[GRASS-SVN] r50076 - in grass/trunk/mswindows: . osgeo4w
svn_grass at osgeo.org
Fri Jan 6 14:35:09 EST 2012
Author: martinl
Date: 2012-01-06 11:35:09 -0800 (Fri, 06 Jan 2012)
New Revision: 50076
grass/trunk/mswindows/GRASS-Installer.nsi
grass/trunk/mswindows/env.bat
grass/trunk/mswindows/osgeo4w/env.bat.tmpl
wingrass: fix cmd/msys launch procedure, clean up env files
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi 2012-01-06 13:49:59 UTC (rev 50075)
+++ grass/trunk/mswindows/GRASS-Installer.nsi 2012-01-06 19:35:09 UTC (rev 50076)
@@ -636,39 +636,28 @@
SetShellVarContext current
CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
- "$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with wxGUI"
- ; not working after changing to start Grass7 by grass70.py
- ;CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
- ;"$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and a MSYS UNIX terminal"
- ; new attempt to get Grass70-wx-gui and a working msys-shell in a windows command line
- CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\set_shell_start_${GRASS_COMMAND}.bat" ""\
- "$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and a MSYS-Windows-commandline"
+ "$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD terminal"
;Create the Windows Start Menu Shortcuts
SetShellVarContext all
CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
+ "$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD console"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS GUI with MSYS.lnk" "$INSTALL_DIR\${GRASS_COMMAND}_msys.bat" "-wx"\
+ "$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and MSYS UNIX console"
CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Command Line.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-text"\
"$INSTALL_DIR\icons\GRASS_CMD.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} in text mode"
CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\MSYS UNIX Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
"$INSTALL_DIR\icons\MSYS_Custom_Icon.ico" "" SW_SHOWNORMAL "" "Open a MSYS UNIX console"
CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
"$INSTALL_DIR\icons\GRASS_Web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS website"
- ;CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS GUI with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wx"\
- CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS GUI with MSYS.lnk" "$INSTALL_DIR\set_shell_start_${GRASS_COMMAND}.bat" ""\
; FIXME: ship the WinGrass release notes .html file instead of URL
; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass70/binary/mswindows/native/README.html?format=raw
; probably ship with devel versions too? ie Release Notes, not the Release Announcement press release.
@@ -695,7 +684,6 @@
FileWrite $0 'rem #$\r$\n'
FileWrite $0 'rem #########################################################################$\r$\n'
FileWrite $0 '$\r$\n'
- FileWrite $0 'rem Set GRASS Installation Directory Variable$\r$\n'
FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
${If} $R_HKLM_INSTALL_PATH != ""
@@ -714,29 +702,40 @@
FileClose $0
done_create_grass_command.bat:
- ;Create the set_shell_start_grass.bat to start Grass7-wxgui and a msys-windows-commandline
+ ;Create the grass_command_msys.bat
ClearErrors
- FileOpen $0 $INSTALL_DIR\set_shell_start_${GRASS_COMMAND}.bat w
- IfErrors done_create_set_shell_start_grass.bat
+ FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}_msys.bat w
