[GRASS-SVN] r50036 - in grass/trunk: gui/wxpython/dbmgr gui/wxpython/vdigit lib/vector/vedit
Mon Jan 2 12:53:39 EST 2012
Author: martinl
Date: 2012-01-02 09:53:39 -0800 (Mon, 02 Jan 2012)
New Revision: 50036
   grass/trunk/gui/wxpython/dbmgr/manager.py
   grass/trunk/gui/wxpython/vdigit/wxdisplay.py
   grass/trunk/lib/vector/vedit/render.c
wxGUI/vdigit: fix highlighting selected features (areas enabled)
Modified: grass/trunk/gui/wxpython/dbmgr/manager.py
--- grass/trunk/gui/wxpython/dbmgr/manager.py	2012-01-02 17:18:38 UTC (rev 50035)
+++ grass/trunk/gui/wxpython/dbmgr/manager.py	2012-01-02 17:53:39 UTC (rev 50036)
@@ -1305,9 +1305,9 @@
                                               update = True)
         if zoom:
-            self.mapdisplay.Map.AdjustRegion() # adjust resolution
+            self.mapdisplay.Map.AdjustRegion()           # adjust resolution
             self.mapdisplay.Map.AlignExtentFromDisplay() # adjust extent
-            self.mapdisplay.MapWindow.UpdateMap(render = True, renderVector = True)
+            self.mapdisplay.MapWindow.UpdateMap(render = True,  renderVector = True)
         else:
             self.mapdisplay.MapWindow.UpdateMap(render = False, renderVector = True)
Modified: grass/trunk/gui/wxpython/vdigit/wxdisplay.py
--- grass/trunk/gui/wxpython/vdigit/wxdisplay.py	2012-01-02 17:18:38 UTC (rev 50035)
+++ grass/trunk/gui/wxpython/vdigit/wxdisplay.py	2012-01-02 17:53:39 UTC (rev 50036)
@@ -239,7 +239,7 @@
         if not self.dc or not self.dcTmp:
             return -1
-        Debug.msg(3, "_drawObject(): type=%d npoints=%d", robj.type, robj.npoints)
+        Debug.msg(3, "_drawObject(): line=%d type=%d npoints=%d", robj.fid, robj.type, robj.npoints)
         brush = None
         if self._isSelected(robj.fid):
             pdc = self.dcTmp
@@ -406,21 +406,8 @@
         @return True if vector object is selected
         @return False if vector object is not selected
-        if len(self.selected['cats']) < 1 or force:
-            # select by id
-            if line in self.selected['ids']:
-                return True
-        else:
-            # select by cat
-            Vect_read_line(self.poMapInfo, None, self.poCats, line)
-            cats = self.poCats.contents
-            for i in range(cats.n_cats):
-                if cats.field[i] == self.selected['field'] and \
-                        cats.cat[i] in self.selected['cats']:
-                    # remember id
-                    # -> after drawing all features selected.cats is reseted */
-                    self.selected['ids'].append(line)
-                    return True
+        if line in self.selected['ids']:
+            return True
         return False
@@ -462,13 +449,10 @@
         if not self.poMapInfo or not self.dc or not self.dcTmp:
             return -1
-        try:
-            rlist = Vedit_render_map(self.poMapInfo, byref(self._getRegionBox()), self._getDrawFlag(),
-                                     self.region['center_easting'], self.region['center_northing'],
-                                     self.mapObj.width, self.mapObj.height,
-                                     max(self.region['nsres'], self.region['ewres'])).contents
-        except SystemExit:
-            pass
+        rlist = Vedit_render_map(self.poMapInfo, byref(self._getRegionBox()), self._getDrawFlag(),
+                                 self.region['center_easting'], self.region['center_northing'],
+                                 self.mapObj.width, self.mapObj.height,
+                                 max(self.region['nsres'], self.region['ewres'])).contents
         self._resetTopology()
Modified: grass/trunk/lib/vector/vedit/render.c
--- grass/trunk/lib/vector/vedit/render.c	2012-01-02 17:18:38 UTC (rev 50035)
+++ grass/trunk/lib/vector/vedit/render.c	2012-01-02 17:53:39 UTC (rev 50036)
@@ -135,6 +135,9 @@
 				     list_obj->nitems *
 				     sizeof(struct robject *));
+    G_debug(1, "Vedit_render_map(): -> nitems = %d",
+	    list_obj->nitems);
     Vect_destroy_boxlist(list);
     return list_obj;
