[GRASS-SVN] r50924 - in grass/trunk/temporal: t.create t.info
t.list t.register t.remove t.sample t.support t.topology
t.unregister tr.aggregate tr.aggregate.ds tr.export
tr.extract tr.import tr.list tr.out.vtk tr.series tr.to.rast3
tr.univar tr3.extract tr3.list tv.list tv.observe.strds
tv.what.strds
svn_grass at osgeo.org
Wed Feb 22 19:26:48 EST 2012
Author: huhabla
Date: 2012-02-22 16:26:48 -0800 (Wed, 22 Feb 2012)
New Revision: 50924
grass/trunk/temporal/t.create/t.create.py
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.register/t.register.py
grass/trunk/temporal/t.remove/t.remove.py
grass/trunk/temporal/t.sample/t.sample.py
grass/trunk/temporal/t.support/t.support.py
grass/trunk/temporal/t.topology/t.topology.py
grass/trunk/temporal/t.unregister/t.unregister.py
grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py
grass/trunk/temporal/tr.aggregate/tr.aggregate.py
grass/trunk/temporal/tr.export/tr.export.py
grass/trunk/temporal/tr.extract/tr.extract.py
grass/trunk/temporal/tr.import/tr.import.py
grass/trunk/temporal/tr.list/tr.list.py
grass/trunk/temporal/tr.out.vtk/tr.out.vtk.py
grass/trunk/temporal/tr.series/tr.series.py
grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py
grass/trunk/temporal/tr.univar/tr.univar.py
grass/trunk/temporal/tr3.extract/tr3.extract.py
grass/trunk/temporal/tr3.list/tr3.list.py
grass/trunk/temporal/tv.list/tv.list.py
grass/trunk/temporal/tv.observe.strds/tv.observe.strds.py
grass/trunk/temporal/tv.what.strds/tv.what.strds.py
Use parser standard options
Modified: grass/trunk/temporal/t.create/t.create.py
--- grass/trunk/temporal/t.create/t.create.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/t.create/t.create.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,19 +16,19 @@
#%module
#% description: Create a space time dataset
-#% keywords: spacetime
-#% keywords: dataset
+#% keywords: temporal
#% keywords: create
#%end
-#%option
-#% key: output
-#% type: string
-#% description: Name of the new space time dataset
-#% required: yes
-#% multiple: no
+#%option G_OPT_STDS_OUTPUT
#%end
+#%option G_OPT_STDS_TYPE
+#%end
+#%option G_OPT_T_TYPE
+#%end
#%option
#% key: semantictype
#% type: string
@@ -40,24 +40,6 @@
#%end
#%option
-#% key: type
-#% type: string
-#% description: Type of the space time dataset, default is strds
-#% required: no
-#% options: strds, str3ds, stvds
-#% answer: strds
-#%end
-#%option
-#% key: temporaltype
-#% type: string
-#% description: The temporal type of the space time dataset, default is absolute
-#% required: no
-#% options: absolute,relative
-#% answer: absolute
-#%end
-#%option
#% key: title
#% type: string
#% description: Title of the new space time dataset
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/t.info/t.info.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,8 +16,8 @@
#%module
#% description: List informtion about space time and map datasets
-#% keywords: spacetime dataset
-#% keywords: remove
+#% keywords: info
#%end
#%option
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/t.list/t.list.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -15,9 +15,8 @@
#%module
-#% description: List space time and map datasets
+#% description: List space time datasets and map
#% keywords: list
#%end
@@ -50,21 +49,10 @@
#% answer: id
#%end
-#%option
-#% key: where
-#% type: string
-#% description: A where statement for selected listing without "WHERE" e.g: "start_time < '2001-01-01' AND end_time > '2001-01-01'"
-#% required: no
-#% multiple: no
+#%option G_OPT_T_WHERE
#%end
-#%option
-#% type: string
-#% required: no
#%end
#%option
Modified: grass/trunk/temporal/t.register/t.register.py
--- grass/trunk/temporal/t.register/t.register.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/t.register/t.register.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,43 +16,24 @@
#%module
#% description: Register raster, vector adn raster3d maps in a space time datasets
-#% keywords: temnporal
-#% keywords: raster
-#% keywords: vector
-#% keywords: raster3d
+#% keywords: register
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of an existing space time dataset of type raster, vector or raster3d
-#% required: yes
-#% multiple: no
+#%option G_OPT_STDS_INPUT
+#% required: no
#%end
-#%option
-#% key: maps
-#% type: string
-#% description: Name(s) of existing map(s) of type raster, vector or raster3d
+#%option G_OPT_MAP_INPUTS
#% required: no
-#% multiple: yes
#%end
-#%option
-#% key: type
-#% type: string
-#% description: Type of the input map(s)
-#% required: no
-#% options: rast, vect, rast3d
-#% answer: rast
+#%option G_OPT_MAP_TYPE
#%end
-#%option
+#%option G_OPT_FILE_INPUT
#% key: file
-#% type: string
#% description: Input file with map names, one per line. Additionally the start time and the end time can be specified per line
-#% required: no
-#% multiple: no
#%end
#%option
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/t.remove/t.remove.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,17 +16,12 @@
#%module
#% description: Remove space time datasets from temporal database
#% keywords: remove
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name(s) of the space time dataset to be removed from the temporal database
