[GRASS-SVN] r50107 - grass/trunk/gui/wxpython/xml
Mon Jan 9 09:22:29 EST 2012
Author: lucadelu
Date: 2012-01-09 06:22:29 -0800 (Mon, 09 Jan 2012)
New Revision: 50107
   grass/trunk/gui/wxpython/xml/menudata.README
   grass/trunk/gui/wxpython/xml/menudata.xml
move entry position and change label of v.to.db;change path to update_menudata.py
Modified: grass/trunk/gui/wxpython/xml/menudata.README
--- grass/trunk/gui/wxpython/xml/menudata.README	2012-01-09 14:20:45 UTC (rev 50106)
+++ grass/trunk/gui/wxpython/xml/menudata.README	2012-01-09 14:22:29 UTC (rev 50107)
@@ -1,5 +1,5 @@
 menudata.xml is in part maintained by this script:
-  gui/wxpython/support/update_menudata.py
+  gui/wxpython/tools/update_menudata.py
 which updates the description and keywords (based on module's
 module->label or module->description, module->keywords), and is in
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2012-01-09 14:20:45 UTC (rev 50106)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2012-01-09 14:22:29 UTC (rev 50107)
@@ -2468,6 +2468,13 @@
 	  <handler>OnMenuCmd</handler>
 	  <command>v.what.vect</command>
 	</menuitem>
+	<menuitem>
+	  <label>Update database values from vector</label>
+	  <help>Populates database values from vector features.</help>
+	  <keywords>vector,database,attribute table</keywords>
+	  <handler>OnMenuCmd</handler>
+	  <command>v.to.db</command>
+	</menuitem>
 	<menu>
 	  <label>Update point attributes from raster</label>
 	  <items>
@@ -2513,13 +2520,6 @@
 	      <command>v.report</command>
 	    </menuitem>
-	    <menuitem>
-	      <label>Report or upload vector features to DB</label>
-	      <help>Populates database values from vector features.</help>
-	      <keywords>vector,database,attribute table</keywords>
-	      <handler>OnMenuCmd</handler>
-	      <command>v.to.db</command>
-	    </menuitem>
 	    <separator />
 	    <menuitem>
 	      <label>Univariate attribute statistics for points</label>
