[GRASS-SVN] r50073 - grass/trunk/mswindows/osgeo4w
Thu Jan 5 14:11:51 EST 2012
Author: martinl
Date: 2012-01-05 11:11:51 -0800 (Thu, 05 Jan 2012)
New Revision: 50073
   grass/trunk/mswindows/osgeo4w/msys.bat
osgeo4w: cosmetics in msys.bat (b/w)
	 (merge r50072 from devbr6)
Modified: grass/trunk/mswindows/osgeo4w/msys.bat
--- grass/trunk/mswindows/osgeo4w/msys.bat	2012-01-05 18:59:28 UTC (rev 50072)
+++ grass/trunk/mswindows/osgeo4w/msys.bat	2012-01-05 19:11:51 UTC (rev 50073)
@@ -88,15 +88,15 @@
 rem Setup the default colors for rxvt.
 if "x%MSYSBGCOLOR%" == "x" set MSYSBGCOLOR=White
 if "x%MSYSFGCOLOR%" == "x" set MSYSFGCOLOR=Black
-if "x%MINGW32BGCOLOR%" == "x" set MINGW32BGCOLOR=LightYellow
-if "x%MINGW32FGCOLOR%" == "x" set MINGW32FGCOLOR=Navy
+if "x%MINGW32BGCOLOR%" == "x" set MINGW32BGCOLOR=Black
+if "x%MINGW32FGCOLOR%" == "x" set MINGW32FGCOLOR=White
 if "%MSYSTEM%" == "MSYS" set BGCOLOR=%MSYSBGCOLOR%
 if "%MSYSTEM%" == "MSYS" set FGCOLOR=%MSYSFGCOLOR%
 if "%MSYSTEM%" == "MINGW32" set BGCOLOR=%MINGW32BGCOLOR%
 if "%MSYSTEM%" == "MINGW32" set FGCOLOR=%MINGW32FGCOLOR%
-if "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -i
-if NOT "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"
+if "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -i
+if NOT "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"
 exit
 :startsh
