[GRASS-SVN] r50172 - grass/branches/develbranch_6/vector/v.distance
svn_grass at osgeo.org
Fri Jan 13 21:07:56 EST 2012
Author: hamish
Date: 2012-01-13 18:07:56 -0800 (Fri, 13 Jan 2012)
New Revision: 50172
grass/branches/develbranch_6/vector/v.distance/main.c
cleanup matrix option descriptions; make variable name less generic;
for clarity use boolean macros where appropriate. (merge from trunk)
Modified: grass/branches/develbranch_6/vector/v.distance/main.c
--- grass/branches/develbranch_6/vector/v.distance/main.c 2012-01-14 01:51:22 UTC (rev 50171)
+++ grass/branches/develbranch_6/vector/v.distance/main.c 2012-01-14 02:07:56 UTC (rev 50172)
@@ -71,8 +71,8 @@
int main(int argc, char *argv[])
int i, j, k;
- int print_as_matrix; /* only for all */
- int all; /* calculate from each to each within the threshold */
+ int print_as_matrix; /* only for do_all=TRUE */
+ int do_all; /* calculate from each to each within the threshold */
char *mapset;
struct GModule *module;
struct Option *from_opt, *to_opt, *from_type_opt, *to_type_opt,
@@ -86,7 +86,7 @@
struct line_pnts *FPoints, *TPoints;
struct line_cats *FCats, *TCats;
NEAR *Near, *near;
- int anear; /* allocated space, used only for all */
+ int anear; /* allocated space, used only for do_all */
UPLOAD *Upload; /* zero terminated */
int ftype, fcat, tcat, count;
int nfrom, nto, nfcats, fline, tline, tseg, tarea, area, isle, nisles;
@@ -104,8 +104,8 @@
dbCatValArray cvarr;
dbColumn *column;
- all = 0;
- print_as_matrix = 0;
+ do_all = FALSE;
+ print_as_matrix = FALSE;
column = NULL;
G_gisinit(argv[0]);
@@ -211,7 +211,7 @@
table_opt = G_define_standard_option(G_OPT_TABLE);
table_opt->gisprompt = "new_dbtable,dbtable,dbtable";
table_opt->description =
- _("Name of table created for output when the distance to all flag is used");
+ _("Name of table created when the 'distance to all' flag is used");
print_flag = G_define_flag();
print_flag->key = 'p';
@@ -224,7 +224,9 @@
all_flag->key = 'a';
all_flag->label =
_("Calculate distances to all features within the threshold");
- all_flag->description = _("The output is written to stdout but may be uploaded " "to a new table created by this module. " "From categories are may be multiple."); /* huh? */
+ all_flag->description =
+ _("Output is written to stdout but may be uploaded to a new table "
+ "created by this module; multiple 'upload' options may be used.");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -239,7 +241,7 @@
min = atof(min_opt->answer);
if (all_flag->answer)
- all = 1;
+ do_all = TRUE;
/* Read upload and column options */
/* count */
@@ -247,8 +249,8 @@
while (upload_opt->answers[i])
i++;
if (strcmp(from_opt->answer, to_opt->answer) == 0 &&
- all && !table_opt->answer && i == 1)
- print_as_matrix = 1;
+ do_all && !table_opt->answer && i == 1)
+ print_as_matrix = TRUE;
/* alloc */
Upload = (UPLOAD *) G_calloc(i + 1, sizeof(UPLOAD));
@@ -351,7 +353,7 @@
driver = NULL;
if (!print_flag->answer) {
- if (!all) {
+ if (!do_all) {
Fi = Vect_get_field(&From, from_field);
if (Fi == NULL)
G_fatal_error(_("Database connection not defined for layer %d"),
@@ -411,7 +413,7 @@
/* Check column types */
- if (!print_flag->answer && !all) {
+ if (!print_flag->answer && !do_all) {
char *fcname = NULL;
int fctype, tctype;
@@ -453,8 +455,8 @@
/* Allocate space ( may be more than needed (duplicate cats and elements without cats) ) */
