[GRASS-SVN] r50112 - in grass/trunk/gui/wxpython: gui_core psmap
Mon Jan 9 16:19:12 EST 2012
Author: annakrat
Date: 2012-01-09 13:19:12 -0800 (Mon, 09 Jan 2012)
New Revision: 50112
   grass/trunk/gui/wxpython/gui_core/dialogs.py
   grass/trunk/gui/wxpython/gui_core/forms.py
   grass/trunk/gui/wxpython/gui_core/widgets.py
   grass/trunk/gui/wxpython/psmap/dialogs.py
wxGUI: revert wrong commit r50111
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2012-01-09 20:09:01 UTC (rev 50111)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2012-01-09 21:19:12 UTC (rev 50112)
@@ -39,10 +39,6 @@
 import wx
 import wx.lib.filebrowsebutton as filebrowse
 import wx.lib.mixins.listctrl as listmix
-try:
-    from wx.lib.buttons import ThemedGenBitmapToggleButton as BTButton
-except ImportError: # not sure about TGBTButton version
-    from wx.lib.buttons import GenBitmapToggleButton as BTButton
 from grass.script import core as grass
 from grass.script import task as gtask
@@ -51,7 +47,6 @@
 from core.gcmd        import GError, RunCommand, GMessage
 from gui_core.gselect import ElementSelect, LocationSelect, MapsetSelect, Select, OgrTypeSelect, GdalSelect, MapsetSelect
 from gui_core.forms   import GUI
-from gui_core.widgets import SingleSymbolPanel, EVT_SYMBOL_SELECTION_CHANGED
 from core.utils       import GetListOfMapsets, GetLayerNameFromCmd, GetValidLayerName
 from core.settings    import UserSettings
 from core.debug       import Debug
@@ -2387,160 +2382,3 @@
         """!Close window
         self.Close()
-class SymbolDialog(wx.Dialog):
-    """!Dialog for GRASS symbols selection.
-    Dialog is called in gui_core::forms module.
-    def __init__(self, parent, symbolPath, currentSymbol = None, title = _("Symbols")):
-        """!Dialog constructor.
-        It is assumed that symbolPath contains folders with symbols.
-        @param parent dialog parent
-        @param symbolPath absolute path to symbols
-        @param currentSymbol currently selected symbol (e.g. 'basic/x')
-        @param title dialog title
-        wx.Dialog.__init__(self, parent = parent, title = title, id = wx.ID_ANY)
-        self.symbolPath = symbolPath
-        self.currentSymbol = currentSymbol # default basic/x
-        self.selected = None
-        self._layout()
-    def _layout(self):
-        mainPanel = wx.Panel(self, id = wx.ID_ANY)
-        mainSizer = wx.BoxSizer(wx.VERTICAL)
-        staticBox = wx.StaticBox(parent = mainPanel, id = wx.ID_ANY,
-                                 label = " %s " % _("Symbol selection"))
-        self.staticSizer = wx.StaticBoxSizer(staticBox, wx.VERTICAL)
-        hSizer = wx.BoxSizer(wx.HORIZONTAL)
-        self.folderChoice = wx.Choice(mainPanel, id = wx.ID_ANY, choices = os.listdir(self.symbolPath))
-        self.folderChoice.Bind(wx.EVT_CHOICE, self.OnFolderSelect)
-        self.staticSizer.Add(self.folderChoice, proportion = 0,
-                             flag = wx.ALL, border = 5)
-        self.panels = self._createSymbolPanels(mainPanel)
-        for panel in self.panels:
-            self.staticSizer.Add(panel, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
-            panel.Bind(EVT_SYMBOL_SELECTION_CHANGED, self.SelectionChanged)
-        self.infoLabel = wx.StaticText(mainPanel, id = wx.ID_ANY)
-        self.staticSizer.Add(self.infoLabel, proportion = 0,
-                             flag = wx.ALL | wx.ALIGN_CENTRE_VERTICAL, border = 5)
-        mainSizer.Add(self.staticSizer, proportion = 1, flag = wx.ALL| wx.EXPAND, border = 5)
-        self.btnCancel = wx.Button(parent = mainPanel, id = wx.ID_CANCEL)
-        self.btnOK     = wx.Button(parent = mainPanel, id = wx.ID_OK)
-        self.btnOK.SetDefault()
-        self.btnOK.Enable(False)
-        # buttons
-        btnSizer = wx.StdDialogButtonSizer()
-        btnSizer.AddButton(self.btnCancel)
-        btnSizer.AddButton(self.btnOK)
-        btnSizer.Realize()
-        mainSizer.Add(item = btnSizer, proportion = 0,
-                      flag = wx.EXPAND | wx.ALL, border = 5)
-        # show panel with the largest number of images and fit size
-        count = []
-        for folder in os.listdir(self.symbolPath):
-            count.append(len(os.listdir(os.path.join(self.symbolPath, folder))))
-        index = count.index(max(count))
-        self.folderChoice.SetSelection(index)
-        self.OnFolderSelect(None)
-        mainPanel.SetSizerAndFit(mainSizer)
-        self.SetSize(self.GetBestSize())
-        # show currently selected symbol
-        if self.currentSymbol:
-            selected = os.path.split(self.currentSymbol)[0]
-            self.folderChoice.SetStringSelection(selected)
-        else:
-            self.folderChoice.SetSelection(0)
-    def _createSymbolPanels(self, parent):
-        """!Creates multiple panels with symbols.