#% required: no
-#% multiple: yes
#%end
#%option
Modified: grass/trunk/temporal/t.sample/t.sample.py
--- grass/trunk/temporal/t.sample/t.sample.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/t.sample/t.sample.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,60 +16,36 @@
#%module
#% description: Sample the input space time dataset with a sample space time dataset and print the result to stdout
#% keywords: sample
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of a space time dataset
-#% required: yes
-#% multiple: no
#%end
-#%option
#% key: sample
-#% type: string
#% description: Name of the sample space time dataset
-#% required: yes
-#% multiple: no
#%end
-#%option
#% key: intype
-#% type: string
-#% description: Type of the input space time dataset, default is space time raster dataset (strds)
-#% required: no
-#% answer: strds
#%end
-#%option
#% key: samtype
-#% type: string
-#% description: Type of the sample space time dataset, default is space time raster dataset (strds)
-#% required: no
-#% answer: strds
+#% description: Type of the sample space time dataset
#%end
-#%option
+#%option G_OPT_T_SAMPLE
#% key: method
-#% type: string
-#% description: The method to be used for sampling
-#% required: no
-#% multiple: yes
-#% options: start,during,overlap,contain,equal
#% answer: during,overlap,contain,equal
#%end
#%option
#% key: fs
#% type: string
-#% description: The field separator character between the columns, default is tabular " | ". Do not use "," as this char is reserved to list several map ids in a sample granule
+#% description: The field separator character between the output columns, default is tabular " | ". Do not use "," as this char is reserved to list several map ids in a sample granule
#% required: no
#%end
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/t.support/t.support.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,17 +16,11 @@
#%module
#% description: Modify the metadata of a space time dataset
-#% keywords: create
+#% keywords: support
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of the space time dataset
-#% required: yes
-#% multiple: no
#%end
#%option
@@ -39,13 +33,7 @@
#% answer: mean
#%end
-#%option
-#% key: type
-#% type: string
-#% required: no
-#% answer: strds
#%end
#%option
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/t.topology/t.topology.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,28 +16,17 @@
#%module
#% description: List and modify temporal topology of a space time dataset
+#% keywords: topology
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
-#%option
-#% key: type
-#% type: string
-#% description: Type of the space time dataset, default is space time raster dataset (strds)
-#% required: no
-#% answer: strds
#%end
-#%option G_OPT_DB_WHERE
#%end
#%flag
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/t.unregister/t.unregister.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -17,46 +17,26 @@
#%module
#% description: Unregister raster, vector and raster3d maps from the temporal database or a specific space time dataset
-#% keywords: strds
-#% keywords: stvds
-#% keywords: str3ds
+#% keywords: unregister
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of an existing space time raster dataset. If no name is provided the raster map(s) are unregistered from all space time datasets in which they are registered.
#% required: no
-#% multiple: no
#%end
-#%option
+#%option G_OPT_F_INPUT
#% key: file
-#% type: string
#% required: no
-#% multiple: no
#%end
-#%option
-#% key: type
-#% type: string
-#% required: no
-#% answer: rast
#%end
-#%option
-#% key: maps
-#% type: string
#% description: Name(s) of existing raster, vector or raster3d map(s) to unregister
#% required: no
-#% multiple: yes
#%end
import grass.script as grass
Modified: grass/trunk/temporal/tr.aggregate/tr.aggregate.py
--- grass/trunk/temporal/tr.aggregate/tr.aggregate.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.aggregate/tr.aggregate.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,20 +16,14 @@
#%module
#% description: Create a new space time raster dataset from the aggregated data of an existing space time raster dataset
-#% keywords: spacetime raster dataset
#% keywords: aggregation
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of a space time raster dataset
-#% required: yes
-#% multiple: no
+#%option G_OPT_STRDS_INPUT
#%end
#%end
#%option
@@ -58,22 +52,10 @@
#% answer: average
#%end
-#%option
-#% key: sampling
-#% type: string
-#% description: The method to be used for sampling the input dataset
-#% required: no
-#% multiple: yes
-#% answer: start
#%end
-#%option
-#% key: base
-#% type: string
-#% description: Base name of the new created raster maps
-#% required: yes
-#% multiple: no
+#%option G_OPT_R_BASE
#%end
#%flag
Modified: grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py
--- grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,34 +16,20 @@
#%module
#% description: Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
-#%option
#% key: sample
-#% type: string
#% description: The time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation.
