[GRASS-SVN] r50126 - in grass/trunk: gui/wxpython/xml locale/po
vector/v.vol.rst
svn_grass at osgeo.org
Tue Jan 10 07:07:32 EST 2012
Author: neteler
Date: 2012-01-10 04:07:32 -0800 (Tue, 10 Jan 2012)
New Revision: 50126
grass/trunk/gui/wxpython/xml/menudata.xml
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grasswxpy_de.po
grass/trunk/locale/po/grasswxpy_ja.po
grass/trunk/locale/po/grasswxpy_pl.po
grass/trunk/locale/po/grasswxpy_pt_br.po
grass/trunk/vector/v.vol.rst/main.c
RASTER3D|G3D grid volume -> 3D raster map
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2012-01-10 12:05:20 UTC (rev 50125)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2012-01-10 12:07:32 UTC (rev 50126)
@@ -3004,7 +3004,7 @@
</menuitem>
<menuitem>
<label>Interpolate volume from points</label>
- <help>Interpolates point data to a RASTER3D grid volume using regularized spline with tension (RST) algorithm.</help>
+ <help>Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm.</help>
<keywords>vector,surface,interpolation,RST</keywords>
<handler>OnMenuCmd</handler>
<command>v.vol.rst</command>
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2012-01-10 12:05:20 UTC (rev 50125)
+++ grass/trunk/locale/po/grassmods_de.po 2012-01-10 12:07:32 UTC (rev 50126)
@@ -38343,7 +38343,7 @@
#~ msgid "Name of input DXF file"
#~ msgstr "Name der Eingabe-DXF-Datei"
-#~ msgid "Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm."
+#~ msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
#~ msgstr "Interpoliert Punkte zu einem G3D Grid Volumen unter Verwendung des regularized spline with tension (RST) Algorithmus."
#~ msgid "Name of column name with route ids"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2012-01-10 12:05:20 UTC (rev 50125)
+++ grass/trunk/locale/po/grassmods_ja.po 2012-01-10 12:07:32 UTC (rev 50126)
@@ -36083,7 +36083,7 @@
#~ msgid "Convex hull calculation requires at least three points. Exiting."
#~ msgstr "å¸å
æ¼ç®ã«ã¯3ç¹ä»¥ä¸ãå¿
è¦ã§ããçµäº"
#~ msgstr "ãã³ã·ã§ã³ (RST) ã¢ã«ã´ãªãºã ã®æ£è¦åã¹ãã©ã¤ã³æ²ç·ã使ã£ã¦ï¼ãã¤ã³ããã¼ã¿ã3Dã°ãªããããªã¥ã¼ã ã¸æ¿å
#~ msgid "Cannot open %s"
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2012-01-10 12:05:20 UTC (rev 50125)
+++ grass/trunk/locale/po/grassmods_pl.po 2012-01-10 12:07:32 UTC (rev 50126)
@@ -37394,7 +37394,7 @@
#~ msgstr "Jednoznakowy separator, newline, comma, space, or tab"
#, fuzzy
#~ msgstr "Interpoluje dane punktowe do G3D za pomocÄ
algorytmu RST."
#, fuzzy
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po 2012-01-10 12:05:20 UTC (rev 50125)
+++ grass/trunk/locale/po/grasswxpy_de.po 2012-01-10 12:07:32 UTC (rev 50126)
@@ -13890,7 +13890,7 @@
#~ msgid "Creates cross section 2D raster map from 3d raster map based on 2D elevation map"
#~ msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
#~ msgid "Generates volume statistics for raster3d maps."
Modified: grass/trunk/locale/po/grasswxpy_ja.po
--- grass/trunk/locale/po/grasswxpy_ja.po 2012-01-10 12:05:20 UTC (rev 50125)
+++ grass/trunk/locale/po/grasswxpy_ja.po 2012-01-10 12:07:32 UTC (rev 50126)
@@ -13140,7 +13140,7 @@
#~ msgstr "2Dæ¨é«ãããã«åºã¥ãã3Dã©ã¹ã¿ã¼ãã2Dã®ã©ã¹ã¿ã¼æé¢ãããã使"
#~ msgstr "ãã³ã·ã§ã³ï¼ï¼²ï¼³ï¼´ï¼ã¢ã«ã´ãªãºã ã«ããæ£è¦åã¹ãã©ã¤ã³æ²ç·ã使ç¨ãã¦3Dã°ãªããã®ãã¤ã³ããè£éãã"
Modified: grass/trunk/locale/po/grasswxpy_pl.po
--- grass/trunk/locale/po/grasswxpy_pl.po 2012-01-10 12:05:20 UTC (rev 50125)
+++ grass/trunk/locale/po/grasswxpy_pl.po 2012-01-10 12:07:32 UTC (rev 50126)
@@ -13093,7 +13093,7 @@
#~ msgstr "Tworzy mapÄ rastrowÄ
przekroju (2D) mapy rastrowej 3D i mapy rastrowej wysokoÅci (2D)"
algorytmu RST."
Modified: grass/trunk/locale/po/grasswxpy_pt_br.po
--- grass/trunk/locale/po/grasswxpy_pt_br.po 2012-01-10 12:05:20 UTC (rev 50125)
+++ grass/trunk/locale/po/grasswxpy_pt_br.po 2012-01-10 12:07:32 UTC (rev 50126)
@@ -16424,7 +16424,7 @@
#, fuzzy
#~ msgid ""
-#~ "Interpolates point data to a G3D grid volume using regularized spline "
+#~ "Interpolates point data to a 3D raster map using regularized spline "
#~ "with tension (RST) algorithm."
#~ msgstr "Interpola datos de puntos a volumen de cuadrÃcula G3D usando"
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2012-01-10 12:05:20 UTC (rev 50125)
+++ grass/trunk/vector/v.vol.rst/main.c 2012-01-10 12:07:32 UTC (rev 50126)
@@ -242,7 +242,7 @@
G_add_keyword(_("interpolation"));
G_add_keyword(_("RST"));
module->description =
- _("Interpolates point data to a RASTER3D grid volume using "
+ _("Interpolates point data to a 3D raster map using "
"regularized spline with tension (RST) algorithm.");
parm.input = G_define_option();