-        Panels are shown/hidden according to selected folder."""
-        folders = os.listdir(self.symbolPath)
-        self.panels = []
-        self.symbolPanels = []
-        maxImages = 0
-        for folder in folders:
-            panel = wx.Panel(parent)
-            sizer = wx.GridSizer(cols = 6, vgap = 3, hgap = 3)
-            images = self._getSymbols(path = os.path.join(self.symbolPath, folder))
-            symbolPanels = []
-            for img in images:
-                btn = BTButton(parent = panel, id = wx.ID_ANY, bitmap = wx.Bitmap(img), name = img)
-                #iP = SingleSymbolPanel(parent = panel, symbolPath = img)
-                sizer.Add(item = btn, proportion = 0, flag = wx.ALL, border = 0)
-                symbolPanels.append(btn)
-            panel.SetSizerAndFit(sizer)
-            panel.Hide()
-            self.panels.append(panel)
-            self.symbolPanels.append(symbolPanels)
-        return self.panels
-    def _getSymbols(self, path):
-        # we assume that images are in subfolders (1 level only)
-        imageList = []
-        for image in os.listdir(path):
-            imageList.append(os.path.join(path, image))
-        return sorted(imageList)
-    def OnFolderSelect(self, event):
-        """!Selected folder with symbols changed."""
-        idx = self.folderChoice.GetSelection()
-        for i in range(len(self.panels)):
-            sizer = self.panels[i].GetContainingSizer()
-            sizer.Show(self.panels[i], i == idx, recursive = True)
-            sizer.Layout()
-        self.infoLabel.SetLabel('')
-        self.btnOK.Disable()
-    def SelectionChanged(self, event):
-        """!Selected symbol changed."""
-        if event.doubleClick:
-            self.EndModal(wx.ID_OK)
-        # deselect all
-            for panel in self.symbolPanels[i]:
-                if panel.GetName() != event.name:
-                    panel.Deselect()
-        self.btnOK.Enable()
-        self.selected = os.path.join(self.folderChoice.GetStringSelection(), event.name)
-        self.infoLabel.SetLabel(event.name)
-    def GetSelectedSymbol(self, fullPath = False):
-        """!Returns currently selected symbol.