-#% required: yes
-#% multiple: no
#%end
-#%option
-#% key: type
-#% type: string
#% description: Type of the aggregation space time dataset, default is strds
-#% required: no
-#% answer: strds
#%end
#%option
@@ -64,22 +50,10 @@
#% answer: average
#%end
-#%option
-#% key: sampling
-#% type: string
-#% required: no
-#% multiple: yes
-#% answer: start
#%end
-#%option
-#% key: base
-#% type: string
-#% required: yes
-#% multiple: no
#%end
#%flag
Modified: grass/trunk/temporal/tr.export/tr.export.py
--- grass/trunk/temporal/tr.export/tr.export.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.export/tr.export.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,26 +16,15 @@
#%module
#% description: Export space time raster dataset
#% keywords: export
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
-#%option
-#% key: output
-#% type: string
+#%option G_OPT_F_OUTPUT
#% description: Name of a space time raster dataset archive
-#% required: yes
-#% multiple: no
#%end
#%option
@@ -58,12 +47,7 @@
#% answer: bzip2
#%end
-#%option
-#% key: where
-#% type: string
-#% description: A where statement for selected listing e.g: start_time < '2001-01-01' and end_time > '2001-01-01"'
-#% required: no
-#% multiple: no
#%end
import shutil
Modified: grass/trunk/temporal/tr.extract/tr.extract.py
--- grass/trunk/temporal/tr.extract/tr.extract.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.extract/tr.extract.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,25 +16,14 @@
#%module
#% description: Extract a subset of a space time raster dataset
#% keywords: extract
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
-#%option
-#% key: where
-#% type: string
-#% required: no
-#% multiple: no
#%end
#%option
@@ -45,20 +34,10 @@
#% multiple: no
#%end
-#%option
-#% key: output
-#% type: string
-#% description: Name of the output space time raster dataset
-#% required: yes
-#% multiple: no
+#%option G_OPT_STRDS_OUTPUT
#%end
-#%option
-#% key: base
-#% type: string
-#% required: no
-#% multiple: no
#%end
#%flag
Modified: grass/trunk/temporal/tr.import/tr.import.py
--- grass/trunk/temporal/tr.import/tr.import.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.import/tr.import.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,26 +16,14 @@
#%module
#% description: Import space time raster dataset
#% keywords: import
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of a space time raster dataset archive file
-#% required: yes
-#% multiple: no
#%end
-#%option
-#% key: output
-#% type: string
-#% required: yes
-#% multiple: no
#%end
#%option
Modified: grass/trunk/temporal/tr.list/tr.list.py
--- grass/trunk/temporal/tr.list/tr.list.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.list/tr.list.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,18 +16,12 @@
#%module
#% description: List registered maps of a space time raster dataset
#% keywords: raster
#% keywords: list
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
#%option
@@ -50,12 +44,7 @@
#% answer: name,mapset,start_time,end_time
#%end
-#%option
-#% key: where
-#% type: string
-#% required: no
-#% multiple: no
#%end
#%option
Modified: grass/trunk/temporal/tr.out.vtk/tr.out.vtk.py
--- grass/trunk/temporal/tr.out.vtk/tr.out.vtk.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.out.vtk/tr.out.vtk.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -23,12 +23,7 @@
#% keywords: VTK
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
#%option
@@ -39,20 +34,11 @@
#% multiple: no
#%end
-#%option G_OPT_R_INPUT
-#% key: elevation
-#% type: string
-#% description: Elevation raster map
+#%option G_OPT_R_ELEV
#% required: no
-#% multiple: no
#%end
-#%option
-#% key: where
-#% type: string
-#% description: A where statement for selected listing e.g: (start_time < '2001-01-01' and end_time > '2001-01-01')
-#% required: no
-#% multiple: no
#%end
#%option
Modified: grass/trunk/temporal/tr.series/tr.series.py
--- grass/trunk/temporal/tr.series/tr.series.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.series/tr.series.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,17 +16,11 @@
#%module
#% description: Performe different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset
-#% keywords: extract
+#% keywords: series
#%end
-#%option
-#% key: input
-#% type: string
-#% required: no
-#% multiple: yes
#%end
#%option
@@ -49,7 +43,7 @@
#% answer: id
#%end
#%end
#%option G_OPT_R_OUTPUT
Modified: grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py
--- grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,18 +16,12 @@
#%module
#% description: Convert a space time raster dataset into a rast3d map
+#% keywords: convert
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
#%option G_OPT_R3_OUTPUT
Modified: grass/trunk/temporal/tr.univar/tr.univar.py
--- grass/trunk/temporal/tr.univar/tr.univar.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr.univar/tr.univar.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -21,21 +21,16 @@