+ IfErrors done_create_grass_command_msys.bat
FileWrite $0 '@echo off$\r$\n'
- FileWrite $0 'rem # File dynamically created by NSIS installer script$\r$\n'
+ FileWrite $0 'rem # File dynamically created by NSIS installer script;$\r$\n'
- FileWrite $0 'rem # Set SHELL and start GRASS$\r$\n'
+ FileWrite $0 'rem # GRASS Initialization (MSYS)$\r$\n'
- FileWrite $0 'rem *******Set SHELL***********$\r$\n'
+ FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
+ FileWrite $0 'set GRASS_SH=%GISBASE%\msys\bin\sh.exe$\r$\n'
- FileWrite $0 'set SHELL="$INSTALL_DIR\msys\bin\sh.exe"$\r$\n'
+ ${If} $R_HKLM_INSTALL_PATH != ""
+ FileWrite $0 'set PATH=$R_HKLM_INSTALL_PATH\bin;%PATH%$\r$\n'
- FileWrite $0 '"$INSTALL_DIR\${GRASS_COMMAND}.bat"$\r$\n'
+ ${EndIf}
+ ${If} $R_HKCU_INSTALL_PATH != ""
+ FileWrite $0 'set PATH=$R_HKCU_INSTALL_PATH\bin;%PATH%$\r$\n'
+ FileWrite $0 '$\r$\n'
+ ${EndIf}
+ FileWrite $0 'call "%GISBASE%\etc\env.bat"$\r$\n'
+ FileWrite $0 'cd "%USERPROFILE%"'
+ FileWrite $0 '%GRASS_PYTHON% "%GISBASE%\etc\grass70.py" %*'
FileClose $0
- done_create_set_shell_start_grass.bat:
+ done_create_grass_command_msys.bat:
;Set the UNIX_LIKE GRASS Path
Var /GLOBAL UNIX_LIKE_DRIVE
Var /GLOBAL UNIX_LIKE_GRASS_PATH
Modified: grass/trunk/mswindows/env.bat
--- grass/trunk/mswindows/env.bat 2012-01-06 13:49:59 UTC (rev 50075)
+++ grass/trunk/mswindows/env.bat 2012-01-06 19:35:09 UTC (rev 50076)
@@ -1,32 +1,15 @@
-set WINGISBASE=%GISBASE%
+rem Environmental variables for GRASS stand-alone installer
-rem Name of the wish (Tk) executable
-set GRASS_WISH=wish.exe
-rem Path to the shell command
-set GRASS_SH=%GISBASE%\msys\bin\sh.exe
-rem Set Path to utilities (libraries and binaries) used by GRASS
-set PATH=%GISBASE%\msys\bin;%PATH%
-set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%
-set PATH=%GISBASE%\tcl-tk\bin;%GISBASE%\sqlite\bin;%GISBASE%\gpsbabel;%PATH%
-set PATH=%GISBASE%\bin;%GISBASE%\scripts;%PATH%
-rem Set Path to default web browser
+set GRASS_WISH=%GISBASE%\extrabin\wish.exe
+set GRASS_PYTHON=python
+set GRASS_PROJSHARE=%GISBASE%\proj
set GRASS_HTML_BROWSER=explorer
-rem Path to the proj files (notably the epsg projection list)
-set GRASS_PROJSHARE=%GISBASE%\proj
-rem Set GDAL_DATA
+set PYTHONHOME=%GISBASE%\Python25
set GDAL_DATA=%GISBASE%\share\gdal
-rem Set PROJ_LIB
set PROJ_LIB=%GISBASE%\proj
-rem Set GEOTIFF_CSV
set GEOTIFF_CSV=%GISBASE%\share\epsg_csv
-rem Path to the python directory
-set PYTHONHOME=%GISBASE%\Python25
-if "x%GRASS_PYTHON%" == "x" set GRASS_PYTHON=python
+set PATH=%GISBASE%\msys\bin;%PATH%
+set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%
+set PATH=%GISBASE%\tcl-tk\bin;%GISBASE%\sqlite\bin;%GISBASE%\gpsbabel;%PATH%
Modified: grass/trunk/mswindows/osgeo4w/env.bat.tmpl
--- grass/trunk/mswindows/osgeo4w/env.bat.tmpl 2012-01-06 13:49:59 UTC (rev 50075)
+++ grass/trunk/mswindows/osgeo4w/env.bat.tmpl 2012-01-06 19:35:09 UTC (rev 50076)
@@ -1,7 +1,14 @@
+rem Environmental variables for GRASS OSGeo4W installer
set GISBASE=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@
set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
set GRASS_WISH=%OSGEO4W_ROOT%\bin\wish.exe
-set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python.exe
set GRASS_PROJSHARE=%OSGEO4W_ROOT%\share\proj
-set PATH=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@\bin;%PATH%
+set PYTHONHOME=%OSGEO4W_ROOT%\apps\Python25
+set GDAL_DATA=%OSGEO4W_ROOT%\share\gdal
+set PROJ_LIB=%OSGEO4W_ROOT%\proj
+set GEOTIFF_CSV=%OSGEO4W_ROOT%\share\epsg_csv