nfrom = Vect_get_num_lines(&From);
nto = Vect_get_num_lines(&To);
- if (all) {
- /* Attention with space for all, it can easily run out of memory */
+ if (do_all) {
+ /* Be careful with do_all, it can easily run out of memory */
anear = 2 * nfrom;
Near = (NEAR *) G_calloc(anear, sizeof(NEAR));
@@ -463,7 +465,7 @@
/* Read all cats from 'from' */
- if (!all) {
+ if (!do_all) {
nfcats = 0;
for (i = 1; i <= nfrom; i++) {
ftype = Vect_read_line(&From, NULL, FCats, i);
@@ -500,7 +502,7 @@
/* Go through all lines in 'from' and find nearest in 'to' for each */
/* Note: as from_type is restricted to GV_POINTS (for now) everything is simple */
- count = 0; /* count of distances in 'all' mode */
+ count = 0; /* count of distances in 'do_all' mode */
/* Find nearest lines */
if (to_type & (GV_POINTS | GV_LINES)) {
struct line_pnts *LLPoints;
@@ -523,7 +525,7 @@
continue;
Vect_cat_get(FCats, from_field, &fcat);
- if (fcat < 0 && !all)
+ if (fcat < 0 && !do_all)
continue;
box.E = FPoints->x[0] + max;
@@ -573,7 +575,7 @@
G_debug(4, " tmp_dist = %f tmp_tcat = %d", tmp_dist,
tmp_tcat);
- if (all) {
+ if (do_all) {
if (anear <= count) {
anear += 10 + nfrom / 10;
Near = (NEAR *) G_realloc(Near, anear * sizeof(NEAR));
@@ -610,7 +612,7 @@
G_debug(4, " dist = %f", dist);
- if (!all && tline > 0) {
+ if (!do_all && tline > 0) {
/* find near by cat */
near =
(NEAR *) bsearch((void *)&fcat, Near, nfcats,
@@ -650,7 +652,7 @@
continue;
continue;
/* select areas by box */
@@ -722,7 +724,7 @@
tmp_tcat);
- if (all) {
+ if (do_all) {
@@ -751,7 +753,7 @@
- if (!all && tarea > 0) {
+ if (!do_all && tarea > 0) {
near =
@@ -787,7 +789,7 @@
fprintf(stdout, "\n");
- else if (all && table_opt->answer) { /* create new table */
+ else if (do_all && table_opt->answer) { /* create new table */
db_set_string(&stmt, "create table ");
db_append_string(&stmt, table_opt->answer);
db_append_string(&stmt, " (from_cat integer");
@@ -826,7 +828,7 @@
table_opt->answer);
- else if (!all) { /* read existing cats from table */
+ else if (!do_all) { /* read existing cats from table */
ncatexist =
db_select_int(driver, Fi->table, Fi->key, NULL, &catexist);
G_debug(1, "%d cats selected from the table", ncatexist);
@@ -834,7 +836,7 @@
update_ok = update_err = update_exist = update_notexist = update_dupl =
update_notfound = 0;
- if (!all) {
+ if (!do_all) {
count = nfcats;
else if (print_as_matrix) {
@@ -888,7 +890,7 @@
db_CatValArray_get_value(&cvarr, Near[i].to_cat, &catval);
- if (print_flag->answer || (all && !table_opt->answer)) { /* print only */
+ if (print_flag->answer || (do_all && !table_opt->answer)) { /* print only */
input and output is the same &&
calculate distances &&
@@ -918,7 +920,7 @@
- else if (all) { /* insert new record */
+ else if (do_all) { /* insert new record */
sprintf(buf1, "insert into %s values ( %d ", table_opt->answer,
Near[i].from_cat);
db_set_string(&stmt, buf1);
@@ -1114,13 +1116,13 @@
db_free_string(&stmt);
/* print stats */
- if (all && table_opt->answer) {
+ if (do_all && table_opt->answer) {
G_message(_("%d distances calculated"), count);
G_message(_("%d records inserted"), update_ok);
if (update_err > 0)
G_message(_("%d insert errors"), update_err);
- else if (!all) {
if (nfcats > 0)
G_message(_("%d categories read from the map"), nfcats);
if (ncatexist > 0)
