "")) {
+ if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_TRANSP,
+ params->isosurf_transp_map->answers[i]) < 0)
+ nisosurfs-1, ATT_TRANSP, id);
+ strcmp(params->isosurf_transp_const->answers[i-ntransp_map], "")) {
+ if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_TRANSP,
+ atof(params->isosurf_transp_const->answers[i-ntransp_map])) < 0)
+ /* shine */
+ nshine_map = opt_get_num_answers(params->isosurf_shine_map);
+ nshine_const = opt_get_num_answers(params->isosurf_shine_const);
+ if (i < nshine_map && strcmp(params->isosurf_shine_map->answers[i], "")) {
+ if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_SHINE,
+ params->isosurf_shine_map->answers[i]) < 0)
+ nisosurfs-1, ATT_SHINE, id);
+ strcmp(params->isosurf_shine_const->answers[i-nshine_map], "")) {
+ if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_SHINE,
+ atof(params->isosurf_shine_const->answers[i-nshine_map])) < 0)
+ /* set draw resolution and shading after isosurfaces are added*/
+ for (i = 0; i < nvols; i++) {
+ id = vol_list[i];
+ /* set resolution */
+ if (opt_get_num_answers(params->volume_res) != nvols)
+ res = atof(params->volume_res->answers[0]);
+ else
+ res = atof(params->volume_res->answers[i]);
+ GVL_isosurf_set_drawres(id, res, res, res);
+ /* set shading */
+ if (opt_get_num_answers(params->volume_shade) != nvols)
+ style = params->volume_shade->answers[0];
+ else
+ style = params->volume_shade->answers[i];
+ draw_mode = 0;
+ if (strcmp(style, "flat") == 0) {
+ draw_mode |= DM_FLAT;
+ else {
+ draw_mode |= DM_GOURAUD;
+ GVL_isosurf_set_drawmode(id, draw_mode);
return 1;
+int add_slices(const struct GParams *params, nv_data *data)
+ int i;
+ int num, nvols, *vol_list, id, nslices, axis;
+ char **tokens;
+ const char* style;
+ vol_list = GVL_get_vol_list(&nvols);
+ for (i = 0; params->slice->answers[i]; i++) {
+ tokens = G_tokenize(params->slice->answers[i], ":");
+ if (G_number_of_tokens(tokens) != 2)
+ G_fatal_error(_("Error tokenize '%s'"),
+ params->slice->answers[i]);
+ num = atoi(tokens[0]);
+ if (!strcmp(tokens[1],"x") || !strcmp(tokens[1],"X"))
+ axis = 0;
+ else if (!strcmp(tokens[1],"y") || !strcmp(tokens[1],"Y"))
+ axis = 1;
+ else if (!strcmp(tokens[1],"z") || !strcmp(tokens[1],"Z"))
+ axis = 2;
+ else
+ G_fatal_error(_("Wrong name for axis: %s"),
+ tokens[1]);
+ G_free_tokens(tokens);
+ if (num > nvols) {
+ G_fatal_error(_("Volume set number %d is not available"),
+ num);
+ id = vol_list[num-1];
+ if (GVL_slice_add(id) < 0) {
+ G_fatal_error(_("Unable to add slice (volume set %d)"),
+ id);
+ nslices = GVL_slice_num_slices(id);
+ if (GVL_slice_set_pos(id, nslices-1, atof(params->slice_pos->answers[i*6+0]),
+ atof(params->slice_pos->answers[i*6+1]),
+ atof(params->slice_pos->answers[i*6+2]),
+ atof(params->slice_pos->answers[i*6+3]),
+ atof(params->slice_pos->answers[i*6+4]),
+ atof(params->slice_pos->answers[i*6+5]),
+ axis) < 0)
+ G_fatal_error(_("Unable to set slice (%d) position of volume %d"),
+ nslices-1, id);
+ /* set transparency */
+ if (GVL_slice_set_transp(id, nslices-1, atoi(params->slice_transp->answers[i])) < 0)
+ G_fatal_error(_("Unable to set slice (%d) transparency of volume %d"),
+ nslices-1, id);
+ /* set draw resolution and shading after slices are added*/
+ id = vol_list[i];
+ else
+ GVL_slice_set_drawres(id, res, res, res);
+ /* set shading */
+ else
+ draw_mode = 0;
+ else {
+ GVL_slice_set_drawmode(id, draw_mode);
+ return 1;