-        @param fullPath true to return absolute path to symbol,
-        otherwise returns e.g. 'basic/x'
-        if fullPath:
-            return os.path.join(self.symbolPath, self.selected)
-        return self.selected
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py	2012-01-09 20:09:01 UTC (rev 50111)
+++ grass/trunk/gui/wxpython/gui_core/forms.py	2012-01-09 21:19:12 UTC (rev 50112)
@@ -92,7 +92,6 @@
 from gui_core.widgets import FloatValidator, GNotebook
 wxUpdateDialog, EVT_DIALOG_UPDATE = NewEvent()
 # From lib/gis/col_str.c, except purple which is mentioned
@@ -153,10 +152,6 @@
     """!Escapes ampersands with additional ampersand for GUI"""
     return string.replace(text, "&", "&&")
-def symbolPath():
-    """!Returnes absolute path to symbols"""
-    return "/home/anna/Desktop/symbols"
 class UpdateThread(Thread):
     """!Update dialog widgets in the thread"""
     def __init__(self, parent, event, eventId, task):
@@ -1039,38 +1034,19 @@
                         p['wxId'] = [ txt2.GetId(), ]
                         txt2.Bind(wx.EVT_TEXT, self.OnSetValue)
                     else:
+                        # list of values (combo)
                         title_txt.SetLabel(title + ':')
+                        cb = wx.ComboBox(parent = which_panel, id = wx.ID_ANY, value = p.get('default',''),
+                                         size = globalvar.DIALOG_COMBOBOX_SIZE,
+                                         choices = valuelist, style = wx.CB_DROPDOWN)
                         value = self._getValue(p)
-                        if p['name'] == 'icon': # symbols
-                            bitmap = wx.Bitmap(os.path.join(symbolPath(), value) + '.png')
-                            bb = wx.BitmapButton(parent = which_panel, id = wx.ID_ANY,
-                                                 bitmap = bitmap)
-                            iconLabel = wx.StaticText(parent = which_panel, id = wx.ID_ANY)
-                            iconLabel.SetLabel(value)
-                            p['value'] = value
-                            p['wxId'] = [bb.GetId(),iconLabel.GetId()]
-                            bb.Bind(wx.EVT_BUTTON, self.OnSetSymbol)
-                            this_sizer = wx.BoxSizer(wx.HORIZONTAL)
-                            this_sizer.Add(item = bb, proportion = 0,
-                                            flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border = 5)
-                            this_sizer.Add(item = iconLabel, proportion = 0,
-                                            flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.ALIGN_CENTER_VERTICAL, border = 5)
-                            which_sizer.Add(item = this_sizer, proportion = 0,
-                                            flag = wx.ADJUST_MINSIZE, border = 0)
-                        else:
-                            # list of values (combo)
-                            cb = wx.ComboBox(parent = which_panel, id = wx.ID_ANY, value = p.get('default',''),
-                                             size = globalvar.DIALOG_COMBOBOX_SIZE,
-                                             choices = valuelist, style = wx.CB_DROPDOWN)
-                            if value:
-                                cb.SetValue(value) # parameter previously set
-                            which_sizer.Add(item = cb, proportion = 0,
-                            p['wxId'] = [cb.GetId(),]
-                            cb.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
-                            cb.Bind(wx.EVT_TEXT, self.OnSetValue)
+                        if value:
+                            cb.SetValue(value) # parameter previously set
+                        which_sizer.Add(item = cb, proportion = 0,
+                                        flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border = 5)
+                        p['wxId'] = [cb.GetId(),]
+                        cb.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
+                        cb.Bind(wx.EVT_TEXT, self.OnSetValue)
             # text entry
             if (p.get('type','string') in ('string','integer','float')
@@ -1887,26 +1863,6 @@
         event.Skip()
-    def OnSetSymbol(self, event):
-        """!Shows dialog for symbol selection"""
-        myId = event.GetId()
-        for p in self.task.params:
-            if 'wxId' in p and myId in p['wxId']:
-                from gui_core.dialogs import SymbolDialog
-                dlg = SymbolDialog(self, symbolPath = symbolPath(), currentSymbol = p['value'])
-                if dlg.ShowModal() == wx.ID_OK:
-                    img = dlg.GetSelectedSymbol(fullPath = True)
-                    bitmapButton = wx.FindWindowById(p['wxId'][0])
-                    label = wx.FindWindowById(p['wxId'][1])
-                    bitmapButton.SetBitmapLabel(wx.Bitmap(img + '.png'))
-                    p['value'] = dlg.GetSelectedSymbol(fullPath = False)
-                    label.SetLabel(p['value'])
-                    self.OnUpdateValues(event)
-                dlg.Destroy()
     def OnUpdateSelection(self, event):
         """!Update dialog (layers, tables, columns, etc.)
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py	2012-01-09 20:09:01 UTC (rev 50111)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py	2012-01-09 21:19:12 UTC (rev 50112)
@@ -25,7 +25,6 @@
 @author Anna Kratochvilova <kratochanna gmail.com> (Google SoC 2011)
-import os
 import string
 import wx
@@ -45,8 +44,6 @@
 from core        import globalvar
-from   wx.lib.newevent import NewEvent
-wxSymbolSelectionChanged, EVT_SYMBOL_SELECTION_CHANGED  = NewEvent()
 class GNotebook(FN.FlatNotebook):
     """!Generic notebook widget
@@ -412,53 +409,3 @@
             if itemSelected:
                 self.ToggleItemSelection(itemSelected)
             self.itemSelected = None
-class SingleSymbolPanel(wx.Panel):
-    """!Panel for displaying one symbol.
-    Changes background when selected. Assumes that parent will catch
-    events emitted on mouse click. Used in gui_core::dialog::SymbolDialog.
