[GRASS-SVN] r50191 -
grass/branches/develbranch_6/vector/v.clean/test
svn_grass at osgeo.org
Sat Jan 14 20:00:41 EST 2012
Author: hamish
Date: 2012-01-14 17:00:41 -0800 (Sat, 14 Jan 2012)
New Revision: 50191
grass/branches/develbranch_6/vector/v.clean/test/topocheck.c
simplify error message handling
Modified: grass/branches/develbranch_6/vector/v.clean/test/topocheck.c
--- grass/branches/develbranch_6/vector/v.clean/test/topocheck.c 2012-01-15 00:49:16 UTC (rev 50190)
+++ grass/branches/develbranch_6/vector/v.clean/test/topocheck.c 2012-01-15 01:00:41 UTC (rev 50191)
@@ -27,7 +27,7 @@
struct line_cats *Cats;
int i, atype, with_z;
int nlines, n;
- char *mapset, errmsg[200];
+ char *mapset;
struct GModule *module;
struct Option *in_opt, *out_opt;
struct Flag *poly_f;
@@ -59,10 +59,8 @@
G_begin_cell_area_calculations();
/* open input vector */
- if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
- sprintf(errmsg, "Could not find input map <%s>\n", in_opt->answer);
- G_fatal_error(errmsg);
+ if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL)
+ G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
Vect_set_open_level(2);
Vect_open_old(&In, in_opt->answer, mapset);
