[GRASS-SVN] r50046 - in grass/branches/releasebranch_6_4/gui:
scripts wxpython/xml
svn_grass at osgeo.org
Tue Jan 3 06:52:34 EST 2012
Author: martinl
Date: 2012-01-03 03:52:34 -0800 (Tue, 03 Jan 2012)
New Revision: 50046
Added:
grass/branches/releasebranch_6_4/gui/scripts/g.extension.rebuild.all.py
grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
wxGUI: backport g.extension.rebuild.all from devbr6
Added: grass/branches/releasebranch_6_4/gui/scripts/g.extension.rebuild.all.py
--- grass/branches/releasebranch_6_4/gui/scripts/g.extension.rebuild.all.py (rev 0)
+++ grass/branches/releasebranch_6_4/gui/scripts/g.extension.rebuild.all.py 2012-01-03 11:52:34 UTC (rev 50046)
@@ -0,0 +1,92 @@
+#!/usr/bin/env python
+# MODULE: g.extension.rebuild.all
+# AUTHOR(S): Martin Landa <landa.martin gmail.com>
+# PURPOSE: Rebuild locally installed GRASS Addons extensions
+# COPYRIGHT: (C) 2011 by Martin Landa, and the GRASS Development Team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+#%module
+#% label: Rebuilds all locally installed GRASS Addons extensions.
+#% description: By default only extensions built against different GIS Library are rebuilt.
+#% keywords: general
+#% keywords: installation
+#% keywords: extensions
+#%end
+#%flag
+#% key: f
+#% description: Force to rebuild all extensions
+#% end
+import os
+import sys
+try:
+ import xml.etree.ElementTree as etree
+except ImportError:
+ import elementtree.ElementTree as etree # Python <= 2.4
+import grass.script as grass
+def get_extensions():
+ addon_base = os.getenv('GRASS_ADDON_PATH')
+ if not addon_base:
+ grass.fatal(_("%s not defined") % "GRASS_ADDON_PATH")
+ fXML = os.path.join(addon_base, 'modules.xml')
+ if not os.path.exists(fXML):
+ return []
+ # read XML file
+ fo = open(fXML, 'r')
+ try:
+ tree = etree.fromstring(fo.read())
+ except StandardError, e:
+ grass.error(_("Unable to parse metadata file: %s") % e)
+ fo.close()
+ return []
+ fo.close()
+ libgis_rev = grass.version()['libgis_revision']
+ ret = list()
+ for tnode in tree.findall('task'):
+ gnode = tnode.find('libgis')
+ if gnode is not None and \
+ gnode.get('revision', '') != libgis_rev:
+ ret.append(tnode.get('name'))
+ return ret
+def main():
+ if flags['f']:
+ extensions = grass.read_command('g.extension.py',
+ quiet = True, flags = 'a').splitlines()
+ else:
+ extensions = get_extensions()
+ if not extensions:
+ grass.info(_("Nothing to rebuild."))
+ return 0
+ for ext in extensions:
+ grass.message('-' * 60)
+ grass.message(_("Reinstalling extension <%s>...") % ext)
+ grass.run_command('g.extension.py',
+ extension = ext)
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass/branches/releasebranch_6_4/gui/scripts/g.extension.rebuild.all.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Modified: grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
--- grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml 2012-01-03 11:33:59 UTC (rev 50045)
+++ grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml 2012-01-03 11:52:34 UTC (rev 50046)
@@ -841,6 +841,13 @@
<command>g.extension</command>
</menuitem>
<menuitem>
+ <label>Update installed extensions</label>
+ <help>Rebuilds all locally installed GRASS Addons extensions.</help>
+ <keywords>general,installation,extensions</keywords>
+ <handler>OnMenuCmd</handler>
+ <command>g.extension.rebuild.all.py</command>
+ </menuitem>
+ <menuitem>
<label>Remove extension</label>
<help>Removes installed GRASS AddOns extension.</help>
<keywords>general,extensions</keywords>