-    def __init__(self, parent, symbolPath):
-        """!Panel constructor
-        @param parent parent (gui_core::dialog::SymbolDialog)
-        wx.Panel.__init__(self, parent, id = wx.ID_ANY, style = wx.BORDER_RAISED)
-        self.SetName(os.path.splitext(os.path.basename(symbolPath))[0])
-        self.sBmp = wx.StaticBitmap(self, wx.ID_ANY, wx.Bitmap(symbolPath))
-        self.selected = False
-        self.selectionColor = wx.Colour(255, 252, 120)
-        sizer = wx.BoxSizer()
-        sizer.Add(item = self.sBmp, proportion = 0, flag = wx.ALL, border = 0)
-        self.SetBackgroundStyle(wx.BG_STYLE_SYSTEM)
-        self.SetMinSize(self.GetBestSize())
-        self.SetSizerAndFit(sizer)
-        # binding to both (staticBitmap, Panel) necessary
-        self.sBmp.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
-        self.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
-        self.Bind(wx.EVT_LEFT_DCLICK, self.OnDoubleClick)
-        self.sBmp.Bind(wx.EVT_LEFT_DCLICK, self.OnDoubleClick)
-    def OnLeftDown(self, event):
-        """!Panel selected, background changes"""
-        self.selected = True
-        self.SetBackgroundColour(self.selectionColor)
-        event.Skip()
-        event = wxSymbolSelectionChanged(name = self.GetName(), doubleClick = False)
-        wx.PostEvent(self.GetParent(), event)
-    def OnDoubleClick(self, event):
-        event = wxSymbolSelectionChanged(name = self.GetName(), doubleClick = True)
-    def Deselect(self):
-        """!Panel deselected, background changes back to default"""
-        self.SetBackgroundColour(wx.NullColor)
Modified: grass/trunk/gui/wxpython/psmap/dialogs.py
--- grass/trunk/gui/wxpython/psmap/dialogs.py	2012-01-09 20:09:01 UTC (rev 50111)
+++ grass/trunk/gui/wxpython/psmap/dialogs.py	2012-01-09 21:19:12 UTC (rev 50112)
@@ -2925,11 +2925,9 @@
         self.select = Select(self, id = wx.ID_ANY,# size = globalvar.DIALOG_GSELECT_SIZE,
                              type = 'vector', multiple = False,
                              updateOnPopup = True, onPopup = None)
-        topologyTypeTr = [_("points"), _("lines"), _("areas")]
-        self.topologyTypeList = ["points", "lines", "areas"]
-        self.vectorType = wx.RadioBox(self, id = wx.ID_ANY, label = " %s " % _("Data Type"), choices = topologyTypeTr,
-                                      majorDimension = 3, style = wx.RA_SPECIFY_COLS)
+        topologyType = [_("points"), _("lines"), _("areas")]
+        self.vectorType = wx.RadioBox(self, id = wx.ID_ANY, label = " %s " % _("Data Type"), choices = topologyType,
+                                        majorDimension = 3, style = wx.RA_SPECIFY_COLS)
         self.AddVector = wx.Button(self, id = wx.ID_ANY, label = _("Add"))
         gridBagSizer.Add(text, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
@@ -3010,17 +3008,16 @@
                 mapset = '(' + vmap.split('@')[1] + ')'
             except IndexError:
                 mapset = ''
-            idx = self.vectorType.GetSelection()
-            ttype = self.topologyTypeList[idx]
-            record = "%s - %s" % (vmap, ttype)
+            type = self.vectorType.GetStringSelection()
+            record = "%s - %s" % (vmap,type)
             id = wx.NewId()
             lpos = 1
             label = mapname + mapset
-            self.vectorList.insert(0, [vmap, ttype, id, lpos, label])
+            self.vectorList.insert(0, [vmap, type, id, lpos, label])
             self.reposition()
             self.listbox.InsertItems([record], 0)
-            vector = VProperties(id, ttype)
+            vector = VProperties(id, type)
             self.tmpDialogDict[id] = vector.GetInstruction()
             self.tmpDialogDict[id]['name'] = vmap
@@ -3227,7 +3224,7 @@
             if id == item[2]:
                 self.vectorName = item[0]
                 self.type = item[1]
-        self.SetTitle(_("%s properties") % self.vectorName)
+        self.SetTitle(self.vectorName + " "+ _("properties"))
         #vector map info
         self.connection = True
