[GRASS-SVN] r50940 - in grass/trunk: imagery/i.aster.toar lib/gis
lib/init lib/raster raster/r.li/r.li.setup raster/r.sun
vector/v.external
svn_grass at osgeo.org
Sat Feb 25 08:38:13 EST 2012
Author: neteler
Date: 2012-02-25 05:38:13 -0800 (Sat, 25 Feb 2012)
New Revision: 50940
grass/trunk/imagery/i.aster.toar/main.c
grass/trunk/lib/gis/parser_wps.c
grass/trunk/lib/init/Makefile
grass/trunk/lib/raster/R.h
grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
grass/trunk/raster/r.sun/r.sun.html
grass/trunk/vector/v.external/v.external.html
typos fixed, part 3 (bug trac #1591)
Modified: grass/trunk/imagery/i.aster.toar/main.c
--- grass/trunk/imagery/i.aster.toar/main.c 2012-02-25 13:38:11 UTC (rev 50939)
+++ grass/trunk/imagery/i.aster.toar/main.c 2012-02-25 13:38:13 UTC (rev 50940)
@@ -162,7 +162,7 @@
radiance = (flag0->answer);
- /*Prepare the ouput file names */
+ /*Prepare the output file names */
sprintf(result0,"%s%s", result, ".1");
Modified: grass/trunk/lib/gis/parser_wps.c
--- grass/trunk/lib/gis/parser_wps.c 2012-02-25 13:38:11 UTC (rev 50939)
+++ grass/trunk/lib/gis/parser_wps.c 2012-02-25 13:38:13 UTC (rev 50940)
@@ -350,7 +350,7 @@
found_output = 0;
- /*parse the ouput. only raster and vector map and stdout are supported */
+ /*parse the output. only raster and vector map and stdout are supported */
if (st->n_opts) {
opt = &st->first_option;
while (opt != NULL) {
Modified: grass/trunk/lib/init/Makefile
--- grass/trunk/lib/init/Makefile 2012-02-25 13:38:11 UTC (rev 50939)
+++ grass/trunk/lib/init/Makefile 2012-02-25 13:38:13 UTC (rev 50940)
@@ -52,7 +52,7 @@
ifneq ($(strip $(MINGW)),)
$(ARCH_BINDIR)/$(START_UP): grass.sh
@test -d $(ARCH_BINDIR) || (echo 'ARCH_BINDIR($(ARCH_BINDIR))' not found; exit 1)
- @test -w $(ARCH_BINDIR) || (echo 'ARCH_BINDIR($(ARCH_BINDIR))' not writeable; exit 1)
+ @test -w $(ARCH_BINDIR) || (echo 'ARCH_BINDIR($(ARCH_BINDIR))' not writable; exit 1)
rm -f $@ ; true
sed \
-e 's#@BINDIR@#$(ARCH_BINDIR)#' \
Modified: grass/trunk/lib/raster/R.h
--- grass/trunk/lib/raster/R.h 2012-02-25 13:38:11 UTC (rev 50939)
+++ grass/trunk/lib/raster/R.h 2012-02-25 13:38:13 UTC (rev 50940)
@@ -82,7 +82,7 @@
int window_set; /* Flag: window set? */
int split_window; /* Separate windows for input and output */
struct Cell_head rd_window; /* Window used for input */
- struct Cell_head wr_window; /* Window used for ouput */
+ struct Cell_head wr_window; /* Window used for output */
int fileinfo_count;
struct fileinfo *fileinfo;
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup.html 2012-02-25 13:38:11 UTC (rev 50939)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup.html 2012-02-25 13:38:13 UTC (rev 50940)
@@ -7,7 +7,7 @@
The configurations are raster map independent,
it means that you can use a file created on a raster map for analyze any
other you have. <br>
-The program is completly interactive and uses a GUI to help you
+The program is completely interactive and uses a GUI to help you
in your choices.
<h3>Analysis methods</h3>
Modified: grass/trunk/raster/r.sun/r.sun.html
--- grass/trunk/raster/r.sun/r.sun.html 2012-02-25 13:38:11 UTC (rev 50939)
+++ grass/trunk/raster/r.sun/r.sun.html 2012-02-25 13:38:13 UTC (rev 50940)
@@ -119,7 +119,7 @@
both cell sizes. The reasonable values are in the range 0.5-1.5. The values
below 0.5 will decrease and values above 1.0 will increase the computing
speed. Values greater than 2.0 may produce estimates with lower accuracy
-in highly dissected relief. The fully shadowed areas are written to the ouput
+in highly dissected relief. The fully shadowed areas are written to the output
maps as zero values. Areas with NULL data are considered as no barrier with
shadowing effect .
<p>The maps' history files are generated containing the following listed
Modified: grass/trunk/vector/v.external/v.external.html
--- grass/trunk/vector/v.external/v.external.html 2012-02-25 13:38:11 UTC (rev 50939)
+++ grass/trunk/vector/v.external/v.external.html 2012-02-25 13:38:13 UTC (rev 50940)
@@ -62,7 +62,7 @@
results with input layers created by <em>v.external</em>.
<p>See <em><a href="v.db.connect.html">v.db.connect</a></em> for an example of
-maintaining attributes in external DBMS in also writeable mode.
+maintaining attributes in external DBMS in also writable mode.
<h2>REFERENCES</h2>