#% keywords: statistics
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
#%end
#%option
#% key: fs
#% type: string
#% required: no
#% answer: |
#%end
Modified: grass/trunk/temporal/tr3.extract/tr3.extract.py
--- grass/trunk/temporal/tr3.extract/tr3.extract.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr3.extract/tr3.extract.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,25 +16,14 @@
#%module
#% description: Extract a subset of a space time raster3d dataset
-#% keywords: spacetime raster3d dataset
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of a space time raster3d dataset
-#% required: yes
-#% multiple: no
+#%option G_OPT_STR3DS_INPUT
#%end
-#%option
-#% key: where
-#% type: string
-#% required: no
-#% multiple: no
#%end
#%option
@@ -45,12 +34,7 @@
#% multiple: no
#%end
-#%option
-#% key: output
-#% type: string
-#% description: Name of the output space time raster3d dataset
-#% required: yes
-#% multiple: no
+#%option G_OPT_STR3DS_OUTPUT
#%end
#%option
Modified: grass/trunk/temporal/tr3.list/tr3.list.py
--- grass/trunk/temporal/tr3.list/tr3.list.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tr3.list/tr3.list.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -22,12 +22,7 @@
#% keywords: list
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
#%option
@@ -50,12 +45,7 @@
#%end
-#%option
-#% key: where
-#% type: string
-#% description: A where statement for selected listing e.g: "start_time < '2001-01-01' and end_time > '2001-01-01'"
-#% required: no
-#% multiple: no
#%end
#%option
@@ -71,7 +61,7 @@
#%option
#% key: fs
#% type: string
-#% description: The field separator character between the columns, default is tabular "\t"
+#% description: The field separator character between the output columns, default is tabular "\t"
#% required: no
#%end
Modified: grass/trunk/temporal/tv.list/tv.list.py
--- grass/trunk/temporal/tv.list/tv.list.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tv.list/tv.list.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,18 +16,11 @@
#%module
#% description: List registered maps of a space time vector dataset
#% keywords: list
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of a space time vector dataset
-#% required: yes
-#% multiple: no
+#%option G_OPT_STVDS_INPUT
#%end
#%option
@@ -50,12 +43,7 @@
#% answer: id,name,layer,mapset,start_time,end_time
#%end
-#%option
-#% key: where
-#% type: string
-#% required: no
-#% multiple: no
#%end
#%option
Modified: grass/trunk/temporal/tv.observe.strds/tv.observe.strds.py
--- grass/trunk/temporal/tv.observe.strds/tv.observe.strds.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tv.observe.strds/tv.observe.strds.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,17 +16,11 @@
#%module
#% description: Observe specific locations in a space time raster dataset over a periode of time using vector points
-#% keywords: space time raster dataset
-#% keywords: space time vector dataset
#% keywords: sampling
#%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of a vector map
-#% required: yes
-#% multiple: no
#%end
#%option
@@ -53,20 +47,11 @@
#% multiple: no
#%end
-#%option
-#% key: where
-#% type: string
-#% description: A where statement for attribute selection related to the input dataset without "WHERE" e.g: "cat < 200"
-#% required: no
-#% multiple: no
+#%option G_OPT_DB_WHERE
#%end
-#%option
-#% key: tempwhere
-#% type: string
-#% description: A where statement for temporal selection related to the input dataset without "WHERE" e.g: "start_time < '2001-01-01' AND end_time > '2001-01-01'"
-#% required: no
-#% multiple: no
+#% key: t_where
#%end
@@ -83,7 +68,7 @@
strds = options["strds"]
where = options["where"]
column = options["column"]
- tempwhere = options["tempwhere"]
+ tempwhere = options["t_where"]
if where == "" or where == " " or where == "\n":
where = None
Modified: grass/trunk/temporal/tv.what.strds/tv.what.strds.py
--- grass/trunk/temporal/tv.what.strds/tv.what.strds.py 2012-02-23 00:22:45 UTC (rev 50923)
+++ grass/trunk/temporal/tv.what.strds/tv.what.strds.py 2012-02-23 00:26:48 UTC (rev 50924)
@@ -16,25 +16,15 @@
#%module
#% description: Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets
#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
#%end
-#%option
#% key: strds
-#% type: string
-#% description: The space time raster dataset to use
-#% required: yes
-#% multiple: no
#%end
#%option
@@ -45,30 +35,14 @@
#% multiple: no
#%end
-#%option
-#% key: where
-#% type: string
-#% required: no
-#% multiple: no
#%end
-#%option
-#% key: tempwhere
-#% type: string
-#% required: no
-#% multiple: no
+#% key: t_where
#%end
-#%option
-#% key: sampling
-#% type: string
-#% description: The method to be used for temporal sampling
-#% required: no
-#% multiple: yes
-#% answer: start
#%end
@@ -85,7 +59,7 @@
sampling = options["sampling"]
