[GRASS-SVN] r50942 - grass-addons/grass6/raster/r.basin
svn_grass at osgeo.org
Sat Feb 25 15:10:32 EST 2012
Author: madi
Date: 2012-02-25 12:10:31 -0800 (Sat, 25 Feb 2012)
New Revision: 50942
grass-addons/grass6/raster/r.basin/r.basin.py
platform recognition
Modified: grass-addons/grass6/raster/r.basin/r.basin.py
--- grass-addons/grass6/raster/r.basin/r.basin.py 2012-02-25 13:38:13 UTC (rev 50941)
+++ grass-addons/grass6/raster/r.basin/r.basin.py 2012-02-25 20:10:31 UTC (rev 50942)
@@ -71,6 +71,7 @@
from numpy import array
from numpy import zeros
import csv
+import platform
if not os.environ.has_key("GISBASE"):
grass.message( "You must be in GRASS GIS to run this program." )
@@ -118,6 +119,9 @@
v_ord_1 = prefix+'_ord_1'
global tmp
+ # get info about the platform
+ plat = platform.system()
# Save current region
grass.read_command('g.region', flags = 'p', save = 'original', overwrite = True)
@@ -287,19 +291,31 @@
flags = 'o',
distance = r_distance,
overwrite = True)
+ if plat == "Windows":
+ # Ipsographic curve
+ grass.message( "##################################" )
+ grass.run_command('r.ipso', map = 'r_elevation_crop', image = prefix, flags = 'ab')
+ # Width Function
+ grass.run_command('r.wf', map = r_distance,
+ image = prefix)
+ else:
+ grass.run_command('r.ipso.py', map = 'r_elevation_crop',
+ image = prefix,
+ flags = 'ab')
- # Width Function
- grass.message( "##################################" )
- grass.run_command('r.wf.py', map = r_distance,
- image = prefix)
- # Ipsographic curve
- grass.run_command('r.ipso.py', map = 'r_elevation_crop',
- image = prefix,
- flags = 'ab')
+ # Width Function
+ grass.run_command('r.wf.py', map = r_distance,
+ image = prefix)
# Creation of map of hillslope distance to river network
grass.run_command('r.stream.distance', stream = r_stream_e,
