[GRASS-SVN] r50897 - grass/trunk/gui/wxpython/psmap
svn_grass at osgeo.org
Mon Feb 20 05:13:55 EST 2012
Author: annakrat
Date: 2012-02-20 02:13:55 -0800 (Mon, 20 Feb 2012)
New Revision: 50897
grass/trunk/gui/wxpython/psmap/instructions.py
grass/trunk/gui/wxpython/psmap/utils.py
wxGUI/wxpsmap: use '/usr/local/src/psmap_trunk/dist.i686-pc-linux-gnu' shortcut in eps file path if possible
Modified: grass/trunk/gui/wxpython/psmap/instructions.py
--- grass/trunk/gui/wxpython/psmap/instructions.py 2012-02-20 09:43:14 UTC (rev 50896)
+++ grass/trunk/gui/wxpython/psmap/instructions.py 2012-02-20 10:13:55 UTC (rev 50897)
@@ -889,9 +889,10 @@
def __str__(self):
self.ChangeRefPoint(toCenter = True)
+ epsfile = self.instruction['epsfile'].replace(os.getenv('GISBASE'), "$GISBASE")
instr = "eps %s %s\n" % (self.instruction['east'], self.instruction['north'])
- instr += string.Template(" epsfile $epsfile\n").substitute(self.instruction)
+ instr += " epsfile %s\n" % epsfile
if self.instruction["rotate"]:
instr += string.Template(" rotate $rotate\n").substitute(self.instruction)
if self.instruction["scale"]:
@@ -916,7 +917,8 @@
instr['east'], instr['north'] = float(e), float(n)
elif sub == 'epsfile':
- instr['epsfile'] = line.split(None, 1)[1]
+ epsfile = line.split(None, 1)[1]
+ instr['epsfile'] = epsfile.replace("$GISBASE", os.getenv("GISBASE"))
elif sub == 'rotate':
instr['rotate'] = float(line.split(None, 1)[1])
elif sub == 'scale':
@@ -999,10 +1001,11 @@
def __str__(self):
instr += "# north arrow\n"
@@ -1663,7 +1666,8 @@
if self.subType == 'areas':
if dic['pat'] is not None:
- vInstruction += string.Template(" pat $pat\n").substitute(dic)
+ patternFile = dic['pat'].replace(os.getenv("GISBASE"), "$GISBASE")
+ vInstruction += " pat %s\n" % patternFile
vInstruction += string.Template(" pwidth $pwidth\n").substitute(dic)
vInstruction += string.Template(" scale $scale\n").substitute(dic)
@@ -1775,7 +1779,8 @@
if line.startswith('fcolor'):
instr['fcolor'] = line.split()[1]
elif line.startswith('pat'):
- instr['pat'] = line.split()[1]
+ patternFile = line.split()[1]
+ instr['pat'] = patternFile.replace("$GISBASE", os.getenv("GISBASE"))
elif line.startswith('pwidth'):
instr['pwidth'] = float(line.split()[1])
elif line.startswith('scale'):
Modified: grass/trunk/gui/wxpython/psmap/utils.py
--- grass/trunk/gui/wxpython/psmap/utils.py 2012-02-20 09:43:14 UTC (rev 50896)
+++ grass/trunk/gui/wxpython/psmap/utils.py 2012-02-20 10:13:55 UTC (rev 50897)
@@ -15,7 +15,7 @@
@author Anna Kratochvilova <kratochanna gmail.com>
+import os
import wx
from math import ceil, floor, sin, cos, pi
